> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - RED
Wheels & Tires - RED Wheels & Tires on red cars.
 Old 02-22-2012, 02:39 PM   #1
dpolseno41's Avatar
Posts: 1,819   (View Stats)
dpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the world
Groaned at 41 Times in 16 Posts
Default Tire size for 18x8 48mm offset
I've looked everywhere, can never find a definitive answer. Will 245/40/18 fit without rubbing on stock suspension or do I have to run 235/40/18?
dpolseno41 is offline   Reply With Quote
 Old 02-23-2012, 09:39 AM   #2
ms3_604's Avatar
Posts: 24   (View Stats)
ms3_604 will become famous soon enough
no one replied yet so I will be the first one, I've lurked through dozens of forums if your specs match the RX8 tire then apparently it won't rub then again if you add passengers it will be a different story. I've read reports it also depends on a tire, some tires are a tad wider some aren't, to be safe I'd go 235/40 difference is minimal this way you are safe than running into rubbing issues and having to roll. I was pretty set on getting 245s before myself on Tenzo Type Ms, 18x8 but since reading about new tires being chewed I wanted to be safe than sorry
ms3_604 is offline   Reply With Quote
 Old 02-23-2012, 09:55 AM   #3
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
go 235's
dturboman is offline   Reply With Quote
 Old 02-23-2012, 10:06 AM   #4
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Gen 1, you'll need to role your fenders to run 245s. Ive got +48 offset but 18x8.5 wheels and run 235s no issues. Wish I would of went 245 tho.
Spoofmastafly is offline   Reply With Quote
 Old 02-23-2012, 04:25 PM   #5
ms3_604's Avatar
Why do you regret I mentioned earlier difference is minimal you saved yourself trouble having to roll if you rubbed running 245s. What tire make are you running anyway? I suppose if I were to go 245 I wouldn't be lucky with a few passengers in the back.
 Old 02-23-2012, 04:27 PM   #6
dpolseno41's Avatar
235 it is! Means I should be able to get those continentals on closeout on tirerack, score!
 Old 02-23-2012, 05:24 PM   #7
Gen2's can run 245s without rolling. Im running Nitto INVO's.
 Old 02-23-2012, 05:25 PM   #8
Bob-o's Avatar
Posts: 1,312   (View Stats)
Bob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the world
I got the continentals on closeout, good deal!
Bob-o is offline   Reply With Quote
 Old 02-23-2012, 06:38 PM   #9
silkyms3's Avatar
Posts: 66   (View Stats)
silkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant future
Depends on brand/model. I have 235/40 on same offset and rubbed on stock height.
silkyms3 is offline   Reply With Quote
 Old 02-23-2012, 06:47 PM   #10
Regulator's Avatar
Posts: 192   (View Stats)
Regulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the worldRegulator is the leader of the world
Groaned at 9 Times in 4 Posts
I had 235/40/18 on my RX-8 (+50 offset) wheels and I never had rubbing on my rear fenders, even with passengers. My car is dropped about 2 inches.
Regulator is offline   Reply With Quote
 Old 02-23-2012, 09:34 PM   #11
ms3_604's Avatar
Rub it in!
TireRack by any chance? Conti's are rated highly on there.
Last edited by ms3_604; 02-23-2012 at 09:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-23-2012, 09:42 PM   #12
speed3sb's Avatar
Posts: 83   (View Stats)
speed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud ofspeed3sb has much to be proud of
i have OZ wheels 48 offset i run 235 40 18 never had any rubbing except on the race track under high cornering..But on the streets with passengers no rubbing and i have not roled the fenders...good Luck!
speed3sb is offline   Reply With Quote
 Old 02-23-2012, 10:07 PM   #13
Bob-o's Avatar
Hell yeah.
Conti DW's for 89 a tire
 Old 02-23-2012, 10:30 PM   #14
86AmishMs3's Avatar
Posts: 3,633   (View Stats)
Groans: 338
I run 245/40 on a 8" 48et rim in the front
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Current: N54 135i FBO
 Old 03-12-2012, 01:01 PM   #15
ms3_604's Avatar
I was just at the dealer, someone mentioned here 245/18 won't rub WTF! I can't decide now!
 Old 12-30-2012, 07:37 PM   #16
apawk's Avatar
Posts: 606   (View Stats)
Groaned at 8 Times in 4 Posts
Old thread revival...
Running 18x8s (et40) and lowered on Eibach PK. I'm looking for tires. Im looking into 235/40s or 245/35s. Any suggestions or recommendations would be appreciated.
FYI: Rear fenders are not rolled yet.
PERM Tuned by Alan and DJ
 Old 01-02-2013, 11:47 AM   #17
goob_os101's Avatar
Posts: 697   (View Stats)
goob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the world
Groaned at 10 Times in 7 Posts
I ran 245/40/18s on 18x8.5 et48 on stock suspension and rolled fenders
08 MS3 RIP
05 Saabaru
goob_os101 is offline   Reply With Quote
Hyperblack Rota Torques 18X8 +48mm Haltech MazdaSpeed 3/6 - Wheels & Tires 9 09-09-2013 07:54 PM
tire size for low offset grids DwightS 2010 MS3 - Wheels & Tires 24 08-28-2011 04:46 AM
18x8.5" +48mm tragik 2010 MS3 - Wheels & Tires 14 07-14-2011 06:22 AM
Need some input on offset and tire size KeysMS3 MazdaSpeed 3/6 - Wheels & Tires 3 07-02-2010 01:32 PM
Page generated in 0.35308 seconds with 30 queries
