MAPerformance Ported Intake Manifold
Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > Mazda Performance Parts & Modifications Vendor Area > Modern Automotive Performance
Modern Automotive Performance Modern Automotive Performance is your source for sport compact performance! You can rely on MAPerformance to provide the best possible customer service and unbeatable prices on a huge selection of performance parts for your Mazdaspeed!
Bookmark and Share LinkBack Thread Tools Display Modes
 Old 09-15-2009, 04:13 PM   #41
maperformance's Avatar
maperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud ofmaperformance has much to be proud of
Activity Longevity
2/20 14/20
Today Posts
1/7 ssssss837
Thanks for the input everyone. Let me know if you want some more info on pricing. Also let me know if you have a core you would like to get rid of.
Thanks,
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Email:
/ AIM: burdatmap
maperformance is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
 Old 09-15-2009, 09:10 PM   #42
NEC
subparpunk03's Avatar
Posts: 1,128   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Here are some pictures of the stock IM:
There's a vacuum port on the top of the intake manifold that needs to be plugged for the VTCS delete
View through the throttle body inlet... little bit of oil in there...
Runners from passengers side to drivers side:
Cosmic Blue Mazdaspeed 3: Nator East Coast official Mad Scientist
Cobb SFI, Swaybars, DA-STS, FMIC, TRZ Poly, HKS BPV, CS Brake Lines, CP-E TBE, PG Rebuilt k04, PG CDFP Internals, KWv3, F2 BSD/Baffle, MAP Ported IM
subparpunk03 is online now
 Old 09-15-2009, 09:12 PM   #43
JumpingJackson's Avatar
Posts: 791   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
Activity Longevity
6/20 19/20
Today Posts
1/7 ssssss791
subparpunk did your manifold come with that VCTS bracket mentioned earlier?
JumpingJackson is offline
 Old 09-15-2009, 09:27 PM   #44
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Negative. No bracket.
 Old 09-15-2009, 11:47 PM   #45
Nator
lenny127's Avatar
lenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the world
Groans: 164
Groaned at 212 Times in 165 Posts
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
very informative thread kurt, thank you!!!
_____________________________________________2007 SILVER MS3______________________________________________
NATOR FMIC // NATOR SRI // NATOR INLET // NATOR COLD AIR BOX // NATOR BPV (RED SPRING, 1 SHIM) // NATOR SHIFT COUNTERWEIGHT // NATOR CATTED DP // NATOR AP (RUNNING N.A.T.R. TUNE 20PSI) // NATOR'S OWN STAGE II METHANOL INJECTION 100% METH !! // NATOR 2 STEP COLDER PLUGS // NATOR TRACTION BARS (WITH NYLON INSERTS) // NATORZ DERLIN REAR MM // NATOR SILICONE RECIRC TUBE // NATOR COOLANT HOSE KIT // NATOR-PE FRONT TOW PLATE // NATORHAWK // NATOREX-MANI V3
lenny127 is offline
 Old 09-16-2009, 08:00 AM   #46
E4Performance's Avatar
Posts: 668   (View Stats)
E4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the world
Groaned at 69 Times in 65 Posts
Activity Longevity
0/20 8/20
Today Posts
0/7 ssssss668
I have a core that I could part with. It has the port/polish done already but by someone else, so probably not as good. PM me.
E4Performance is offline
The Following User Says NO Thank You to E4Performance For This Un-useful Post:
glocK23 (09-24-2009)
 Old 09-19-2009, 02:33 PM   #47
ILL3ST
xcoldricex's Avatar
Posts: 2,157   (View Stats)
Groaned at 19 Times in 14 Posts
Activity Longevity
18/20 18/20
Today Posts
2/7 sssss2157
Send a message via AIM to xcoldricex
looks great! what coatings do you guys use? how much for just the coating service?
xcoldricex is online now
 Old 09-21-2009, 02:48 PM   #48
Bob @ MA Performance's Avatar
Posts: 2   (View Stats)
Bob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of lightBob @ MA Performance is a glorious beacon of light
Activity Longevity
0/20 8/20
Today Posts
0/7 ssssssss2
Thanks for the compliments!
We use a thermal dispersant on the exterior (black only) that helps pull heat out of the manifold, and a second thermal blocking coating that goes on the flange. This coating acts similar to a phenoelic and milimizes heat transfer from the head itself. Good stuff for sure.
Typically we charge $90 for the coating for most 4cyl applications, but it can be more if we are talking about another platform.
Bob Schreiber
Airflow Engineer
Porting and Advanced Ceramic Coating Specialist
IM: PortingGuru
763-545-3800
Bob @ MA Performance is offline
The Following User Says Thank You to Bob @ MA Performance For This Useful Post:
xcoldricex (09-21-2009)
 Old 09-21-2009, 03:43 PM   #49
ILL3ST
xcoldricex's Avatar
Activity Longevity
18/20 18/20
Today Posts
2/7 sssss2157
have you seen any chipping of the coating after awhile at all? i've heard the swaintech BBE coating chips off after awhile unfortunately.
 Old 09-21-2009, 03:46 PM   #50
says hi!
taf0422's Avatar
Posts: 804   (View Stats)
Groans: 31
Groaned at 7 Times in 6 Posts
Activity Longevity
5/20 13/20
Today Posts
0/7 ssssss804
Send a message via AIM to taf0422
ohh subbing! Very very nice!!
2007 Comsic Blue MS3 GT...
no mods what so ever
taf0422 is offline
 Old 09-23-2009, 02:04 PM   #51
Activity Longevity
2/20 14/20
Today Posts
1/7 ssssss837
No we have not seen any issues. But if the item being coated was not prepped well before hand which we do very well in house then yes I could see how some company's having issues with it holding up..
Email:
/ AIM: burdatmap
 Old 10-15-2009, 09:49 PM   #52
This Space For Rent
hnda etr's Avatar
Posts: 1,638   (View Stats)
Groans: 66
Groaned at 250 Times in 227 Posts
Activity Longevity
14/20 9/20
Today Posts
2/7 sssss1638
what happened to those dyno numbers?
Cobb SRI : Cobb TIP : Cobb Shifter Weight : Cobb STS : Cobb DP : Cobb F&R Sway Bars : Cobb AP : AWR F&R Endlinks : SU Shifter Bushings : SU Rear Motor Mount : SU Side Motor Mounts : SU Blackout Emblems : Spin On Oil Filter : O.Z. Racing Ultraleggera Rims : Muteki Lug Nuts : Synchronic BOV : Valentine 1 : CP-E Towplate : Denso ITV-22 : Powerslot F&R Slotted Rotors : Hawk HPS F&R Pads : Goodridge SS Brake Lines : JDM Coin Holder : E4P Heavyweight Shift Knob : Clear Side & Rear Reflectors : Nextmod CF Rear Spoiler Lip : PTP CDFP : AEM UEGO WBO2 & Boost Gauges : Mearcat Double Gauge Pod : Saikou Michi Stage 2 DC3 OCCs : Custom 3" Magnaflow CBE : PG FMIC : PTP Kicker Mount : HID Fogs : Mazdaspeed Coilovers & Camber Links : Devil's Own Meth Injection : ACT Clutch & Lightened Flywheel : HKS Twin Power : Redline Hood Struts : PG v3 Exhaust Manifold : GTSpec Everything
Saved by Nator!
hnda etr is online now
 Old 10-18-2009, 12:18 PM   #53
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Like I said in the steedspeed thread, I'm working on it.
 Old 11-04-2009, 02:12 PM   #54
QuickSpool's Avatar
Posts: 231   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
Groaned at 9 Times in 5 Posts
Activity Longevity
1/20 11/20
Today Posts
0/7 ssssss231
Is there going to be a GB on these soon?
What kind of deal would I get if I sent you 2 unmodified mani's and only wanted 1 ported/coated one back?
How much would it be to have the head port matched? Valve job?
Can you leave the VCTS and provide larger flappers that are port matched?
Thanks!
QuickSpool is offline
 Old 11-18-2009, 01:19 PM   #55
QuickSpool's Avatar
Activity Longevity
1/20 11/20
Today Posts
0/7 ssssss231
Hello?
 Old 11-18-2009, 04:04 PM   #56
Activity Longevity
2/20 14/20
Today Posts
1/7 ssssss837
You have A pm
Email:
/ AIM: burdatmap
 Old 12-09-2009, 07:56 PM   #57
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Sorry for the delay fellas, but Dyno is finally in.
Both runs were done at 15 psi boost. I tried to get a 20psi before/after run in, but I'm having trouble getting spikes to go away so 15psi is what I've got to show for now. The tune is a work in progress, so don't hate on the shitty curves
Red is before, blue is after, the torque lines are a little faint so you may have to zoom a bit to see 'em.
The runs were done with the same hardware configuration (except the MAP im of course) and small changes to the tune. No fueling or timing changes, JUST boost control to get the boost curve as close to the same as pre-MAP im as possible.
Happy to answer any questions anyone may have... I'd say I'm pretty darn happy with the gains... I'll get a 20psi run in as soon as I can.
The Following 4 Users Say Thank You to subparpunk03 For This Useful Post:
06Speed6 (12-11-2009), djuosnteisn (12-10-2009), JumpingJackson (12-15-2009), madvillain (12-09-2009)
 Old 12-09-2009, 09:18 PM   #58
Murse's Avatar
Posts: 122   (View Stats)
Murse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond reputeMurse has a reputation beyond repute
Activity Longevity
2/20 19/20
Today Posts
0/7 ssssss122
26 hp gain???? very nice
Murse is offline
 Old 12-09-2009, 09:38 PM   #59
I Got Race Rooted.
madvillain's Avatar
Posts: 3,626   (View Stats)
Groans: 64
Groaned at 15 Times in 14 Posts
Activity Longevity
19/20 15/20
Today Posts
2/7 sssss3626
need moar info.
Mike's Hard Lemonade sounds like a gay porn. Oh wait, maybe that was Hard Mike's Lemonade....
madvillain is online now
 Old 12-09-2009, 11:11 PM   #60
bf360's Avatar
Posts: 1,928   (View Stats)
Groaned at 39 Times in 32 Posts
Activity Longevity
5/20 17/20
Today Posts
1/7 sssss1928
both dyno runs were std corrected?
what were the dyno conditions? no uncorrected sheets?
bf360 is offline
 Old 12-09-2009, 11:29 PM   #61
Nator
lenny127's Avatar
Groans: 164
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
a)did u try to run the car with just changing the IM and if so what were the numbers.
b)what was the extent of the tune changes? any logs?
hard to know for sure the tuning u did didnt influence the outcome at all but......looks like it breathes alot better after 4k
very interested in the higher boost results kurt.
good job ese
lenny127 is offline
 Old 12-10-2009, 07:10 AM   #62
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Originally Posted by madvillain View Post
need moar info.
Ask and you shall receive.... what would you like to know?
Don't know about the STD correction, I drive up to greensboro and do 3 pulls and come home... they print the sheet out for me. They don't do any reconfoobling of the dynomotron between runs that I know of.
It was significantly colder for the run with the MAP IM, maybe a 25* difference which may account for some of the gains, but is by no means the only factor in the equation. Once the car gets goin the BATs are pretty consistent around 100* no matter what the temp is outside.
good job ese
Yeah, I ran the car with just the IM change. It put down almost EXACTLY the same numbers as before but with a 2.5-3 psi drop in boost. As I mentioned above, all I did was try and get the boost/load setup so it would run boost as close to what it was doing before, but obviously with more load requested.
Bottom line is I was able to make more power at the same boost levels, but I had to change the tune to hit those boost targets. I didn't touch fueling or timing or vvt. Just boost/requested load.
I'll be monitoring this thread so let me know if you have any other questions or if you'd like to see any other tests.
The Following User Says Thank You to subparpunk03 For This Useful Post:
lenny127 (12-10-2009)
 Old 12-10-2009, 07:13 AM   #63
Nator
lenny127's Avatar
Groans: 164
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
thats what i wanted to know....basically the added volume dropped u psi and u dialed it up. kinda like going from tmic to fmic...ty
lenny127 is offline
 Old 12-10-2009, 07:21 AM   #64
bf360's Avatar
Activity Longevity
5/20 17/20
Today Posts
1/7 sssss1928
IF both dynos were std corrected the temperature shouldnt have made a difference, i would hope they left it at std corrected for both runs
bf360 is offline
 Old 12-11-2009, 12:07 PM   #65
QuickSpool's Avatar
Activity Longevity
1/20 11/20
Today Posts
0/7 ssssss231
Sweet! Now if MAP would just respond to me....
 Old 12-11-2009, 01:16 PM   #66
Activity Longevity
2/20 14/20
Today Posts
1/7 ssssss837
Sorry sir I just checked my inbox and dont show a PM from you if you could please resend it that would be great.
Email:
/ AIM: burdatmap
 Old 12-11-2009, 01:37 PM   #67
Speeeeeed
06Speed6's Avatar
Posts: 2,426   (View Stats)
Activity Longevity
12/20 20/20
Today Posts
4/7 sssss2426
The dyno shows basically what it should show, the stock IM is a restriction at stock boost levels when the rpm is higher than 4k. Obviously if you are running higher than 15psi of boost the restriction will hit earlier.
2006 Mazdaspeed 6
First Ever P&P, flow benched, big valve 2.3L DISI head with inconel exhaust valves and welded EGR
First Ever MZR DISI Cams - Exhaust: .348 lift with 204° @ .050" & Intake: .398 lift with 216° @ .050"; LSA = 115°
First Ever crankcase breather with integrated air/oil seperator
First Ever CNC AN-12 ORB block oil adapter
and too much other stuff to list.
06Speed6 is online now
 Old 12-11-2009, 04:03 PM   #68
I Got Race Rooted.
madvillain's Avatar
Groans: 64
Activity Longevity
19/20 15/20
Today Posts
2/7 sssss3626
I wish someone would make a bomb ass manifold, like the one:
 Old 12-12-2009, 09:29 AM   #69
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
Yep, restriction gone, the part does what its supposed to. I'm VERY happy with it. The 3071 is going on soon, so well see how it does with that
The Following 2 Users Say Thank You to subparpunk03 For This Useful Post:
djuosnteisn (12-12-2009), lenny127 (12-12-2009)
 Old 12-12-2009, 09:31 AM   #70
Nator
lenny127's Avatar
Groans: 164
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
give that biotch socks a run for his money kurt!!!
lenny127 is offline
The Following 3 Users Say Thank You to lenny127 For This Useful Post:
djuosnteisn (12-12-2009), Murse (12-12-2009), subparpunk03 (12-12-2009)
 Old 12-12-2009, 09:42 AM   #71
djuosnteisn's Avatar
Posts: 3,706   (View Stats)
Groans: 60
Groaned at 17 Times in 17 Posts
Activity Longevity
17/20 18/20
Today Posts
7/7 sssss3706
yeah socks, you need to slow down and let us catch up.
Highest hp stock block ms6
449awhp 527awtq WCF
gt3071, SB + flash combo, self tuned and more on the way...
djuosnteisn is online now
 Old 12-12-2009, 05:35 PM   #72
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
At the last cars 'n coffee socks popped his hood for a family of four and the toddler started crying in fear when he saw that engine. True story.
djuosnteisn (12-12-2009), FreeFlyFreak (12-14-2009), lenny127 (12-13-2009), Murse (12-12-2009)
 Old 12-14-2009, 09:51 AM   #73
Activity Longevity
2/20 14/20
Today Posts
1/7 ssssss837
I just wanted to say thanks again to Kurt for obtaining this information and sharing it with us! We're considering a group buy on these in the near future, would that be of interest to anyone?
Email:
/ AIM: burdatmap
 Old 12-14-2009, 09:54 AM   #74
Nator
lenny127's Avatar
Groans: 164
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
maaaaaaybe....
i might want in on this action. especially since i really dont think anyone is making a manifold from scratch
lenny127 is offline
 Old 12-14-2009, 12:17 PM   #75
bf360's Avatar
Activity Longevity
5/20 17/20
Today Posts
1/7 sssss1928
yes for sure pending on price of course
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline
 Old 12-14-2009, 12:42 PM   #76
Speeeeeed
06Speed6's Avatar
Activity Longevity
12/20 20/20
Today Posts
4/7 sssss2426
If you can get it down under $500 I might consider it, a ported stock cast unit that costs more than most of our aftermarket exhaust manifolds just doesnt seem right.
Im not knocking the work though, I have had several sets of heads ported and I know the costs of hand porting and your price is reasonable.
I think there are quite a few people that would pony up for a full aftermarket unit that is around the same price point as a exhaust mani.
2006 Mazdaspeed 6
 Old 12-14-2009, 12:45 PM   #77
NEC
Activity Longevity
6/20 20/20
Today Posts
2/7 sssss1128
I'm about to get my throttle body all did up by Maxbore... its gonna get real when that guy and the 3071 go on.
 Old 12-14-2009, 04:08 PM   #78
I Got Race Rooted.
madvillain's Avatar
Groans: 64
Activity Longevity
19/20 15/20
Today Posts
2/7 sssss3626
Instead of gathering up a bunch of stock IM and doing a group buy on a P&P, I think a lot of us would much rather see one built from scratch... just a thought. Even if the price is higher.
 Old 12-14-2009, 06:28 PM   #79
bf360's Avatar
Activity Longevity
5/20 17/20
Today Posts
1/7 sssss1928
I think the ported manifold should come down in price, and like 06speed6 said, around 500 for the gb would get me interested.
Then you should develop a whole new manifold for the guys that would prefer that, and im sure they would pay 800-1000 for a quality manifold, but 750 for a ported manifold is definitely too high for most, 500 for a gb and im sure you would get a large amount.
bf360 is offline
 Old 12-14-2009, 06:58 PM   #80
Miembro
nighthawk358's Avatar
Posts: 542   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Activity Longevity
4/20 18/20
Today Posts
1/7 ssssss542
subpar..is that dyno with the steedspeed manifold?
2008.5 MS3 Metro Gray
nighthawk358 is offline
Thread Tools
Fully Ported Intake mani... GhostSpeed Appearance - BLACK 29 06-18-2009 04:35 AM
*Fully Ported Intake Manifold COMPLETE!* Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-04-2009 01:57 PM
WTB Intake Manifold BaseballD2 MazdaSpeed 3/6 - For Sale / Trade 0 05-26-2009 04:42 PM
**WTB** MS6 intake manifold Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 0 12-27-2008 05:24 PM
Ported intake manifold? driver311 PT-Performance 17 03-26-2008 12:59 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.1
Advertisement System V2.6 By   Branden
©Copyright 2008 ; 2010 Cymru Internet Services LLC
Page generated in 0.98470 seconds with 129 queries
