| Canada Welcome our boys from the deep, cold north! |
![]() | | #1 | ![]() |
![]() Join Date: Jan 2012 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7899 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,590
Groans: 121
Do you mean replacing the frosted lens on the low-beam projectors with a fresnel lens? If so, hit up M247. They go ape shit for that stuff. Tapadatass
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
I did it. I was needing to bake the lights to clean them out and re-seal (moisture inside) so i figured what the hell. Its not bad, the cutoff is definitely better than the stock lenses. The one thing I dont like is that there is a retaining clip that you need a pair of pliers to push in place to hold the bulb there. The stock bulbs are nice and screw in easily so i'm not overly looking forward to replacing the bulbs (hopefully i wont have to for a while)
__________________ 2006 Mazdaspeed 6 GT w/ Nav - Black Cherry Mica Cobb SRI / Cobb TIP / Cobb AP / PTP FP internals /IVT 22 / Turbosmart BPV / ETS TMIC / SURE TP / Flex-Innovations grounding kit / Stage 2 TWM SS / Corksport strut tower brace / Corksport SS Brake lines / SU Rear interior brace / SU Stiff Diff / TT Top Diff Mount / Morimoto projectors / 3000k HID Fogs |
![]() | | #4 | ![]() |
Thanks for the replies guys. Yea I read a couple DIY's on the clear lenses, just wasn't too sure how difficult it would be to put everything back together (lol i've seen a couple of pics of people who screwed up, cut-off's don't look too nice), but thanks for the input! Maybe if a coup[le of people want to get the lenses too, we can all do a "clear-lenses install day" |
![]() | | #5 | ![]() |
![]() Join Date: Sep 2008 Location: Calgary, AB
Rep Power: 64 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
I switched to clear lens (evo 8 i think?) in my projectors. I did this about 4 years ago when i first got my car but with the help of a guy that was pretty good at cracking open housings. Makes a pretty huge difference and its your preference of if you want to do a washer mod for the color flicker. If you do the washer mod you have to do trial and error to find the compromise of a crisp cutoff and good color. Both projectors will be different so you might be using different number of washers. |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2011
Rep Power: 2826 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,554
Groans: 380
Groaned at 66 Times in 63 Posts
__________________ Stage 6 Electric Supercharger - 12k HIDS - X3 Performance Chip with O2 Sensor Control - Molecule Fuel Saver - Turbo Sound Tip - CageyVet Exhaust Manifold - EnginePerformanceChip.com Sponsored Shawn Shreve Custom Wheels - Racebuilt Sponsored - Sandal Tuned ![]() ![]() ![]() |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score | |
![]() | | #8 | ![]() |
You got a oven? One of my screws came off so i gotta bake one open....
![]() | | #9 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Burlington, VT
Rep Power: 2410 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,365
Groans: 188
Groaned at 102 Times in 55 Posts
probably one of my favorite mods. Its literally a night and day difference. our cars come with the osram HID bulbs, which a lot of people consider to be better than phillips. the next step up for the 5000k osram bulbs will cost almost $200. the clear lenses make it look like you upped the bulb color a little without actually changing the bulbs. you already need to remove the headlight to swap the bulbs, so why not just bake and open them up. I recommend getting this stuff to seal up the headlight after youre done. OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc
__________________ '08 White MS3 w/ ported ATP 3071r, fat tires, and other sheit. No Meth or E. hit up NJSPEED3 so he can port yo intake mani! |
![]() | | #10 | ![]() |
@ Monkey_3: Unfortunately no I don't have an oven that will fit the lights lol... 802MS3: Thanks for the input ... Ill remember that when I do the swap (whenever that may be) |
![]() | | #11 | ![]() |
![]() Join Date: Jun 2009 Location: Baltimore, MD
Rep Power: 148 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score The Retrofit Source online: headlight upgrades for all applications got my clear lenses from here...good vendor...excellent customer service. did it with an HID upgrade and the results were impressive.
__________________ Go Fast Parts: ETS 3.25" TMIC, Cobb TIP, COBB SF Intake, Racing Beat CBE, Cobb AP, Ultimate Racing Resonated TP, AT Internals Other Stuff: Denso ITV22, CS LED Kit, DDM 35w HID kit w/ TRS Lenses, Cobb shift weight, CS Urethane exhaust hangers, Bilstein sports, CP-e stage II RMM, Whiteline F/R Endlinks, Rays Forged Mazdaspeed Wheels |
![]() | | #12 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,722
Groans: 98
Groaned at 122 Times in 91 Posts
i have the TRS kit on both my 3 and my 6 and they were both an incredible difference.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
![]() | | #13 | ![]() |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 9
2 days ago I upgraded my stock HID to 6000K, which I purchased from hidcanada.com for a great price, I do not know what brand was the blub, but my cut off it's more defined after replacing the blub... and yes I was thinking about the clear lens upgrade from TRS as well, but the thing I'm worried about it's moisture getting into the headlight housing once baked open. I've done it before to my GTI and everytime when it rains I will have moisture in it, regardless how well I've sealed the housing....anyone having problems with mositure issue after baking the housing open??? I think in a few month I'm going to get a pair of Osram Cool Blue Intense D2S and call it a day....
![]() | | #14 | ![]() |
I've had no issues with moisture build up in the headlight and it's been about 5 months. Just take your time when you reheat and reseal the headlight. Use a pair of mechanics gloves so you can work with it when it is nice and hot. Also somewhere on here someone posted a link to a good sealant to use if you are worried about it. I bought a tube of clear silicone sealant but ended up not needing it. Sent from my DROID BIONIC using Tapatalk 2
| Projector Lens? | Spoofmastafly | 2010 MS3 - Car Audio & Electronics | 4 | 02-21-2011 10:29 PM |
| Mitsubishi PK20 SVGA Pocket Projector DLP Projector $399.99 Free Shipping | Haltech | Hot Deals Section | 0 | 03-26-2008 11:10 AM |
| Mitsubishi HC4900 LCD Projector 1080P $1479AR Free Shipping | Haltech | Hot Deals Section | 0 | 03-26-2008 12:24 AM |
