> MazdaSpeed 3 - How-To's
Like Tree14Likes
 Old 05-22-2013, 01:02 PM   #1
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Default The MSF guide to Torque
This guide is intended to help you through all the steps required to setup the Torque application and it’s plugins (mainly the Mazdaspeed plugin) to run on your android phone or tablet, to help you use the basic features (real time monitoring, logging and fault code reading) and to use custom themes. In time, I will also update with in depth use of the other features and plugins such as racing meter and track recorder.
Index:
  1. Requirements
  2. Software Installation
  3. Initial Setup
… stay tuned for more …
1- Requirements
Hardware:
  • Android 1.5+ phone or tablet with bluetooth
  • ELM327 Bluetooth OBDII adapter
Software:
  • Torque Pro (Current version is 1.6.46)
  • Torque Mazdaspeed plugin (choose the one that corresponds to your car’s year)
2 - Installation
Install Torque Pro and desired plugins through the Android Market or the Google Play store. If you need special instructions on how to do that well honestly, don’t go any further, Torque isn’t for you.
3 - Initial Setup
To monitor or log properly the first time, certain options need to be set. These can be accessed by pressing the menu button on your phone or tablet or the menu icon on your tablet (bottom left corner of screen):
  1. Plugin Preferences (Plugins)
  2. Unit Preferences (Units)
  3. OBD2 Adapter Settings
  4. Custom OBD2 PIDs (Manage extra PIDs/Sensors)
  5. The Vehicle Profile
Of course there are other options that need to be set to enjoy the app to its full potential (such as themes). Those will be explained further on in this guide.
3a - Plugin Preferences
Accessed through: Menu Button >> Settings >> Plugins
  • Allow plugins full access = CHECKED
  • Installed plugins = Take the time to see if the Mazdaspeed plugin is correctly installed
3b - Unit Preferences
Accessed through: Menu Button >> Settings >> Units
  • Check/Uncheck the various options to your personal preferences.
3c - OBD2 Adapter Settings
Accessed through: Menu Button >> Settings >> OBD2 Adapter Settings
*Connection Settings*
  • Connection Type = Bluetooth
*Bluetooth Settings*
  • Choose Bluetooth Device = Choose the name of your OBD2 Adapter (name given while paring)
  • Auto Bluetooth On/Off = Check to ensure that Bluetooth turns on automatically when Torque starts.
  • Only if BT was already off = I recommend to check this especially for phones that use Bluetooth often.
*OBD2/ELM Adapter preferences*
  • Faster communication= CHECK to speed up monitoring and to maximize loggi- ng speed.
  • Disable ELM327 auto timing adjustment = Leave unchecked unless you have problems connecting to the car.
  • Don’t calculate MPG/Fuel = CHECK to speed up monitoring and to maximize logging speed but the app won’t log fuel consumption.
  • Enhanced MPG calculation = UNCHECK (check to use more sensors to calculate fuel consumption, to the detriment of other PID monitoring latency)
  • Use vehicle fuel level sensor = Check or Uncheck to your preference.
  • Boost calculation method = Prefer MAP (Default)
  • ScanTool.net (ODBLink) Power Saver = Check only if you use ScanTool.net
*Wifi Preferences*
Not covered in this guide
*USB Adapter settings*
3d - Custom OBD2 PIDs
Accessed through: Menu Button >> Settings >> Manage extra PIDs/Sensors
To add the Mazdaspeed PIDs:
  • Phone= Menu Button >> Add predefined set >> Mazdaspeed 20xx
  • Tablet = Menu Button OR Icon in top right corner of screen >> Add predefined set >> Mazdaspeed 20xx
3e - Vehicle Profile
Accessed through: Menu Button >> Vehicle Profile >> Create new Profile
  • Profile Name = Name it whatever you want (ex.: MS3)
  • Engine Displacement = 2.3
  • Total Vehicle Weight = 3500lbs (curb weight + driver + luggage/groceries. As reference, 1st gen= 3108lbs and 2nd gen=3281lbs)
  • Fuel Type = Petrol or E85
  • Fuel tank capacity = 15.9 (US gal.)
  • Current fuel level = You’ll want to set this at 100% after a fill-up at the pump.
  • Boost Adjustment = 0.0 for most, those living high above sea level might need to tinker with this setting.
  • Volumetric Efficiency % = 85.0
  • Fuel Cost = Fuel cost in your area
  • Accumulated Distance travelled with Torque running = Follow on screen instructions, used to calculate average fuel consumption.
  • MPG ‘trim’ adjustment = Follow on screen instructions, used to calculate fuel consumption.
  • OBD Speed multiplier = Follow on screen instructions, used if you tires differ in overall diameter/circumference from OEM.
  • Use separate dashboard layout = CHECKED
  • Advanced- Connect using this Bluetooth adapter = As defined in global OBD2 preferences
  • Use Alternate OBD Header = Check if the Mazdaspeed PIDs don’t display correctly
  • Prefered OBD2 Protocol = Automatic – Thorough protocol
  • Very Advanced- ELM custom configuration = Leave Blank
*Don’t forget to save the configuration!*
You are now set monitor your MS3!
There's a lot more to come so stay tuned!
speedaholic is offline   Reply With Quote
The Following 16 Users Say Thank You to speedaholic For This Useful Post:
Addikted To Boost (11-20-2013), ajkulish (06-04-2013), aromig (12-26-2014), BigRedSpecial (06-04-2013), darkproximity (05-07-2014), evil MS3 (05-22-2013), f15ms6 (09-20-2014), Finchee (09-01-2014), grazamataz (03-09-2014), jcolton (08-17-2013), MBalik (08-08-2015), N2o (02-28-2014), pebenito (05-22-2013), rdjr74 (05-22-2013), SarcasticOne (05-22-2013), SofaKingAwesome (03-24-2015)
 Old 06-04-2013, 12:21 PM   #2
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
Groaned at 15 Times in 12 Posts
thanks for the info, i wasnt sure about some of those fields!
also, is the mazdaspeed plug in worth 10 dollars?
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
Last edited by ajkulish; 06-04-2013 at 12:21 PM. Reason: MSF Database - Automerged Doublepost
ajkulish is offline   Reply With Quote
 Old 06-04-2013, 12:35 PM   #3
It's the only way to monitor certain PIDs (ex: KR). 15$ for the app+plugin isn't too bad imo. The whole setup in my car cost me 180$ total (tablet, mount, hardwire, software).
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
 Old 06-04-2013, 12:38 PM   #4
ajkulish's Avatar
Groans: 40
is that the only extra PID it handles? some of the recent reviews dont necessarily praise the mazdaspeed plug in
 Old 06-04-2013, 12:44 PM   #5
It reads a bunch of them (more for Gen 1). Check the plugin description.
tapsayeule avec mon HTC
RIP 2015-06-27
 Old 06-04-2013, 02:49 PM   #6
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
I'd say it's definitely worth it. There are a TON of PIDs that the generic OBDII codes won't touch.
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
 Old 06-04-2013, 03:09 PM   #7
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
When other datalogging setups cost hundreds, I'm a little skeptical about the efficacy of something cheap.
Any details on response time and PIDs?
-feejay
-wetzel
m8357510 (09-30-2018)
 Old 06-04-2013, 05:20 PM   #8
PID latency is hardware dependent. The bluetooth unit I purchased for 12$ on ebay reads over 28 PIDs/sec. average so I log 12-14 at 0.5 sec interval.
RIP 2015-06-27
 Old 06-04-2013, 05:48 PM   #9
Groans: 56
It won't replace my AP or my dashdaq, but for the price it's awful convenient.
The only downside I can see is that it doesn't read BATs... unless I'm missing something
Needed: Driver mod
 Old 06-04-2013, 05:58 PM   #10
It does with the mazdaspeed plugin.
RIP 2015-06-27
 Old 06-04-2013, 07:20 PM   #11
Groans: 56
I have the plugin for gen won; couldn't find it. Found ambient and iat but no bat.
Needed: Driver mod
 Old 06-04-2013, 07:59 PM   #12
djern's Avatar
Posts: 1,132   (View Stats)
djern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the worlddjern is the leader of the world
Groans: 24
got installed on a old android phone and a dongle...not as fast as the AP buuut you can live monitor so many parameters at the same time its a useful tool... a better dongle will give faster PID's though, I got mine set to monitor = boost, fp, kr, bat, fuel economy, fuel level engine temp, wgdc, pedal position, and map voltage all at the same time... only drawback with the mazdaspeed plugin is that if you turn the car off and back on mine stops reading pedal position, BAT, and KR until i restart the app.. i found out if you leave the dongle plugged in and leave the car parked for a week it will kill the battery lol
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6)
twitter.com/djern
instagram.com/djern
facebook.com/djern
djern is offline   Reply With Quote
 Old 06-05-2013, 04:23 AM   #13
Groans: 56
Hmmm...I looked for an hour last night and couldn't find BAT; checked again this morning and it's there. weird.
Needed: Driver mod
 Old 06-05-2013, 05:42 AM   #14
ajkulish's Avatar
Groans: 40
how do you get fuel pressure?
 Old 06-08-2013, 01:15 PM   #15
dodorkus's Avatar
Posts: 5   (View Stats)
dodorkus has a spectacular aura aboutdodorkus has a spectacular aura about
Default How to manually start/stop datalogging?
Does anybody know how to manually start/stop datalogging? The only way I've found to log is to enable the following setting:
Settings > Data Logging & Upload > Log when Torque is started
For my setup, I'm using:
- Nexus 4 (running CyanogenMod 10.1)
- Mountek nGroove Universal CD Slot Mount
- AGPtek® Super Mini ELM327 V1.5 Bluetooth OBD2 OBD-II CAN-BUS Auto Diagnostic Scanner Tool (works flawlessly)
Fuel pressure is avaliavble under Realtime Information > Add Display (tap & hold on a blank area) > Fuel Rail Pressure.
This is available even if you haven't purchased the Mazdaspeed plugin, and it works great!
Last edited by dodorkus; 06-08-2013 at 01:15 PM. Reason: MSF Database - Automerged Doublepost
dodorkus is offline   Reply With Quote
The Following User Says Thank You to dodorkus For This Useful Post:
ajkulish (06-08-2013)
 Old 06-08-2013, 01:33 PM   #16
djern's Avatar
Groans: 24
My torque setup
tapatapa zoom
twitter.com/djern
instagram.com/djern
facebook.com/djern
 Old 06-08-2013, 01:45 PM   #17
In dashboard view while monitoring >> press and hold on screen >> start/stop logging.
I wish I had more time to continue this guide.
Klatapat gnisu tnes
RIP 2015-06-27
 Old 06-08-2013, 04:47 PM   #18
ajkulish's Avatar
Groans: 40
thanks dude, i never bothered to check rail pressure.
 Old 06-24-2013, 12:37 PM   #19
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
Has anyone figured out how to recalibrate the Boost PID for a 3 Bar MAP sensor?
Pickles Tune in progress
 Old 02-27-2014, 02:49 PM   #20
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Would like to know this too...
 Old 02-27-2014, 03:09 PM   #21
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
They still don't make this shit for iOS? Damn... That's a lot cheaper than buying an aeroforce or dashhawk. Easier to mount a phone as well.
2006 Mazdaspeed6
 Old 02-27-2014, 06:51 PM   #22
Your best bet would be to contact Torque's creator on his forum. His user name is piemm if I recall correctly.
RIP 2015-06-27
 Old 04-07-2014, 12:58 PM   #23
Teeeerell's Avatar
Posts: 39   (View Stats)
Teeeerell will become famous soon enoughTeeeerell will become famous soon enough
So fuel pressure and rail pressure are the same?
Teeeerell is offline   Reply With Quote
 Old 04-07-2014, 02:29 PM   #24
They are different PIDs in Torque, but the MS3's fuel pressure is read through the "fuel rail pressure".
RIP 2015-06-27
 Old 04-30-2014, 06:05 AM   #25
Jtaylor's Avatar
Posts: 656   (View Stats)
Jtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the worldJtaylor is the leader of the world
This is available for iOS but since Apple locks down their Bluetooth capabilities you would need a WIFI based OBDII transmitter, which is quite a bit more.
08 MazdaSpeed3
| Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 |
| AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM |
| Black Powdercoated Stockers | Built Motor |
| Mahle 88mm Pistons | Manley H-Beam Rods |
Jtaylor is offline   Reply With Quote
 Old 05-01-2014, 12:21 AM   #26
sidekick's Avatar
Groans: 47
Was it recently added? When I posted that, nothing came up when searching the app store for "torque".
I'm most likely switching to a google nexus 5 soon anyways, so I can join the torque party soon. Lol.
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
speedaholic (05-01-2014)
 Old 05-01-2014, 06:35 AM   #27
N2o
BoooOost !
N2o's Avatar
Posts: 85   (View Stats)
N2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond reputeN2o has a reputation beyond repute
Just bought a Nexus 7 and an extra sun visor for a little project
speedaholic likes this.
2010 Mazdaspeed3 - Freektuned with some bolt ons.
N2o is offline   Reply With Quote
The Following User Says Thank You to N2o For This Useful Post:
 Old 05-01-2014, 10:07 AM   #28
Patty-Wack's Avatar
Posts: 884   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
My Mazdaspeed add on stopped working. I re downloaded etc and no go. The regular torque app works I just don't get knock etc from plugin. Anyone run into this?
Sent from my big ass Note 3
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
 Old 05-01-2014, 10:12 AM   #29
SpencerC's Avatar
Posts: 2,159   (View Stats)
SpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the world
I haven't run into this issue. I'll maybe see if I can link it up tonight and try it again to make sure.
SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount -
CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit
1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights
Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3?
SpencerC is offline   Reply With Quote
 Old 05-01-2014, 10:14 AM   #30
This happens randomly when the plugin tries to check it's license status. If the phone or tablet isn't connected to the www, the plugin is disabled. The fact that you reinstalled and still does't work is weird though...
I'd try to contact the author @MattJackson86;, maybe he can chime in on this.
RIP 2015-06-27
 Old 05-01-2014, 04:33 PM   #31
MattJackson86's Avatar
Posts: 1,407   (View Stats)
How do you mean "stopped working"? If the PID's are in the available list then the plugin should be "working". All this plugin does is provide the PID data to Torque, so if the customer PIDs are in the list of available ones to add to display, then all should be good. If not data is being returned then it would be a Torque or hardware issue. Let me know some specific details and I can get back to you. PM me or email me.
The Following User Says Thank You to MattJackson86 For This Useful Post:
 Old 05-02-2014, 07:53 PM   #32
Patty-Wack's Avatar
This is it I bet. I'm using old phone with no Internet when in car. Bummer. @MattJackson86; how often does it run a check? I could maybe take thing in house for wifi..
Thanks for help guys.
 Old 05-07-2014, 06:21 AM   #33
Jtaylor's Avatar
Unfortunately my Verizon phone will only allow firmware updates over the actual network so I am unable to download any extensions since my phone is loaded the "market" app instead of the newer google app
08 MazdaSpeed3
 Old 05-20-2014, 10:32 AM   #34
sidekick's Avatar
Groans: 47
Is anyone using this adapter? It claims over 100pid/sec and is recommended on the wiki for torque.
ScanTool.net LLC - OBDLink LX Scan Tool | OBD Interface | App Accelerator - ScanTool.net
2006 Mazdaspeed6
 Old 05-23-2014, 08:55 AM   #35
Jeff23spl's Avatar
Posts: 1,896   (View Stats)
What happend to my old phone used as a tablet (without sims card) is that your specials PIDS just disapear from the list from time to time .
The selected meter just doesn't show results and the green dot on them became white.
It took time to figure it out, i connected the phone manually to wifi ethernet but it doesn't help, i had to re-select again your plug in in the torque function to get them to re-appear on the list and now it works
How often do your plug in check for autorization ? This is kind of anoying, is there any way to go around this ?
Is there a way to change the Boost sensor math calcul representation inside torque when we run a 3bars ones. I changed it fine with access tuner and i can read the correct boost level but Torque is maxed out to 22.x psi
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 05-23-2014 at 08:55 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-23-2014, 09:33 AM   #36
Jeff23spl's Avatar
i would be interrested also because the adapter permit 100pid/s but is our pcm communication speed permit it too ??? I had a wired Dashawk that broke but i could remember the update speed was way better than with torque.
sidekick likes this.
Wife drive 2010 CX7
 Old 05-25-2014, 04:01 PM   #37
sidekick's Avatar
Groans: 47
Anyone?
2006 Mazdaspeed6
 Old 05-25-2014, 06:31 PM   #38
For me, the elcheapo from ebay does the job and I don't think a lot of guys want to invest 100$+ just for the module. The best way to know is to buy and try!
RIP 2015-06-27
 Old 05-27-2014, 07:42 AM   #39
Jtaylor's Avatar
Same
08 MazdaSpeed3
 Old 05-27-2014, 08:35 AM   #40
sidekick's Avatar
Groans: 47
Meh, I ended up buying a BAFX off of amazon, because it was $23 and had nothing but good reviews on there and on some forums. If it's too slow, I'll sell it and buy the one I linked. I should have it some time this week and I'll make a post here about it for people looking in the future.
2006 Mazdaspeed6
speedaholic (05-27-2014)
COMPLETE HOW TO GUIDE MS3Axela703 MazdaSpeed 3 - How-To's 28 11-05-2014 02:47 PM
Abilor Guide Help for VT SpeedRebirth MazdaSpeed 3/6 - ECU Computer Tuning 10 04-08-2013 01:50 PM
My maintenance guide cham87 Gen2 MS3 General Discussion 8 10-31-2012 06:30 PM
Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque Haltech Automotive News 0 08-03-2010 06:30 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-22-2009 11:25 PM
Page generated in 0.67305 seconds with 36 queries
