![]() | | #1 | ![]() |
![]() Join Date: Jul 2009 Location: Boston, MA
Rep Power: 2864 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,403
(Thread Starter) | Neutral : +2 score You probably want to download the excel file below, so you can follow what I'm talking about. Ok, I'll assume you understand everything except how exactly to do perform the MAF g/s test and make the changes to your MAF tables (A & B). If you don't, see post #49 on p. 2 where I break it down a bit. The only thing you need to log is MAF g/s, MAF volts, and LTFTs. Start in 2nd @ 1,500 rpms (like 5 mph or so), and SLOWLY accelerate (Have your AP set to MAF g/s on the display) until you hit over 100 g/s. I usually do it up to 130 g/s or whatever until I run out of gear, but it doesn't really matter over 100 (that's the last breakpoint iirc). You may find it takes several tries to do this smoothly before "runing out of gear" lol. It's not that hard, but you'll see what I mean. So, now you should see you're LTFT's following a "pattern"... As you look at how the MAF g/s increase on your datalaog, you''ll see different 'blocks' of fuel trims (color coded in excel file) across different MAF voltages (theres's 5 breakbpoints... re-read that section in the helpfile, it's Step 2). I attached an old MAF g/s test I did to calibrate my MAF in the past. This isn't a great one, but you should be able to follow and understand it. The top part in yellow... my LTFT's are +2.18 for voltages between about 1.32 and 1.74 volts (we'll see a little 'problem' here, but that's good because it'll happen to you too.. we'll get to later). Next is Orange.... LTFT's are +5.3 for voltages between about 1.55 and 2.17 Next is Light blue... LTFT's are +2.18 for voltages between about 2.24-2.37 Last = blue.. LTFT's are +1.4 from 2.4 volts to the end for the most part. -------------------------------------------------------------------------------- So, in my case as all the numbers are positive, that means my car is ADDING that percent of fuel and those given MAF voltage ranges we just figured out by doing the MAF g/s test. So, now you open the MAF table A, and highlight the cells that correspond to these, and adjust. For example: The minor issue I was saying earlier was that "oh no! there's overlap!!" with the top yellow volts.. I wouldn't worry about this. Notice my foot wasn't on the gas at the beginning... Instead of using that FIRST +2.18 from 1.32-1.74, I would just use it to 1.54 volts. So open your MAF cal table A, and here's what you do: 1. Highlight MAF volts 1.33 through 1.55, Press the "M" key (mulitipler) and type in 1.02 (for the 2.18% you're adding). You can also click in cell for 1.33 volts and then shift click into the cell for the 1.55 volts, and it will select all the values in between. You can also copy and past like excel (and to and from excel) just FYI. 2. Highlight volts 1.56 to 2.17 volts (or whatever the closest one is), press "M" and enter 1.05 (for the 5% fuel it has been adding). 3. Hihghlight volts 2.24- 2.37, press "M" and enter 1.02 4. Volts 2.4 and up, press "M" and enter 1.01 (because we only need 1% more here) Now, if some of your fuel trims are negative, you simply subtract the %LTFT from 100, and use that as your multiplier. That is, if your LTFT is -3% for a certain MAF voltage range, you simply highlight those cells as above, press "M" and enter 0.97 so it pulls 3% of fuel. FINALLY, now that you have made all the changes to MAF table "A", simply copy and paste them into MAF table "B." To do this, click in the far left cell of MAF table A (0 volts), and then scroll all the way to the right side (5.0 volts or whatever) and hold SHIFT, and then click in the last cell on the right. That will highlight the whole area (works the same elsewhere in ATR). Now hit "CTRL + C" to copy the entire set of values, and then click in the MAF B table, click 0 volts, scroll all the way to the right, and shift-click the last cell as before to highlight the entire MAF B table, and hit "CTRL + V". That will past the values you copied from MAF table A into MAF table B. Check to make sure the values are the same before moving on (just to make sure you copied it right the first time). IIRC, I don't think the helpfile mentions these "short cuts." I haven't done mine in while, but I'm kinda anal about it. I'll do like 4 MAF g/s tests and try to eliminate any "cross over"... different LTFT's in the same voltages from 2 separate logs, etc. I'm rusty as hell though! I calibrated my old map like 3 times, and I had all my LTFT's within 1.6! They wre 0 just about everywhere, except one "breakpoint" but it was already so good, I didn't want to mess with it. I hope you find this helpful. I wanted to add a discussion of fuel trims, what they are and what they mean, but I haven't had a chance. EDIT: Brief overview of the MAF, Fuel Trims, and the MAF calibration is in post #49 on page 2. -------------------------------------------------------------------------------------------------------- PART 2: Calibrating Your WOT afrs. ***Be sure to do step 1 above first and make sure you understand it***. Now read Step 4 of the Helpfile, which is right here, verbatim:
I was running a bit rich (wot afrs around 11.3 with a commanded afr of 11.7), so I had to adjust my maf. I had also previously added 3% fuel to the upper portion of my maf cal when I went BT just to be safe. Now, just to be clear there are two ways to pull fuel if your wot afrs are rich (lower # than your commanded afrs in your OL/WOT No Knock Table A). The WRONG way would be to pull fuel from your ol/wot no knock a fuel table. Don't do that. The correct way is under Cobb's step 4 of the Helpfile which is "establishing proper, safe fuel curves," copied and pasted above in quotes. All you need to do is compare your actual afrs to commanded, and apply the correction as follows: Actual Afrs/Commanded AFRs and take that decimal and apply it to corresponding maf volts. I attached the two logs in one additional excel file named "How to Cal Wot AFRs Meth" I used to do this for people to see. I know you need clean pulls with no kr but there's barely any kr in the first log (1st sheet), and the afrs were consistent to what I have seen previously with no kr, so my ecu wasn't dumping a lot of fuel. Plus my command afrs are only 11.7 to begin with, which is very conservative while running meth (50/50 mix). Note I just added a column for my commanded wot afrs of 11.7 (from 2.5K to redline) and dragged it all the way down. I then added another column called MAF ADJ as seen in thte log (for Maf Adjustment), and entered in a simple formula that divided my Acutal AFRs (AFRs column) by my Commanded values of 11.7 (OL/WOT NO Knock A), and dragged that formula down. And viola, I have all the correction factors I need in that column. Now I just looked at the corresponding voltages, pressed the "M" key and entered in the corresponding decimal. Now, if you were lean instead of rich, you will end up with decimals greater than one, which means you are getting more air in, and by using the multitplier "M" key and multiplying but a number > 1 that will let the ecu know there's more air coming in (which is why you were a bit lean), and it will add more fuel, and you should be good to go. It's just the opposite of my example here as I was running a bit rich. MAKE SURE BOTH YOUR LTFTs and STFTs are -.16 and you are in open loop when you got wot before you start adding fuel. You'll be adding fuel to the wrong table, which you shouldn't be doing anyways if that's the case. That is a discussion for other threads so search and you'll find some good ones. Also, pay no attention to where I blocked certain things off.. it was just so I could keep easier track of what volts I was adjusting as I moved up the maf calibration in ATR. Finally, don't forget to copy and paste Maf Table A into Table B when you're done. GL
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 06-26-2011 at 02:01 PM. | |
| The Following 124 Users Say Thank You to dougefresh_ For This Useful Post: | 09speedaddict (10-03-2011), 5doorsoffury (09-07-2012), 801MS3 (07-15-2010), Addikted To Boost (07-14-2010), AJ713 (12-31-2010), ak_spray (02-20-2012), alien_sporez (05-23-2012), awdfun (04-24-2011), AZSPEED3 (08-04-2010), bayarea_pat (03-08-2011), BeeZaa (06-23-2011), bertrand_CX_7 (06-05-2011), BloodySpeed3 (03-01-2013), Boosten Ya(josh) (03-30-2011), Breakdown81 (12-23-2010), Broxer (03-12-2011), Caldazar (07-03-2010), Cataphract_40 (05-29-2011), cbusby (06-08-2011), cfdp (11-23-2010), dachtler (06-16-2011), Dash08 (06-06-2012), Dawgbizkitz (04-22-2011), Decepticon (02-20-2012), DingoDave (07-28-2012), djthom (05-30-2011), Docnox (07-04-2011), DownSideFX (01-31-2012), DuoofDeath1 (12-14-2012), ELiTeNeSs (10-20-2011), eljefe62 (01-06-2013), Elusivellama (03-24-2012), Enki (10-16-2011), Eric28243 (05-31-2011), FistPump20fo7 (12-30-2011), flyrevs2 (07-14-2010), forcedinduktion (03-08-2013), franz (09-14-2011), Frequentflyer (06-30-2010), FridayGt (04-29-2011), Ginger Manchu (12-08-2011), Haltech (07-15-2010), harryclay (01-26-2012), hartlch (05-24-2012), hnda etr (06-27-2011), I<3Groceries (07-13-2010), IMASA (06-26-2011), indianaryan (03-26-2011), JacksonMS30 (07-29-2010), JasonMzdSpd3 (03-28-2012), jax ms3gt (07-20-2010), jeoje (05-22-2012), jmhinkle (03-21-2012), JmkC (07-19-2010), johnredding (07-16-2012), Jon2000 (09-10-2011), JS + MS3 (04-07-2011), justint5387 (01-21-2011), jwilkins88 (11-09-2010), kabobulate (05-05-2011), KayWhy (07-03-2010), keefover (06-19-2011), Keemo577 (03-20-2011), keridil (03-10-2012), kingbird72 (09-08-2012), laxplayermjd (07-11-2010), ljudgeii (04-15-2012), llescaflownell (06-30-2010), LMB77 (07-13-2011), MattJackson86 (05-31-2011), Meder (10-06-2011), meelo88 (06-04-2011), mghtymouse380 (06-19-2011), mike8748 (05-19-2011), misiekwaw (01-18-2012), Mistersix (07-10-2012), mn3kgtvr4 (07-05-2010), mroclimbr (05-13-2011), MS3-44 (09-16-2011), MS3G35 (03-22-2012), MS6FL (05-14-2011), mysleeper6 (08-28-2011), nichall10 (04-15-2011), Night Wolf (06-20-2011), NoTraction (04-26-2012), paveltol (04-12-2013), Pointless (05-13-2012), PoMan (03-07-2012), public enemy #1 (07-30-2012), PunjabiPlaya (06-02-2011), QwkEVO (06-13-2011), redbathtub (09-12-2011), RichieRichness (06-22-2011), richkidone (01-25-2013), rigor (06-30-2011), Rokusek (06-17-2011), sellers (07-14-2010), shadesofgray19 (06-11-2012), Sid3wayS (11-07-2011), skeeter149 (07-15-2010), sLow6 (06-21-2011), Snyeed (07-21-2010), Speed3eak (03-12-2011), SpeedCheese (10-09-2011), Speedn3 (11-27-2010), SPEEDRAC3R (03-10-2011), speedtown (07-14-2010), spnkr21 (04-24-2011), Standsideways (05-19-2012), SweetJP (09-18-2011), Takinato (04-22-2012), The Nut (05-13-2013), thehead (07-07-2011), theschrum (09-14-2011), tomek_46 (12-20-2011), triphop631 (07-29-2011), uncorked11 (11-01-2011), vatordoc (04-02-2011), Vinnie (04-22-2012), volodya84 (05-09-2011), wolly6973 (06-02-2011), xfeejayx (04-22-2011), Z3roFlaw (06-09-2011), zxhoya (01-02-2012) |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 553
| Not Ranked : 0 score
gonna do this today, thank-you for the write up !!!
__________________ Mazdaspeed3 {Blowed Up 7/17/09} Mods: MS-CAI2, Tip, Turbosmart BPV, Cobb AP, Cobb DP, Cobb CBE, CPE HPFP, CPE RMM, PTP Kicker Mount, StealthBox w/ 8" JBL, Alpine 500W Amp, CurbAlert |
| The Following User Says Thank You to flyrevs2 For This Useful Post: | dougefresh_ (07-14-2010) |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
will this work for calibrating larger maf housings?
| The Following User Says Thank You to xcoldricex For This Useful Post: | dougefresh_ (07-14-2010) |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score You're welcome man, I'm glad that helped. After you've done it once, it's really easy (and quick) to do. Just make sure your map is broken in well before you do a maf cal. I don't see how you could calibrate the maf any other way, regardless of maf size. SS Installer said that he's never seen a MAF that didn't have 0-5volts (same as ours), so I think it should be NP. I'd double check w/ someone who is running a larger MAF just to double check, but I'm pretty sure it's the same. I have no experience w/ the larger maf, so I'm not 100% on this.
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 |
![]() | | #5 | ![]() |
Rep Power: 14985 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,866
Groans: 79
You calibrate it the exact same way for a big maf (maf is the same, just diameter of the tube is bigger). But first you have to get the maf curve close enough for the car to idle and run. You do this buy calculating the % increase in AREA of the stock tube to the bigger tube. Here's a quick example (i'm not 100% sure what stock intake size is, cause it's been so long. So i'll use 2.75" for this example): Area of 2.75" intake = pi * r ^ 2 = 23.75 Area of 3.25" intake = pi * r ^ 2 = 33.16 That's an increase of 33.16 / 23.75 = 39% So you'd want to do an initial maf scaling of 1.39 just to get your car running. Then follow the normal maf cal procedure.
__________________ 500awhp 440awtq uncorrected ![]() BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Mounts be popping, and trans be hurting 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 10 Users Say Thank You to djuosnteisn For This Useful Post: | dougefresh_ (07-14-2010), eljefe62 (01-06-2013), FistPump20fo7 (12-30-2011), jmhinkle (03-21-2012), m249saw (06-22-2011), MattJackson86 (05-31-2011), rigor (03-17-2012), Wigster (12-30-2011), xcoldricex (07-14-2010), Ziggo (07-14-2010) |
![]() | | #6 | ![]() |
^Hey thanks DJ. I was going to say to ask you, but I wasn't sure if you had a larger maf or not. I haven't been on here too much lately. I just noticed your sig, and was like wtf? So now I"m gonna venture to the dyno section
| The Following User Says Thank You to dougefresh_ For This Useful Post: | djuosnteisn (07-14-2010) |
![]() | | #7 | ![]() |
Groans: 79
Okay, had a quick sec to look, and I think stock MAF size is 2.62" (66.5mm), so the correct calculation for going to a 3.25" intake is this: Area of stock: pi * (2.62 ^ 2) = 21.55 Area of 3.25": pi * (3.25 ^ 2) = 33.17 % increase = 33.17 / 21.55 = 1.54 So you need to multiply MAF curve by 1.54 to get the car running in first place for 3.25" intake
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #8 | ![]() |
Groans: 105
sweet i think i'll try this on the weekend. thanks dustin!
| The Following User Says Thank You to xcoldricex For This Useful Post: | djuosnteisn (07-14-2010) |
![]() | | #9 | ![]() |
Rep Power: 4104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,498
Am I doing something wrong here? I have about 200mi on this flash, but I am not seeing the break points in the LTFT. I was planning on doing the LTFT+STFT thing anyway, but seeing the LTFTs flatlined like they are concerns me. I know in theory they could be the same across the rev range, but that doesnt seem very probable. Makes me think the ECU just hasnt been learning. Maf cal run 1: ![]() maf cal run 2:
| The Following User Says Thank You to Ziggo For This Useful Post: | dougefresh_ (07-15-2010) |
![]() | | #10 | ![]() |
![]() Join Date: Jun 2009 Location: Lost Angels, Cali
Rep Power: 5080 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,712
Groans: 79
Groaned at 274 Times in 243 Posts
What would I need to do for a bored out (maxbore) throttle body?
__________________ ![]() |
| The Following 2 Users Say Thank You to hnda etr For This Useful Post: | dougefresh_ (07-15-2010), xcoldricex (07-19-2010) |
![]() | | #11 | ![]() |
Groans: 79
FYI - when I was doing my MAF calibration, I would log 3-4 runs, then combine all of them into 1 spreadsheet and sort by g/s and then MAF voltage, etc... I did this to see how the data was trending... Lots of color coding lol May not be the best way, or for everyone, but my LTFT's are 0 to -1.6 across the board.. I wanted my trims to be negative as opposed to positive... I figure it's better to be removing fuel than adding it... But I'm sure it's all the same... Also, I didn't do the summing of the short and long term trims - just long term..
| The Following User Says Thank You to hnda etr For This Useful Post: | dougefresh_ (07-15-2010) |
![]() | | #12 | ![]() |
If you look at your LTFT in light blue, you can see that they pretty constant throughout the MAF g/s range, but you can see a breakpoint clearly between 10.5 and about 13 seconds. I'm not sure what values the blue line is at, but I'm assuming the DH is using the yellow scale. If that's the case, then they look like they are only ~ +3.75, which is great. However, what you are doing wrong is using your DH to do this. Use your AP, and just log what I said in the OP... LTFT, MAF g/s, and MAF Volts. Leave your AP display on MAF g/s so you can watch them slowly increase, and don't forget to record the log(s)! Just re-read the OP, and log w/ the AP and NOT the DH, and you'll be fine. You can actually covert DH logs into .csv files, but they come out sloppy. You must have an AP, otherwise you can't calibrate the MAF. Unless you are tuning with a standback, and I know nothing about them. Try again with the AP, and it will be much easier, and make more sense. Check out the excel file attached to the OP, and that should help.
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 | |
![]() | | #13 | ![]() |
I wouldn't think it would matter as long as you are using the stock MAF housing. I think of it as just reducing airflow restriction like any other mod after the MAF. Like if you just had an intake, and you calibrated your MAF, and then you added a TIP. The TIP just made the system less restrictive, but you'll have to recalibrate your MAF. I have no experience w/ the bored out TB, so I'd run it by DJ.
![]() | | #14 | ![]() |
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
![]() | | #15 | ![]() |
Groans: 79
Bored throttle body's can be tricky. There is a throttle table IIRC, and you may need to massage some numbers in there. I've heard they hunt at idle sometimes. I'd have to open up my copy of ATR later and see what tables are available, but you basically want to reduce the necessary drive current down low, and keep it the same up top... kinda like making it more steep. Cause for the same degree of opening (angle), there will be significantly more airflow than with a smaller TB.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #16 | ![]() |
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 | ||
| The Following 2 Users Say Thank You to dougefresh_ For This Useful Post: | djuosnteisn (07-15-2010), Ziggo (07-16-2010) |
![]() | | #17 | ![]() |
Groans: 79
just no knuckle balls, hahaha. And definitely no hairy balls.
__________________ 500awhp 440awtq uncorrected ![]() BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Mounts be popping, and trans be hurting 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 07-15-2010 at 09:21 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | dougefresh_ (07-15-2010), Ziggo (07-16-2010) |
![]() | | #18 | ![]() |
(Thread Starter) | Not Ranked : 0 score Haha. Smooth, shaven balls are okay then? lol EDIT: Did he ever come out w/ any new stuff since years ago?? I miss Chappelle... really funny dude!
__________________ 2006 Mazdaspeed6 GT (40K miles) T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30 Last edited by dougefresh_; 07-15-2010 at 09:39 AM. |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | djuosnteisn (07-15-2010) |
![]() | | #19 | ![]() |
Groans: 79
lil boi ballz
![]() | | #20 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,136
Groans: 86
Groaned at 22 Times in 17 Posts
ok i think i actually understand how to do this now and am gonna try it now.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP, TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals. "Garaged Indefinately", (Got My Perm On) 1996 200sx SE-R- Injen CAI, GReddy SP2 CBE, Progress FSB, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "The Daily" |
| The Following 2 Users Say Thank You to skeeter149 For This Useful Post: | djuosnteisn (07-15-2010), dougefresh_ (07-15-2010) |
![]() | | #21 | ![]() |
Rep Power: 332 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
I use the DH exclusively to do MAF cal, because it's so easy that way, and I can tell you that on my car, on a fresh map, R4 and R5 are often the same, so you look fine. All you have to do to cal your MAF with the DH is set up a screen with g/s and LTFT and just monitor them. If you know the break points (write them down if you can't remember) you just play it around them to see what it's doing and adjust accordingly.
__________________ ![]() | |
| The Following 3 Users Say Thank You to fjames For This Useful Post: |
![]() | | #22 | ![]() |
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
After all this time.. I finally did this. I haven't driven it yet but at idle, my LTFTs are at 0! Even when I rev! Great write up!
__________________ 2012 BMW 135i //M-Sport |
| The Following 3 Users Say Thank You to ms3brendan For This Useful Post: |
![]() | | #23 | ![]() |
![]() Join Date: Apr 2010 Location: Salt lake city, Utah
Rep Power: 334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
Groans: 30
Looking forward to doing my calibration.. Question.. I know you (doug) addressed this in another thread but.. Is there in sort of consistancy in what you need to do to your TRL after doing the calibration? I had mine calibrated a few months back by a cobb employee (i had a different inlet and sri and stock tmic) And the fuel trims and afr were spot on, but the car felt much slower and the boost was lower. Now i know the calibration effects your calc load, but other than just moving up the TRL slowly, is there any sort of percentage that it can be increased based off the amount of adjustment the calibration took? I think i just confused myself..
__________________ 08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS: 465whp 468 wtq Best e.t 11.9 Best trap 123mph ![]() ![]() |
| The Following User Says Thank You to 801MS3 For This Useful Post: | dougefresh_ (07-16-2010) |
![]() | | #24 | ![]() |
Groans: 79
Compare your previous MAF #'s in the voltage range you typically hit at WOT, with the new #'s. If the new numbers are lower, your gonna hit higher boost. If the new numbers are higher, you'll hit lower boost. Adjust the TRL's by that same percentage, lower or higher accordingly.
![]() | | #25 | ![]() |
Groans: 79
__________________ ![]() | ||
| The Following 2 Users Say Thank You to hnda etr For This Useful Post: | djuosnteisn (07-16-2010), dougefresh_ (07-16-2010) |
![]() | | #26 | ![]() |
Thanks for the help guys, I got it all figured out last night and reflashed this morning. Now I just have to get some miles on it and see if they settle down. (since I just installed a FMIC I am somewhat concerned about boost leaks) I am looking to detune the car anyhow, so upping the MAF values around 10% (they were all close to 10) should help with that too.
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | djuosnteisn (07-16-2010), dougefresh_ (07-17-2010) |
![]() | | #27 | ![]() |
Groans: 30
Is that normal.. The 13.2 at the first break point is weirding me out.. Also when i am doing live monitoring of the ltft's it never goes above 8-9 but when i do the log it's showing 13.2?
__________________ 08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS: 465whp 468 wtq Best e.t 11.9 Best trap 123mph ![]() ![]() | |
| The Following User Says Thank You to 801MS3 For This Useful Post: | dougefresh_ (07-19-2010) |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
Sticky icky icky
![]() | | #30 | ![]() |
| Not Ranked : 0 score +1 This is the first thread on this that I found to be incredibly easy to understand rather than the ATR documentation. I never really thought to just read it off the car's breakpoints in the log instead of going off the documentation and using the MAF g/s breakpoints since those vary. After that realization this process was incredibly easy. After I calibrated mine though the LTFTs got worse and I reflashed back to the OTS map and after 100 miles they've settled a bit. I'm sure I'll need to do it after today though, CPE DP is going on and I'll be fully bolted... Haha. Pro-tune should probably be next..
| The Following User Says Thank You to ms3brendan For This Useful Post: | dougefresh_ (07-20-2010) |
![]() | | #31 | ![]() |
Sweet, I'm glad it helped. Why were your LTFT's worse after the calibration though? I need a mani & a catted DP to be fully bolted . I'm waiting for the Labonte Stage 2 meth kit, and I may just get a catted DP, and a pro-tune after that.
![]() | | #32 | ![]() |
Yeah I guess I won't be technically fully bolted but semi-fully-bolted haha. I won't have the mani. I haven't considered meth yet since after the FMIC install it's pretty much taken care of any of the KR issues I was getting before and the only reason I'd get meth is to take care of any unwanted KR.
__________________ 2012 BMW 135i //M-Sport | |
![]() | | #33 | ![]() |
Yeah, I don't have much KR at all, but I was planning on running pretty high boost, so I can't really afford any KR! We'll see how it goes.
![]() | | #34 | ![]() |
![]() Join Date: Oct 2008 Location: Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groaned at 23 Times in 12 Posts
subing for when i get home..
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED dire need of retuning, changed IC and live in Guam now... Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
| The Following User Says Thank You to jax ms3gt For This Useful Post: | dougefresh_ (07-21-2010) |
![]() | | #35 | ![]() |
Groans: 79
This of course, would differ between the 3's and 6's..
| The Following User Says Thank You to hnda etr For This Useful Post: | dougefresh_ (07-21-2010) |
![]() | | #36 | ![]() |
| Utahmazdas.com ![]() Join Date: Feb 2009 Location: Utah
Rep Power: 218 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
Jayspeed3 posted this info in another calibrate your maf thread. There are break points that the ecu uses for LTFT based on MAF AirFlow (g/s). Which is why when you slightly accelerate the LTFT's change. Breakpoints (MS3): 0 ~ 5 g/s 5.01 ~ 16 g/s 16.01 ~ 28 g/s 28.01 ~ 77 g/s 77.01 ~ Full Range g/s
__________________ |
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
Groans: 79
I was looking for the VOLTAGE breakpoints...
![]() | | #39 | ![]() |
Groans: 79
| Not Ranked : 0 score Hopefully he does and chimes in!
![]() | | #40 | ![]() |
Groans: 79
I don't think there is a specific voltage breakpoints, because you could assign a g/s value to any voltage you wish. So as your scaling for a Big Maf for example... all of your g/s values are going to move left on the voltage axis... thus reducing their associated voltages. And after you scale (IIRC), the break points remain the same... 0-5, 5-16, etc etc etc. so the ecu doesn't concern itself with the voltage... only the assigned g/s.
| Do I need to calibrate my MAF? | Qtip | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 05-02-2010 09:54 AM |
| can someone send me link or pdf or whatever of that cobb ATR user guide, that shows how to calibrate your mafs?? | Wenis Prinkle | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 08-05-2009 03:17 PM |
