> MazdaSpeed 3 - How-To's
Like Tree2Likes
  • 1 Post By 08mzr
  • 1 Post By Tomas
 Old 02-05-2019, 05:42 PM   #1
raven4life's Avatar
Posts: 5   (View Stats)
raven4life is an unknown quantity at this point
Default No heat at idle
My car warms up from a cold start but when I drive and come to a stop cold air comes out but if I rev it or drive the heat is hot also the lower radiator hose is cold
raven4life is offline   Reply With Quote
 Old 02-05-2019, 09:17 PM   #2
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
In my expirence, 90% of the time is low coolant, 5% is air in the system because of a leak or recent cooling system repair, and 5% other.
Start with checking coolant level and be sure the system is properly bled a d that you have no leaks.
If it was a thermostat issue you would have poorish heat while driving.
With most owners never exchanging coolant as they're supposed to, replacing the thermostat is good maintenance, but dont expect it to fix you're issue.
raven4life likes this.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 02-05-2019, 09:36 PM   #3
raven4life's Avatar
Neutral  -1 score
How would I bleed the system? And also the coolant reservoir is at the max amount
 Old 02-06-2019, 05:44 AM   #4
08mzr's Avatar
Have you had to add any coolant to it?
Bleeding is usually done by just letting the car run up to operating temp with the reservoir/radiator cap off. After it's up to operating temp let it run for a little while longer, revving it to 1500rpm during the warm up and running process helps circulate coolant.
After letting it run I like to turn the car off and let it sit without the cap on it until it cools and then repeat the process. I have had air escape a lot during the cool down proccess.
Some people like to jack the car up on just the side with the reservoir, but this is up to you.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
The Following User Says Thank You to 08mzr For This Useful Post:
raven4life (02-07-2019)
 Old 02-07-2019, 11:45 AM   #5
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
You may have a faulty thermostat that's sticking. Or like stated, low coolant. I would drain and fill with new coolant, bleed, and go. Do not open the cap when the engine is hot as the system is under positive pressure!
 Old 02-07-2019, 11:52 AM   #6
raven4life's Avatar
I haven’t added any coolant and never took the cap off. Just started to happen with it was -30 outside
 Old 02-07-2019, 01:03 PM   #7
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,810   (View Stats)
At -30F I am not sure the thermostat will ever open. You know how cold that is nigga? Fuuuuuu.
Db09ms3 (02-25-2019), raven4life (02-07-2019), Thor Hammer (02-07-2019)
 Old 02-07-2019, 02:09 PM   #8
Jeff23spl's Avatar
Posts: 2,192   (View Stats)
to bleed it, you can lift the front higher than the back while doing the above instruction to help the bubbles to get out.
It can also be your heater core that is plugged with deposit when someone never replace the coolant. A flush with cleaning product may help but when it is too late, it means a core replacement....
Some leak fixing stuff is terrible at blocking heater core and some other part of the system...Never use that.
In the other hand, you may monitor your coolant temp, it takes a lot more time to heat up a car with a -30deg C outside...And when the turbo is used, you quickly feel the heat generated....
Our thermostat are likely to bloc at some opening position a bit more than usual. If you monitor an unstable temperature, it may return a bad TH. During very cold days, it is likely to get up to temp and then drop a bit while slowing down 1 or 2 times but if it keep going up and down when the car is up to temp for a long while, your TH is bad.....
I would start with a new TH, a coolant flush and new coolant perfectly bleeded. Then if it isn't better, i would investigate into a core replacement but it is usually a pita...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-07-2019, 02:30 PM   #9
MSMS3's Avatar
Posts: 2,795   (View Stats)
Groans: 157
OP just do this outlined above. I call it "burping" the air out of the system. Same thing.
I just had to increase antifreeze to water concentration for winter. I was selling the car (my baby) to someone in a more frigid climate. I run a higher water ratio most of the year. I drained out about a gallon from the plastic plug in the bottom left side of the radiator and then began adding pure antifreeze and testing until I got the ratio to 50-50.
I left the cap off the reservoir, it did a lot, I mean a lot of burping of air before I got it all out. Had to leave it running quite a while with the cap off until the coolant level normalized. Turned it off, let it sit, watched the reservoir and then restarted it and ran it some more. As more and more air escaped I slowly topped off with a 50-50 solution until it stabilized at the proper level.
You may just have air in the system. Good time for a drain and flush if it's never been done, anyway.
Good luck.
 Old 02-19-2019, 06:27 PM   #10
raven4life's Avatar
So I replaced the thermostat a couple days ago and the heat worked but my temps would go up on the high way and when I slow down/stop it goes down about 20 degrees. And just last night I got cold air at idle again
 Old 02-25-2019, 08:29 AM   #11
Jeff23spl's Avatar
have you bleeded it again after running for a while with the front leveled ?
I bet your belt was spinning fine around the pump so if the air is gone and TH is new, the only part remaining is a plugged heater core...
I would give few more try at bleeding it with enough temperature.
I cost nothing while replacing the heater core is a pita...
Wife drive 2010 CX7
 Old 02-25-2019, 05:32 PM   #12
raven4life's Avatar
It was good for a couple days after I bled it then again it happened today so I bled it and it’s good again. Also when my car is up in temp I see slight steam coming from the top of the rad could that be a hole? My coolant level hasn’t moved since
 Old 02-26-2019, 10:17 AM   #13
Jeff23spl's Avatar
sometimes you have some drops when filling the rad and it makes that but vanish after few days of driving. If it is dry outside and it keep smoking, yest you may have a leaking rad.
Wife drive 2010 CX7
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 03:42 PM
MS6 no heat mattymogue MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 01-02-2013 07:43 PM
NO HEAT? avento MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-02-2012 09:45 PM
Page generated in 0.33870 seconds with 25 queries
