> MazdaSpeed 3 - How-To's
Like Tree3Likes
  • 1 Post By Xxblinddzxx
  • 1 Post By Vansquish
 Old 08-01-2017, 10:50 AM   #1
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Default Need help KOEO
Hi guys,
I'm currently having some fueling issue and saw alot of replies in threads that says to do the KOEO test ... anyone can tell how to do it exactly?
Are those instruction ok ?
Warm the car up.
Then shut the car off while monitoring HPFP pressure.
Turn the key to the on position(car is still off) since the AP doesn't get data when key is in ACC position.
If fuel pressure builds slowly rail/relief valve is good.
If all you see is ~60psi (in tank pump pressure) rail valve is bad.
You will not see 60 psi immediately -- the fuel pressure will not build up but instead it will fall steadily to ~60 psi
Thanks !
Bryce99 likes this.
Xxblinddzxx is offline   Reply With Quote
 Old 08-01-2017, 11:04 AM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
turn your key to the on position but dont start the car and watch your fuel pressure, on your AP. It should keep rising
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 08-01-2017, 11:06 AM   #3
Does the car need to be warmed up?
When I checked the fuel pressure this morning it was stuck arround 48-51 psi
 Old 08-01-2017, 11:57 AM   #4
danb's Avatar
yes, i think it should be warmed up. and it should go up and keep rising. could be the pressure relief valve if it doesnt
https://cse.google.com/cse/publicurl...KOEO&gsc.sort=
mazdaspeed forums google results of "KOEO"
save the search for further needz...
2011 mazda 6
 Old 09-11-2019, 06:03 AM   #5
Erayners's Avatar
Posts: 3   (View Stats)
Erayners will become famous soon enough
Default KOEO
Hi there. I read up on how to text below. When putting ignition to the on position, when HPFP reading, when it rises, till what psi should it rise to when you have Autotech internals?
Erayners is offline   Reply With Quote
 Old 09-11-2019, 09:08 AM   #6
Police - Grammarhead
Vansquish's Avatar
Groans: 1,909
The internals will not change the KOEO fuel pressure readings. The high pressure relief valve (HPRV) is what determines the pressure in the rail during the KOEO test.
The only way to know if you have upgraded (Autotech/Corksport/etc.) HPFP internals is to remove them from the HPFP and inspect them.
Erayners likes this.
danb (09-12-2019)
 Old 09-11-2019, 12:48 PM   #7
Erayners's Avatar
Hi, thanks for tip. I have a AP2. Reading on AP were 1326psi, and just stayed there. What should it read with autotech internal.upgrade?
 Old 09-11-2019, 01:29 PM   #8
Vansquish's Avatar
Groans: 1,909
Did you not read what I just wrote above? In case you missed it, I am quoting myself below and highlighting the important bits.
"The internals will not change the KOEO fuel pressure readings. The high pressure relief valve (HPRV) is what determines the pressure in the rail during the KOEO test.
The only way to know if you have upgraded (Autotech/Corksport/etc.) HPFP internals is to remove them from the HPFP and inspect them."
To be clear, the TYPE of fuel pump internals that you have will not have any effect on your KOEO fuel rail pressure. The only thing that can and will alter that pressure is the HPRV.
If you want to find out if you have aftermarket fuel pump internals, YOU HAVE TO REMOVE THEM FROM THE PUMP AND INSPECT THEM.THERE IS LITERALLY NO OTHER WAY TO KNOW.
If you want to know if you have healthy fuel pressure while you are driving, then you have to datalog the HPFP Actual pressure while you are at WOT from 3000rpm - 6000rpm in a single gear (preferably third or fourth gear), and look to see if there are any dips in pressure below 1600psi during the WOT portion of the datalog.
You cannot assess the health of your fuel system while driving without datalogging. Watching the AP's screen will not help you at all, as the refresh rate is far too low to be useful.
 Old 09-12-2019, 05:30 AM   #9
Erayners's Avatar
Thank you very much for that. I know I have the autotech cause I had it installed myself. Car was doing great after I had fuel rail sensor issues. I changed that, as well as in tank pump. After that, doing WOT logs, I am not seeing anything over 1400psi or something. That is when I knew I have fueling issues. Is there a way to use AP to see what in tank pump is doing, and if it's doing what it should, as well as for hpfp ? The issue must come from somewhere, I just don't know where.
The Following User Says Thank You to Erayners For This Useful Post:
Vansquish (09-12-2019)
 Old 09-12-2019, 07:49 AM   #10
Vansquish's Avatar
Groans: 1,909
I don't recall any particular way to read in-tank fuel pump pressures. Could you post a WOT datalog so we can take a look at it?
KOEO Boost Fluctuation+Idle RPM Fluctuation Emew MazdaSpeed 3/6 - ECU Computer Tuning 8 05-23-2014 11:48 AM
MAF voltage KOEO MaverickX3 MazdaSpeed 3/6 - ECU Computer Tuning 1 06-07-2012 02:48 PM
Page generated in 0.30464 seconds with 23 queries
