> Cobb Tuning >
Cobb ATR Support
Notices
Like Tree7Likes
 Old 05-22-2012, 04:00 PM   #201
psn boostenya
Boosten Ya(josh)'s Avatar
Posts: 4,102   (View Stats)
Boosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the world
Groaned at 15 Times in 13 Posts
Are you trying to stay out of boost? If so then its ok to get in boost.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosten Ya(josh) is online now   Reply With Quote
The Following User Says Thank You to Boosten Ya(josh) For This Useful Post:
dougefresh_ (05-22-2012)
 Old 05-22-2012, 04:23 PM   #202
dougefresh_'s Avatar
Posts: 4,084   (View Stats)
Originally Posted by inglouriousbasterd View Post
For the life of me I can't seem to get over 66 g/s and I run out of gear in 2nd , would that be good enough to calibrate ?or could there be other issues that are preventing my from getting near 100g/s? , my current mod is a cobb sri, cp-e hpfp and a ap. The highest I get is 7% LTFT through out the whole log on the four runs I logged.
Sounds like your car needs some breather mods (or maf cal driver mod, lol), or you're at a higher elevation. There's another breakpoint at 100g/s that you want to check out so go into boost a bit like he said.
2006 Mazdaspeed6 GT (40K miles)
T3 Twinscroll GT 3076 w/ .78 3" V-Band Hotside, Steed Speed Top Mount Twinscroll Mani w/ Single Tial 38mm EWG Vta'd, Custom 3" Catless DP, Custom SRI/TIP, Dump Tube, & Oil Lines. Cobb AP~FreshTune @23psi, Dash Hawk, CPE HPFP, CPE FMIC+HKS BOV, CPE Rear Diff Mount, 3" GHL CBE w/ Resonator, BSD w/ Gpwerks Baffle, Hallman Pro MBC, H&R Sport Springs, Labonte Stage 2 W/M Kit w/ BCS FS & D07 Nozzle (50/50 Boost Juice), Perrin Pro EBCS in Interrupt Mode (Disconnected), Silver Demon Injector Seals, SU RMM, SPC BJs, TWM Stage 2 STS. Badgeless Grill, Sharkfin, Wheels, & 30% Tint. Rod Swap=2nd Life, Thanks to Nator NE!! 385/370 Uncorrected, 369/357 SAE on a Dyno Jet here: http://www.youtube.com/watch?v=zYIt0rqzL30
 Old 05-22-2012, 08:08 PM   #203
inglouriousbasterd's Avatar
Posts: 81   (View Stats)
inglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to beholdinglouriousbasterd is a splendid one to behold
Groaned at 4 Times in 2 Posts
Fuck I thought the whole point was to stay out of it , hence the gradual increase, but if that 's the case i have to stop pussy footing around, thanks.
When you decide to be something, you can be it. That's what they don't tell you in the church. When I was your age they would say we can become cops, or criminals. Today, what I'm saying to you is this: when you're facing a loaded gun, what's the difference?
inglouriousbasterd is offline   Reply With Quote
 Old 05-22-2012, 08:11 PM   #204
You should try to stay out of boost, especially up to 75g/s or so, but go into boost a bit if you must to break 100 g/s. You should be able to do it without boost. It's like you gradually increase the rate of acceleration up top, and it can be done staying out of boost. Once you get it, it's super easy. It's just kind of a wierd way of driving until you get the hang of it. GL
 Old 05-22-2012, 08:36 PM   #205
dpolseno41's Avatar
Posts: 1,635   (View Stats)
dpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the world
Groaned at 29 Times in 11 Posts
Is it possible for the MAF volts seen in a data log to not correspond with those in ATR?
08.5' MS3 GT
dpolseno41 is online now   Reply With Quote
 Old 05-23-2012, 05:50 AM   #206
Volts should go from 0-5v. If you're out of that range, you maf is fucked up. You won't see 5v either.
The Following User Says Thank You to dougefresh_ For This Useful Post:
Boosten Ya(josh) (05-23-2012)
 Old 05-23-2012, 10:25 AM   #207
weakdog85's Avatar
Posts: 385   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
Groaned at 15 Times in 3 Posts
oh i thought you had to stay out of OL the whole time, my MAF cal log hits a constant -.16 LTFT before hitting 100g/s so i figured it was a bad log cause i hit OL.
07 MS6 Sport.............
JBR SSP * JBR Shifter Bushings * JBR RMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP *
weakdog85 is offline   Reply With Quote
 Old 05-23-2012, 03:04 PM   #208
I stay out of boost the whole time. I can feather that bitch up to 160g/s, lol. You hit OL dependent on your CL Max Calc Load table C. Once load is higher than those values, your trims will zero. I have mine set to 1.1 across the board (excpet for the first lower values, I leave those alone). That way I don't get any afrs drifting at dip in, or any bs trim action when I go wot. I wouldn't anyway anymore bc of BT and higher loads.
 Old 05-23-2012, 03:09 PM   #209
dpolseno41's Avatar
I meant the specific voltages between 0 and 5.
08.5' MS3 GT
 Old 05-23-2012, 03:20 PM   #210
Idk man, I've never had a problem with my afrs that wasn't related to something mechanical (leak, etc).
 Old 06-26-2012, 06:26 PM   #211
himurax13's Avatar
Posts: 2,575   (View Stats)
Groans: 44
Subbed for later.
Ohnononono pinoyboi.
Listen my adobo cooking friend. You will move to NJ. I shall take you under my wing. You will void that warranty. Your wife will be very upset with you that you spend every Tuesday night with us, and you use all your extra monies to buy all the parts I shall find for you. You will sushi roll and ffs up and down the GSP with us. You will end up on YouTube and in the street racing videos. And last, but not least, you will allow us access to employee pricing on all parts thru your dealership.
Are you sure you still want to come to NJ? We go hard here.....be warned.
I too once was a naive ayshun with a stock pu. Then I met these fuckers. My wife hates me now Tuesday nights. My neighbors hate my car for the uber cool cold start. My garage is a fucking mess. My warranty went out the window. My life has not been the same since April. I should have bought a Mazda2.
himurax13 is online now   Reply With Quote
 Old 07-07-2012, 11:39 PM   #212
EdMazdaMan's Avatar
Posts: 23   (View Stats)
EdMazdaMan has a spectacular aura aboutEdMazdaMan has a spectacular aura about
Plan to calibrate MAF next week or so when I have > 50 miles. I have been reading this thread for the last couple of hours. Just want to be sure that if STFT = 0 in DL then DL is no good to do MAF calibration. Is this correct? I plan to log STFT just to be sure. Thanks.
2011 MazdaSpeed 3 - Sure SRI/TIP, AT Internals, JBR SSP, Sure RMM.
EdMazdaMan is offline   Reply With Quote
 Old 07-08-2012, 10:22 AM   #213
How to Calibrate a Vagina Boob
 Old 07-08-2012, 11:13 AM   #214
psn boostenya
Whats up brownie
08 Mazdaspeed 3
 Old 07-08-2012, 11:13 AM   #215
ms3blackmica's Avatar
Posts: 3,950   (View Stats)
very possible. happens almost always.
what i do is just use the closest maf voltage in ATR.
In other words, just as an example...if i want to make a correction for airflow at a 4.29 Volts, i'll just make that correction in the cell corresponding to 4.30 Volts.
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
 Old 07-10-2012, 10:33 AM   #216
Originally Posted by Boosten Ya(josh) View Post
Whats up brownie
Nothing faggot.
"He called me brownie.... I had Jenny call the police" haha
Boosten Ya(josh) (07-10-2012)
 Old 07-10-2012, 12:21 PM   #217
psn boostenya
Please dont call the cops......brownie
08 Mazdaspeed 3
dougefresh_ (07-10-2012)
 Old 07-28-2012, 02:10 AM   #218
New Beginnings
The Nut's Avatar
Posts: 640   (View Stats)
The Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the world
Groaned at 24 Times in 10 Posts
Wow, I am going to be so fucked when I go to try and do any self tuning when the time comes. I just read every post on this entire thread and with the exception of "the blessed dummy-down explanation post #49), I just kept getting more and more lost. I sure hope when I get my first batch of go-fast bits ie: internals, sri, & tip- that there's someone in L.A. who is willing to sit down with this (noob, brownie, dumbshit - call me what you will) to help me take my ride out with my AP, take some logs, and explain this shit in real life. I've studied quantum mechanics and it wasn't this complicated. I sure hope my OTS Stage 1 flash on stock parts doesn't cause my engine to go boom till then. That's why I installed my sub. Argh!
The Nut
2012 Black Mica Pu w/Tech. Brand new 2013 Engine - BACK IN ACTION!!!
Go:Cobb AP/AT Internals/ETS TMIC/ITV22's/Cobb SRI & TIP/Nator TP/JBR- SSP/Counterweight/Anchors/Special Edition Cylindrical Knob/Sure RMM
Looks: Tint-20%(ft)~5%(rr)/Black-out symbols & MAZDASPEED 3 badge/Painted fog light bezels
Stereo: Kenwood DNX9990HD HU/Polk Audio dB series 6 1/2 components fr. & back/Pushed by Alpine PDX 100.4/Kicker 12" L7 Solobaric in custom sealed enclosure/Pushed by Alpine PDX 600.1/ Monster 1 farad cap/ PAC SWI-RC s.w.c.m./All wiring by Monster Cable.
The Nut is offline   Reply With Quote
 Old 07-28-2012, 09:43 AM   #219
himurax13's Avatar
Groans: 44
For sure. You bring your laptop, ap, and some beer. I will provide the wooden ruler or some reasonable facsimile.
The Nut likes this.
lilred (07-28-2012)
 Old 07-28-2012, 01:26 PM   #220
Mfinlay04's Avatar
Posts: 601   (View Stats)
Mfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the world
Groaned at 13 Times in 7 Posts
Is it normal for the MAF grams/sec to jump around a little bit? I have the issue where randomly my data log show eg. 200 Grams/sec and then the next cell is 195 and then the next cell is 210. Like I lost some airflow even though I'm WOT. It seems 98% linear but every now and again I get weird dips?!
2006 MS6 Titanium Grey
AP, TP, BSD, AEM CAI, Custom 2.5" Single Exit Exhaust, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, AWR RMM (pending install), Short Shifter
Mfinlay04 is online now   Reply With Quote
 Old 08-07-2012, 11:44 PM   #221
Jhornbrook's Avatar
Posts: 636   (View Stats)
subbed for more maf cal help. started messing with atr, still appears to be ching chang chong talk. this is way easier to understand than abilor's guide.
 Old 08-08-2012, 12:21 AM   #222
this deffinitely is not normal. Sometimes you can see a very slight dip near redline when you start maxing out your g/s on the K04. But nothing drastic. You sometimes might see for example 260...259....260....
but what your seeing deffinitely is not normal. You should always see your maf g/s increasing without any dips.
 Old 08-08-2012, 07:45 AM   #223
Mfinlay04's Avatar
I've seen it in multiple peoples logs that they post around here. I haven't done a log at wot since I installed my egr block and its possible my TIP was loose so maybe I shouldnt see this any more
 Old 08-08-2012, 09:04 AM   #224
really ?
very strange in IMO. I've always seen my maf g/s increase at WOT all the way to redline. Never had a dip like that.
 Old 03-01-2013, 06:03 AM   #225
BloodySpeed3's Avatar
Posts: 127   (View Stats)
BloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond reputeBloodySpeed3 has a reputation beyond repute
I took 15 logs between two series of runs and averaged out all the breakpoints, kind of like what you did, and I got my LTFT's down to .8% and -1.6% on the first shot! They were originally 2.45% and -5.45%. The car feels much more consistent and evened-out in power delivery. I'll break this map in and do one more MAF cal. Hopefully it goes over well, then I'll get started on WOT cal. Thanks for this still-useful info!
IS 2013 Ford Explorer Sport
AWD 3.5L V6 TwinTurbo EcoBoost
Stocked 'n Traded:_________________________________
VRM 2010 MazdaSpeed3
Progressive Self Tune
Cobb AccessPort - SOLD | Cobb SRI | Cobb TIH | Cobb XLE BPV - SOLD
AutoTech HPFP Internals - GONE | cp-e Stage 2 RMM - SOLD | UR CatlessTurboback Exhaust
VD: 283whp @ 4968 rpm
322 lb-ft @ 3608 rpm
BloodySpeed3 is offline   Reply With Quote
 Old 05-12-2013, 09:32 AM   #226
SSXtreme's Avatar
Posts: 58   (View Stats)
SSXtreme is a jewel in the roughSSXtreme is a jewel in the roughSSXtreme is a jewel in the roughSSXtreme is a jewel in the rough
I have been through Alibor's guide and the Youtube Maf cal video. I am now dumbfounded, unfortunately. I have trouble getting over 75 g/s with a MSCAI2 and a 3.25 TMIC. The logs, I am attaching are a MAF CAL log (Datalog 2) and a WOT log (Datalog 7). In the MAF cal, the MAF g/s jumps around a lot, as is the MAF volts and I know that is not normal. I am hitting my head against the wall on this one, as I just got done pulling the fuel pump and tightening all hoses when I was done putting it all back together. Might I ask for assistance, please.
"My mind is the space where my Id, Ego, and Anima all come together to exchange cookie recipes!"
SSXtreme is offline   Reply With Quote
Do I need to calibrate my MAF? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 15 05-02-2010 09:54 AM
can someone send me link or pdf or whatever of that cobb ATR user guide, that shows how to calibrate your mafs?? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 5 08-05-2009 03:17 PM
Page generated in 0.48858 seconds with 33 queries
