Mazdaspeed Forums Reviews/Articles
> Mazdaspeed Forums Performance Parts Reviews
Mazdaspeed Forums Performance Parts Reviews Mazdaspeed Forums takes a look at performance parts aimed for you Mazdaspeed vehicle. These are honest, thorough & unbiased reviews based off a manufacturers products.
Like Tree8Likes
  • 5 Post By Raider
  • 1 Post By Turbo_Steve
  • 1 Post By JSmith
 Old 10-22-2015, 12:45 PM   #1
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Default Turbo_Steve's Valve Cover and HPFP cover review
As many of you know, @Turbo_Steve; has been playing with fabrication of parts for us. He's also working to get vendor status here, and this thread will move there once established.
I have received and installed the covers. These are aluminum panels that were powder coated wrinkle black. Initial review was of packaging. Packed nicely and no scratches. Both coated panels were plastic wrapped. Then they were wrapped in enough material to keep it immobilized in the box. Color instructions are nice and ended up easy to follow.
For the install, total time was 15 minutes including pics and backing out my car.
Before
Because my piping is protege garage v1, it's own fitment is pretty much butthole. But I was able to remove the coil pack bolts without removing the hot pipe.
Hardware consists of Allen bolts, a washer, a spacer, and a little rubber o-ring that just holds it in place for install which is great, when all 4 are hanging prior to install.
Installed quickly. I slid into place, lining each bolt with the coil pack prior to tightening any.
Hpfp was cake too. Same thing as before. Remove bolts, put plate and hardware on. This one used 2 spacers, but the little o-ring kept it right. Installed in a couple minutes.
Fitment was spot on. I bet others will have a lot more clearance than I do.
Covers the coil mess and looks clean. Not sure if this counts as another modification I have installed, but I'm claiming it. 6 now.
Look for @Turbo_Steve; to be a vendor soon under Adapted Performance.
The Following 19 Users Say Thank You to Raider For This Useful Post:
Boost_creep (10-31-2015), Code Monkey (10-22-2015), dale_gribble (10-22-2015), DevinS (12-23-2015), Easter Bunny (10-22-2015), Finchee (11-06-2015), ItsNox (10-27-2015), John596 (04-08-2016), Justin@Freektune (10-24-2015), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015), monkey.bones.007 (10-22-2015), robbspeed (11-28-2015), Scare Dem (10-22-2015), SofaKingAwesome (10-22-2015), therapist510 (10-23-2015), ToyCop (01-15-2016), Turbo_Steve (10-22-2015), Zoom66 (10-22-2015)
 Old 10-22-2015, 12:55 PM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Turbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the world
Looks good! Nice writeup.
Only sad part is the mazdaspeed logo is partially covered with this charge piping.
I will offer versions with no logo cutout as well & lots of color options.
Thanks!
ouchmonkey likes this.
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline   Reply With Quote
The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post:
DingoDave (12-05-2015), Easter Bunny (10-22-2015), ericrapp0507@gmail.com (06-16-2016), ItsNox (10-27-2015), jcolton (02-10-2017), Mauro_Penguin (10-22-2015), Raider (10-22-2015), Zoom66 (10-22-2015)
 Old 10-22-2015, 01:03 PM   #3
Raider's Avatar
Groans: 856
Thanks!
The MPS logo would be badass too, or just blank. I am sure other piping kits wont be as suckballs as my kit.
 Old 10-22-2015, 01:51 PM   #4
Zoom66's Avatar
Posts: 281   (View Stats)
Zoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the worldZoom66 is the leader of the world
Need me one of those sets in red with the mazda speed logo. It will be easier to install on mine with the fmic piping routed under the engine. This looks really good.
2013 MS3 Velocity Red - FLOW Tuned 25% E85
Mods - GTX2867R Turbo, Snow Meth Kit, Forged Manley Platinum pistons and Rods, Matt Dammond Balance Shaft Delete, Southbend Stage 3 Clutch, SPerformance Aux Fan Controller, 4" HTP Intake, Greddy FV BOV, Stratified Guardian Angel V2, Cobb AP V3, Tanabe Strut Tower Brace, Magna-flow CBE, HPFP Autotech Internals, CorkSport Shifter Bushings, CorkSport short throw shifter, CP-e Stage 2 RMM, CP-e Catless Downpipe, QTP Electric Exhaust Cutoff, NGK one step colder plugs, Cobb 3-port EBCS, Whiteline FSB, EBC 3GD Slotted Rotors, Hawk HPS Brake Pads, Goodridge Stainless Steel Brake Lines, HTP Small Battery Box, 51R Optima Yellow, SPC adjustable Rear Camber Arms, KW Variant 3 Coilover setup, Matt Dammond Passenger and Transmission mounts, Falken Azenis tires (street use), Defi Boost Gauge, AEM UEGO Wideband Gauge, AEM Water Temperature Gauge, AEM Oil pressure gauge, Corksport Short Shifter, Apexi Turbo Timer, Corksport Skid Plate, Threadstone TR8 core and crash bar, DOCRACE exhaust manifold, Reletnless Customs Ported IM, JBR 250 Competition Rear Sway Bar, Kuhmo V710 on RX8 wheels (track use), Matt Dammond OCC (VC and intake), Speed Performance Vented Oil Cap,
Rice - 20% tint, Morimoto HID kit, Retrofit High Beams, Morimoto projector clear lenses, Corksport Hood Strut Kit, Corksport eyelids color matched, Ebay rear spoiler extension, Morimoto RGB Halos, LED Red Evil Eye, VG Shark Fin Antenna, Coil Cover, Blue Vacuum Hoses, Morimoto LED low beams, Cover King custom Seat Covers
Zoom66 is offline   Reply With Quote
 Old 10-22-2015, 02:42 PM   #5
knocturnal's Avatar
Posts: 266   (View Stats)
knocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond reputeknocturnal has a reputation beyond repute
I need one in MattDamond gold. looks good
2012 Crystal White Pearl MazdaSpeed 3
Mods:
BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
Purple Drank Tuned BNR S4 V2 and 100%Meth
412whp/373wtq
knocturnal is offline   Reply With Quote
 Old 10-22-2015, 03:06 PM   #6
aackthpt's Avatar
Posts: 1,450   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
That is sweet.
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 10-22-2015, 04:30 PM   #7
macdiesel's Avatar
Posts: 825   (View Stats)
macdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the world
Is it possible to do a smaller mazdaspeed logo and align it to the left? Looks great though.
2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts//
Coming up: Corksport injector seals
macdiesel is offline   Reply With Quote
 Old 10-22-2015, 07:47 PM   #8
The version with no Mazdaspeed logo would be ideal. You can apply vinyl anywhere you wish like in this version.
Soon to come.
The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post:
Easter Bunny (10-24-2015), ericrapp0507@gmail.com (06-16-2016), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015)
 Old 10-23-2015, 08:54 PM   #9
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Groaned at 61 Times in 34 Posts
Wow those really look good for engine dress up I like them but the only problem is that those of us who have TMIC won't get the benefit of this nice piece of work! Great work Steve!
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 10-24-2015, 05:37 AM   #10
Raider's Avatar
Groans: 856
I do want to follow up that it passes the wheel hop/spin test with the JBR high duro trilogy mounts. Had some fun, wheels spun, a little hop in 2nd and no banging heard or damage seen after.
Turbo_Steve (10-28-2015)
 Old 11-28-2015, 07:23 PM   #11
MY DICK IS SMALL-beautfpowers@gmail.com's Avatar
Posts: 327   (View Stats)
MY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these partsMY DICK IS SMALL-beautfpowers@gmail.com is infamous around these parts
Groaned at 212 Times in 84 Posts
sex
MY DICK IS SMALL-beautfpowers@gmail.com is offline   Reply With Quote
The Following User Says Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Useful Post:
Raider (11-30-2015)
 Old 07-08-2017, 09:40 PM   #12
Partiesplayin's Avatar
Posts: 18   (View Stats)
Partiesplayin is on a distinguished road
Groaned at 3 Times in 1 Post
I want a set with logos
Partiesplayin is offline   Reply With Quote
 Old 07-08-2017, 10:00 PM   #13
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Groaned at 6 Times in 6 Posts
@Partiesplayin; It is generally frowned upon to resurrect 2 year old threads without adding useful content.
macdiesel likes this.
 Old 11-08-2017, 08:17 AM   #14
darkmx-6's Avatar
Posts: 126   (View Stats)
darkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nice
At least he searched lol
but It would be better not to revive such an old thread though. Just send the guy a private message.
darkmx-6 is offline   Reply With Quote
The Following User Says NO Thank You to darkmx-6 For This Un-useful Post:
JSmith (11-08-2017)
Page generated in 0.35586 seconds with 31 queries
