> Members Rides Gallery
Members Rides Gallery General Area For Posting Pictures, Thread Themes, Etc for your car
Like Tree47Likes
 Old 01-16-2017, 11:50 AM   #41
BobtailedSnail's Avatar
Posts: 1,360   (View Stats)
BobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the world
Heading to South Jersey tomorrow to pick up a Gen4 4.8 and a TH400, give me some options to play with.
RhoadBlock likes this.
2006 Mazdaspeed 6 GT-unDISI swap in progress
1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5
Skreets be calling...
BobtailedSnail is offline   Reply With Quote
The Following 3 Users Say Thank You to BobtailedSnail For This Useful Post:
Bingo (07-14-2017), Mauro_Penguin (01-17-2017), RhoadBlock (01-16-2017)
 Old 01-17-2017, 06:25 PM   #42
$250 for a GEN4 4.8L short block, TH400, and Powerglide.
The Following 6 Users Say Thank You to BobtailedSnail For This Useful Post:
CWP_MS3 (01-18-2017), Mack_Sant (01-20-2017), Mauro_Penguin (01-17-2017), RhoadBlock (01-17-2017), rymanmazda (01-18-2017), thrisnospork (01-17-2017)
 Old 01-23-2017, 11:04 AM   #43
Default BobtailedSnail's LSx MS6 and N/T Nova
While we wait for this project to lift off, here's a video of Matt Hapel's second Colorado build, Gen 3 LQ4, reused the stock headbolts and headgasket. These motors amaze me everytime I see them.
https://www.youtube.com/watch?v=Zo3kZ8wbnkA
 Old 01-27-2017, 06:18 PM   #44
Little teaser. Friend let me borrow one of his Welds to test fit.
This is a 15x8 5.5"BS (21mm offset) with a 275/60 (28") I'll be doing a 26" tall but tire width is unknown. Also the wheel hit the caliper on the face of all places. So a little spacer will solve that issue or shaving the caliper down. Right where the barrel dips to meet the spokes. I'll probably order a set of 15x8 6.5"BS (51mm offset)
The Following 2 Users Say Thank You to BobtailedSnail For This Useful Post:
Mauro_Penguin (01-28-2017), RhoadBlock (01-29-2017)
 Old 01-28-2017, 07:19 PM   #45
BigRed06's Avatar
Posts: 96   (View Stats)
BigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to all
Subbing to this so I can follow along even more, I'll continue to help where I can. Glad someone is making my dream come true, I'll be planning out my swap along the way of urs
MODS: AP V3, 3.5" intake, 3bar, gt3076 atp ewg, 38mm wg, SS turbo lines, 3" catless dp, 3" exhaust dp, hpfp, egr delete, vtcs delete, Mac 4port, lil intake mani port work, cxracing fmic, 51R battery cut stock battery tray, Toyota injector seals
BigRed06 is offline   Reply With Quote
The Following User Says Thank You to BigRed06 For This Useful Post:
 Old 01-28-2017, 07:50 PM   #46
More pics
Where it nicks the caliper.
I know the poke is corny. It'll tuck nicely inside the car on the finished product. Thank you to @BigRed06; for getting me straight on what brakes to use in the rear to eliminate the contact issue all together.
Last edited by BobtailedSnail; 01-28-2017 at 07:50 PM. Reason: MSF Database - Automerged Doublepost
Mazdazilla6 (01-29-2017), qtrmile beast (07-16-2017), RhoadBlock (01-29-2017)
 Old 01-29-2017, 06:05 AM   #47
RhoadBlock's Avatar
Posts: 793   (View Stats)
RhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the world
Groaned at 7 Times in 4 Posts
Good to know that 15s will work. What brakes are you gonna use in the rear?
Also, I know fender flares are sorta corny but they would cover the poke.
Sent from my Pixel XL using Tapatalk
2007 MS6 - broked
2006 MS6 - not broked
rhoadblock- the ms6 that will never run again
RhoadBlock is offline   Reply With Quote
 Old 01-29-2017, 06:46 AM   #48
03-05 Mazda6 rears. They should be considerably smaller. A set of good rotors and pads and I should be fine.
I really do want them to tuck. And I'm sure the 6.5"BS (51mm offset) will be nice and flush. I also decided to run 245/55/15 M&H radials. Equivalent to a 26x9. I've had good luck with M&H on my Chevelle (325/45/17) and my Nova (390/45/15). This makes it easier for me on the front tires as well. I can do a 17 in the front with Evo calipers and 245/45/17
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 04-15-2017, 06:35 PM   #49
Little update. Finally sold the motor out of the speed! No more 4cyl in my life.
Also wrapped up a single turbo Silverado build for a friend of mine.
My first order of business is to finish my Nova before May 18th and have Nishan tune it so I can go to the Cruisin' in Ocean City. Then the Mazda will be focused on. But I did purchase a motor plate and heads for it so it's not on the back burner by any means. I also sold the Powerglide today and am going to cut to make this TH400 fit. Look for mockup pics soon.
RhoadBlock, SVTJon87 and Mack_Sant like this.
The Following 4 Users Say Thank You to BobtailedSnail For This Useful Post:
cld12pk2go (04-17-2017), Easter Bunny (04-27-2017), Mauro_Penguin (04-16-2017), RhoadBlock (04-15-2017)
 Old 04-26-2017, 08:40 PM   #50
Picked up some coils for the 6 today
Mack_Sant likes this.
 Old 07-14-2017, 09:09 AM   #51
turbskies's Avatar
Posts: 156   (View Stats)
turbskies is a name known to allturbskies is a name known to allturbskies is a name known to allturbskies is a name known to allturbskies is a name known to allturbskies is a name known to all
https://clinchedflares.com/product/glider12/
I think these should help you fit a bigger tire.
Sent from my XT1254 using Tapatalk
turbskies is offline   Reply With Quote
 Old 12-21-2017, 08:33 PM   #52
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,665   (View Stats)
Groans: 524
Groaned at 169 Times in 106 Posts
bump.
sharksinspace and turbskies like this.
06 MS6
Pu Manchu is online now   Reply With Quote
The Following 4 Users Say Thank You to Pu Manchu For This Useful Post:
KiwiFlavor (12-22-2017), Mauro_Penguin (01-11-2018), rymanmazda (12-25-2017), Vansquish (12-21-2017)
« Building an Exocet | - »
BobtailedSnail's Compound Turbo MS6 BobtailedSnail MazdaSpeed 3/6 - Build Diaries 271 12-31-2016 07:07 PM
New guy from NoVa McBlack Mazdaspeed3/6 General Discussion 14 05-09-2012 10:42 AM
Page generated in 0.33293 seconds with 24 queries
