![]() | | #1 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 398 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 320
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10003 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,737
Groans: 98
you removed the second O2 sensor?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
Yeah i was getting the lean at idle code. p0127. There was a number of things that it could have been... I dont have any boost leaks, maf is sealed and reading proeperly. Someone suggested it could be either of the o2 sensors. Rather than shell out the money for both (being that i dont know what one was faulty) i figured id remove the secondary and clear the code. Since then i have not gotten the lean at idle code... So that was probably the issue. I had a bung cap and that was a lot cheaper than 180 bucks for a new sensor. Is removing the secondary o2 not common? guess i thought it was.
![]() | | #4 | ![]() |
well looks like i need to put it back in... Just ditch the defoulers. I really should read more before i do dumb shit... Thank you for helping me to to somewhat figure this out on my own super
| 2 Codes popping up | greg08 | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 07-27-2011 09:01 PM |
| keeps popping out of second | TWOptSL0W | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 06-30-2011 03:40 PM |
| Why all the new TMICs popping up? | FADE2GRY | Mazdaspeed3/6 General Discussion | 56 | 01-27-2011 05:01 PM |
| CS SRI+TIP, now popping when I shift | fywdyl | 2010 MS3 - Turbo Induction | 13 | 11-15-2010 10:14 AM |
| popping out of gear???? | the518speedster3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 03-26-2010 05:47 PM |
