Mazdaspeed Forums Reviews/Articles
> Mazdaspeed Forums Performance Parts Reviews > Review Discussion
Review Discussion Want to comment on a review, do it here.
  • 1 Post By GroceryGtr
 Old 07-05-2018, 09:12 PM   #1
arnold600's Avatar
Posts: 31   (View Stats)
arnold600 is on a distinguished road
Exclamation Mazdaspeed 6 low boost issue
I have a 2006 mazdaspeed 6 with a corksport srt + tip, Cobb apv3, corksport hpfp, and some other mods. anyway, I only get 13 peak psi of boost and the most ive ever seen was 14.1 on the cobb. I looked all over my pre and post turbo connections and everything seems tight and secure. Ive also tried unplugging the battery and doing a re-flash of the cobb ots stage 1+sf 93 map. still not hitting over 13psi. my idle is smooth. However, my wastegate duty cycle on the cobb seems to be a bit suspect and starts to kick in around 10 ish psi. Thoughts?
arnold600 is offline   Reply With Quote
 Old 07-06-2018, 05:49 AM   #2
GroceryGtr's Avatar
Posts: 472   (View Stats)
do a boost leak test, a visual inspection doesn't do much.
Jeff23spl likes this.
arnold600 (07-06-2018)
 Old 07-06-2018, 06:24 AM   #3
Police - Grammarhead
Vansquish's Avatar
Groans: 1,827
You need a real tune. Cobb's OTS maps are pretty shitty.
 Old 07-06-2018, 07:43 AM   #4
MSMS3's Avatar
Posts: 2,324   (View Stats)
Groans: 126
You're right, but he should be seeing 15 psi or a bit more, even with that shitty map.
He does need to do a true boost leak test. He may also want to check vacuum lines on his elrctronic boost control. They get hard and get little splits almost invisible over time.
 Old 07-06-2018, 08:29 AM   #5
Jeff23spl's Avatar
Posts: 1,622   (View Stats)
IMo, you don't play with the tune before being sure the mechanic is in shape.
-Boost leak test
-Engine compression/ leak test
Then if everything is fine, you can start to play with it.
It could be a cheap intake/bad maf (or bad maf cal. in the tune) that read too much g/s and drop the boost because the target load number is reached...But if you fix it by a tune and then find and fix a leak, you will need another tune to avoid overboost.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-06-2018, 08:57 AM   #6
Jeff23spl's Avatar
Yes but usually a leak would just increase boost. WG duty create a leak thru the solenoid valve to reduce the pressure seen by the WG actuator. So any added leak, is just like more ''hydraulic wg duty''
(Drilling tiny holes in the vac lines was a cheap and easy trick in the old days to increase boost with cars without boost control...)
Wife drive 2010 CX7
 Old 07-07-2018, 11:53 AM   #7
arnold600's Avatar
FOUND THE ISSUE.
So I unplugged my boost control solenoid to diagnose where the issue was. I.E., if unplugging the solenoid still yealded low boost, I would have a turbo piping leak, but if I made boost, I would have a bad boost control solenoid. So, sure enough, a small pull generated 20lbs of boost. DEFINITELY engine destroying territory. So im going to measure the resistance of the BCS, and if its in spec im going to do some wire hunting.. Thanks for everyones suggestions and help.
 Old 07-08-2018, 08:49 AM   #8
Fstrnyou's Avatar
Posts: 2,148   (View Stats)
Unplugging (electrically) the BCS should result in spring pressure boost (about 10-12psi).
Unplugging either hose to the wastegate is an easy way to go really fast for a very short period...read ZZB.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 07-08-2018, 09:42 PM   #9
arnold600's Avatar
Definitely, It was just a quick test. I unplugged the BCS wire and only got 8psi, I also did a data log with it plugged in and i see a signal being sent and received. So i believe the wiring is good. I ordered a new BCS, so hopefully the issue gets resolved.
 Old 07-09-2018, 06:25 AM   #10
Jeff23spl's Avatar
what do you mean by login a signal being sent and received ? How did you confirmed the feedback ?
Wife drive 2010 CX7
 Old 07-09-2018, 06:50 AM   #11
Fstrnyou's Avatar
I would agree that 8psi (with unplugged wires) comfirms the electrical is good, but 8psi is too low for spring pressure. Unless that falls within manufacturing tolerances of wastegates and Mazda said "IDGAF, the ECU can figure it out."
Other rides:
History:
 Old 07-09-2018, 07:26 AM   #12
MSMS3's Avatar
Groans: 126
Spring pressure should be maxing at 10-11 psi.
I still think he has a boost leak somewhere.
OP should post that data log he did. Might prove helpful, depending on which parameters he was monitoring and how he did the log.
 Old 10-23-2018, 03:20 PM   #13
mituc's Avatar
Posts: 3,504   (View Stats)
Groans: 111
We can only tell if you post a log. It may be a boost leak, or it may be the turbo (it was the case for a local which I was tuning, he bought the car with the wrong chinese turbo replacement).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Low boost issue nicknguyenle 2010 MS3 - Troubleshoot/Diagnostics 4 02-05-2018 08:30 AM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.33405 seconds with 26 queries
