> MazdaSpeed 3 - How-To's
Like Tree7Likes
  • 5 Post By tddvrrn
  • 1 Post By bigriver
  • 1 Post By wankular
 Old 01-24-2012, 09:14 AM   #1
realkewl's Avatar
Posts: 6   (View Stats)
realkewl will become famous soon enough
Default Replace spark plugs
Ok guys, I'm sure this has been answered time and time again, but since it's my turn to replace my plugs on my MS3 2008, here goes the $1M question. How to you get the Intercooler off.
I loosen the ring, but how do you get the rubber hose off. BTW the ring does loosen, but will not slide down the hose. Not sure if that's an issue, but I cannot see what is keeping it from freely sliding around.
Keep in mind I'm not a mechanic, just like to do some things myself, so I'm assured it's done correctly.
I've already bought my plugs, and I downloaded a how to guide, but the rubber hoses is giving me grief.
Peace,
Realkewl
realkewl is offline   Reply With Quote
 Old 01-24-2012, 09:18 AM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
did you remove the bolts holding the IC down?
if so, just pull. unscrew the hose clamp more, slide it down, and pull upwards on the intercooler.
07 MS3
The original Genpoo Hater
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
BobbleHead (02-02-2012), rfinkle2 (01-24-2012)
 Old 01-24-2012, 09:21 AM   #3
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
i'm actually a bit torn between ripping you the proverbial new anus for asking a very easily searchable topic and actually answering your question since it seems you have read up and are having problems with a specific step..
so.. the hose clamp, which is the 'ring' you are speaking of i think, should loosen up enough to move freely on the boost tube. if it doesn't, it may be stuck to the tube, in which case a good whack with a wrench should loosen it. or, it may be too short and you'll have to remove it completely.
as long as you have removed the 3 nuts holding on the ic and loosened the hose clamps on both boost tubes (one towards the back of the car, one towards the front), you should be able to wiggle and pull the intercooler off.
if you are having trouble, let the car warm up a few minutes. warm rubber is much more pliable than ice cold.
good luck. this is really quite easy. be careful doing the rest, i am afraid you may be a bit retarded.
The Following 10 Users Say Thank You to tddvrrn For This Useful Post:
Black Metal (01-24-2012), BobbleHead (02-02-2012), chaser27 (07-28-2014), Easter Bunny (05-09-2013), Fermion (07-28-2014), kgb (12-21-2013), pipe (05-31-2012), rfinkle2 (01-24-2012), sadak (05-09-2013), uncorked11 (01-24-2012)
 Old 01-24-2012, 09:34 AM   #4
bigriver's Avatar
Posts: 1,123   (View Stats)
Easier to just squeeze the hose to break it loose from the intercooler.
The Following 2 Users Say Thank You to bigriver For This Useful Post:
rfinkle2 (01-24-2012), tddvrrn (01-24-2012)
 Old 01-24-2012, 09:37 AM   #5
wankular's Avatar
Posts: 4,343   (View Stats)
I remember my stock hose clamps being glued to the tubes. Only in one spot so a good wiggle should get them off.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 01-24-2012, 09:41 AM   #6
theurgy's Avatar
Posts: 2,580   (View Stats)
I've encountered what you're experiencing as well. Loosen the hose clamp and sometimes it get stuck on the rubber boost tube. Try to get enough slack on it and move that slack all along the edge of the clamp. It's not until you're able to rotate that clamp that it's free.
Also keep in mind that the bypass valve is connected to the cold pipe of the intercooler and you'll need to either remove the vacuum hose and return hose or take out the 2 bolts holding it to the cold pipe and leave it hanging there.
Just make sure that when you re-attach the BPV that the gasket isn't kinked and is well seated.
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
The Following 3 Users Say Thank You to theurgy For This Useful Post:
realkewl (01-24-2012), rfinkle2 (01-24-2012), tddvrrn (01-24-2012)
 Old 01-24-2012, 09:55 AM   #7
bigriver's Avatar
Ya the clamp is glued to the hose. Just loosen it up a LOT and also squeeze the hose to break the gunk that might be between the hose and the IC inlet.
The Following User Says Thank You to bigriver For This Useful Post:
 Old 01-24-2012, 10:18 AM   #8
realkewl's Avatar
Cool, thanks for the feedback. Now, I cannot recall, which hose is the hot or cold, but I do recall there being three hoses that connected to the IC. Two towards the front. Is one of them the BPV you are referring too?
I think I"ll give it another go this weekend, so basically, I need to keep working the clamp until it freely moves around the hose, before I attempt to remove the hose.
Too bad there's no youtube on this.
Peace,
Realkewl
 Old 01-24-2012, 10:24 AM   #9
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
oh, but there is.
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
Chimmike (01-24-2012), tddvrrn (01-24-2012), uncorked11 (01-24-2012)
 Old 01-24-2012, 10:51 AM   #10
Will fuck up ur day
Chimmike's Avatar
Groans: 433
dude. this is honestly a 15 minute job. Weekend? Srsly?
remove 3 nuts. disconnect 3 hose clamps (or loosen completely). Pull up firmly on intercooler (trust me, you're not going to break any hoses or anything.) viola, intercooler off.
then, unplug/remove individual coils. Take out old spark plugs.
check gap on new spark plugs.
install.
What plugs are you installing? Please don't say autolite or shit like that.
07 MS3
 Old 01-24-2012, 10:57 AM   #11
anavrinIV's Avatar
Posts: 4,481   (View Stats)
Groans: 63
Corksport TMIC instructions
that's corksport's instructions for their TMIC installation, but it goes through the removal as well. Maybe it will help you out. It was written for a gen2 but it's the same procedure for a gen1.
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
realkewl (01-24-2012), tddvrrn (01-24-2012)
 Old 01-24-2012, 11:11 AM   #12
bigriver's Avatar
Good one! But OP is busy finger banging the hose clamps.
OP - the clamps will just get loose and wont rotate around the hose. You can stop fingering it.
 Old 01-24-2012, 11:19 AM   #13
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
This is the OP after swapping out the plugs.
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
The Following 2 Users Say Thank You to deadlandxtreme For This Useful Post:
karl-hungus (01-24-2012), msalva2 (09-14-2012)
 Old 01-24-2012, 01:32 PM   #14
realkewl's Avatar
install.
15 min would be great! I just ordered the OEM plugs which I think are NGK's...my days of ordering high-end stuff have passed. I like my speed3 the way it is...a real sleeper. Plus, I just bought another ride to compliment it, Kia Optima SX. So I just want to maintain my speed3 as is and do as much as I can...because time has showed me that your car gets messed up when you start taking it to the dealership. Not to offend any dealership mechanics here...you guys are different...
Peace,
Realkewl
The Following User Says Thank You to realkewl For This Useful Post:
tddvrrn (06-27-2012)
 Old 01-24-2012, 01:46 PM   #15
theurgy's Avatar
Sigh...... I tried.
 Old 01-24-2012, 02:40 PM   #16
wankular's Avatar
Yeah, right.
Re-visit this thread one year from today. And take a look at all the parts you have on your car. It's funny reading threads from like 2008 with dudes asking how to do an oil change and now present day they've gone BT with built motors.
2009 MS3 sport MGM
theurgy (01-24-2012)
 Old 02-21-2012, 03:37 AM   #17
thomas_cory2000's Avatar
Posts: 675   (View Stats)
thomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the world
Yea right - my car is bone stock and I refuse to do any modding to it!! (just kidding)
The Money Pit: 2011 MS3 - Mica Black - Tech Package - Cobb SRI, TIH, AP, Hella horns, CP-E Stage II RMM, JBR OCC, SSB, ATP Catless DP, UR catback exhaust, Autotech HPFP Internals, Turbo Smart Kompact bpv, Sure Shortcut, DIY clutch travel mod, DMM tuning HID 4300K fogs, & Freek tuned!
2010 FZ1, ZG double bubble, Yoshi carbon slip on exhaust, Pro Grips super bike grips & tank pad, fender eliminator, OES Frame/swing arm sliders, BMC Race Filter, Ram Mount, R6 throttle tube mod, heated grip inserts, PCIII with Duken map.
zoom zoom bitches...
thomas_cory2000 is online now   Reply With Quote
 Old 05-02-2012, 07:51 PM   #18
randino69's Avatar
Posts: 272   (View Stats)
randino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the worldrandino69 is the leader of the world
This post had me just rolling! It is so easy to pull off the damn TMIC. haha.
2010 Black Mazdaspeed 3 - SOLD 6-15-2013
JBR 88 Dogbone & PTP Kicker | SURE AEROS/Countershift/Shortcut/Anchor Shift Bushings | COBB AP/TIP | CPE Catted DP/CBE/FMIC | Forge v2 BPV | DENSO ITV22 | PTP HPFP/Windage/BSD | Tanabe Strut Bar | JBR RSB/Camber Arms | BC Coilovers | GS EBCS | Guardian Angel | Coolant Bypass | CS Tow Plate & Hangers | Rotella T6 | LEX tuned!
Drive it like you stole it!!
randino69 is offline   Reply With Quote
 Old 05-08-2013, 03:14 PM   #19
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
Originally Posted by wankular View Post
Yeah, right.
Been over a year and this dude is still a tool... with a fresh set of dusty oem plugs sitting in his garage.
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
 Old 05-08-2013, 03:31 PM   #20
realkewl's Avatar
WRONG!!
The plugs have been changed thank you very much. You should inquiry first before making a false statement.
And for randino69, just because something is easy for you doesn't means it's easy for the next person. For example you know how to calculate the stochastics? How about land an airplane in a 20 knot crosswind?
And yes, it's been over a year and I'm still happy with my stock car. MAYBE because I have another car and a motorcycle. ;-)
 Old 05-08-2013, 04:12 PM   #21
kimura's Avatar
Posts: 170   (View Stats)
kimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the world
WRONG!!
I just read this thread for the first time and couldn't decide if it was a complete troll job or not... with the gratuitous Kia mention... and because I couldn't actually believe that anybody could be as mechanically useless as you claim to be. then I got to this post and it looks like the whole thread is legit? lolwut?
seriously I think you are mechanically handicapped. I'm not sure you should try to even operate complicated machines like cars. please tell me you are posting from a Mac
09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold
kimura is offline   Reply With Quote
 Old 05-08-2013, 04:17 PM   #22
Jeremy3eb's Avatar
Posts: 359   (View Stats)
Jeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the world
Groans: 29
WRONG!!
You would think that if you could do these things that you could removed some worm clamps and rubber tubes. You shoulda asked him if he knew how to make a sammich cause that's what I'm going to get him to do next time I see him!
@randino69;
Jeremy3eb is offline   Reply With Quote
 Old 05-09-2013, 07:32 AM   #23
realkewl's Avatar
@randino69;
Hmmm...let me guess generation 'Y' living at home with moms.
 Old 05-09-2013, 07:38 AM   #24
realkewl's Avatar
Seriously, NOT!!!
Forums are going the way of chat rooms...I pray to God you never need help with anything. Oh...and my guess is you do not know what I mean of going the way of chat rooms.
Dude you drive a Mazda...not a lexus, benz or Bimmer....A MAZDA ... my guess you never had either...and your reference to MAC WTF...that's so....not even words can express...thank God I do not need this forum anymore...one it's lack of moderation.
 Old 05-09-2013, 07:54 AM   #25
Jeremy3eb's Avatar
Groans: 29
Yeah, your moms.
The Following User Says Thank You to Jeremy3eb For This Useful Post:
DoMiNic (05-09-2013)
 Old 05-09-2013, 08:17 AM   #26
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,458   (View Stats)
Groans: 2,978
Too gay to even troll.
I hugged rfinkle2
DoMiNic (05-09-2013), Jeremy3eb (05-09-2013)
 Old 05-21-2013, 04:22 PM   #27
randino69's Avatar
Wow, what the hell happened on this thread? LOL. Yes, pretty much the EASIEST thing to remove on the car is the TMIC, but I digress. I will get back to living with MY mother, and tell my wife to take a hike. Actually, this thread is quite entertaining.
The Following User Says Thank You to randino69 For This Useful Post:
Jeremy3eb (05-22-2013)
 Old 07-28-2014, 01:58 PM   #28
TheSki1974's Avatar
TheSki1974 is on a distinguished road
Groaned at 5 Times in 1 Post
This thread was actually very helpful... I was also having a minor problem removing my intercooler. Just one question: what's an IC?
haaaa... just fuckin' with you, ya' hardcore supertuners, you. Everyone knows it's an integrated circuit.
TheSki1974 is offline   Reply With Quote
The Following 5 Users Say NO Thank You to TheSki1974 For This Un-useful Post:
Big Dog (07-28-2014), chaser27 (07-28-2014), ms6mil (08-02-2014), mxlplx71 (07-28-2014), smoogs12 (08-02-2014)
 Old 07-28-2014, 02:09 PM   #29
mxlplx71's Avatar
Posts: 3,262   (View Stats)
Groans: 128
thanks for reviving this bs
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
 Old 07-28-2014, 03:08 PM   #30
chaser27's Avatar
Posts: 1,276   (View Stats)
chaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the world
Groans: 42
Groaned at 16 Times in 12 Posts
INB4 @TheSki1974; tries to sell something at exactly 150 posts
EDIT: Nevermind. been a member for months and only posted once today... just a pointless ass post
Coming at ya with all 297/359
POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP
ECU: self-tuned
HANDLING: JBR RSB (Middle Setting)
RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc.
RADAR: Passport Escort 9500ci
chaser27 is offline   Reply With Quote
 Old 07-28-2014, 04:29 PM   #31
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
The MS3 intercooler is cake, but the early MS6 intercooler is a bitch because of the 180° cold pipe and short coupler.
EDIT: I wasted my 3,000th post on this.
2006 Mazdaspeed6
 Old 08-02-2014, 08:06 AM   #32
mazdaspeed333's Avatar
Posts: 81   (View Stats)
mazdaspeed333 is infamous around these partsmazdaspeed333 is infamous around these partsmazdaspeed333 is infamous around these parts
Groaned at 89 Times in 48 Posts
We'll I'm bout to throw in some denzo 22's and and gap em at .27, let's see how this tmic is to pop off >
mazdaspeed333 is offline   Reply With Quote
 Old 08-02-2014, 11:25 AM   #33
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
For real, if you need help figuring out how to take your IC off, you probably shouldn't be doing your spark plugs.
Just don't over torque them bitches....
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 08-02-2014, 12:23 PM   #34
Dead Ms3's Avatar
Posts: 206   (View Stats)
Dead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the worldDead Ms3 is the leader of the world
When in doubt use a hammer , it works all the time for Jeremy Clarksonso why not
2012 BLACK MS3 (SOLD)
-Cobb AP -CP-E stg 2 RMM -JBR Rear sway bar
-K&N SRI -UR TP -AT Internals -JBR TIP
-CX Racing fmic piping -TR8L core
2008 WHITE EVO X
-UR TP -UR Cat Back Single exit -Eibach springs
-UR UICP -TurboSmart dual port set fully recirculated
-Injen intake -3 port
...need moar money !
1995 Miata M Edition - DD
-The gay mobile
Dead Ms3 is offline   Reply With Quote
 Old 08-03-2014, 02:16 PM   #35
Shouldn't be to hard, seems pretty straight foward.
Spark Plugs jerseymazda CX-7 > General Lounge + New Member Welcome 18 09-11-2011 06:07 PM
Spark plugs.. lax22pearl MazdaSpeed 3 - Engine, Transmission & Driveline 14 07-31-2011 08:56 PM
Engineers create laser beams that could replace spark plugs Haltech Automotive News 0 04-28-2011 10:10 PM
E3 Spark Plugs bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 6 07-17-2008 05:32 AM
Page generated in 0.55360 seconds with 41 queries
