> Cobb Tuning >
Cobb ATR Support
Notices
 Old 06-26-2010, 09:48 PM   #681
Posts: 8,038   (View Stats)
Groans: 34
Default ECU Load cap shattered!
"I feel good! nah naw nah naw nah naw nah? I knew I would now"
That the cap is gone!!
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
Dano is online now   Reply With Quote
 Old 06-26-2010, 11:27 PM   #682
cpolly69's Avatar
Posts: 2,109   (View Stats)
Groans: 27
is it really gone or is it just being avoided?
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 06-27-2010, 12:12 AM   #683
hnda etr's Avatar
Posts: 3,295   (View Stats)
Groans: 78
Groaned at 274 Times in 243 Posts
From my understanding, the load cap still exists, it's just moved up high enough that you don't hit it - if you change your calc load a/b maps to 3.0...
 Old 06-27-2010, 12:35 AM   #684
WhiteNoise's Avatar
Posts: 60   (View Stats)
WhiteNoise is just really niceWhiteNoise is just really niceWhiteNoise is just really niceWhiteNoise is just really niceWhiteNoise is just really nice
Originally Posted by Dano2010 View Post
your logged Actual AFR should match the Commanded AFR in all the fuel tables. If it doesn't the MAF is off. At that point you can decide what you want to do to make them match.
1) change the MAF around the voltages in your logs that are off. Keeping the MAF curve smooth.
2) change your fuel tables around the areas that are off.
Doesn't realy matter which you choose. Having the MAF correct is the best way but takes the most time to get just right
I'm sorry - I'm tired and it's been a late night, and I haven't read the tech. documents or downloaded the latest ATR/docs.
All I'm concerned about is this: Assuming I had a OTS map and I did little beyond dialling in the MAF curve, and I had it working well with the pre-load-cap set of maps, can I keep that curve.
If I copy and paste my MAF curve into the latest maps can I expect the same LTFTs? (Of course, I'm going to take it easy, monitor, record, analyse, etc., but I don't need an upgrade to take me off into crazy tuner land )
WhiteNoise is offline   Reply With Quote
 Old 06-27-2010, 03:53 AM   #685
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,781   (View Stats)
Yes, your MAF curve should still apply just fine as long as your weren't playing load cap avoidance games with it before.
08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E30 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071)
 Old 06-27-2010, 08:55 AM   #686
Groans: 34
Guess it depends on how you define "gone". It is now tunable up to 3.0 so IMO it is gone. Has anyone achieved 3.0 load on this platform?
I am currently etuning a 3076 car and only see 230ish so far IIRC. His OTS map dynoed at 345WHP and I have him up 20 g/s at this point without any boost tuning. Just removed the cap and tuned fuel
PERM
dougefresh_ (07-30-2010), Fobio (06-27-2010)
 Old 06-27-2010, 09:39 AM   #687
SJP0tato's Avatar
Posts: 298   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
Something that still seems unresolved to me about the load cap issue:
The fuel/ignition tables still only go to 2.13/2.00 respectively.
Even though we can go up to 3.00 and the ecu will properly recognize it, we can't really seem to tune for much beyond the 2.13 still. I wonder if another version of ATR will be released soon that addresses this?
SJP0tato is offline   Reply With Quote
 Old 06-27-2010, 10:11 AM   #688
Groans: 34
I haven't looked at my "released" version but I thought that would be in this version. Trey is working on it and I believe what was decided was to scale the load axis acording to what you set as your Calc Load Max values.
i.e. if you set your max to 2.5 the load axis in all tables will go up to 2.5, calc max load to 2.75, axis goes to 2.75.
At lease I hope that's the way they will do it. That way if you don't need big power you will have more resolution in your load axis and if you need big power your axis will cover it.
maybe this will be in the next version. At this point the ECU will just use the values at the 2.13 load point for any higher calc load.
PERM
 Old 06-27-2010, 10:46 AM   #689
Eth/Meth Junkie
cld12pk2go's Avatar
The version of ATR I got on Friday does not have the load axis scaled above 2 or 2.13. I hope this is resolved in a near future release.
It is still a huge upgrade...
Dano (06-27-2010)
 Old 06-27-2010, 10:54 AM   #690
Groans: 34
amen! on the huge upgrade. I just DLd ATR on Friday as well so I guess the load axis scaling will be in a future release.
PERM
 Old 06-27-2010, 11:29 AM   #691
SJP0tato's Avatar
Agreed this is still a win for us.
I've thought about it, I don't think the resolution matters nearly as much for us as previous ECUs I've used. Reason being is we target A:F ratio. Chances are if you want 14.7 at 0.1 load you probably want 14.7 at 0.2-0.8 load too. Same for boost, if your load is 1.2 and you want 11.5 you still probably want 11.5 as you go higher in boost/rpm too.
It isn't like the "old days" where you had to deal with injector pulse width at each discrete point for RPM/Boost levels. In those cases you had to be very specific and needed as many data points as possible so you could manually work out the A:F ratio.
So I don't think a loss of resolution would matter nearly as much on our platform.
The Following User Says Thank You to SJP0tato For This Useful Post:
Dano (06-27-2010)
 Old 06-27-2010, 01:56 PM   #692
manelscout4life's Avatar
Posts: 1,782   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
dano or anyone else whos been working with cobb,
with theses new maps was the only thing changed the addition of Max Calculated load?
if I open up a 1.06 in the new ATR and change the Max Calc load to 3.0 would it be the same as the 1.07 maps?
I don't feel like recalibrating my maf and doing all that again.
manelscout4life is offline   Reply With Quote
 Old 06-27-2010, 02:06 PM   #693
SJP0tato's Avatar
You can copy your MAF values over to the new version (along with any other changed values) incase there's anything else different that they haven't disclosed.
 Old 06-27-2010, 02:17 PM   #694
Groans: 34
all you really have to do is open your old map in the new ATR, change the Calc Max load A & B values and resave the map. no need to use the new OTS maps at all.
PERM
manelscout4life (06-27-2010)
 Old 06-27-2010, 03:46 PM   #695
Groans: 661
oh okay thanks thats what i figured
 Old 06-30-2010, 05:37 PM   #696
evidence's Avatar
Posts: 1,031   (View Stats)
evidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the worldevidence is the leader of the world
Seems we do really have Trey's ear right now. Wanted to mull over the list of tables real quick before I submit them. Below is a list of all with a load axis. Not sure we want him to ignore any tables really. The CL ones obviously don't need to be scaled up, but would be nice to have complete control. Bolded ones I said aren't required, but should be included if they share tables with the others or are easy enough to implement.
Fuel CL Commanded EQ (base)
Fuel OL Commanded EQ (Throttle Closed)
Fuel OL Commanded EQ (base)
Fuel OL/Part Throttle Commanded EQ (Knocking)
Fuel OL/Part Throttle Commanded EQ (No Knock)
Fuel OL/Part Throttle Commanded EQ (unused)
Ign Table - High Throttle/OL (Knocking)
Ign Table - High Throttle/OL (No Knock)
Ign Table - Low Throttle/CL (Knocking)
Ign Table - Low Throttle/CL (No Knock)
DBW Throttle A
DBW Throttle B
DBW Throttle C
VVT Intake Cam Adv.
Side note.. he said he figured out most of the fueling stuff and has the table mapped out for commanded pressure. Posting more in the wish list thread.
Need input guys:
I think I have a method to allow you to set the Load Axis values for tables on a cell by cell basis without it being as difficult as I original thought. It will require some custom code and testing, but the results will be better and it shouldn't take months and months to do.
What I need to know from the community are the tables you wish to rescale the Load axis values. Please list them, table by table, using the names as they appear in ATR. This way I'm not wasting time on tables you don't actually use/care to scale.
The way it'll work is that I'll add some new tables that are axis values for various groups of tables (ex: The Ign Tables share the same axis value). You can then edit those axis tables and they'll automatically alter the axis values for the table(s) that use those values.
I'm also going to bump the Calc. Load range in the ATR from 3.0 up to 5.0. That should give you plenty of head room should someone decide to attempt a 700HP build or something.
Trey
Some things.
evidence is offline   Reply With Quote
The Following 2 Users Say Thank You to evidence For This Useful Post:
Dano (06-30-2010), Fobio (06-30-2010)
 Old 06-30-2010, 05:41 PM   #697
Groans: 34
Great to hear!!!
Fuel CL cmd EQ base
Fuel OL cmd EQ base
Fuel OL/PT knock
Fuel OL/PT no knock
Both ign high throttle tables.
PERM
 Old 06-30-2010, 06:48 PM   #698
Cataphract_40's Avatar
Posts: 1,576   (View Stats)
Groans: 28
500 calc load?!?!
2008 GT MS3
Cobb SRI - PG Turbo Inlet - M3M FMIC - Cobb Catted DP - Turbosmart BPV - Denso ITV22 plugs - KMD HPFP - Cobb AP - JBR RMM - CP-e Side Mounts - Hotchkis RSB - Moog Endlinks - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18
1995 Miata
Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - Hail Dents - Bent Suspension
 Old 06-30-2010, 06:51 PM   #699
evidence's Avatar
Originally Posted by Cataphract_40 View Post
500 calc load?!?!
Just the allowed range, maps will likely be left at 3
Some things.
 Old 06-30-2010, 07:02 PM   #700
Groans: 28
Yeah, but you could theoretically request up to 5.00. and then bad things would happen
2008 GT MS3
1995 Miata
 Old 06-30-2010, 07:19 PM   #701
Groans: 34
nah...hardware wouldn't take you that far....right? I mean 4" MAF some sort of 7786 Garrett monster w T6 1.8 AR back housing.....hahahahah
sorry....i ramble sometimes....but I am glad Trey is on the case....ya know all the scoobie guys have open source so it makes good $ and sense for Cobb to cater at least some to the Mazda world. Small pie is better than no pie at all.....
thank again Ev
PERM
 Old 06-30-2010, 08:31 PM   #702
Groans: 28
this sucker could probably hit 5.00 load
2008 GT MS3
1995 Miata
 Old 06-30-2010, 09:27 PM   #703
Groans: 34
Hahahaaha
I think we have a winner!!!
PERM
 Old 07-01-2010, 02:27 PM   #704
sbspeed's Avatar
Posts: 111   (View Stats)
sbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to behold
Trey
700HP?
sbspeed is offline   Reply With Quote
 Old 01-06-2011, 03:32 PM   #705
super_pablo_'s Avatar
Posts: 1,608   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
i went from page 1 to 18 without reading it all, sorry if i skipped it but... are the initial documents from OP unavailable now? I cant download em
super_pablo_ is offline   Reply With Quote
 Old 01-06-2011, 03:37 PM   #706
Captain
djuosnteisn's Avatar
Posts: 11,192   (View Stats)
Groans: 79
No longer necessary.
Set the CL max in your tune to like 3, and voila.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
 Old 01-06-2011, 03:40 PM   #707
Groans: 34
holy resurrection Batman!
yes CL Max Load A & B to 3 and ur done.
PERM
 Old 01-06-2011, 03:43 PM   #708
i have done that already... i guess i dont need it then... shoulda read more... lol. I just wanted to compare my tuning with someone else's i guess.. so i wanted to check out his map.
i still have OTS timing tables cause im not comfortable with changing it yet... i need more reading on it. thanks anyway
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f418/ecu-load-cap-shattered-49009/
VersaTune • View topic - 3 BAR MAP This thread Refback 05-08-2010 12:18 PM
MS3/ATR: ECU Max Load clipping/scaling This thread Refback 02-16-2010 04:34 PM
Load Tables Dano
Cobb ATR Support
17 01-20-2010 11:25 AM
ATR AP load change? LiEast MazdaSpeed 3/6 - ECU Computer Tuning 6 10-17-2009 02:10 PM
Max Load C djuosnteisn
Cobb ATR Support
5 07-11-2009 09:57 PM
What is this load cut? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 90 06-23-2009 08:36 AM
LOAD!!! superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 12 01-14-2009 02:59 PM
Page generated in 0.51495 seconds with 32 queries
