> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - COSMIC BLUE
Wheels & Tires - COSMIC BLUE Wheels & Tires on cosmic blue cars.
Like Tree3Likes
 Old 02-22-2012, 01:42 PM   #41
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Originally Posted by durtrid3r View Post
Alright thanks man...i appreciate the info. I dont plan on "slamming" the car but i will most likely run a little lower on the coils. I'd like to be able to get this stance without killing the handling so im going to do a little more research first.
if you set the car up correctly your handling should be superb on a good set of coilovers.
Blue Pu.
 Old 04-12-2012, 10:01 PM   #42
crtguns's Avatar
Posts: 464   (View Stats)
crtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the world
Groaned at 340 Times in 107 Posts
Originally Posted by Toymachinespeed View Post
Where can you buy these? I want some so bad...
Start by making freinds with an EVO driver. Then find him a killer deal on some Grids or the sort, and convince him he needs to change. Then he will have some extra wheels around. YOu'll free up some space in his garage!
I actually did this... his Rota Grids will be here next week.
crtguns is offline   Reply With Quote
 Old 05-06-2012, 10:28 PM   #43
crtguns's Avatar
I just put my evo9 wheels on (enkei pf-01)... could not use COs without spacers. The regular shock only misses the inside of the wheel too close to fit my finger between. My wheel guy says that's a bad idea. The CO and/or strut is in no way designed to bear a load from the side- even if it very slight from some tire wobble.
 Old 05-19-2012, 07:57 PM   #44
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
What offset?
new wheels Caldazar Wheels & Tires - RED 13 04-17-2010 12:49 PM
Page generated in 0.24933 seconds with 23 queries
