> Cobb Tuning >
Cobb ATR Support
Notices
 Old 05-16-2010, 06:41 PM   #201
kalix's Avatar
Posts: 73   (View Stats)
kalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to beholdkalix is a splendid one to behold
Default Changed the APP
Ok I have about 25 miles on the moddified map, so far my initial impression is that I like the urgency of the engine, I know it's not faster, but it feels faster and more "turbo" like. Which is good IMO, I know with the throttle fix, it made the car feel more N/A-like. But with this APP tuned, the car feels more ready to go. BTW, since the APP was changed, does this mean more load is being requested?
For anyone reading this that just started learning ATR: So far I've tuned only the Stg 1 +SF 91 OTS map and tuned the Throttle Request Load A & C. Tuned my MAF and now my APP. I LOVE ATR and my AP.
I'll try to post some logs soon!
2oo8 Black Mica Mazdaspeed 3. CPE Nano - COBB TIP - COBB AP (Stage 1 +SF/91/Throttle Fix) - Custom fabricated TMIC heat shield - Denso ITV22s - CPE RMM - Shifter Bushings - HID Custom Kit (I can't remember the name ) - Custom "hidden behind the back seat" Strut bar - Soon to be installed: HPS Front Brakes - Future planned mods: FMIC/DP/COBB Springs/Lighter Wheels (ENKEI RPF1?)
kalix is offline   Reply With Quote
The Following User Says Thank You to kalix For This Useful Post:
ToledoSpeed3 (05-17-2010)
 Old 05-17-2010, 05:48 AM   #202
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
Thanks for the feedback kalix, glad you like it. The only thing my APP Translation table tweaks really do is that now you don't have to push the pedal quite as far to request more load. You are still following the same "smoothed" load tables, but it now "feels" more peppy because not as much pedal is required to get it going off the line. If you look at the stock TRL tables compared to the ones in post 1, the stock table is a bit more agressive down low (more load is requested) up until a throttle position of ~43%. During light acceleration at partial throttle, the car feels more dead than stock when using the same amount of pedal. The APP changes I did are simply compensating for this. Some like the heavier pedal feel, but I wanted it to be a little less heavy. My wife used to have a Jetta 1.8t wagon and I loved how responsive that little engine felt off the line during casual driving. I wanted it to feel more like that. For me, these 2 changes make everyday driving more enjoyable.
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline   Reply With Quote
 Old 06-30-2010, 02:50 PM   #203
KayWhy's Avatar
Posts: 289   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
With the new 1.07 i noticed that the abs load for a and c have changed where the max load is 1.99 Should i still follow the 2.50 scale as listed in the opp or drop it? The 1.07 maps are yet again jerky as hell
KayWhy is offline   Reply With Quote
 Old 06-30-2010, 04:47 PM   #204
aaronc7's Avatar
Posts: 7,054   (View Stats)
Groans: 357
Groaned at 151 Times in 125 Posts
should be fine the way it's always done. once u get that high into load, you'd be in open loop anyway. this fix is more about fixing/changing throttle response in the closed loop/part throttle region
'99 Miata | engine delete mod | GTX2867R | ARTech exhaust | Tein Flex 9/6 kg | C3M 15x9 225/45 RS3 | DIYPNP
The Following User Says Thank You to aaronc7 For This Useful Post:
mr_mazda329 (07-27-2010)
 Old 07-01-2010, 09:31 PM   #205
KayWhy's Avatar
crap i just realized, the 09s change a and b. That means C is the ABS ? ? ? If that's the case why does normal A and C match and B is the odd one out?
 Old 07-01-2010, 09:40 PM   #206
aaronc7's Avatar
Groans: 357
we don't really know-limp mode?. but yes. its A and B for 09
 Old 07-01-2010, 09:44 PM   #207
KayWhy's Avatar
Alright so change A and B got it. thanks for the help
 Old 07-16-2010, 10:12 AM   #208
Ziggo's Avatar
Posts: 3,090   (View Stats)
I used Freefly's table and it worked out great, I think this should be done before you try to calibrate your MAF, it would have made getting a smooth MAF curve much easier
Ask Me About My:
Ziggo is online now   Reply With Quote
 Old 07-19-2010, 08:49 AM   #209
Nliiitend1's Avatar
Posts: 3,837   (View Stats)
Groans: 59
Originally Posted by FreeFlyFreak View Post
The best map I have tried and it is fantastic is a combo of my base map 91 Stage1+
with the following changes.
The throttle smoothing posted by Aaronc7 from one of the Stage 2 maps in this thread.
And the tweaks to Boost and throttle DBW tables posted by fjames here:
http://www.mazdaspeedforums.org/foru...-response.html Post 1 Boost change, post 24 Throttle DBW change.
I would recommend this combo of changes for anyone to try.
It is my favorite map by far, it basically drives/responds like stock, but more powerful, and pulls all the way to redline.
My thanks goes out to Aaronc7 and fjames for posting these tweaks.
It took me a while to come across/notice this post, but I put together a map like the one you describe here this past weekend (with, of course, a calibrated MAF curve - and also the "closed loop" fixes that have been posted elsewhere), and it's my new "favorite" as well.
I was previously using the aaronc7/dread (aaronc7's linear throttle changes + dreads app changes) combo, and the "new" combo is noticeably smoother at part throttle with less of a "dead/laggy" feeling immediately following shifts and without any noticeable loss in power.
I love it!
Kudos to all you guys that are putting in the work to find solid workable solutions to some the "persnickety" problems that plague the the OTS maps!
Stance is not a verb.
Nliiitend1 is online now   Reply With Quote
 Old 07-19-2010, 12:34 PM   #210
SJP0tato's Avatar
Posts: 298   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
I had skimmed this post in the past, but finally today got time to read & understand the whole thing. I've decided to try out a combo of aaronc7's TRL and ToledoSpeed3's settings:
aaronc TRL A/C:
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
0.64	0.46	0.34	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19	0.19
0.67	0.68	0.61	0.38	0.38	0.38	0.38	0.38	0.38	0.38	0.38	0.38	0.38	0.38	0.38
0.68	0.77	0.80	0.58	0.58	0.58	0.58	0.58	0.58	0.58	0.58	0.58	0.58	0.58	0.58
0.69	0.80	0.90	0.77	0.77	0.77	0.77	0.77	0.77	0.77	0.77	0.77	0.77	0.77	0.77
0.69	0.81	0.94	0.96	0.96	0.96	0.96	0.96	0.96	0.96	0.96	0.96	0.96	0.96	0.96
0.70	0.82	0.95	1.15	1.15	1.15	1.15	1.15	1.15	1.15	1.15	1.15	1.15	1.15	1.15
0.70	0.83	0.96	1.35	1.35	1.35	1.35	1.35	1.35	1.35	1.35	1.35	1.35	1.35	1.35
0.70	0.82	0.97	1.54	1.54	1.54	1.54	1.54	1.54	1.54	1.54	1.54	1.54	1.54	1.54
0.70	0.83	0.97	1.73	1.73	1.73	1.73	1.73	1.73	1.73	1.73	1.73	1.73	1.73	1.73
0.70	0.83	0.97	1.92	1.92	1.92	1.92	1.92	1.92	1.92	1.92	1.92	1.92	1.92	1.92
0.70	0.83	0.97	2.12	2.12	2.12	2.12	2.12	2.12	2.12	2.12	2.12	2.12	2.12	2.12
0.70	0.83	0.97	2.31	2.31	2.31	2.31	2.31	2.31	2.31	2.31	2.31	2.31	2.31	2.31
0.70	0.83	0.97	2.50	2.50	2.50	2.50	2.50	2.50	2.50	2.50	2.50	2.50	2.50	2.50
ToledoSpeed3 APP translation values:
1st gear:
Code:
0.00	0.27	0.69	1.80	3.48	4.81	6.42	8.03	9.63	11.24	12.84	14.44	16.50	18.37	20.47	22.50	27.50	30.98	34.98	38.16	41.34	43.46	46.01	48.15	50.29	52.43	54.57	56.71	60.99	77.04	100.00
2nd - 6th gears:
Code:
0.00	0.25	0.75	1.78	3.35	4.75	6.25	7.75	9.50	11.00	12.70	14.50	16.00	17.70	19.50	21.50	25.50	29.50	33.75	37.00	40.00	43.00	46.00	49.00	52.00	57.00	62.50	69.00	75.00	87.92	100.00
I'm going to try this out & report back. I wanted to consolidate everything in one post for anyone who wants to try it out without going through all the posts and having to mix & match to put it together.
Edit:
Well, this pretty much cleared up all my "issues" with the part throttle oddities I've had with the car since I bought it 8 months ago. I spent the first 2-3 months trying to figure out what the ecu was doing, because smooth up/down shifts were tough. This fixes the "bubble" as I thought of it, where about 20% into the throttle suddenly there's a bubble of power, and you have to just nudge into it for part throttle operation.
I'm going to guess this would help with gas mileage too, I often would see 95-99% wastegate duty cycle at 18-25% throttle which is ridiculous IMHO. Now the car properly responds as all the cable driven throttles I've driven over the past 15 years. It's actually possible to drive under the spool of the turbo now, I'm guessing the aim of the stock tables was to keep the turbo spooled under almost all conditions for lag/response issues most people that have never driven a turbo'd car might have.
The only downside is I have to un-learn the odd stock behavior, and get re-accustomed to proper throttle response.
Thanks guys!
SJP0tato is offline   Reply With Quote
The Following 3 Users Say Thank You to SJP0tato For This Useful Post:
posty (06-30-2011), R.MS3 (07-24-2010), Z3roFlaw (06-20-2011)
 Old 06-05-2011, 07:30 AM   #211
rorys speed's Avatar
Posts: 92   (View Stats)
rorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud ofrorys speed has much to be proud of
Groaned at 11 Times in 3 Posts
Ok.. I just want to give respect to all of the guys who are trying to make the MS3 better, because it seems everyday someone is adding to the list of things that can be done to our cars to make them perform better in someway. My question is, I wanted to see if someone could send me a really good map to try out. I am not the best when it comes to changing #'s on the AP. This is my daily driver and with 2 kids and a mortgage keeping my car drivable is important in my wife's eyes lol. I have done a bit to the car, Upgraded TMIC, cobb SRI, Catless TB exhaust, rear motor mount, tranny mount, up graded fuel internals, cobb TIP and turbo smart BPV (and obviously the AP). I live in VA so I have been using the 93 oct TMIC SRI map. Any help or recommendations would be awesome! Thanks!
rorys speed is offline   Reply With Quote
 Old 06-06-2011, 03:27 PM   #212
Nliiitend1's Avatar
Groans: 59
Start reading.
HOW TO CALIBRATE YOUR MAF! With An Example
Got the Cobb AP
http://www.mazdaspeedforums.org/foru...l-stuff-68239/
...and much much more.
 Old 06-20-2011, 09:44 PM   #213
Z3roFlaw's Avatar
Posts: 64   (View Stats)
Z3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the worldZ3roFlaw is the leader of the world
aaronc TRL A/C:
Code:
1st gear:
Code:
2nd - 6th gears:
Code:
Edit:
Thanks guys!
Thanks for consolidating this info into one post! I was also suffering from a jerky throttle response, but after changing the TRL and APP tables with the values listed above, that has all been cleared up and the throttle response is much more evenly spread out amongst the RPM band. Thank you all for the awesome sticky!
AP - Church Pro Tune Dynapack 317HP & 332lbft| AEM CAI | HKS SSQV III BPV | COBB TIP | ETS 3.25" TMIC | HKS Hi-Power Exhaust | CS Racepipe | SU Silicone Boost Tube Kit
SURE Recirculation Tube | SURE Countershift | SURE Anchors | DENSO ITV-22 .28 Plugs | Autotech HPFP Internals | SURE Torq R3 RMM | DRAG DR-33 18X7.55 | GOODYEAR: EAGLE F1 A/S-C 215/45
Z3roFlaw is offline   Reply With Quote
 Old 06-22-2011, 05:26 PM   #214
friscoplayrsf's Avatar
Posts: 71   (View Stats)
friscoplayrsf will become famous soon enoughfriscoplayrsf will become famous soon enough
Worked well for me too. Just need to tune my load to hit boost targets now.
friscoplayrsf is offline   Reply With Quote
 Old 06-23-2011, 01:25 PM   #215
super_pablo_'s Avatar
Posts: 1,605   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
^^or just do some boost based tuning
super_pablo_ is offline   Reply With Quote
 Old 06-26-2011, 06:12 PM   #216
Can we use these throttle tables with boost based tuning
 Old 06-26-2011, 06:47 PM   #217
Z3roFlaw's Avatar
That is actually a good question. I recently switched maps to a beta BT map.
Another question. Does the TRL and APP adjustments carry over between flashes? I adjusted these tables when running a stage 1 tune, saved the changes and reflashed. After ow loading COBBs beta BT tune, I opened it up in ATR to just take a peek at various settings and I noticed that the BT tune map didn't make any changes to the TRL and APP tables. I thought that changing these tables to a map made them specific to that map. Am I wrong or even possibly seeing things lol!?
 Old 06-26-2011, 07:23 PM   #218
R.MS3's Avatar
Posts: 983   (View Stats)
What? Each map is its OWN file, so if you flash another map how do you expect to carry the changes you did to ANOTHER map?
Back when i was tuning the changes made to the TRL A/C tables DID have an impact on throttle response. Just put the "combo" you like the best in there, along with any APP changes, and you should feel the change.
The reason it still works is because it changes the lower load levels of that table, so the ECU still targets them. Most of the changes on a boost-based map are on the upper levels of load.
R.MS3 is online now   Reply With Quote
 Old 08-12-2011, 08:51 PM   #219
kunfu's Avatar
Posts: 474   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
So whats the consensus on this? Are these fixes helpful and suitable with newest boost based maps?
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 09-06-2011, 03:44 PM   #220
Enki's Avatar
Posts: 2,989   (View Stats)
Enki has disabled reputation
Groans: 103
Groaned at 21 Times in 19 Posts
At this moment, I use the following for all gears and neutral, and it seems to make drivability much nicer (even with OTS DBW Throttle tables):
Code:
0.00	0.25	0.50	1.50	3.00	4.50	6.00	7.00	8.00	9.00	10.00	11.00	12.00	13.00	14.00	15.00	20.00	25.00	30.00	35.00	40.00	45.00	50.00	57.50	65.00	75.00	84.00	87.50	90.00	95.00	100.00
It's basically a three stage mapping with a desensitized low end, aggressive mid end and less aggressive top end. I find it very easy to blip the throttle for rev matching when coming down in gears at lower RPMs.
Enki is online now   Reply With Quote
 Old 02-03-2012, 08:59 AM   #221
jamesr242's Avatar
Posts: 332   (View Stats)
jamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the world
Does anybody know how to fix this with a boost based tune (I'm Gen 2)? I'm using the Stage 2 CPE CAI, IC, TIH map and it has essentially the same table posted here. I am really not liking the part throttle response. For example, I'll be boosting part throttle at 3 psi and move the pedal a millimeter and it jumps to 8 psi. For a DD, I would like more controllable boost. Any ideas?
2011 Liquid Silver w/Tech: CP-e CAI, Ultimate Racing Downpipe + Test Pipe, CP-e TMIC, HTP Inlet Pipe, Cobb Accessport, Autotech Internals, JBR Shifter Bushings/EGR Block Off/Rear Sway, H&R Springs, SPC Rear Camber
2000 Miata LS, I haz da gaiz
2004 Honda VFR800, got mad VTEC yo
jamesr242 is online now   Reply With Quote
 Old 02-03-2012, 09:07 AM   #222
rfinkle2's Avatar
Posts: 12,563   (View Stats)
Groans: 235
Do you have a copy of Access Tuner Race?
Are you thinking of getting a custom tune, or going to modify your map yourself?
Either way, you can request a copy of ATR here... You will need it regardless of whether or not you make adjustments yourself, or have a custom tune made for you.
Cobb Tuning
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
 Old 02-03-2012, 01:46 PM   #223
jamesr242's Avatar
Cobb Tuning
Thanks for the response. I have ATR. I'm not really sure if I am going to get a custom tune. I'm not trying to squeeze every last HP out of this engine so I might be satisfied with the OTS provided I can get rid of the jerkyness. I am hoping this is a somewhat easy fix that I can do myself because I have little ATR skills. If it involves changing lots of parameters then I will probably go with an e-tune to get smoothness and some more powah
 Old 02-03-2012, 02:25 PM   #224
rfinkle2's Avatar
Groans: 235
Without sacrificing reliability, one of the "teams" would be able to get you quite a few more hp and tq, and cater to your specific driving habits.
It seems all of the "teams" are really helpful, and will listen to how you want your car set-up from cruising around town to wot.
That being said, I think the table that will help your jerkiness is an easy temporary fix.
By jerkiness, you feel there is a very small amount of pedal modulation needed to induce a lot of boost (I saw your 2psi to 8psi post)?
If you can post a screenshot of the wgdc table in your map, I can suggest some tweaks that may help.
 Old 02-03-2012, 03:55 PM   #225
jamesr242's Avatar
This is exactly what I mean; a little pedal movement equals lots more boost. Basically it's not very linear and hard to control precisely. This map is the unmodified Stage 2 CPE CAI, IC, TIH map (with one round of MAF cal). What you think of this? The graph looks crazy, lol
 Old 02-03-2012, 05:16 PM   #226
rfinkle2's Avatar
Groans: 235
Give this a try:
-populate the 50% throttle position with a value of 5 (5's in each column) from 2500 rpm to redline. (note: this will include making above 50% throttle position 0 in the 5000 rpm to redline 0).
-highlight from 75% throttle position up to the 50% throttle position (again from 2500 - redline) and once highlighted, press "v".
Resave the map, flash it and lmk how the throttle feels.
EDIT: Note: also changed 120 values to 100 for consistency
jamesr242 (02-04-2012)
 Old 02-03-2012, 08:38 PM   #227
Enki's Avatar
Groans: 103
This issue can also be caused by an improper MAF calibration (like for E85 mixes and/or boost/vac leaks) skewing the load values.
rfinkle2 (02-04-2012)
 Old 02-04-2012, 02:01 PM   #228
jamesr242's Avatar
Thanks, I loaded up that table. Just gotta break the map in a little before I can test it out.
The Following User Says Thank You to jamesr242 For This Useful Post:
 Old 02-08-2012, 07:38 AM   #229
jamesr242's Avatar
The boost definitely comes on smoother with this table, thanks. I'm wondering though if that WGDC can't be spread across the lower APP's. I find it somewhat annoying that you don't really get any boost until you hit 50% APP. Could I spread that out to 31 APP or maybe 37 to make it more controllable? Would I have to start changing my boost targets at that point?
 Old 02-08-2012, 07:43 AM   #230
rfinkle2's Avatar
Groans: 235
You could definitely spread the table up some. You would use the same logic, move the 5 up by a few rows, vertically interpolate from the 75% throttle position and see how it goes.
I don't like a lot of part throttle boost, but some guys do.
That is the beauty of ATR... customizing the way your car drives the way you'd like it to.
Keep an eye on the boost targets table as well, because it is set to achieve positive gauge pressure @ the 50% APP position...
jamesr242 (02-08-2012)
 Old 05-22-2012, 06:32 PM   #231
jwright32's Avatar
Posts: 86   (View Stats)
jwright32 is just really nicejwright32 is just really nicejwright32 is just really nicejwright32 is just really nice
Default app translation values question
I am trying to work on smoothing out some jerkiness in my OTS cp-n stage 1 (91) map. Seems other have had some luck with this by smoothing the app translation values for each gear. My question is, how do you get that many cells. Looking at my map on atr, i only count 20 cells for each gear. Toledospeed3's setting include 31 numbers, What am i missing on how to be able to input that many variables, or is this something that has changed in the program since this was posted?
aaronc TRL A/C:
Code:
1st gear:
Code:
2nd - 6th gears:
Code:
Edit:
Thanks guys!
-- 2010 Celestial Blue Mazda Speed3 -- Cobb AP, CP-E Nano SRI ,18x8.5-e48 Rota G-Force [Hankook V12 Evo 245/40/18], Sure Motorsports Shifter Busings, JBR 80a RMM, JBR SSP, DDM 35w 6000k HID Lows/ 35w 3000k Fogs, UR Testpipe, Res. Delete, TWM M1 Abrams shift knob
jwright32 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f418/fixing-jerky-throttle-response-atr-26456/
Catless DP Tune This thread Refback 11-20-2010 08:05 AM
MS3 vs. MS6 vs. CX7 engine failure - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 02-28-2010 09:07 AM
MS3 vs. MS6 vs. CX7 engine failure - Mazda6 / Atenza This thread Refback 11-20-2009 12:20 PM
MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 This thread Refback 05-29-2009 07:35 AM
MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 This thread Refback 05-23-2009 05:19 AM
Jerky part throttle acceleration dread
Cobb ATR Support
38 04-25-2009 08:19 AM
car feels jerky in 5 and 6 Tcman2006 MazdaSpeed 3/6 - Turbo Induction 30 03-08-2009 01:15 PM
fixing my broken used MS3 Boonestafa MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 02-25-2009 08:19 PM
The HKS CORPORATE response to the HKS SSQ BOV clown_car MazdaSpeed 3/6 - Turbo Induction 5 01-30-2009 08:02 PM
Whats the problem? (Car jerky while in boost) MattJackson86 MazdaSpeed 3 - Engine, Transmission & Driveline 14 12-24-2008 10:20 AM
Page generated in 0.55916 seconds with 37 queries
