> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - WHITE
Wheels & Tires - WHITE Wheels & Tires on white cars.
 Old 11-08-2010, 10:47 PM   #1
MSP611's Avatar
Posts: 2,291   (View Stats)
Default Will these fit 18x8 +35?
Wat tires will fit without tuck or stretch? I was thinking a 225/35? This is on stock suspension, but soon will be on some h&r springs and bilstein struts. Mayb lowered 1-1.5in. Would I need wheel spacers or adjustable endlinks?
In progress:
 Old 11-08-2010, 11:27 PM   #2
snowms3's Avatar
Posts: 287   (View Stats)
snowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond repute
shouldnt i fit these just fine. i didnt drop it yet
2009 cwp MS3. COBB SRI, COBB inlet pipe, CPE catless DP, GHL catback(drone-free), SURE RMM, JBR PMM 80d, DASHHAWK, COBB AP STRATIFIED TUNED BY LEX 3/10 E85, ATP FMIC, HKS SSQ Full recirc, AUTOTECH INTERNALS, WHITELINE 27mm Adjustable RSB, Einkei RPF1 gold/ Firestone Wide Oval Indy 500 235/45/17, GORILLA BLACK LUGNUTS.
snowms3 is offline   Reply With Quote
 Old 11-08-2010, 11:44 PM   #3
MSP611's Avatar
Dude I'm not askin if they'll fit u I'm askin if they'll fit period. By the way it's on a ms6
In progress:
 Old 11-09-2010, 05:41 AM   #4
Dark's Avatar
Posts: 130   (View Stats)
Dark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the worldDark is the leader of the world
with 18x8.5+38 and 235/40 tires I needed to roll my rear fenders completely.
(running h&r coils, koni shocks)
I think you'll have to roll the rear fenders with either 235 or 225 tires.
Ryan | 06 ZX10r | 08.5 Speed3 GT
Dark is offline   Reply With Quote
 Old 03-07-2011, 07:34 AM   #5
mx931's Avatar
Posts: 33   (View Stats)
mx931 is on a distinguished road
i want
mx931 is offline   Reply With Quote
 Old 03-07-2011, 01:41 PM   #6
MSP611's Avatar
Hmmm alright... Do u think more of an offset would help??? Like +42 or more? I'm only Gunna be run an 18x8 too.. Not sure on tire size yet either 225or235
In progress:
 Old 03-07-2011, 01:42 PM   #7
m4tic's Avatar
Posts: 4,923   (View Stats)
im on 18x8 +35 235/40 on coilovers, you need a fender roll...
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
Docnox (04-17-2011)
 Old 03-07-2011, 01:54 PM   #8
MSP611's Avatar
Alright coo. Need to pull Any fenders?
In progress:
 Old 03-07-2011, 03:15 PM   #9
m4tic's Avatar
sure if you got the money... but not necessary
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 03-10-2011, 12:01 PM   #10
soaringeagle129's Avatar
Posts: 227   (View Stats)
soaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
I just put on some 235s and I need to roll my fenders. Do you guys know the best way to do that?
soaringeagle129 is offline   Reply With Quote
 Old 03-10-2011, 12:03 PM   #11
MSP611's Avatar
U can rent a roller from SU
In progress:
 Old 03-10-2011, 04:22 PM   #12
jeb8699's Avatar
Posts: 122   (View Stats)
jeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to behold
im on 18x8+45 with 225 45 18 and i have a lil issue with the front rubbing if im on the brakes and turning had to roll the rear
jeb8699 is offline   Reply With Quote
 Old 03-10-2011, 06:00 PM   #13
m4tic's Avatar
my fronts rub a lil on hard turns, my fender/bumper plastic screws are smooth.. a good alignment will fix that, just gotta install my balljoints
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 03-11-2011, 08:02 AM   #14
swales's Avatar
Posts: 20   (View Stats)
swales is a jewel in the roughswales is a jewel in the roughswales is a jewel in the roughswales is a jewel in the rough
You stock height?
swales is offline   Reply With Quote
 Old 03-11-2011, 05:03 PM   #15
ZoomByU's Avatar
Posts: 1,236   (View Stats)
i have 18x9.5.....i had 225/35s on there...worst ride ever. my 215/40 are night n day difference in comfort....do anything to stay away from 35s
 Old 03-12-2011, 02:32 PM   #16
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
yes they will fit with 245/40's thats what im running. and it rubbed in back until i rolled the fenders a bit. im on stock height
greg08 is offline   Reply With Quote
 Old 04-06-2011, 09:25 PM   #17
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
I'm lowered on Cobb springs running 245/40/18 on 18x9s +35 offset I think. Fenders rolled front and rear works perfect. Will be autocrossing soon see how it really feels then
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
 Old 04-10-2011, 05:52 PM   #18
greg08's Avatar
How are the cpe injector ses doing for you man?
 Old 05-16-2011, 04:22 PM   #19
matto's Avatar
Posts: 34   (View Stats)
matto is a jewel in the roughmatto is a jewel in the roughmatto is a jewel in the rough
Groaned at 10 Times in 4 Posts
sorry to bring up an old thread, but what about a 17x8 +35?
matto is offline   Reply With Quote
 Old 05-19-2011, 07:47 PM   #20
MSP611's Avatar
17x8 will def fit i have tried it... mayb with a minor fender rub... so im looking into some 18x8 or 18x8.5 with 245s or 255s im thinking something with atleast +42 offset.
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
matto (06-14-2011)
 Old 06-14-2011, 01:30 PM   #21
matto's Avatar
Getting some volks tomorrow 18x8.5+35 will post some pics up once I have them on the car. I'm going to run some 3mm spacers in the rear just incase but yes getting the fenders rolled and still on stock height.
 Old 06-14-2011, 02:36 PM   #22
m4tic's Avatar
spacers in the rear? dont need those itll be tight enough without them.
2017 Daytona 392
2007 MS6 w/ Cheez
SIXual Panda (06-24-2011)
 Old 06-24-2011, 05:23 AM   #23
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
SIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the world
Groans: 56
3 mm spacers will turn your +35 offset into a +32 offset.. not the other way around.. which is pushing your luck. as bmorrisj also said, i would skip the spacers.
I envy your ass raping.
The Money Pit: 2006 Mazdaspeed6 GT (BCM)
Fully built, Ported everything, GTX3582r, Port Injection, Twin disk clutch, 2-piece Driveshaft.... still slow.
The Daily Bitch: 2003 Mazda Protege5 with infinity miles on it
SIXual Panda is offline   Reply With Quote
The Following User Says Thank You to SIXual Panda For This Useful Post:
m4tic (06-24-2011)
215/45/18 on 18x8 Dros MazdaSpeed 3/6 - Wheels & Tires 6 04-29-2009 01:22 PM
18x8.5 on 235/40/18 ms3boost MazdaSpeed 3/6 - Wheels & Tires 10 04-15-2009 07:00 AM
245/40 with 18x8 +50: will i rub? aaronc7 MazdaSpeed 3/6 - Wheels & Tires 20 03-25-2009 05:25 AM
18x8 +40 Fit? SSLow3 MazdaSpeed 3/6 - Wheels & Tires 8 03-14-2009 06:08 PM
To all those with 18x8 +45 meha11 MazdaSpeed 3/6 - Wheels & Tires 8 11-16-2008 03:48 PM
Page generated in 0.39571 seconds with 32 queries
