> Cobb Tuning >
Cobb Access Port/Maps
Like Tree4Likes
  • 2 Post By SLOWHATCH
  • 2 Post By Cobb Tuning
 Old 01-31-2012, 05:41 PM   #1
SSinstaller's Avatar
Posts: 3,943   (View Stats)
Groans: 55
Default Still losing communication?
What there ever a fix for this, my AP is still losing communication at least 25% of the time I try to log..
If you can't fix it 100% could you at least make the AP end the log so I can view what it managed to catch before the issue..instead of trying to re-connect forever forcing me to unplug the ap to reset it--and lose the entire log in the process..
Nothing sucks more than logging WOT through 4 gears and then it losing communication and losing the entire thing..
Soon to be installed:
The Following 11 Users Say Thank You to SSinstaller For This Useful Post:
08cosmic3 (02-25-2012), atvfreek (02-18-2012), Boost_creep (03-19-2012), helmetface (02-25-2012), MindCrimes (02-25-2012), nindoja (01-31-2012), sick_role (01-31-2012), SLOWHATCH (01-31-2012), SofaKingAwesome (02-01-2012), TriO (02-01-2012), wolly6973 (02-01-2012)
 Old 01-31-2012, 06:15 PM   #2
Poet-Tek's Avatar
Posts: 82   (View Stats)
Poet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond repute
90% it's the cable/connectors if you are losing communication between the car and AP during WOT. Have you replaced the USB cable/dongle to eliminate that possibility? You might even just want to position the cable and AP differently during driving and see if that helps. When you just drive around does the AP reboot or go blank momentarily often?
If it's the actual log file not capturing data, I think they have a firmware update that addresses it. But it sounds to me like there's a cable/connector problem or you need to send your AP for repair.
You could try rewriting/updating the firmware to eliminate a software glitch. If there is a cold solder joint or some other defect on the board or internal AP USB Connector, your best bet is to send it for repair.
Hope that helps.
Poet-Tek is offline   Reply With Quote
The Following User Says NO Thank You to Poet-Tek For This Un-useful Post:
 Old 01-31-2012, 06:18 PM   #3
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I feel your pain. Although mine seemed to be doing it pretty often a few weeks ago, not so much lately.
Its weird how it's so unpredictable. Only thing I figured to do was to make sure it was actually logging before going wot. I found that if I do it this way it still records the log vs other times where I would loose the entire log if it lost communication from the start.
Also once it does lose communication you can just hit the back button without unplugging the ap. At least that works on mine.
Hope there is a TRUE fix for this at some point. But I wouldn't trade my AP for anything else either way.
Hope that helps.
AP only seems to lose communication when datalogging. Never on the live data screen or at any point except when datalogging.
Stealth01 and rfinkle2 like this.
Last edited by SLOWHATCH; 01-31-2012 at 06:18 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to SLOWHATCH For This Useful Post:
MindCrimes (02-25-2012), rfinkle2 (02-01-2012)
 Old 01-31-2012, 06:23 PM   #4
Groans: 55
Hope that helps.
I have tried several different mounts/mounting locations, removed and zip tied the OBD2 connector, installed ferrules on the cable and car harness, it makes no difference. It never has any issues driving around showing live data. The issue only happens when actually logging. It says it's lost communication, and tries to reconnect forever, I have to unplug it to reset it.
If the AP occasionally loses connection because of how fast it's polling the ECM, I can live with that.
What's annoying is how the AP handles the issue.. It should save the log immediately after the connection is lost, and then try and reconnect to the ECM. I'd rather the AP save whatever portion of the log it can, than lose everything because it sticks trying to reconnect, and I'm forced to unplug it.
None of the buttons work for me, I have to unplug the AP to reset it..
 Old 01-31-2012, 06:25 PM   #5
bigriver's Avatar
Posts: 1,123   (View Stats)
Has only happened once since the last software update. Used to happen a lot more frequently before then. I know there wasnt a fix in the last update but at least its less frequent for me.
 Old 01-31-2012, 06:38 PM   #6
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
really frustrating. happens to me often.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 01-31-2012, 06:39 PM   #7
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
Better than mines. mine disconnects every other log. It's getting annoying. =\
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 01-31-2012, 06:46 PM   #8
Metal409's Avatar
Posts: 316   (View Stats)
Metal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the world
Im lucky to get one log out of 3 attempts. It's so hit or miss too, sometimes I can get a good long log, other times it drops out right after starting the log. I also have to unplug mine in order for it to reconnect. I really like the new rate, but it seems to have unleashed some gremlins.
2016 Ford Focus ST
2013 Ford Fusion Titanium AWD - Sold
2009 Mazdaspeed 3 GT - Sold
Metal409 is offline   Reply With Quote
 Old 02-01-2012, 06:46 AM   #9
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Mine loses connection right when starting the log- It'll monitor fine, and when you start the log it just loses connection, have to go back to the main screen and start monitoring again, then start a log again. This fail is about 1 in 5 logging attempts.
I lose connection during a log only rarely, maybe 1 in 30 or so, but that happens during the long logs and most of mine are under a minute.
340hp / 371tq
 Old 02-01-2012, 06:51 AM   #10
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
You can minimize the amount of communication errors if you log from the data log screen vs. the live data screen.
It isn't a 100% fix, but seems to work pretty well for many guys.
It also seems that it is best to move back to the main menu, and choose datalog>the paramater you wish to log> and start logging right away.
(e.g. don't monitor for a long period of time in the datalog screen before starting the log)
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Metal409 (02-01-2012), shawn. (02-25-2012), SofaKingAwesome (02-01-2012)
 Old 02-01-2012, 06:56 AM   #11
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,443   (View Stats)
Groans: 890
@David@COBB, is there an ETA for a fix? My offer for test vehicle/AP still stands.
 Old 02-01-2012, 07:00 AM   #12
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
Same here. This never happened to me before but since I recently updated atr/AP firmware its happening quite often. It's a pita which Cobb should fix. it was definitely caused by one of the updates....
TriO is offline   Reply With Quote
 Old 02-01-2012, 08:18 AM   #13
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Cobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the worldCobb Tuning is the leader of the world
Groaned at 47 Times in 18 Posts
I'm working on it guys. It isn't easy to track down, as I believe it to be linked to some form of memory allocation issues.
-David@COBB
TiGraySpeed6 and rfinkle2 like this.
Cobb Tuning is offline   Reply With Quote
The Following 14 Users Say Thank You to Cobb Tuning For This Useful Post:
08cosmic3 (02-25-2012), atvfreek (02-18-2012), BobbleHead (02-06-2012), Boost_creep (03-19-2012), Easter Bunny (09-05-2012), fywdyl (02-01-2012), knarfies (03-15-2012), Metal409 (02-02-2012), MindCrimes (02-25-2012), rfinkle2 (02-01-2012), SofaKingAwesome (02-01-2012), SSinstaller (02-01-2012), TriO (02-01-2012), xtasy (02-01-2012)
 Old 02-01-2012, 08:22 AM   #14
Atomic41's Avatar
Posts: 1,167   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
Nice to know you're on it !
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline   Reply With Quote
 Old 02-01-2012, 08:31 AM   #15
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
Groans: 52
Remember back in the good ol' days, you had to blow into the NES cartridge to get it to work?
Try that before plugging in the AP.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline   Reply With Quote
The Following 3 Users Say Thank You to fywdyl For This Useful Post:
Easter Bunny (09-05-2012), rfinkle2 (02-01-2012), Stealth01 (02-25-2012)
 Old 02-06-2012, 12:52 AM   #16
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
It rarely happens to me if I wait for it to start logging then go WOT. If I press the button and go WOT at the same time, I always have errors
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
 Old 02-17-2012, 11:55 PM   #17
TriO's Avatar
This issue is really starting to get annoying for me... Every time I go out to get logs it crashes a few times... Which sucks when I'm fighting for clear roads with no
Po Po.
Any update from Cobb?
The Following User Says Thank You to TriO For This Useful Post:
qtrmile beast (09-05-2012)
 Old 02-25-2012, 09:06 AM   #18
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Glad you're working in it, David. THis happens to me about one in every three logs, and it seems to happen randomly, with no rhyme or reason as to why. WOT MIGHT have something to do with it...but not positive on that.
PLEASE let us know when this is fixed. LOVE my AP, but this is a pain.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
 Old 02-25-2012, 09:16 AM   #19
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groans: 29
i've noticed it happens any time you sit at the datalog screen for a long period of time. if i go to monitor>datalog>KR then immediately start my log, i never once lose communication. however, if i go to monitor>datalog>KR and drive for 10 seconds (or more) or so THEN hit the middle button to start my log, it loses connection. and that happens almost every time if i don't start my datalog quickly.
i've just been making sure i start everything immediately and it works 100% of the time, but it is kind of annoying still to be doing all of that and time it exactly to where you want to start your log etc. haha
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 02-25-2012, 11:43 AM   #20
radbrad's Avatar
Posts: 538   (View Stats)
radbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the world
I've had this issue since day one. About 1 out of 4 logs would loose connection.
But since the latest update it has been happening much less.. About 1 out of eve 10 logs.
Also I've noticed it looses connection a lot less if you data log from the data log menu, not from the live data menu.
My .02 cents.
RadBrad
07Speed3
TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. ||
radbrad is offline   Reply With Quote
 Old 03-22-2012, 07:34 PM   #21
08cosmic3's Avatar
Posts: 2,920   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groaned at 54 Times in 43 Posts
I'm still having this issue and it's really starting to piss me off. I made three passes at the strip and tried to log all three and everyone lost contact during the run. This happens half the time now. I never had this issue until an update several months ago.
@cobb fix this issue please. If it's a cable let me know, I'll buy another cable if it's not under warranty. I don't have any issue except logging so I doubt it's the cable in my case.
EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14
____________________________________________Dragon Slayer _________________________________________________
08cosmic3 is offline   Reply With Quote
The Following User Says Thank You to 08cosmic3 For This Useful Post:
shawn. (03-22-2012)
 Old 03-22-2012, 09:56 PM   #22
scorpiorc10's Avatar
Posts: 167   (View Stats)
scorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the worldscorpiorc10 is the leader of the world
Groans: 77
Groaned at 103 Times in 42 Posts
This is what is happening to me
Connection Issues NOT logging
scorpiorc10 is offline   Reply With Quote
 Old 09-05-2012, 04:10 AM   #23
qtrmile beast's Avatar
Posts: 2,417   (View Stats)
Well i just bought mine about 3 months ago but i just started driving the car with it in the car and i am already getting this almost every time i go to log.......it also seems like it is having problems connected to my ATR as well..
track weight 3220
street weight 3370
 Old 09-09-2012, 08:43 PM   #24
Groans: 77
I had to get this
New OBD-II OBD2 16Pin Male to Female Extension Cable Diagnostic Extender M16P | eBay
because I guess a small % of us have stretched pins in the OBD2 port.
@David@COBB they told they would not make a better cable with longer and thicker pins like the cable I bought off ebay that works great!
My Communication with as Asshat about my car volodya84 Mazdaspeed3/6 General Discussion 30 12-14-2010 05:41 PM
Toyota chief orders communication reform task force Haltech Automotive News 0 02-26-2010 09:10 PM
Losing oil TegRacer324 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 01-07-2010 10:17 AM
Autometer Nexus - Module Communication Error vbt101 MazdaSpeed 3/6 - Car Audio & Electronics 0 07-23-2009 01:16 AM
Page generated in 0.46517 seconds with 40 queries
