> MazdaSpeed 3/6 - Dyno Sheets/Discussions
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
Like Tree2Likes
  • 1 Post By Thor Hammer
  • 1 Post By Fstrnyou
 Old 04-12-2019, 09:35 AM   #1
DjSinestro's Avatar
Posts: 13   (View Stats)
DjSinestro will become famous soon enough
Default Access ports and HP
Is there a way to figure out torque/HP with an access port?
DjSinestro is offline   Reply With Quote
 Old 04-12-2019, 09:43 AM   #2
Db09ms3's Avatar
Posts: 380   (View Stats)
Groans: 80
Plug it in your peepee
Stockish
The Following 3 Users Say Thank You to Db09ms3 For This Useful Post:
andale927 (04-16-2019), danb (04-12-2019), InkedInspector (04-17-2019)
 Old 04-12-2019, 02:35 PM   #3
Jeff23spl's Avatar
Posts: 1,897   (View Stats)
the only way is to datalog carefully under specific conditions and plot is with vdyno software. You can search vdyno thread to figure out how to do it. At the end of the day, it is more usefull to compare the same car tested at the same place against new modifications than comparing different car at different places because the power units have some difference according to different conditions and cars.
You have other device that read g-force or or calculator that estimate hp based on the time it takes to accelerate a specific mass but all of them are affected by measuring parameters. The best way is to put 2 car side by side on a track or strapped on the same roller back to back.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-12-2019, 05:05 PM   #4
5doorsoffury's Avatar
Posts: 1,122   (View Stats)
Groans: 74
Take a wot log and bake it in the oven @350f for 35 mins. Let cool off and cover in chocolate frosting. Make sure to let it cool before frosting it or it will rip and crumble.
MECP
2012 BM
Rfinkle tune in progress
The Following 4 Users Say Thank You to 5doorsoffury For This Useful Post:
Db09ms3 (04-12-2019), InkedInspector (04-17-2019), sjdannen (04-13-2019), Thor Hammer (04-16-2019)
 Old 04-16-2019, 09:07 AM   #5
Thor Hammer's Avatar
Posts: 1,846   (View Stats)
Groans: 211
Vdyno. Look it up on the Google thingamajig while eating your AP cake recipe from 5doorsoffury.
Db09ms3 likes this.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
Db09ms3 (04-17-2019), InkedInspector (04-17-2019)
 Old 04-17-2019, 07:14 AM   #6
Fstrnyou's Avatar
Posts: 2,383   (View Stats)
More specifically, let it cool slowly at room temperature. I cheated and put it in the fridge. Now I have low compression in cylinder 4.
Db09ms3 likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-17-2019, 01:19 PM   #7
MSMS3's Avatar
Posts: 2,511   (View Stats)
Groans: 140
If there is, it would be terribly inaccurate. You can, however, as stated, datalog the correct PID parameters and run it through Virtual Dyno with a 1.01 correction factor and get a general idea.
Read the Virtual Dyno threads on what to log and how to do the log. Lots of such threads here.
2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 430 hp.
Throttle Body Spacer with 2 Meth Ports cshunter 2010 MS3 - Fuel, Nitrous & Water Injection 145 08-05-2015 06:23 AM
Honda slowing US production due to ports dispute Haltech Automotive News 0 02-19-2015 07:50 AM
NJSPEED3 ports my manifold-review atvfreek Gen2 MS3 General Discussion 11 04-07-2013 09:08 PM
SYNC FTW: Ford adding mobile internet compatibility to USB ports Haltech Automotive News 0 12-21-2009 11:10 AM
Toshiba Launches New L350 Notebook With Innovative USB Ports Haltech Computers & Technology News 0 04-01-2008 12:10 PM
Page generated in 0.28374 seconds with 26 queries
