![]() | | #1 | ![]() |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
(Thread Starter) | Not Ranked : 0 score Closed Loop - Exit Delay A Code: 15 Code: 40 Code: 40 Code: 2.00 2.00 2.00 1.20 1.55 1.57 1.57 1.40 1.40 0.40 0.33 0.00 0.00 0.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle Last edited by SLS MS3; 05-05-2009 at 09:58 PM. Reason: changed to standard code formatting for easy cut/paste |
| The Following 9 Users Say Thank You to SLS MS3 For This Useful Post: | acidbbg (01-25-2011), Broxer (03-15-2011), evidence (04-24-2009), Fobio (04-24-2009), kgb (04-26-2009), LBV (04-24-2009), mike8748 (06-15-2009), SPEEDRAC3R (06-07-2011), thatsmrgimp2u (05-09-2011) |
![]() Join Date: Mar 2008 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 55
On that Max Load D table, are you sure the 2000 rpm # is 1.20? Just doesn't look like it fits .. Thx
__________________ 2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual. |
(Thread Starter) | Not Ranked : 0 score I'm positive. That's the actual the stock value and the changes start at 2500 rpm. Guess I should edit out 1500 and 2000 since no changes are made at those points.
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle |
![]() | | #4 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
speed6 guys better be careful looking at speed3 guys stuff cause its not going to be the same.
| The Following 2 Users Say Thank You to bova For This Useful Post: | dougefresh_ (03-30-2010), SLS MS3 (04-24-2009) |
![]() | | #5 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4169 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,140
Groans: 357
Groaned at 151 Times in 125 Posts
1.20 @ 2000rpm is same as stock/default... looks fine btw I found a cool "trick" when you're changing a bunch of values like this that are the same. manually edit (E), the first and last number to 60 (in this case), then select all cells and push (H) for horizontal interpolation, and it will apply a value of 60 to all of them quick and easy.
__________________ '99 Miata | engine delete mod | GTX2867R | ARTech exhaust | Tein Flex 9/6 kg | C3M 15x9 225/45 RS3 | DIYPNP |
![]() | | #6 | ![]() |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
so basically you are letting the ecu stay in closed loop at higher loads. What does the 15 stand for in exit delay? I know you cut the values in half but does that mean the ecu switches to open loop earlier? If so that is the opposite of what the other tables seem to be doing. My closed loop throttle tables are all maxed out, which probably means they are not being used. You say the car was more responsive, but were there any things you didn't like? Do you still run that map?
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock |
![]() | | #7 | ![]() |
There was nothing I really didn't like about the change, but it took some adjusting to the way the car drives. I'm still running with these changes and have been for about 3 months.
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle | ||
![]() | | #8 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
Awesome.. thx for this. Gunna try it out in a bit. BTW in Closed Loop - Max Load D the 5000 and 5500 values are stock and the same as the Cobb maps also. One other trick to changing multiple values is just holding the left mouse button down to select a couple, and you can hit e and change em all quick like.
__________________ Some things. Last edited by evidence; 04-24-2009 at 09:23 PM. |
![]() | | #9 | ![]() |
![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
i've been driving with these changes all night....makes a very nice diff. The car feels more eager to go, but not in a jerky throttle way like some maps have. Half throttle to 3/4 throttle acceleration feels much better. On WOT it takes less time for the AFR's to get out of the 13's and into the safe zone.
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+
| The Following User Says Thank You to itzl0l For This Useful Post: | Fobio (04-26-2009) |
![]() | | #10 | ![]() |
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock | |
![]() | | #11 | ![]() |
Groans: 357
i did and i agree it feels good. I like how AFRs drop quickly when going into WOT also
| The Following User Says Thank You to aaronc7 For This Useful Post: | Fobio (04-26-2009) |
![]() | | #12 | ![]() |
| Driver ![]() ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1892 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,111
Groans: 44
| Not Ranked : 0 score Yes. +1
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #13 | ![]() |
I made this change last night and I honostly don't notice a difference. If anything I like it better in stock configuration. The car doesn't really feel any peppier to me. Its definately not a night and day difference like the throttle change.
![]() | | #14 | ![]() |
![]() Join Date: Nov 2008 Location: Citrus Heights, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Should max throttle stay at 75% under 2500 rpms or do all of the max throttle values need to be changed to 60% to run this change?
![]() | | #15 | ![]() |
yea the biggest thing is the throttle fix. This fixonly made a little bit of difference in driving, but under WOT the afr's get down into the safe zone much quicker.
![]() | | #16 | ![]() |
![]() Join Date: Mar 2008 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,091
Groaned at 9 Times in 7 Posts
I noticed zero difference, open loop doesnt even seem to happen earlier on my car...dunno. And the linear throttle thing is not for me, way too smooth, way too boring, way too toyotaish. I love the hard hitting power of the "jerky" maps. Guess I'm different...
__________________ ![]() 07 Mazdaspeed3 |
![]() | | #17 | ![]() |
Last Friday at the local dragstrip, I worked with MS6 Alan to figure out which tables to change on Speed6's. He was very pleased with the changes and we'll make a seperate post for anyone that wants to try them out.
| The Following User Says Thank You to SLS MS3 For This Useful Post: | MS6 Alan (05-07-2009) |
![]() | | #18 | ![]() |
![]() Join Date: Apr 2008 Location: STL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 727
Here are the changes we made to my MS6 map at the track last week. The stock tables and values are different for the MS6, some of the table names are different too, but we figured all that out. It definitely changed the way the car drives, and its for the better, IMO. I've been running it for a few hundred miles now, seems to smooth my 2-3 stutter a bit more. 2006 US Federal Mazdaspeed6 Exit Delay A Code: 15 Code: 40 Code: 40 Code: 2.00 2.00 2.00 1.20 1.55 1.57 1.57 1.40 1.30 0.40 0.33 0.00 0.00 0.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 Code: 75.00 75.00 75.00 75.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00 60.00
__________________ '06 Mazdaspeed6 GT - Titanium Gray - ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC - |
![]() | | #19 | ![]() |
So you made Closed Loop changes at the track? Aren't you going WOT at the track? That's open loop. Just clarifying.
![]() | | #20 | ![]() |
| Not Ranked : 0 score Actually the ms3 and probably the ms6 is just about the same stays in CL until 4500+ RPMs at WOT under normal circumstances. If you bump the load down in those closed loop tables it lets WOT load pass over that threshold and you should then be OL from 2500+ RPMs. Lets your AFRs come down earlier, and theoretically make more power if all goes well.
__________________ Some things. |
![]() | | #21 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() Thanks: 0
Is there any way someone that is making changes to Speed6 CL tables to start a new thread. I'm in Iraq and I'm trying to understand all this before I get home sometime next month. I would like to get the PT knock fixed while i am home and I dont want to input changes for the Speed3.
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
going to do this tonight. any reason this would not work with any stage from stage 1 all the way up to stage2+++
![]() | | #24 | ![]() |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,366
Groans: 48
Groaned at 19 Times in 16 Posts
| Not Ranked : 0 score no
__________________ ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
So, does everyone agree that making these adjustments makes the car run quicker AND safer?
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
![]() | | #26 | ![]() |
Well, you have to wonder why Mazda set things up to stay in closed in all but the more extreme situations. Was this for safety and emissions? Did they then add the sharp jerk in the throttle tables to combat the high AFRs that are produced in closed loop at high throttle before 4500k? My feeling is at the sacrifice of tight control/safety (which we don't seem to like anyway) and maybe a little bit of gas mileage the early and often open loop changes here are for the best.
| The Following User Says Thank You to evidence For This Useful Post: | DaleNixon (06-29-2009) |
![]() | | #27 | ![]() |
Groans: 91
When I said "safety", I meant safety for the engine, not the occupants I'm sure you knew what I meant.I'm assuming doing this is theoretically safer for the motor because it drops the AFR's quicker when you're getting on it.
![]() | | #28 | ![]() |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
Made this change using the Genpu ATR beta and holy cow it made a HUGE difference! Increased the fun driving factor by atleast 10. I'll get some logs after work.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
| The Following User Says Thank You to Broxer For This Useful Post: | R.MS3 (03-18-2011) |
![]() | | #29 | ![]() |
![]() Join Date: May 2009 Location: MA
Rep Power: 137 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
sub for reference...
__________________ 2009 MS3GT MGM - CorkSport SRI/TIP | CorkSport TMIC | COBB AP self tuned | DENSO ITV22's | SURE Anchors | Bilstein B8's | 35% Tint To be installed - SURE CounterShift |
![]() | | #30 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 398 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 319
Did this the other night, subtle but noticeable I know what you mean when you say more "eager".
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
| How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02 | 94jedi | MazdaSpeed 3/6 - ECU Computer Tuning | 21 | 12-03-2010 08:48 AM |
| open and closed loop | Doc | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 11-14-2008 02:04 PM |
| Closed and open loop | booya620 | MazdaSpeed 3/6 - ECU Computer Tuning | 39 | 09-23-2008 02:06 PM |
| Open/Closed Loop Transition, Some New Observations | superskaterxes | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-18-2008 10:35 AM |
| Trunk Storage Tables (Set of 2) - $174.99 | Haltech | Hot Deals Section | 0 | 03-28-2008 02:30 PM |
