> MazdaSpeed 3/6 - Dyno Sheets/Discussions
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
 Old 02-21-2019, 11:47 AM   #1
Coltzxli's Avatar
Posts: 45   (View Stats)
Coltzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to behold
Default Before and After Boost Controller (1 revision PD Tune)
Attached is the PDF. Much better numbers.
Mods: Intake, Exhaust, DP, BCS, HPFP, AP v3 tuned by PD
Coltzxli is offline   Reply With Quote
 Old 02-21-2019, 12:10 PM   #2
Loophole35's Avatar
Posts: 44   (View Stats)
Loophole35 is a jewel in the roughLoophole35 is a jewel in the roughLoophole35 is a jewel in the rough
Looks like wheel spin or clutch slip to me.
Third gear likely wheel spin.
Try a 4th gear pull. The data to Will will be better.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
 Old 02-21-2019, 12:21 PM   #3
Coltzxli's Avatar
Dead on, the road was slick with some rain. I let him know it was spinning and told him I could redo the pull if I needed to
 Old 02-21-2019, 07:25 PM   #4
MSMS3's Avatar
Posts: 2,372   (View Stats)
Groans: 134
If that torque was real and truly under load, there would have been a likely bent rod. That is slip. I would want to see the actual data log.
 Old 02-22-2019, 08:02 AM   #5
Fstrnyou's Avatar
Posts: 2,228   (View Stats)
vDyno rules: dry, flat, AND smooth road with little to no wind.
If datalogging for a tune updates, the road only needs to be dry and smooth.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 02-22-2019, 09:10 AM   #6
Coltzxli's Avatar
Thank god that was artificial then, lol
Noted, thanks for the tip, Will try and replicate today since it is dry
Last edited by Coltzxli; 02-22-2019 at 09:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-22-2019, 10:40 AM   #7
Coltzxli's Avatar
Ahhhh, these numbers look better and realistic on a dry road!
Snow maf/boost controller boost Line question speed3gen1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 10-29-2012 06:29 PM
What boost controller? Fagwagon MazdaSpeed 3/6 - Big Turbo Builds 19 12-10-2010 06:54 PM
Page generated in 0.28870 seconds with 24 queries
