![]() | | #321 | ![]() |
| [MSF STIG] ![]() ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 1997 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,458
| Not Ranked : 0 score
__________________ `07 Speed6 Sport Tit Gray w/Cobb; ETS; CorkSport; TXS; M2Perf; BNR; DNP; MAP; Perrin; KMD; F2; SM; Labonte; Autometer & DH; Koni; Whiteline; Racing Beat; SPC; 18x8 SSR; 225/45 Z1 SS Dunlops (17x9 RPF1 w/ 245/40s waiting); SU; TT, etc... currently broken Sleeper Express `11 Ducati 1198SP SBK Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq Land Rocket `12 Ducati 1100SP EVO Hyper CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq Hooligan Toy `12 Aprilia RSV4 Factory SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq Land Rocket 2 |
![]() | | #322 | ![]() |
Rep Power: 14994 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,869
Groans: 79
| Not Ranked : 0 score Sure sounds alot like surge. Is your bov adjustable? Maybe back it off a bit, or try a lighter spring.
__________________ 500awhp 440awtq uncorrected ![]() BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Mounts be popping, and trans be hurting 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #323 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 1327 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,661
Groaned at 14 Times in 7 Posts
If it's what I had, it's not surge. It's literally like the car can't decide weather it wants to be in boost or vac and just keeps shooting back and forth between the two on my car, and it only happens when your are slowly letting of the throttle after moderate boost... All I know is I plugged my WG back in two days ago and it hasn't done it once since...
![]() | | #324 | ![]() |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 474 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
More logs i took. all done in 5th gear around 65-75 mph
![]() | | #325 | ![]() |
![]() Join Date: Jul 2009 Location: Boston, MA
Rep Power: 2865 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,408
| Not Ranked : 0 score In datalog 6, check out row 44. Your cacl load spikes a bit (like before) as you let off the gas and right when you go into vacuum. You're AFR's also plummet from 15.43 to 11.32, which suggests your car is popping into OL there, when it should not. You're calc load seems to spike again in row 100, but there is no big change in AFR's here. I'll let someone else eyeball log 7, as I'm a noob and want to pick up some brews at the store.
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 |
![]() | | #326 | ![]() |
Groans: 79
JJ, are you using a bov or bpv? sorry to keep kicking the valve horse...
![]() | | #327 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10081 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,769
Groans: 98
jj what r u using to control boost?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
![]() | | #328 | ![]() |
Just wanna let everyone know that I unplugged my wg again tonight to test this out and I got it to have this exact same issue again... May be coincidence but idk.
![]() | | #329 | ![]() |
logged this phenomenon on the way to work this morning so i'll post is up tonight and see if it looks the same as JJ's
![]() | | #330 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
i notice every time i let off the throttle afr's dip down first before going to 29.xx. My theory on this was that from adding a FMIC you make the path air has to travel longer so you will have a momentary rich spike when the throttle closes. probably not the best explanation, but its early and i can't find the words i'm looking for to explain it, haha.
![]() | | #331 | ![]() |
Rep Power: 7967 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,117
Groans: 34
Is it true that logging direct into ATR gives higher res and is anyone here doing it? It might help with weeding out these strange anomalies. My setup will not work and I haven't tried to figure out why...just plugged it in an it didn't work...some sort of dongle driver issue with my Win 7 laptop. It worked with Vista
__________________ ![]() ![]() PERM ![]() 07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
![]() | | #332 | ![]() |
![]() Join Date: Feb 2009 Location: Cincy, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
__________________ True Red 2008.5 SPEED3 Sport....MS CAI, TIP, TurboXS RP, AP, SSP | |
| The Following User Says Thank You to RJTSi For This Useful Post: | Dano (03-31-2010) |
![]() | | #333 | ![]() |
Alright here's a log of the "stutter" and then a log of my 4th gear pull, I hit traffic pretty quick so I had to let off around 5500 rpm... o well, can wait to open up the exhaust a little so I can run some real boost though.. and DJ, I need a ckt asap. Since you're bailing for a SB I think you owe it to me jk... but really I want one.
![]() | | #334 | ![]() |
Are you using the CL Max Load table values of 1.1 across the board as stated in the .pdf in the OP of this thread? Look at row 5 compared to row 6...Your APP only increased 2%, and your TPP increased 42%. This caused you to go into boost here, which made your calculated Load jump from 65 to 116, which triggers OL in row 6. Look at your LTFT's and your AFR... you're in OL during this "stutter." I think it's because you go can go into boost quickly on the highway with just part throttle (even on the stock map). This causes your Calc load to spike, and if you have your CL exit delays really low, you'll jump into OL. So, if you breach your lowest CL Max Calc load table value for longer than what is set in your CL exit delays (and if they're really low, it'll probably trigger OL immediately) you'll be forced into OL, and it stays there for a while, flooding the engine with excess fuel which causes the temporary stutter. Note in our tables there is no such table as "OL/WOT exit delays." This is to prevent the ECU from exiting OL/WOT fuel targets prematurely, and causing a dangerous lean condition. The other thing is the boost spike (to 14 PSI) that occurred in row 7, despite you letting off the throttle. Perhaps check your BPV/BOV. Regardless, I think you're engine is being flooded by a premature transition into OL, which is triggered by the spike in Calc Load. EDIT: I just noticed from your WOT pull that you're running a high level of boost (>20PSI). That boost spike may not be due to a problem with your BPV/BOV, but when you hit 14PSI in row 7, this is due to your calc load jumping up to 134. When your car targets higher calc loads (and therefore tq), it demands boost to reach those targets. This could be a combination of your calc load, and your boost targets in higher gears. I'm telling you guys, this is directly related to calc load, and triggering OL prematurely.
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 03-31-2010 at 09:02 PM. | |
![]() | | #335 | ![]() |
CL values and all my delays are stock right now... Considering the ONLY time I can get this to happen is when my WG is unplugged, I think it's more of a boost causing a load/fuel increase rather than the other way around... On a positive note, this tune is actually really smooth 99% of the time and I have a LOT of room to work with under the load cap, so when I get my exhaust free'd up(hopefully this weekend) then I'll tune for 23 pounds(any be able to hold it a lot longer) then turn it up to 26 ish once I can get fuel pressure up, and still be under the cap...
![]() | | #336 | ![]() |
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 | |
![]() | | #337 | ![]() |
I originally had it unplugged for a different test, but then unplugged it again so I could get a log of this issue, since nobody believes it could be wg related. I see exactly what your saying, and what I'm saying is all of my max tables, and exit delays are stock in this map, and I believe it's the wg causing a boost spike, which in turn causes a load spike which needs more fuel and less timing... New wg goes on this weekend with some other goodies, so I can actually tune with the wg connected lol.
![]() | | #338 | ![]() |
![]() | | #339 | ![]() |
Yea, I'm not worried at all since with the wg plugged in it runs absolutely perfectly... just only hits 17 psi due to wg issues, but very soon that will all be taken care of... and yes this car really makes it tough to troubleshoot. Everything that seems like a mech. issue on any other car turns out to be tuning on this... and then when you finally start thinking everything is a tuning issue... it's mechanical. No win, but I love the challenge!
![]() | | #340 | ![]() |
John @ PTP thinks if i switch to VTA on my BOV it will fix it this issue.
![]() | | #341 | ![]() |
Hmmm, I'm running a forge but I'll pull it apart and make sure it's all good in there...
![]() | | #342 | ![]() |
Groans: 34
Edit: I have noticed a slight “stumble” when I slowly roll into throttle and pass thru the MAF voltage where I cut my MAF down. This is due to a lean condition where the MAF abruptly drops and the fueling is cut accordingly BUT g/s is actually increasing. It is so slight it doesn't even show up as an AFR change in a log. I have promised to IP my MAF around my transition voltages and post the results but work has kept me too busy to do it. ![]() The reality is, in normal driving I never see the anomaly and it is difficult to reproduce anyway.
![]() | | #343 | ![]() |
Yea I remember when I was having that issue as well, and that's gone now since my fueling is more "blended in" This strange though, but if it gets annoying I'll just plug the wg back in and be slow but somehow I don't think it will be annoying enough for me to give up the boost increase lol.
![]() | | #344 | ![]() |
Quick question for you guys. I'm not sure if this is a 'load cap' issue or not.... I don't think so.... Anyways, I flashed a new map that's a bit leaner (from super rich) with some other changes, and my AFR's hit 12.4 in a few spots at WOT. I want to make those a bit richer, but I decided to first re-calibrate my maf, as I had over-scaled 2.5v and up. Here's my quesiton: I did the MAF g/s test, but I was able to do it gradually all the way up to where I hit OL. My LTFT's were -5.6 from about 2.3v all the way up to 3.84v (~170g/s). Can I use the -5.6 for my MAF cal all the way up to 3.84v? The helpfile says to just do it to 2.6v or so. I'd appreciate some advice!
![]() | | #345 | ![]() |
Groans: 34
scale it all the way to the end. help file is wrong or maybe right, depending on where you stand. I think Cobb knows about the load cap and scaling your MAF up gets you closer to the cap if not over it. The way to tell if you are hitting the cap is if logged Load flat lines early in a WOT run and doesn't start to fall until the upper RPMs. You engine is obviously increasing load the entire time in a gradual curve but the ECU can't calc it.
| The Following User Says Thank You to Dano For This Useful Post: | dougefresh_ (04-02-2010) |
![]() | | #346 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Estero, FL
Rep Power: 1294 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 166
Im pretty sure you can use it if you didnt go into OL. anyways....I thought the help file just said to use the same values that you got close to the 2.3v and apply them all the way to the end
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
| The Following User Says Thank You to Blackspeed For This Useful Post: | dougefresh_ (04-02-2010) |
![]() | | #347 | ![]() |
Groans: 79
The reason the helpfile suggest only making adjustments up to that voltage is cause i believe that's where the last LTFT segment stops, or something along those lines. But by all means you can make MAF adjustments anywhere on the curve. And this is exactly what you should do if your experiencing lean conditions at wot, you should increase the maf curve. This simply tells the ecu that there is more air coming in for that sensor voltage, and that it needs to add more fuel. It will work perfectly until you do hit a calc load cap. At that point you can increase the maf curve to 1000 and it will make no difference at all.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | dougefresh_ (04-02-2010) |
![]() | | #348 | ![]() |
Groans: 34
been so long since I read the file I don't remmember exactly what it said. LOL back then my ECU didn't do anything I told it to so I threw the help file out the window and started hacking on that bitch on my own. hahahahaha amen to what DJ said!
Last edited by Dano; 04-02-2010 at 08:24 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (04-02-2010) |
![]() | | #349 | ![]() |
ALSO, for the first time ever... I hit OL at a calc load under 200. OL IS dictated by my MAF g/s and not calc load over 200 for me. I rechecked a bunch of prior logs, and it switches to OL when the g/s hit 170g/s. This is what you guys have been saying all along! Totally my bad. It was just that every time I hit OL before, it was during WOT runs and therefore higher calc loads (in WOT it just happens to be calc load hit 200). But comparing my WOT runs to this "gradual throttle" MAF g/s test, I saw (for the first time) OL occurs at ~170g/s. Today that happened at a calc load of ~147 and ~167 because it was a lighter throttle increase (and loads). So, cacl load has nothing to do with it. I was just fooled by my consistent calc load of 200 because I was always in WOT there when g/s breached 170 g/s. So, I take back the calc load business = OL, and reiterate, that I was WRONG!! I'm glad I did the MAF test again though up to OL, because that def supports what you guys were saying.
![]() | | #350 | ![]() |
Groans: 34
I don't know if I agree with your thinking. There are no tables [in ATR at least] that would indicate that the transition is based on MAF g/s. There are of course many that indicate it is based on Throtle and or load.
![]() | | #351 | ![]() |
Groans: 166
So, are the CL table changes you made according to Dano's pdf still working like you thought? I made these changes last night and flashed it, so I just want to make sure.
![]() | | #352 | ![]() |
EDIT: Another MAF g/s test that has my LTFT's up to 3.8v attached PS: I've seen my Calc Load as high as 225 EDIT 2: I just applied the MAF changes, and added 2% more fuel after towards the tail end of the MAF curve. I also made my both my Part throttle/OL fuel tables 1% richer as I was sick of seeing my AFR's jump to the mid 15's at dip in. I know that'll affect fuel economy a bit, but I don't care. I'm not sure how much if any power loss that'll make, but I want to see it it will drop my AFRs at dip in. Thanks for you input, and I hope you can figure out what's going on w/ the LTFT's up to 3.8v. Peace
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 04-02-2010 at 10:34 AM. | ||
![]() | | #353 | ![]() |
I'm pretty psyched about this!! EDIT:Where it's a bit lean and says "what you said about shift issue here" was meant for Forzda, lol. I wanted to post this over here though in case you guys wanted to try it, or hit OL a row before your FT's zero. I think there may be other tuning applications here, but I gotta get some work done! EDIT: Came up with another half-baked "theory" that explains why this worked.
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 04-02-2010 at 07:42 PM. | |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | Blackspeed (04-02-2010) |
![]() | | #354 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008 Location: Santa Cruz, California
Rep Power: 1719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,785
Groans: 754
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Welcome to the club of........... Thinking you have stuff figured out with the ECU......... and then realizing you have nothing figured out and almost everything you thought you had figured... was BS. There are many members of that club here me included.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
| The Following User Says Thank You to FreeFlyFreak For This Useful Post: | dougefresh_ (04-03-2010) |
![]() | | #355 | ![]() |
Groans: 34
exactly, I think there are actually two "flashable" areas within the ECU and IT swaps them out randomly. So you get one tuned the way you want...it works great for a few runs then WHAM! ECU goes skitzo and swaps to the other one. you tune that one and ...well, you get the pic hahahahahaha
![]() | | #356 | ![]() |
![]() Join Date: Mar 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 456
Very nice. And you were incredulous that I (partially) blamed the part throttle OL tables. :P (directed at doug mind you)
__________________ '06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout. |
| The Following 2 Users Say Thank You to Smoker6 For This Useful Post: | Dano (04-02-2010), dougefresh_ (04-02-2010) |
![]() | | #357 | ![]() |
Groans: 34
hahahaha all I know now is my shit is running FAST & safe due to the changes in post #1. I don't have enough experience to say much more than that. If I was a dick about this in the past...I am truely sorry LOL
![]() | | #358 | ![]() |
All I know is that I'm fucked now. We went out for a while earlier, and I did some WOT pulls in the process... including a full 2-3 to redline. I was looking forward to the checking out the logs, but when I pulled in, I saw the screen was all black. I was like, Hmmm the cord must've popped out. Well, it didn't. My AP SHIT THE BED TONIGHT!! For no good reason. It won't turn on when I plug it into my laptop. It just happened between my last stop to grab a few brews, and home. I'm glad those first logs look healthy, because I'm driving now until Cobb fixes this thing. Oh, and I saw a decent accident in my rear view mirror on the way home, two cars behind me at a red light. Some moron switched lanes right into this dude pretty hard. I was on the gas getting the FO before more idiots piled in, lol. Bummed about the AP though, and more so that the great WOT pull data that was on there
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 04-02-2010 at 06:34 PM. | ||
![]() | | #359 | ![]() |
![]() Join Date: May 2009 Location: Toledo, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
__________________ ToledoSpeed3 ![]() 09 MazdaSpeed3 GT, True Red | |
![]() | | #360 | ![]() |
Hey Douge, Here are a few logs I just took on the map I sent you. You can run the comparisons on these vs your logs/map and see the differences. I REALLY like this map and have no plans to make any changes until the BNR turbo and DNP go in.
| The Following User Says Thank You to FORZDA 1 For This Useful Post: | dougefresh_ (04-03-2010) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f418/ecu-load-cap-shattered-49009/ | ||||
| VersaTune • View topic - 3 BAR MAP | This thread | Refback | 05-08-2010 12:18 PM | |
| MS3/ATR: ECU Max Load clipping/scaling | This thread | Refback | 02-16-2010 04:34 PM | |
| Load Tables | Dano | Cobb ATR Support | 17 | 01-20-2010 11:25 AM |
| ATR AP load change? | LiEast | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 10-17-2009 02:10 PM |
| Max Load C | djuosnteisn | Cobb ATR Support | 5 | 07-11-2009 09:57 PM |
| What is this load cut? | gsrtype1 | MazdaSpeed 3/6 - ECU Computer Tuning | 90 | 06-23-2009 08:36 AM |
| LOAD!!! | superskaterxes | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 01-14-2009 02:59 PM |
