> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - BLACK
Wheels & Tires - BLACK Wheels & Tires on black cars.
 Old 03-22-2013, 02:06 PM   #1
Atomic41's Avatar
Posts: 1,167   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
Default New tires on RX-8 wheel
Hi !
I only have 4/32 on my current Bridgestone RE760 Sport 225/40/R18... must I change it during this summer ??? I will drive maybe 8000-10000km more before next winter.
With my currently setup ... RX-8 wheel + eibach pro kit + eibach pro spacer 10mm can I put 235/40/R18 easily without any rubbing ?
I want the much larger setup possible without any rubbing
thanks for your help
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline   Reply With Quote
 Old 03-22-2013, 04:54 PM   #2
Atomic41's Avatar
 Old 03-22-2013, 05:19 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Don't know much about Speed3s but one thing I can tell you is the tire makes all of the difference in the world. Some tires are known for having rounder sidewalls and some tires have very square sidewalls. I ran 235/40R18 Continental DWS on 8.5 wheels with +37mm offset without issue. Then, I tried to run a 235/40R18 Toyo Proxes Plus 4 on 8" wheel with +38mm offset and it rubbed like crazy even with a full roll.
Here, let me do your homework for you:
OFFICIAL AGGRESSIVE OFFSET THREAD
MINI H1 6.0 - CAR LED TAILS
 Old 03-22-2013, 06:06 PM   #4
Atomic41's Avatar
First of all ... must I need to change my tire if I only got 4/32 ?
Secondly, I already see this thread ... but nobody have the exactly the same setup of me so it's why I'm asking if somebody here the same setup ...
 Old 03-22-2013, 07:22 PM   #5
True, but I bet there are some with more aggressive fitments on there. If they fit, you know you are gtg.
 Old 03-23-2013, 07:25 AM   #6
Atomic41's Avatar
 Old 03-23-2013, 04:13 PM   #7
Atomic41's Avatar
... Must I change it ???
And with my setup ... must I go with 235/40/R18 ??? or keeping again 225/40/R18 ?
Feedback please
 Old 03-23-2013, 06:20 PM   #8
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the world
225/40. and i would say replace it now, before you regret it later. you have about 1k miles left, but thats not including how you drive as well though
rolanblack is offline   Reply With Quote
 Old 03-23-2013, 06:40 PM   #9
mazdaspeeding's Avatar
Posts: 260   (View Stats)
mazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the worldmazdaspeeding is the leader of the world
Groaned at 8 Times in 4 Posts
I'm lowered running 235/40's on RX-8's and I don't rub, not even close.
mazdaspeeding is offline   Reply With Quote
 Old 03-23-2013, 07:54 PM   #10
Poet-Tek's Avatar
Posts: 82   (View Stats)
Poet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond reputePoet-Tek has a reputation beyond repute
2/32nd (or 1/16) is generally considered the end of tire tread life. At 4/32 you still have some time. Most tires have wear bars molded into the tread. When the tread is even with the wear bar, it is time to get new tires.
Tire Tech Information - Tire Specs Explained: Tread Depth
Poet-Tek is offline   Reply With Quote
 Old 03-23-2013, 08:02 PM   #11
Tenchix's Avatar
Posts: 450   (View Stats)
Tenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the world
Shit a tire is still good till the wire shows and sparking!! Those where the good old days..
Tenchix is offline   Reply With Quote
 Old 03-24-2013, 05:01 AM   #12
Atomic41's Avatar
Thanks man !!! I will go with 235/40/R18 ... you like your ride with this tire size ?
 Old 03-24-2013, 05:07 AM   #13
PUGENE's Avatar
Posts: 1,902   (View Stats)
Groans: 61
I just got a set of Fuzion ZRi on tire rack for $92 a tire in 245/40r18 for my RX-8s. They'll be on the car today with corksport springs if you would like a pic
tappy, tap tap taparoo.
Precision: PTE 5858
Tial: 44mm EWG
CPE: Stage 2 RMM//Manifold
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
POWERED BY PURPLE DRANK
PUGENE is offline   Reply With Quote
 Old 03-24-2013, 05:51 AM   #14
Atomic41's Avatar
Yes sir please ... picture and will you have any rubbing with this setup ...
 Old 03-24-2013, 06:17 AM   #15
PUGENE's Avatar
Groans: 61
As far as I can tell, no and from the research I've done, no. If it does, then I shall be rolling my fenders.
Precision: PTE 5858
Tial: 44mm EWG
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
 Old 03-24-2013, 07:22 AM   #16
Atomic41's Avatar
Keep me update with your pictures after your installation ...
 Old 03-24-2013, 09:59 AM   #17
sassyspeed3's Avatar
Posts: 1,054   (View Stats)
sassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the world
I just bought 235/40s for my rx8's. I'm stock height but there is still a good inch to inch and a half to go before rubbing.
My opinion is you'll be fine.
sent from my cleavage via tapatalk
2013 Mitsubishi Lancer Evolution GSR
2008 Red MS3
BT & All
Eth Mix - 460hp/429tq
Pump - 411hp/403tq
**SOLD**
[02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for
[09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough
sassyspeed3 is offline   Reply With Quote
 Old 03-24-2013, 03:31 PM   #18
Atomic41's Avatar
Yes but the only thing it's different between us is my eibach 10 mm spacer ... can I rub with this and my rx-8 + 235/40/R18 ?
 Old 03-24-2013, 04:09 PM   #19
PUGENE's Avatar
Groans: 61
Just realized ur a Juan and I'm a pu, springs wheels and tires are all on, no rubbing and they look damn good... Hope u get it sorted out.
Precision: PTE 5858
Tial: 44mm EWG
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
 Old 03-24-2013, 04:12 PM   #20
Atomic41's Avatar
So you drive it and no rubbing issue ???
 Old 03-24-2013, 04:14 PM   #21
PUGENE's Avatar
Groans: 61
Yes but I'm in a pu and we have more room for wheels/tires.
Precision: PTE 5858
Tial: 44mm EWG
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
 Old 03-24-2013, 04:21 PM   #22
Atomic41's Avatar
shit ... ok
Thanks
 Old 03-30-2016, 07:28 AM   #23
Atomic41's Avatar
Will I have more benefit if I go with 245/35/R18 versus 235/40/R18 on my RX8 wheel.
More traction, more corner fun ... I think I gonna go with Michelin Pilot Super Sport
 Old 03-30-2016, 08:36 AM   #24
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
If its a decent price difference in tires, I wouldn't think it would be a significant enough difference in ride to justify the price.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 03-30-2016, 08:41 AM   #25
Atomic41's Avatar
31$ by tire
I'm a stage 2 - 94 octane - Stratified during summer
I just want tires that can keep with the torque ... so I know Michelin Pilot Super Sport will help versus my old Bridgestone RE760 Sport but I want to know if it's money well spending to go larger like 235/40/R18 or maybe 245/35/R18 versus 225/40/R18 or no really a gain versus the stock form for my wheel 225/40/R18 ...
Last edited by Atomic41; 03-30-2016 at 08:41 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-30-2016, 09:30 AM   #26
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I certainly do not think they are worth an extra 125 dollars. I don't know how sticky the Michelins are, but the Continentals DWs (not DWS) grab really well for me on E85. And I'm making way more power and torque than any OTS map. You want a tire with a soft sidewall. The michelins are probably decently soft, but I would definitely not get a tire like the Bridgestone, or Dunlop, or Hankook.
Lots of guys have the DWs and they hook pretty fucking well for being an 18 inch street tire. Very soft sidewall, but still handle pretty well. Best all around tire IMO.
Rich Tuned
330WHP and 363TQ
Atomic41 (03-30-2016)
 Old 03-30-2016, 05:07 PM   #27
Atomic41's Avatar
No other opinions ???
 Old 04-02-2016, 11:28 AM   #28
Atomic41's Avatar
so here in Canada the 235/40/R18 is BO so if I want a Michelin Pilot Super Sport ... I need to choose between 225/40/R18 or 245/35/R18 ...
Do you think I can fit the 245/35/R18 without a problem if I have 10mm spacer all around and my rear fender is already rolled and lightly push ???
Thanks for your help
My last setup was a 235/40/R18 Bridgestone RE760 SPORT ...
Last edited by Atomic41; 04-02-2016 at 11:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-03-2016, 04:44 AM   #29
Atomic41's Avatar
Nobody ? Can help
Tire and Wheel Calculator SpdFreak MazdaSpeed 3/6 - Wheels & Tires 11 01-06-2012 08:21 AM
Need help with wheel/tire sizing epoch Wheels & Tires - SILVER 2 11-16-2010 07:26 PM
New wheel / tire question Blink MazdaSpeed 3/6 - Wheels & Tires 0 09-30-2009 10:23 AM
tire and wheel Dros MazdaSpeed 3/6 - Wheels & Tires 0 04-21-2009 08:29 AM
Tire and wheel help Please RUMBLEFISH MazdaSpeed 3/6 - Wheels & Tires 6 10-10-2008 05:52 AM
Page generated in 0.45189 seconds with 29 queries
