> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - BLACK
Wheels & Tires - BLACK Wheels & Tires on black cars.
 Old 04-17-2015, 08:50 PM   #1
Atomic41's Avatar
Posts: 1,170   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
Default Avoid rubbing - RX-8 + eibach 10mm spacer
I already rolled my rear fender, I got JBR rear camber arm
my camber up front = -1.1 degree
and my rear camber = -1.7 degree
I'm on H&R Coilover not slammed but more for a flush stanced (you can see picture in my car thread : Atomic - MazdaSpeed 3 2008 - The Black Beast). I have 235/40/r18 tire and With a offset of 42 at the final. Must i add more camber in the rear , must i increase the height of my suspension in the rear ...
I just want to know how I can avoid any rubbing. This time I just got rubbing on big valley on high speed everytime else I got no rubbing ...
Thanks for your help
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline   Reply With Quote
 Old 04-17-2015, 09:23 PM   #2
Z32_MS3's Avatar
Posts: 590   (View Stats)
Z32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the worldZ32_MS3 is the leader of the world
I found that grinding the inner rear bumper tab took care of all my rubbing when I was slammed on BCs.
Z32_MS3 is offline   Reply With Quote
 Old 04-18-2015, 05:28 AM   #3
Atomic41's Avatar
and your rear bumper stay in place ???
 Old 04-18-2015, 06:07 AM   #4
Z32_MS3's Avatar
Ohh yeah. Just grind all the way to the fastener not past it.
 Old 04-18-2015, 06:27 AM   #5
Atomic41's Avatar
Do you have a picture for me please ... To make the good move without Any mistake
Envoyé de mon HTC One X
 Old 05-19-2015, 04:09 PM   #6
Atomic41's Avatar
After removing this tab and all redone the paint on my rear fender ... two days ago I take a bump on highway and I heard a little rub in the rear so yesterday I remove my rear Wheel and check ... and I see my paint in my rear fender paint has been remove a little the top section of my fender both side. So I remove my rear 10 mm spacer right now ... clean up these section and apply mazda paint pen. But I really want to drive my setup with 42 offset in the rear....
How I can procress to avoid this rub in the rear. When I redone the paint in the rear fender I fill the space between the fender and the body with a paint sealer to avoid anything enter there and create rust so I can't increase mu Rolling fender ... I speak with a body shop to cut the section where there is rubbing but he told me that will remove the solidity of my rear fender !?!?!? is it true ... just remove 5 to 6 inch of fender (just the section in the fender that be Rolling)
If somebody can help me with a better solution it will be very helpful
Thank guys
 Old 05-19-2015, 05:34 PM   #7
Atomic41's Avatar
I'm right now at -1.7 rear camber if I go -2.2 to be at the limit of the oem spec can I maybe avoid this rubbing in the rear ... is it a good difference and my wheel will maybe don't touch my rear fender like this ... I got JBR rear camber arm so I can go +/- 4 degree in camber.
 Old 05-21-2015, 01:35 PM   #8
Atomic41's Avatar
anybody ???
 Old 05-21-2015, 01:49 PM   #9
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
We can't tell you the exact degree of camber you need to clear, just bump it up a little and see if it still rubs, every car and setup is different.
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 05-21-2015, 01:52 PM   #10
kicksonfiyah92's Avatar
Posts: 83   (View Stats)
kicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to beholdkicksonfiyah92 is a splendid one to behold
Groaned at 6 Times in 3 Posts
Maybe get your fenders pulled if you don't want more negative camber.
Cobb AP, SRI, Short Shift Plate, CS Springs, JBR 80 RMM, JBR SSB, DDM tuning 5k HIDs
kicksonfiyah92 is offline   Reply With Quote
 Old 05-21-2015, 01:56 PM   #11
Atomic41's Avatar
Do you know how to do it without damage my new paint fender ?
 Old 05-21-2015, 03:02 PM   #12
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
First off, if you're using 10mm spacers on RX-8 wheels, your effective offset is +40, not +42.
That said, the best way to solve the problem is to ditch the spacers.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Mauro_Penguin (05-21-2015)
 Old 05-21-2015, 03:47 PM   #13
Atomic41's Avatar
I know its the easy way but nobody can help With their camber number on their own setup. I know i can solve this problem but i just dont want to take the easy way
 Old 05-21-2015, 03:54 PM   #14
Spec's Avatar
Posts: 4,472   (View Stats)
Where are you from, atomic?
 Old 05-21-2015, 04:03 PM   #15
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
Ive been running the same setup minus the spacers for years with zero rubbing. Ditch the spacers or go to a 5mm. Id give you my specs but cars still winterized.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 05-21-2015, 04:09 PM   #16
Atomic41's Avatar
Yeah I know with no spacer no rubbing ... I just want to try to fit everything and no rubbing
 Old 05-21-2015, 04:23 PM   #17
Spec's Avatar
Then add Camber or pull your fenders, I don't see what is so hard about this?
 Old 05-21-2015, 04:25 PM   #18
Atomic41's Avatar
 Old 05-21-2015, 04:28 PM   #19
Spec's Avatar
Fender roller, heat gun.
Pay a shop to do it?
 Old 05-21-2015, 04:35 PM   #20
Atomic41's Avatar
If I have sealer in my rear fender can they pull it easily ? or the sealer will crack ?
 Old 05-21-2015, 04:41 PM   #21
Spec's Avatar
I have no clue what you're talking about.
Where are you from?
 Old 05-21-2015, 04:41 PM   #22
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
There is no definite answer to this until you do it...it might crack. If you dont want to remove the spacers this is the only other thing to do.
nilashish is offline   Reply With Quote
 Old 05-21-2015, 05:20 PM   #23
Nliiitend1's Avatar
Groans: 67
I think you may have misread my post.
I said best. Not easiest.
2008 MS3 GT
2016 MX-5 Club
 Old 05-21-2015, 05:25 PM   #24
Atomic41's Avatar
Why best can you explain ...
Last edited by Atomic41; 05-21-2015 at 05:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-21-2015, 07:40 PM   #25
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,805   (View Stats)
Holly shit brah you must hais teh retards.
Roll the fucking fernders or ditch the spacers.
No other way around. Not even Jesus can give you another option.
Oh wait, you could also run 215 width tires. That might solve it. If you don't change tires than refer back to the sentence subsequent to the retards reference.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
Mauro_Penguin (05-21-2015), Micha (06-23-2015), naoandlater (05-22-2015), nilashish (05-21-2015), Nliiitend1 (05-22-2015), WetzMS3 (05-22-2015)
 Old 05-21-2015, 09:57 PM   #26
Spec's Avatar
I was getting to the point of saying the same thing. You must have some big balls......... Oh wait... My bad, are they still a sore subject? Tee hee hee hee!
The Following User Says Thank You to Spec For This Useful Post:
Tomas (05-23-2015)
 Old 05-21-2015, 10:55 PM   #27
kevin2.3's Avatar
Posts: 50   (View Stats)
kevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond reputekevin2.3 has a reputation beyond repute
Where are you from?
Pretty sure he is a Quebecer
kevin2.3 is offline   Reply With Quote
 Old 05-22-2015, 07:51 AM   #28
Nliiitend1's Avatar
Groans: 67
OK. I'll indulge.
The spacers aren't giving you any handling advantage or added functiionality.
They are not needed to clear your brakes or your suspension.
It could even be argued that they are a detriment to your car's overall handling profile.
Why do you want to keep them?
2008 MS3 GT
2016 MX-5 Club
Tomas (05-23-2015)
 Old 05-22-2015, 07:59 AM   #29
Atomic41's Avatar
 Old 05-22-2015, 08:01 AM   #30
Nliiitend1's Avatar
Groans: 67
Lol
2008 MS3 GT
2016 MX-5 Club
 Old 05-22-2015, 08:34 AM   #31
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
So that means in a couple of months this will be slammed to the ground, with the rear wheels at a 45* angle.
The Following User Says Thank You to g00s3y For This Useful Post:
Tomas (05-23-2015)
 Old 05-22-2015, 08:37 AM   #32
Atomic41's Avatar
Lol
 Old 05-22-2015, 09:04 AM   #33
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Lol
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 05-23-2015, 02:07 PM   #34
Bob Ross Fanclub
Tomas's Avatar
They actually recovered rather quickly thank you very much. In less than two days they were back to normal.
Well I object to that assertion.
Absent detrimental consequences due to changes in offset such as bumpsteer, a wider track will get you faster through the turns.
Not that the OP is really using the spacers for that purpose.
Nliiitend1 (05-24-2015)
 Old 05-24-2015, 10:10 AM   #35
Nliiitend1's Avatar
Groans: 67
...but it wouldn't be "absent detrimental consequences" at all. You can't really widen the track with spacers without introducing the negatives (scrub radius changes, wheel rate changes, etc.).
2008 MS3 GT
2016 MX-5 Club
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
Tomas (05-24-2015), WetzMS3 (05-27-2015)
Eibach pro spacer 10mm Atomic41 Mazdaspeed3/6 General Discussion 14 01-17-2017 02:06 PM
Eibach 10mm spacer kit impression /info Mazdaspeed3KHP 2010 MS3 - Wheels & Tires 2 07-30-2013 12:34 AM
Genpus + 10mm eibach spacers + ARP studs dale_gribble MazdaSpeed 3/6 - Wheels & Tires 1 02-01-2013 03:38 PM
10mm spacer + 5mm spacer Atomic41 Wheels & Tires - BLACK 3 12-05-2012 11:47 AM
Page generated in 0.51320 seconds with 31 queries
