Miata MX-5
> Miata - Wheels, Tires & Appearance
 Old 12-28-2016, 04:00 PM   #1
Ethan23's Avatar
Posts: 2   (View Stats)
Ethan23 has a little shameless behaviour in the past
Default 2007 cx7 nock
Ok folks I know about all the trouble with the cx7 with the timing chains and all well I didn't know this when I bought my wife this car a year ago.
I have a 2007 cx7 2.3 turbo with 110,000 on the way home from doctor yesterday the car just quit running with no forewarning. I am pretty mechanically inclined so I have pulled the cam cover and all spark plugs. The timing chain is fine not loose and not broke. The motor turns over but has no compression and makes a loud knock when it turns over also the motor is about 2,000 out from needing an oil change and noticed that the motor still has oil but is not touching the dip stick but the timing chain is still picking up oil.
Any help will be greatly appreciated I don't know anything about these motors
Ethan23 is offline   Reply With Quote
The Following User Says NO Thank You to Ethan23 For This Un-useful Post:
Neverlift (12-29-2016)
Page generated in 0.22292 seconds with 20 queries
