> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - BLACK
Wheels & Tires - BLACK Wheels & Tires on black cars.
 Old 04-29-2015, 03:42 PM   #1
tiny's Avatar
Posts: 7   (View Stats)
tiny is infamous around these partstiny is infamous around these partstiny is infamous around these partstiny is infamous around these partstiny is infamous around these partstiny is infamous around these parts
Groaned at 7 Times in 2 Posts
Default 235/55r18 tires on 1gen speed 3
Hey I really need some help will 235/55r18 tires fit on my 1gen speed 3. I had 235/40r18 those were fine
tiny is offline   Reply With Quote
 Old 04-29-2015, 04:15 PM   #2
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
I think you might be pushing it there.
Mattyhawk1 is offline   Reply With Quote
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
Nliiitend1 (04-30-2015)
 Old 04-29-2015, 04:22 PM   #3
tegxsi's Avatar
Posts: 1,255   (View Stats)
Groans: 87
I would probably do 225/45R18 on a gen1 wheel... I have a pu so what do I know? lol
2018 Audi RS3
2007 Acura TSX 6MT
 Old 04-29-2015, 04:25 PM   #4
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
235/55/18s are nearly 3" taller than 235/40/18s. They will also throw off your speedo by around 11% relative to 235/40/18s.
 Old 04-29-2015, 05:39 PM   #5
tiny's Avatar
Thanks everyone for your help I accidentally bought the the 235 55 r18 so now I'm screwed madias said they won't fit. Haha anyone wants to buy some tires
But they also said the 235/40/r18 won't fit ethier wich ofcourse were good so I don't know if I shuld just have them go ahead and mount them
Last edited by tiny; 04-29-2015 at 05:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-29-2015, 05:51 PM   #6
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
235/40/18 shouldn't be put on a 7" wide wheel.
So that's why they're saying those don't fit.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 04-29-2015, 06:16 PM   #7
MSMS3's Avatar
Posts: 2,755   (View Stats)
Groans: 155
Just get higher performance tires with stickier tread compound in the stock size. Wider is not necessarily going to give you more traction, but will give you more unspring weight, which is not good. Spend a little more per tire and move up to good summer UHP, Max or Extreme grade.
225/55r18's on an ms6? ADHDAdditiv MazdaSpeed 3/6 - Wheels & Tires 11 11-19-2014 06:38 PM
Perrin Dual Gauge Pod for 1Gen MS3? v8killer MazdaSpeed 3/6 - Car Audio & Electronics 1 08-30-2012 09:14 AM
Powder Coated 1gen wheels? vargon09 Wheels & Tires - BLACK 7 05-18-2011 11:54 PM
Page generated in 0.27096 seconds with 25 queries
