| AUS/UK MPS Turbo Induction All related turbo/intercooler questions |
![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #41 | ![]() |
| Thunder from Down Under ![]() Join Date: Jul 2008 Location: SYDNEY AUSTRALIA ex JHB,South Africa
Rep Power: 0 ![]() ![]() Thanks: 0
| Not Ranked : 0 score
cheers!! Now what is the best replacement for this pump? Brand name & model? | ||||||||
![]() | | #42 | ![]() |
![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 0 ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score I have the 16GB iPhone and ill keep this one until they get out to the market the 32GB. The good thing now is that the 16GB 1.1.4 is so easy to hack. I have millions of game and apps with Installer and Cydia. But ill change when they bring the 32GB.
__________________ Puerto Rico's Fastest Mitsubishi Mirage LS 1.8 SOHC without WillieBar To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AutoX @ Ponce: Mazdaspeed 3 100% stock 1:35.947 Mazdaspeed3: COBB Tuning Intake, HKS SSQ BPV, TurboXS Stealth Exhaust (DP+RP). | ||||||||
![]() | | #43 | ![]() |
| Rotary inside ![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score I just want the 3g and GPS.
![]() | | #44 | ![]() |
| Not Ranked : 0 score | ||||||||
![]() | | #45 | ![]() |
| Project MS307 ![]() Join Date: Apr 2008 Location: Cali
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 171
I think people tend to get overexcited with bolting this and bolting that on, that they forget a well built bottom end will give you alot more room to play, and alot less money and heartache.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 1990 Totoya Corrolla DX TRD limited edition w/ Back to the future Delorian body kit/ K&N snorkel inlet ram-air intake/ Mazdaspeed T3/T4 turbo-supercharged hybrid 5 PSI and many more mods. 11.92 @120 MPH | ||||||||
![]() | | #46 | ![]() |
![]() | | #47 | ![]() |
| Super Moderator ![]() Join Date: Mar 2008 Location: Australia
Rep Power: 91 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
Groans: 31
Groaned at 22 Times in 10 Posts
| Like pulling teeth ain't it? Anyone who knows something about this willing to step up and say, this pump upgrade is the best because: A, B, C? CPE? PTP? Lil Fella?
__________________ How to deflower virgins: At the crucial point the guy bites her on the ear. Distracts from the pain. Ever try that? Mitch: Hell no, I sock 'em in the jaw and yell, "Pop goes the weasel." To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #48 | ![]() |
| Super Moderator ![]() Join Date: Jun 2008
Rep Power: 119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Groans: 35
well here is my uneducated thoughts CPE is too expensice, and doesnt flow as well PTP slags off lilguy.. and hasnt a great deal of info Mrlilguy i can buy the bits and do it myself.. <--- bing bing winner Doc | ||||||||
![]() | | #49 | ![]() |
Cosmic you not wrong!! Thanks doc, il do some more research on this | ||||||||
![]() | | #51 | ![]() |
| Master Pokemon ![]() Join Date: Jun 2008
Rep Power: 0 ![]() Thanks: 0
^^ Yeah how did you go?
![]() | | #52 | ![]() |
Yeah it is doc. Done @ SAS 187kw atw This was over a month ago. Was happy with the result | ||||||||
![]() | | #53 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
or you can just order the parts yourself from the kmd and call it a day lol
![]() | | #56 | ![]() |
| Not Ranked : 0 score TXS front mount TXS turbo back + downpipe + high flow CAT Forge BOV TXS CAI (short ram) So thats why im interested in the Xede. Want to hit 210 thats roughly another 20kw atw. Then i will look at getting serious later on. Bottom end rebuild forge pistons & turbonetics T3/T4 @ 22psi. What ya think? reasonable | ||||||||
![]() | | #58 | ![]() |
Groans: 35
yeah id have it done all in one hit (water meth and the Xede.. im sure SAS can do it) as the Xede seems to do a pretty good job of running it Give SAS a call Doc | ||||||||
![]() | | #59 | ![]() |
il do some more research When it comes to water/meth basically a bottle with injector is set up to the CAI? Where do you get the water meth mixture to refill? Last edited by Corzza; 07-10-2008 at 02:14 AM. | ||||||||
![]() | | #60 | ![]() |
Groans: 31
Mine injects into the hot side end tank on the intercooler (top mount for now). This way all of the mixture is fully vapourised and cools the charge as it passes across the IC. Chiptorque have actually never installed w/m. They knew about the Xede function and explained it but had not actually installed before. The Xede allows 2 channel control which means that if you wanted could run two injectors to engage under differing conditions.The place that installed mine do it routinely but first time with the Xede as the controller. You make your own mixture (just use methylated spirits also known as denatured alcohol which works just as well as pure methanol). The hardest part is finding a location for the bottle as there is stuff all room under the hood. They did a great job on mine. Looks like it factory installed. 50/50 or 60/40 maximum mixture gives the best results to control detonation, increase the octane rating of your fuel, cool your air charge and clean the crap out of your engine. Promise you won't regret doing this. It is a great choice.
![]() | | #62 | ![]() |
__________________ Puerto Rico's Fastest Mitsubishi Mirage LS 1.8 SOHC without WillieBar To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. AutoX @ Ponce: Mazdaspeed 3 100% stock 1:35.947 Mazdaspeed3: COBB Tuning Intake, HKS SSQ BPV, TurboXS Stealth Exhaust (DP+RP). | |||||||||
![]() | | #63 | ![]() |
Hey cosmic thanks for the info man! Sounds well worth the effort. alextek i will take that into consideration, Thanks! | ||||||||
![]() | | #64 | ![]() |
Groans: 31
Pleasure mate. Do a bit of research on w/m and it is a fascinating area. Goes back to WW2 and the german fighter planes (the brits caught on and copied for their planes later). It made a brief appearance in Formula 1 as well but was soon banned as the cars were making ridiculous amounts of power.
![]() | | #65 | ![]() |
Groans: 35
I remember working on the old 707's (as in first Boeing passenger jetliner) and that had water injection on it jet engines to gets its arse off the ground on hot days.. It was a real kick in the pants when you flipped it on during an engine run on the ground.Think fire hose of water.. well almost Back on topic Doc | ||||||||
![]() | | #66 | ![]() |
| Thread Tools | |
| Why Different Designs In Pumps? | mrlilguy157 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 18 | 09-09-2009 02:58 PM |
| Spy Shots: Porsche 911 Turbo due for upgrades, intent on beating GT-R | Haltech | Automotive News | 0 | 06-25-2008 10:00 AM |
