> MazdaSpeed 3/6 - Dyno Sheets/Discussions
Notices
MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information.
Like Tree33Likes
 Old 10-12-2012, 09:20 AM   #1
dturboman's Avatar
Posts: 1,049   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
Default GTX35 build 39psi
39psi - keep hitting fuel pressure cut @ around 6200-6400, had one clean run that got us 620's and about the same in TQ, Still has maybe 20-30whp left on the table with a clean pull.
*No Nitrous* yet. All numbers are uncorrected. dyno is at 550ASL - not that it matters much
DAM you FP cut
maybe 650whp 625tq tomorrow at the dyno day on a clean run. - lets hope, might throw the Vstack on it on place of the giant filter and see what it does
Fuel pressure cut right as it was climbing to peak
dturboman is offline   Reply With Quote
The Following 86 Users Say Thank You to dturboman For This Useful Post:
2k4_8 (10-12-2012), 801MS3 (10-12-2012), Alejo_NIN (11-08-2012), Alpha (10-12-2012), atvfreek (10-12-2012), AZSPEED3 (10-12-2012), BigjohnB20 (10-12-2012), Black Metal (10-12-2012), BlueStreak (10-14-2012), bostongeorge (10-12-2012), CJM (10-12-2012), crazyp (10-13-2012), CWP_MS3 (10-12-2012), daafisch (10-13-2012), DiGi Faggot (10-30-2012), DingoDave (10-12-2012), djuosnteisn (10-12-2012), Domino81 (10-14-2012), Downmented (10-15-2012), Dralphy (10-12-2012), Dumyz (11-30-2012), Easter Bunny (10-12-2012), EdgeAutosport.com (10-12-2012), Eric28243 (11-06-2012), Etipp98 (10-12-2012), exentix (10-14-2012), faeker (10-12-2012), Fobio (10-12-2012), h0ckeyman (10-13-2012), Hamilton69 (10-14-2012), helmetface (10-12-2012), IshiKage (10-14-2012), J'sSpeed3 (10-12-2012), J-Liss (11-06-2012), JacksonMS30 (10-12-2012), jeopardy98 (11-11-2012), jman46 (10-12-2012), johnredding (11-27-2012), jracer (10-13-2012), JTMS3 (10-12-2012), Juyoung (11-10-2012), JWSpeedWorkz (10-12-2012), kylec_2003 (11-29-2012), Lex (10-12-2012), lilred (10-12-2012), Mase (10-12-2012), mason (11-15-2012), Mast (11-06-2012), maxspeed3 (11-06-2012), MazdaGaragePat (11-09-2012), mazdaspeedemon3 (11-03-2012), Mchart (10-30-2012), Menace1 (11-20-2012), Micha (10-12-2012), Monotonous ONE (10-13-2012), MonstaSpeed6 (10-14-2012), MS3-a(sore)ASS-rex (10-12-2012), Ms3_Miami (11-27-2012), MSFer87 (10-12-2012), mtnrunner (10-15-2012), nighthawk358 (10-14-2012), nybe0010 (11-13-2012), PapaSmurf (10-12-2012), Payne Racing 67 (11-11-2012), psychophyr (10-13-2012), RayRay (10-13-2012), rghispanic88 (10-13-2012), rigor (10-12-2012), Roddiy (10-12-2012), SarcasticOne (10-13-2012), silvapain (10-12-2012), smoogs12 (10-12-2012), Snap Off (10-15-2012), Snyeed (10-12-2012), Speed13 (11-07-2012), speed23 (10-12-2012), Speed3eak (10-12-2012), Speed_j23 (10-15-2012), StayBroke (10-13-2012), tddvrrn (10-13-2012), tooslow10 (11-06-2012), TWOptSL0W (10-12-2012), Vader (10-12-2012), Vinnie (11-28-2012), xdm88 (10-17-2012), xI Leveler Ix (10-12-2012)
 Old 10-12-2012, 09:23 AM   #2
2k4_8's Avatar
Posts: 533   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 53
Groaned at 18 Times in 6 Posts
Nice man! Almost 40 psi, get some!
COBB AP, JBR RMM, CS SRI/TIP, AT HPFP INTERNALS, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is online now   Reply With Quote
 Old 10-12-2012, 09:33 AM   #3
lokiaparandi's Avatar
Posts: 1   (View Stats)
lokiaparandi has a little shameless behaviour in the past
39 psi or 29 psi?
lokiaparandi is offline   Reply With Quote
The Following User Says NO Thank You to lokiaparandi For This Un-useful Post:
 Old 10-12-2012, 09:54 AM   #4
drummermike58's Avatar
Posts: 358   (View Stats)
drummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the worlddrummermike58 is the leader of the world
would like to see RPM on the graph if you have it, impressive.
Originally Posted by lokiaparandi View Post
39 psi or 29 psi?
I bet he has MBC and stock MAP sensor which is why you see a huge climb in boost then flatline... 39psi would make 600+ hp, 29 psi not likely.
--2010 BM MS3--
Treadstone tr8 fmic core, custom piping, self made 3.5" MAF, gtx3076 .82 a/r ts/vband hotside, RaceRoots EWG exh mani/3" vband DP, TIAL MVR EWG, UR Catback, Sure shortcut, Sure R3 rmm, Eagle Rods, Custom 10.5:1 .020 over pistons, balanced rotating assy., ARP head and main studs, Autotech internals, Accessport, 3bar map sensor, vtcs delete, EGR delete, Balance shaft delete, Hallman MBC, HKS SSQV 4 BOV, NGK iridium spark plugs, D2 coilovers, Nextmod lip kit, painted Enkei Aegis 19x8.5 et +35, 245/40/19 potenza tires, chinese HIDs, JB shift knob, 35% tinted, still tuning...
Last edited by drummermike58; 10-12-2012 at 09:54 AM. Reason: MSF Database - Automerged Doublepost
drummermike58 is offline   Reply With Quote
The Following 2 Users Say Thank You to drummermike58 For This Useful Post:
Juyoung (11-10-2012), smoogs12 (10-12-2012)
 Old 10-12-2012, 09:55 AM   #5
smoogs12's Avatar
Posts: 3,274   (View Stats)
Groans: 153
Believe its the x axis in the graph.
Makes sense to me and im not sure what else it could be.
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
smoogs12 is online now   Reply With Quote
 Old 10-12-2012, 09:59 AM   #6
bostongeorge's Avatar
Posts: 55   (View Stats)
bostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond repute
Totally impressive!!
"In the end, there can be only one"
COBB AP STAGE 2 // COBB TBE // COBB TIH // AUTOTECH INTERNALS // KSPORT KONTROL PRO COILOVERS // JBR RSB // JBR RMM // DENSO IRIDIUM ITV22//MAISONVI SS SHIFT KNOB
2008 Black Mica MS3
bostongeorge is online now   Reply With Quote
 Old 10-12-2012, 10:22 AM   #7
Posts: 10,142   (View Stats)
Groans: 98
thats the dyno's MAP sensor.
its prob a 3bar sensor since it caps at 29psi
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
 Old 10-12-2012, 10:24 AM   #8
JacksonMS30's Avatar
Posts: 2,208   (View Stats)
JacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the world
Awesome numbers!! What are you using for fuel?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M. Fifth/Sixth Port Injection -
- P.E.R.M.Tuning -
JacksonMS30 is offline   Reply With Quote
The Following User Says Thank You to JacksonMS30 For This Useful Post:
drummermike58 (10-12-2012)
 Old 10-12-2012, 10:25 AM   #9
Sweetsandman's Avatar
Posts: 378   (View Stats)
Sweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the world
Sweet mother!! That. Is. Awesome!!
I Tapped that
'08 Cobalt SS - 334whp- SOLD
'09 WRX - Stage 1 - SOLD
'12 Mazdaspeed3
Sweetsandman is offline   Reply With Quote
 Old 10-12-2012, 10:25 AM   #10
Posts: 9,594   (View Stats)
What are you doing for the extra fuel and is the cut load, boost, or MAF?
Lex is online now   Reply With Quote
 Old 10-12-2012, 10:33 AM   #11
dturboman's Avatar
100% correct
Direct port meth , and its fuel pressure cut, pegging the sensor @2075, it was still climbing @6200 when she cut out on the run above
Last edited by dturboman; 10-12-2012 at 10:34 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to dturboman For This Useful Post:
Fobio (10-12-2012)
 Old 10-12-2012, 10:34 AM   #12
smoogs12's Avatar
Groans: 153
Hold on. Just wanna make sure we're talking about the same thing. I was saying that the decimal numbers on the x axis of the dyno were the rpm. Is this incorrect?
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 10-12-2012, 10:36 AM   #13
Groans: 98
Tapa
haha sorry, i was going to reference drummermike about the map sensor. it does look like the decimals' are RPM
WWW.SONICTUNING.COM
 Old 10-12-2012, 10:37 AM   #14
dturboman's Avatar
running EBC - for boost by gear tuning
yes those are representing RPM, as you can see the cut ending us about 1200 RPM early.
Last edited by dturboman; 10-12-2012 at 10:38 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-12-2012, 10:46 AM   #15
smoogs12's Avatar
Groans: 153
Hows the 60-100 time? Having trouble hooking up now?
Would be pretty crazy if you could get in to the 2.xx range.
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 10-12-2012, 10:50 AM   #16
dturboman's Avatar
lol 600lbs of Tq and hooking up in FWD = never!
and I'm not done yet, plan is to get to 700 on just boost .... then bring on the nitrous.
and of course finish all the suspension, remove everything again and install cage.
The Following 9 Users Say Thank You to dturboman For This Useful Post:
h0ckeyman (10-13-2012), helmetface (10-12-2012), Juyoung (11-10-2012), mason (11-15-2012), Ms3_Miami (11-27-2012), MSFer87 (11-29-2012), Payne Racing 67 (11-11-2012), psychophyr (10-13-2012), smoogs12 (10-12-2012)
 Old 10-12-2012, 11:03 AM   #17
smoogs12's Avatar
Groans: 153
Thats insane.
Inforvids
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 10-12-2012, 11:22 AM   #18
Jarods7920's Avatar
Posts: 1,174   (View Stats)
Whats in the motor?
2008 MazdaSpeed 3 AWD big turbo...blah blah blah
Jarods7920 is offline   Reply With Quote
 Old 10-12-2012, 11:28 AM   #19
dturboman's Avatar
Originally Posted by Jarods7920 View Post
Whats in the motor?
3 Mexicans
The Following 40 Users Say Thank You to dturboman For This Useful Post:
Abu Zib (10-12-2012), AZSPEED3 (10-12-2012), BPASPEED (10-12-2012), BrianB6 (10-15-2012), CosmicArkie (11-06-2012), crazyp (10-13-2012), CWP_MS3 (10-15-2012), DingoDave (10-12-2012), drummermike58 (10-12-2012), Easter Bunny (10-12-2012), emag remrofni (10-13-2012), exentix (10-14-2012), GunGuru727 (11-05-2012), Hamilton69 (10-14-2012), J'sSpeed3 (10-12-2012), J-Liss (11-06-2012), Jackis (10-30-2012), jman46 (10-12-2012), jracer (10-13-2012), Juyoung (11-10-2012), kylec_2003 (11-29-2012), L3THAL6 (03-11-2013), lilred (10-12-2012), mason (11-15-2012), Menace1 (11-20-2012), Micha (10-12-2012), Ms3_Miami (11-27-2012), mzr0818 (10-13-2012), N2o (11-27-2012), nighthawk358 (10-14-2012), rghispanic88 (10-13-2012), rigor (04-14-2013), Roddiy (10-12-2012), ScarMS3 (10-12-2012), smoogs12 (10-12-2012), Speed13 (11-07-2012), StayBroke (10-13-2012), tddvrrn (10-13-2012), v8killer (10-19-2012), Zabbin123 (11-11-2012)
 Old 10-12-2012, 11:44 AM   #20
801MS3's Avatar
Posts: 438   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Good shit Dan!
Keep it up.. can't wait to see video of this thing.
Fucking fuel pressure cut.. I am all too familiar with that bullshit (although on a much smaller scale) I could not get that 2150 valve to work at all on my car.. swapped it out for the 1950 and i still hit it.. im back on my stock valve..
There was a thread a while back about upgrading the fuel pressure sensor.. That might be your best option.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 10-12-2012, 05:49 PM   #21
surebOOst's Avatar
Posts: 1,345   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groans: 33
Groaned at 54 Times in 35 Posts
Time to shift that redline to the right with a nice set of cams yo. Im impressed! You guys are making shit tons of power and doing it nicely!
2006 Evolution IX RS
ER Built 2.3l // ETS Vband Hta3586r // Exedy Triple HD // AEM v1 EMS
English Racing Tuned Pump Gas 550awhp // E85 740awhp
surebOOst is offline   Reply With Quote
 Old 10-12-2012, 06:14 PM   #22
Dirty Miamian
Roddiy's Avatar
Posts: 3,018   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 156
Carajo,
throw some cams on that hoe.
may I ask: What's the point if there's no traction? not that I don't admire the work being put in, that's fucking amazing, but if you're looking at 650 w/o NOS, throwing a wet shot in there will get you easily past the 700s, at which point you'll burn rubber all day.
Just to say you can?
2010 LSM Speed3
Powered by Alcohol
// Cobb AP // Cobb SRI
// CP-E TIP
// Tein SuperStreet Coilovers
// SPC Camber Arms
// JBR Dogbone RMM
// KMD V3 FP // ATP 3" Full Catless Downpipe
// Grimspeed EBCS // Forge BPV
"What's a Mazdaspeed?"
Roddiy is online now   Reply With Quote
 Old 10-12-2012, 06:28 PM   #23
dturboman's Avatar
Originally Posted by Roddiy View Post
Carajo,
Cams - got em, but the head I pushed to headgames is not ready yet so thats for the next update.
no traction on the STREET, the strip is another story, I wont see much street time. But with slick and once I finish my tractions bars it will hook hard at the track, you cant go nailing 600+ on the street... unless your on slicks all the time.
you know?
and its not to say I can, its to run 9.7s @145+ - I'm a track guy not a dyno queen
it was making power to 7k+ but tack was breaking up so I dont have any runs showing RPM all the way to 7k+
But from my quick math it was holding 600+ to about 7500 and tq was still in the 500's
chimmike likes this.
Last edited by dturboman; 10-12-2012 at 06:37 PM. Reason: MSF Database - Automerged Doublepost
801MS3 (10-13-2012), Easter Bunny (10-13-2012), helmetface (10-12-2012), Juyoung (11-10-2012), Ms3_Miami (11-27-2012), MSFer87 (11-29-2012), psychophyr (10-13-2012), smoogs12 (10-12-2012), tddvrrn (10-13-2012)
 Old 10-12-2012, 06:30 PM   #24
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 413
Groaned at 205 Times in 121 Posts
Time for a bigger turbo? Lol.
Highly respectable numbers man. Time to go smoke some evos!
Sent from my iPhone your mom's face
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is online now   Reply With Quote
 Old 10-12-2012, 06:33 PM   #25
dturboman's Avatar
time for less exhaust restriction, maybe 1.06 hotside and better exhaust manifold.
all I want is 700 on turbo, then slap some juice on it.
you know nothing crazy
The Following 13 Users Say Thank You to dturboman For This Useful Post:
801MS3 (10-13-2012), AZSPEED3 (10-13-2012), Boosten Ya(josh) (10-12-2012), Dumyz (11-30-2012), Easter Bunny (10-13-2012), J-Liss (11-06-2012), Juyoung (11-10-2012), lilred (10-12-2012), Ms3_Miami (11-27-2012), rghispanic88 (10-13-2012), smoogs12 (10-12-2012), spnkr21 (10-15-2012), tddvrrn (10-13-2012)
 Old 10-12-2012, 06:39 PM   #26
93silvergt's Avatar
Posts: 499   (View Stats)
93silvergt has disabled reputation
Little pre cum came out when I read this.eeek!
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
The Following User Says NO Thank You to 93silvergt For This Un-useful Post:
Manny (10-17-2012)
 Old 10-12-2012, 06:59 PM   #27
MSFer87's Avatar
Posts: 1,135   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
Carajo,
Hmm..............I don't know but if I were to guess it would probably be to build the fastest Speed 3.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
The Following User Says Thank You to MSFer87 For This Useful Post:
 Old 10-12-2012, 07:00 PM   #28
SarcasticOne's Avatar
Posts: 415   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Very impressive!!!
I'm also amazed at how well that gtx35 spooled... 20psi at 3600ish rpm... doesn't loom far off a 3076....
GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP | Hyperflow TMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | SURE REM | Forge V2 BPV
SarcasticOne is online now   Reply With Quote
 Old 10-12-2012, 10:36 PM   #29
708
Erich's Avatar
Groaned at 26 Times in 22 Posts
Originally Posted by dturboman View Post
100% correct
Want my fuel pressure table?
I'm doing it wrong, just ask all the other Mazda DISIs making 700+HP
Erich is offline   Reply With Quote
The Following 5 Users Say Thank You to Erich For This Useful Post:
Easter Bunny (10-13-2012), helmetface (10-13-2012), mason (11-15-2012), psychophyr (10-13-2012), socks (10-13-2012)
 Old 10-13-2012, 02:03 AM   #30
dturboman's Avatar
Yes please... can never get enough material.
Thanks!
socks (10-13-2012)
 Old 10-13-2012, 10:21 AM   #31
708
Erich's Avatar
I also had to adjust down low. With the large MAF, Throttle Body, IM, etc. my car idles at slightly elevated calculated load, so I had to edit pressures from .25 load to .60 load to avoid idling at 700-1100 PSI. I started out just editing the pressures in the idle RPM range but in the end propagated the change across the entire RPM range in that load range as the car was having to hunt for 14.7 a little too much at low load and that seemed to help. If you aren't having similar issues just copy from .70 load and up. Not sure if it will help you, but I have never had any problems with FP cut and run a stage 2 pump and 2150 RV. My FP stays in the 2050 to 2073 range with never more than 2-3 cells of 2073 in a row (except after lifting.)
Good luck today. Give me a reason to do more work on my car.
Code:
430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3	430.3
579.0	579.0	618.7	727.7	727.7	727.7	727.7	797.1	797.1	797.1	797.1	797.1	797.1	797.1	797.1
797.1	797.1	846.7	935.9	975.6	1015.3	1054.9	1124.3	1154.1	1193.7	1233.4	1273.0	1273.0	1283.0	1273.0
1015.3	1015.3	1074.8	1144.2	1223.5	1292.9	1372.2	1441.6	1511.0	1590.3	1659.7	1739.0	1749.0	1758.9	1749.0
1015.3	1015.3	1074.8	1154.1	1223.5	1302.8	1372.2	1451.5	1530.8	1600.2	1679.5	1749.0	1758.9	1768.8	1749.0
1015.3	1015.3	1104.5	1213.6	1322.6	1392.0	1451.5	1520.9	1590.3	1649.8	1719.2	1778.7	1778.7	1768.8	1749.0
1015.3	1015.3	1124.3	1273.0	1411.9	1471.3	1530.8	1590.3	1649.8	1699.4	1758.9	1808.4	1798.5	1778.7	1749.0
1015.3	1015.3	1154.1	1332.5	1511.0	1560.6	1610.1	1659.7	1709.3	1749.0	1798.5	1838.2	1838.2	1818.4	1788.6
1015.3	1015.3	1203.6	1451.5	1709.3	1739.0	1768.8	1798.5	1818.4	1848.1	1877.8	1907.6	1907.6	1897.7	1858.0
1015.3	1015.3	1253.2	1570.5	1897.7	1907.6	1927.4	1937.3	1937.3	1947.2	1957.2	1967.1	1937.3	1897.7	1858.0
1015.3	1015.3	1253.2	1570.5	1897.7	1907.6	1967.1	1977.0	1986.9	1996.8	2006.7	2006.7	1977.0	1937.3	1897.7
The Following 10 Users Say Thank You to Erich For This Useful Post:
AZSPEED3 (10-13-2012), Black Metal (10-13-2012), dturboman (10-13-2012), Dumyz (11-30-2012), Easter Bunny (10-13-2012), Juyoung (11-10-2012), lilred (10-13-2012), psychophyr (10-13-2012), tooslow10 (11-06-2012), uncorked11 (10-14-2012)
 Old 10-13-2012, 11:14 AM   #32
rghispanic88's Avatar
Posts: 3,006   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 256
Groaned at 69 Times in 41 Posts
fucking awesome.
thanks for the NARB (non aticipated random boner)
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following 2 Users Say Thank You to rghispanic88 For This Useful Post:
BrianB6 (10-15-2012), GunGuru727 (11-05-2012)
 Old 10-13-2012, 12:08 PM   #33
801MS3's Avatar
Groans: 30
Erich Use this as motivation to cage your car and get it on the TRACK!!! haha
 Old 10-13-2012, 02:44 PM   #34
duappleganger's Avatar
Posts: 373   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groaned at 54 Times in 17 Posts
Call the boner police because i've got a raging hard-on! Do work son!
2011 Black Mica MS3
FREEKTUNE IN PROGRESS, ATP GTX3071R IWG Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport SRI + TIP + CBE Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45
Installation TBD: , H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 10-13-2012, 03:32 PM   #35
dturboman's Avatar
No luck on dyno day, fuel pressure cut like a mofo in this cold, right as she was skyrocketing, ended in the low 600s. Ending at 6100;(
Based on the graph 650 is in it... Time to tweak it.
The Following 2 Users Say Thank You to dturboman For This Useful Post:
helmetface (10-15-2012), mason (11-15-2012)
 Old 10-14-2012, 04:06 PM   #36
Jarods7920's Avatar
Any details on your set up?
 Old 10-14-2012, 04:27 PM   #37
BobtailedSnail's Avatar
Posts: 912   (View Stats)
BobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the world
Didnt see this but anyway, OP what CR pistons are you running?
Littering and...littering and...littering and...smokin' the reefer
--Super Troopers
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.
2006 MS6 MS CAI-Corksport TIP-Forge BPV-Denso one step colder plugs
ET: 13.900@97.31 Full Street Trim
Mods added: AP S2 OTS--KMD HPFP--3" Catless TBE--SURE RMM--Dreadnaught-- Anchors--EGR delete...Custom tune coming
ET: TBA
Holset H1C/Garrett GT4088 Compound Build coming to NATOR DE
BobtailedSnail is online now   Reply With Quote
 Old 10-14-2012, 04:29 PM   #38
exentix's Avatar
Posts: 1,143   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 44
Groaned at 14 Times in 5 Posts
you were on the funny fuel yesterday right? sucks you couldnt get a clean run in, i really wanted to see your numbers (and i know Tokay444 did, he ran in like a little kid every time it started) between you and ben (the car that went after yours that threw down 375ish) we could have roasted a whole bag of marshmellows. he threw flames like that on the cruise down but not on the dyno.
exentix is online now   Reply With Quote
 Old 10-14-2012, 04:34 PM   #39
(Toe-kay)
Tokay444's Avatar
Posts: 9,542   (View Stats)
Groans: 503
I was going in for the flames. Not the run.
Love flaming.
Shop car is shop car.
SIXual Panda likes this.
Demodded.
Mwho?
Tokay444 is online now   Reply With Quote
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
09Speed3Z (11-13-2012), kritz (10-15-2012), Sines (10-16-2012), SIXual Panda (10-14-2012)
 Old 10-14-2012, 08:04 PM   #40
Miembro
nighthawk358's Avatar
Posts: 716   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
Groaned at 6 Times in 6 Posts
holy shit..nice numbers, are you tuning it yourself?
2008.5 MS3 Metro Gray
nighthawk358 is offline   Reply With Quote
BT MS6 - Go GTX30 OR GTX35 WWPearlMS6 MazdaSpeed 3/6 - Big Turbo Builds 69 06-18-2012 11:58 AM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 06:20 AM
Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup Haltech Automotive News 0 03-22-2010 09:10 PM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 05:52 PM
Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 Haltech Automotive News 0 04-01-2008 04:20 PM
Page generated in 0.64414 seconds with 45 queries
