> Cobb Tuning >
Cobb ATR Support
Notices
 Old 02-16-2010, 01:47 PM   #81
Realgib3's Avatar
Posts: 1,427   (View Stats)
Groaned at 14 Times in 7 Posts
I don't think you were have the calc load capping issue... So i don't think this will fix your afr's. My best guess for your situation would be that your maf table is too low in the higher g/s values (higher volts). Check out where your lean on your logs (while logging maf volts) and adjust the maf table up in that area.
You may also want to play with your OL PT fuel tables and transition delays.
Yep all you should need to do is raise your MAF up top BUT, when you do that, you will see your calc load go up... which could bring you into the clipping zone.. which would then make it so you need this fix.
This is the exact chain of events that really brought this about. We raised our MAF's more, and more and more to combat lean AFR's but then nothing happened... hence the "car was acting a fool" thread.
Built Motor
PTE 6466 BIG Turbo
Tuned by me
4 cylinders... 6 injectors... Because Racecar
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
BudUMfan (02-17-2010), djuosnteisn (02-16-2010)
 Old 02-16-2010, 01:58 PM   #82
manelscout4life's Avatar
Posts: 1,782   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
i never really messed with my mafs because dont people get less boost after adjusting them?
my ltfts are always pretty close to 0 as well
manelscout4life is offline   Reply With Quote
 Old 02-16-2010, 02:15 PM   #83
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
Just an update for how my car is reacting to it...
So far so good. After I first bumped it down 5% I was getting a peak calc load of 190. So I bumped it down another 5%...and now Im seeing a peak of 177. Fuel is holding perfectly at 11.3 now. So I am going to try to use this MAF table (-10% OTS...stage 2 SF + FMIC 93 oct).
I bumped up fuel .3...so I should be now seeing 11.6 AFR at WOT...and I bumped up load .05 in the upper RPMs because Im peaking at about 18.5 psi tapering to 16.8. And I want to be more around mid/upper 19 psi tapering to 17.5-18 psi. Ill have to monitor load and make sure I stay in the 180s and not bump up into the 190s and run into load clipping again.
If I get to close to 190...Ill have to take off another 5% of MAF to be a total of -15%.
I was also getting .35 and a flash of .7 of knock during my WOT runs @ 11.3 AFR...so I bumped up the Ign OL tables one block...and the ign tables at 1.94 are now lined up with 1.75
I know you all have already made these discoveries and had it work on your car...so Im not trying to take credit for finding the solution...but I thought I'd keep you posted on how my car is reacting to confirm that all this shit is working...and triple/quadruple check that this is a universal fix...and not a fix for just your car.
AFcadet is offline   Reply With Quote
The Following 6 Users Say Thank You to AFcadet For This Useful Post:
bioevolve (02-16-2010), BudUMfan (02-16-2010), Dano (02-16-2010), djuosnteisn (02-16-2010), flyrevs2 (02-16-2010), Realgib3 (02-16-2010)
 Old 02-16-2010, 02:30 PM   #84
Posts: 8,166   (View Stats)
Groans: 34
Great info AF!!!
it looks like you have your issues resolved and all you need to do now is polish it off a bit.
Keep in mind that as the weather warms up your Calc load will drop so I am targeting to stay right at the cap for my load.
Some speculate that a KR of <1 is just the ECU trying to fine MBT [VE effency crap] and can be safely ignored.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The grind on was with a chick. Given the amount I had though, I should probably check in with friends to confirm... Her body was pretty tight, could've been a dude with a 6 pack tho...
Originally Posted by djuosnteisn on 5/28/13 View Post
I keep telling my wife that this is the last "mod" on the 6. She doesn't believe me...
I want to tackle the 3 already. The 6 is plenty exotic at this point lol.
Dano is online now   Reply With Quote
 Old 02-16-2010, 02:39 PM   #85
fjames's Avatar
Posts: 1,058   (View Stats)
Originally Posted by manelscout4life View Post
wow i didnt even see that your right though thats definitely not good.
it appears that the the flat shift to 4 did that o well no more flat shifts till I can richen that up a bit.
Your pedal position is weird in 4th, so look into that before you do anything. It's always been 99.x to my memory when WOT, and yours is 95.x. It looks like you think it's floored since it's holding an exact number, but it should be higher. If you didn't have it floored on purpose, then you can't really compare AFR to 3rd. Yeah, it's high for that boost, but it could have been following your map for all you know, since you're not at WOT apparently.
Keep it up man, you're doing us all a favor, applying the theory to a real-world tune.
Last edited by fjames; 02-16-2010 at 02:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-16-2010, 02:39 PM   #86
Captain
djuosnteisn's Avatar
Posts: 11,274   (View Stats)
Groans: 79
I'm not sure you even need to "undo" this fix as the weather warms up. Yeah your load will drop some, but that would happen even if the fix wasn't needed.
Only time you should have to adjust anything is if you decided to further up the boost, or further mod the car, thus pushing you back into the clip zone.
But as i see it, this is a one time adjustment.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
djuosnteisn is online now   Reply With Quote
BudUMfan (02-16-2010), Realgib3 (02-16-2010), SpeedSixxx (02-16-2010)
 Old 02-16-2010, 03:19 PM   #87
Smoker6's Avatar
Posts: 983   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
Well I paid extra attention to load on my way home and my DH was showing me hitting and holding 230 (tapering off towards redline to mimic torque curve) which matches my requested load. I suppose this may do nothing for me. My AFR's are a solid 11.8 dropping to 11.4 by redline, also no issues.
This was just me watching the dashhawk, so I'll take some actual logs on the weekend to see if I even need to bother with this.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline   Reply With Quote
 Old 02-16-2010, 03:37 PM   #88
Captain
Groans: 79
yeah supers load cap was right around 240 IIRC.
You should up the boost so you have an excuse to do this, lol.
www.permtuning.com
 Old 02-16-2010, 03:50 PM   #89
Smoker6's Avatar
I'm already at 21.5psi. :O And yeah I have an '06 so perhaps mine is at 240 as well.
 Old 02-16-2010, 04:17 PM   #90
Posts: 10,186   (View Stats)
Groans: 98
heres my first log from the dyno, you can CLEARLY see that the load is pegged but im also not closing my throttle
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
 Old 02-16-2010, 04:22 PM   #91
Police
JmkC's Avatar
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
Groaned at 6 Times in 6 Posts
i do have one question and something strikes me as odd. i get the closed loop max load tables. but doesnt changing the closed loop max throttle table to higher values, make the car stay in closed loop longer, wouldnt lower values be better?
JmkC is offline   Reply With Quote
 Old 02-16-2010, 04:33 PM   #92
Posts: 9,798   (View Stats)
Groaned at 39 Times in 33 Posts
Super, is that knock that pulled 2 degrees from your timing or something else?
Lex is online now   Reply With Quote
 Old 02-16-2010, 04:47 PM   #93
Captain
Groans: 79
You have to force the car's CL -> OL transition to be based solely on load to avoid any issue with lean or rich afr's.
www.permtuning.com
 Old 02-16-2010, 04:56 PM   #94
Realgib3's Avatar
nope all it does is make the transition strictly based on load, rather than pedal position, rpm, or anything else...
Again though guys, this information is all over in the links I posted...
I can only speculate on this, but I would have to say that although your throttle is not closing, it may still not be open as far as it could be, because as soon as your calc load stops rising, your throttle is also going to stop opening, as your throttle position is a product of your load calculation.
Also, on this log, were your DBW tables set to 100? or 80?
And now is when we need you to do this fix... and turn up the boost, and see what kind of power you can make
Built Motor
PTE 6466 BIG Turbo
Tuned by me
Last edited by Realgib3; 02-16-2010 at 05:00 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Realgib3 For This Useful Post:
 Old 02-16-2010, 05:09 PM   #95
AFcadet's Avatar
Alright...looks like a final update for me. I am pretty much one flash away from having my car identical to previously when it comes to AFR and boost.
I just have to tweak my fuel tables a little bit. After I bumped up my fuel by .3...I now have a very slight taper which looks like this....12, 12, 12, 12, 11.9, 11.9, 11.9, 11.9, 11.8, 11.8, 11.8.
Im going to bump the 12 AFR RPM areas down by .2, and the 11.9 RPM areas down by .1...and I should have a flat 11.8 (11.76) actual AFR line.
Boost is basically exactly where I want it. Peak boost of 19.5 @ 4700 RPM...tapering down to 17.5 psi.
Now here is the great part...My Calc load is peaking at 185 on this new map...where before on the same boost...it was maxed out at 195.
Also...I got no KR on any of my pulls...which Im sure it was because I bumped the timing tables up one box.
I may bump up boost @ redline to 18 psi...but my calc load will still be quiet low since it tapers down alot after 5000 RPM.
Only thing that confuses me a little bit...is my throttle position closing a bit after 5500 rpm. It goes from 75.66 @ 5500...and tapers down to 73 @ 6000. Not sure why...but its kind of the least of my worries at this point. Gotta tweak other stuff first.
The Following User Says Thank You to AFcadet For This Useful Post:
 Old 02-16-2010, 05:29 PM   #96
Tripple OG
NJSPEED3's Avatar
Posts: 4,978   (View Stats)
Groans: 110
Groaned at 41 Times in 35 Posts
Looks like my calculated load clips at 210! 2 secs after going wot
8:5:1CP pistons...Pauter rods...NJSPEED P&P cyl head...ACT 6 puck...T3 HTA3586...CPE Big maf...Custom inlet....Hks Bov....44mm Tial ewg vta..... T3 SCH40 ARdesign Tubular Manifold...3" Vband dp....Greddy TI-c...custom fmic...Hallman MBC...CPE HPFP...JBR dogbone...SU sidemounts...Occ w/t MD checkvalve...SILVERDEMONS Injector Seals...Perm tuned..Sixth Port powered.
445whp 397wtq 4/12
478whp 470ishwtq 10/12
Killah Built Perm tuned
The Following User Says Thank You to NJSPEED3 For This Useful Post:
 Old 02-16-2010, 06:25 PM   #97
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
My AP is gone and I'm back to stock prepping to sell the car ... but I just had a question regarding this. What does playing with the MAF tables do to the stft and ltft's? Does it throw them all out of whack?
GQ_WhiteMS3 is offline   Reply With Quote
 Old 02-16-2010, 06:38 PM   #98
Groans: 98
no, i only had like .7 knock on that run and all of my logs have this wierd timing dump at that same rpm. i obvi cant see the map so i dunno if its something he put in there. max timing at RL is also like 7-8 deg below stock values
lol my clalc load never stops rising, BT bitch haha. i dont really know if that was 80 or 100 but im gona assume 100.
we will know thursday if the fix works for BT. im hoping but not getting my hopes up.
WWW.SONICTUNING.COM
The Following User Says NO Thank You to superskaterxes For This Un-useful Post:
 Old 02-16-2010, 06:45 PM   #99
Alittle Faster
bioevolve's Avatar
Posts: 3,274   (View Stats)
I'm nowhere near the load you guys are talking about. I'm on stock turbo thou.
Why is there such a big load difference on a big turbo when the power is close in the same?
Here is my log on a pull this morning.
datalog10.csv
JOIN MY BRUTE CLAN!!!!
 Old 02-16-2010, 07:06 PM   #100
Realgib3's Avatar
Fuel trims are only used during CL, so no it does not affect them.
datalog10.csv
Hmmmm you got some weird stuff goin on in this log.
1) It looks like you might be stuck in CL for a LONG time till about 4800rpm @ WOT
2) Your AFR's are kinda all over the place... and idk why
3) You're keeping the boost pretty steady... but your Timing Advance is jumping all over...
Lastly, what is your MAF curve peaking at?
Again, the mods/turbo you have, and the amount of power you are putting down DOES NOT have anything to do with your load being clipped. The higher your MAF values are, the easier you will hit the load clipping area. It's all in the calculation, NOT in your power level.
Built Motor
PTE 6466 BIG Turbo
Tuned by me
Last edited by Realgib3; 02-16-2010 at 07:06 PM. Reason: MSF Database - Automerged Doublepost
bioevolve (02-16-2010), GQ_WhiteMS3 (02-17-2010)
 Old 02-16-2010, 07:11 PM   #101
Police
JmkC's Avatar
Groans: 109
i hit 232 right now and its cold out
 Old 02-16-2010, 08:27 PM   #102
Groans: 34
We are only changing MAF above the voltage WE set to enter OL. no fuel trimming goes on up there. In a log this point is where LTFT and STFT go 0.
I think its outlined in the doc
PERM
 Old 02-16-2010, 09:52 PM   #103
Cataphract_40's Avatar
Posts: 1,577   (View Stats)
Groans: 28
any hypotheses on WHY this 'wall' is encoded into the ECU?
mazda usa just trying to rain on our parade yet again?
2008 GT MS3
Cobb SRI - PG Turbo Inlet - M3M FMIC - Cobb Catted DP - Turbosmart BPV - Denso ITV22 plugs - KMD HPFP - Cobb AP - JBR RMM - CP-e Side Mounts - Hotchkis RSB - Moog Endlinks - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18
1995 Miata
Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - Hail Dents - Bent Suspension
 Old 02-16-2010, 09:58 PM   #104
There is a slight correction - if your maf is calibrated correctly, load should mimic torque at the motor.
I have been wondering myself why put this load cap. It is below all fuel cuts on the stock car. I wonder if it's there to prevent the fuel system from being overtaxed, or to prevent "tuning" the car with bolt ons, or simply mandated by the EPA that the car should not fuel any more than a certain amount to meet emissions.
djuosnteisn (02-17-2010), Realgib3 (02-17-2010), SpeedSixxx (02-17-2010)
 Old 02-17-2010, 03:57 AM   #105
Realgib3's Avatar
Mazda was having a well documented issue with people complaining of sputtering and stuff at WOT. They ended up replacing a lot of HPFP's. And Lex you are exactly right, this was put in place for that reason, to save some fuel pumps.
Built Motor
PTE 6466 BIG Turbo
Tuned by me
 Old 02-17-2010, 05:34 AM   #106
AFcadet's Avatar
No...because right when the ECU hits that big dip in the MAF curve (around 3.6v), is @ 1.1 load... which is when we switch over to OL (and we changed the CL max load to 1.1). And in OL...fuel trims are ignored and it only goes by the MAF.
802MS3 (02-17-2010)
 Old 02-17-2010, 07:36 AM   #107
Groans: 34
slightly off topic here or maybe only premature, but is it true that even if this MAF scaling works, and Super indicated that the Cobb tuners use this method when needed, we still have a fueling issue with BT motors due to lower than needed fuel rail pressure and/or injector timing? In essence we are still "capped" at a certain g/s airflow into the motor by fueling limitations?
And further, this is why DJ made his little ckt CDFP pressure scaling device and does this get us a little further along?
PERM
 Old 02-17-2010, 07:41 AM   #108
AFcadet's Avatar
Not sure...when I hear fueling problems with big turbos...its due to injector problems because of lack of pressure...not volume. I think our upgraded internals have enough volume being pumped...its just turning up the pressure (our ECU limits pressure by re-routing fuel from the fuel rail back to the CDFP)
My only question...is big turbos will be able to put down A LOT more load. So will they turn down the MAF by something like 40%? That seems excessive...and I wonder if it would still work.
 Old 02-17-2010, 08:12 AM   #109
Driver
Fobio's Avatar
Posts: 2,477   (View Stats)
Groans: 44
I think there will be only so much room to scale at this end before we run into another limit at the fueling end, like fuel rail pressure?
I'd think that PTP's fuel rail valve will be coming at just the right time. Unless of course, we can have better control of fueling thru the ECU instead...
is Christian setting up a new shop?
-- Mario Andretti --
Fobio is online now   Reply With Quote
 Old 02-17-2010, 03:13 PM   #110
m4tic's Avatar
Posts: 4,565   (View Stats)
Groaned at 22 Times in 20 Posts
are there any issues with the 2-3 shift studder with this? (or is it gone with the ap)
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob
m4tic is online now   Reply With Quote
 Old 02-17-2010, 03:51 PM   #111
SpeedSixxx's Avatar
Posts: 4,160   (View Stats)
Groans: 778
Groaned at 443 Times in 239 Posts
yea why is that? when I shift from 1 to 2 or 2 to 3 the car stutters? no power then BAM didggity niggity..gone./..???
 Old 02-17-2010, 04:11 PM   #112
AFcadet's Avatar
i never had a stutter...
 Old 02-17-2010, 04:12 PM   #113
Groans: 34
that vid in your sig makes me studder....
PERM
flyrevs2 (02-18-2010)
 Old 02-17-2010, 04:17 PM   #114
Docnox's Avatar
Posts: 1,432   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
What are your mods? Happens to me going 2 to 3. I think it's boost cut. Vroooom, shift, spike, cut, VRROOOMm. Stop double clutching and just Paul Walker it in and it might drive better.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
The Following User Says Thank You to Docnox For This Useful Post:
 Old 02-17-2010, 05:22 PM   #115
Alittle Faster
bioevolve's Avatar
Here is another log with MAF:
datalog1.csv
 Old 02-17-2010, 06:08 PM   #116
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,196   (View Stats)
FORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the world
Fuel trims are only used during CL, so no it does not affect them........
Yeah, I've been trying to explain to some dude "matsuda" in another thread that the LTFT is dropped in OL and that is your ONLY true indicator of OL, but he just refused to accept it.
Anyway, I reviewed the last log posted to see if I could determine the CL/OL delay timing and it matches up quite nicely. I used the STFT zeroing out as the start of "WOT" which is likely what the ECU triggers from rather than pure TPS as well. The stock map has the CL Exit delay A set at "30" which equates to ~3 seconds in that log. I have mine set to 15 which would be ~1.5 sec and it fits nicely as well. I would assume the stock map value of "80" for CL Exit B & C would be 8 seconds to keep the ECU in CL possibly for TCS/DSC action or some other emissions testing reason?
I have mine set to 15 (1.5 sec?) and 30 (3.0 sec?) respectively and I go into OL right after I step on the gas and look up at the DH fuel trims screen. I haven't logged it because I usually don't log STFT, but I'll check it out.
Just another point of data on ECU operation.....
`07 Speed6 Sport Tit Gray w/Cobb; ETS; CorkSport; TXS; M2Perf; BNR; DNP; MAP; Perrin; KMD; F2; SM; Labonte; Autometer & DH; Koni; Whiteline; Racing Beat; SPC; 18x8 SSR; 225/45 Z1 SS Dunlops (17x9 RPF1 w/ 245/40s waiting); SU; TT, etc... currently broken Sleeper Express
`11 Ducati 1198SP SBK Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq Land Rocket
`12 Ducati 1100SP EVO Hyper CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq Hooligan Toy
`12 Aprilia RSV4 Factory SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq Land Rocket 2
FORZDA 1 is offline   Reply With Quote
The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post:
Dano (02-17-2010), djuosnteisn (02-17-2010), Realgib3 (02-17-2010)
 Old 02-17-2010, 06:45 PM   #117
Groans: 98
i never get the 2-3 studder when i FFS. i think it has to do with FP recovering
WWW.SONICTUNING.COM
Docnox (02-18-2010), Realgib3 (02-17-2010), SpeedSixxx (02-17-2010)
 Old 02-17-2010, 06:50 PM   #118
ATE BALLER's Avatar
Posts: 3,226   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
So, if it were possible to raise the calculated load cap up to whatever, or even eliminate it, would that theoretically solve this problem all together?
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 02-17-2010, 06:54 PM   #119
Realgib3's Avatar
Yep, problem is we can't, at least not right now, so we just stay under it to solve the problem just as well.
Built Motor
PTE 6466 BIG Turbo
Tuned by me
 Old 02-17-2010, 06:54 PM   #120
[MSF STIG]
FORZDA 1's Avatar
All you guys with this studder on shifting try this: Using AP, raise your normal rev limiter to..., say at least 7k rpms and try again. It seemed to fix my occasional high rpm shift studder with simply raising it to 7k.
If you don't have an AP, try shifting about 300 rpms lower...
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f418/ecu-load-cap-shattered-49009/
VersaTune • View topic - 3 BAR MAP This thread Refback 05-08-2010 12:18 PM
MS3/ATR: ECU Max Load clipping/scaling This thread Refback 02-16-2010 04:34 PM
Load Tables Dano
Cobb ATR Support
17 01-20-2010 11:25 AM
ATR AP load change? LiEast MazdaSpeed 3/6 - ECU Computer Tuning 6 10-17-2009 02:10 PM
Max Load C djuosnteisn
Cobb ATR Support
5 07-11-2009 09:57 PM
What is this load cut? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 90 06-23-2009 08:36 AM
LOAD!!! superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 12 01-14-2009 02:59 PM
Page generated in 0.71907 seconds with 40 queries
