> 2010 MS3 - Turbo Induction
Notices
 Old 10-03-2012, 02:02 PM   #1
MPS_Fan's Avatar
Posts: 313   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Default BNR S3 Boost tapers up to 17.5psi from spring pressure??
Today i just started to monitor my car because Cobb AP is no supporting EU Cars. After my first log run with my BNR S3 i noticed that my boost tapers up from 14psi to 17.5psi at redline. At the moment i am running just from spring pressure, because there was no AP support before. Shouldn´t the boost stay at about 14-15psi? Does it mean that i have a mechanical issues (Wastegate doesn´t open far enough) or is the inner line diameter (4mm) i´m running to the WGA to small? Don´t want to start custom tuning without being sure that everything is fine.
MPS_Fan is offline   Reply With Quote
 Old 10-03-2012, 02:05 PM   #2
Posts: 9,588   (View Stats)
17.5 psi is not too bad since you'll target at least 20psi by redline. Sounds like you have a bit of creep. Do you have a catless downpipe?
 Old 10-03-2012, 02:12 PM   #3
MPS_Fan's Avatar
No, i have stock downpipe, testpipe and 3" Catback. I always thought, that BNR S3 has no problems with creep?
 Old 10-03-2012, 02:29 PM   #4
I generally don't see it creep but even if it gets to 17psi it's not a huge amount. Does it spike at all when it spools?
 Old 10-03-2012, 02:45 PM   #5
MPS_Fan's Avatar
No Problems with spiking. It climbs to 14-14.5psi at 3200rpm then holds at 14-15psi and starts tappering up at 5000rpm.
So you think everything is fine? If yes i will hook up my Grimmspeed and start dial in my boost and MAF calibration tomorrow.
 Old 10-03-2012, 03:19 PM   #6
Yup you shouldn't have a problem.
ms3blackmica (10-04-2012)
 Old 10-03-2012, 04:10 PM   #7
atvfreek's Avatar
Posts: 6,296   (View Stats)
Groans: 31
Groaned at 19 Times in 16 Posts
This is the first I've seen or heard of a bnr creeping, but as lex said, you will be targetting higher boost. So you shouldn't have any issues with tuning
Freekn tappin
2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS
Perm Tune by the Freek
417hp/395tq
12.903@117.33 Street tires and shitty 2.25 60ft
atvfreek is online now   Reply With Quote
The Following User Says Thank You to atvfreek For This Useful Post:
 Old 10-04-2012, 12:56 AM   #8
MPS_Fan's Avatar
I have to check the heat shileding on my turbo. I reused the old and put it on my bnr. I cut it out, so that the WGA has enough room to move. But maybe its touching somehow the sielding on higher rpm and cant open enough. I will check today…
This boost creep leads to traction problems in first gear. I think i have to use the throttle correction to reduce boost in first gear.
 Old 10-04-2012, 01:10 AM   #9
speedy308's Avatar
Posts: 138   (View Stats)
speedy308 has disabled reputation
If i understand correctly, you are using an AP now. Use the APP translation tables to limit throttle in 1st gear.
2012 Mazdaspeed 3 w/ Tech - Few mods
speedy308 is offline   Reply With Quote
The Following 2 Users Say Thank You to speedy308 For This Useful Post:
MPS_Fan (10-04-2012), ms3blackmica (10-04-2012)
 Old 10-04-2012, 02:44 AM   #10
can't take out voltron
ms3blackmica's Avatar
Posts: 3,836   (View Stats)
Just as everyone said, if you are seeing a max of 17.5 on just spring pressure then I am sure you will be fine when tuning for higher boost.
You shouldn't have any issue controlling higher boost levels.
Good luck with your tuning adventure. I am glad to see that Cobb has taken care of mazdaspeeds worldwide now!
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
 Old 10-04-2012, 04:55 AM   #11
skeurton's Avatar
Posts: 767   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
I was going to do the same thing and cut that one heat shield to make it fit, but decided to just leave it off in order to avoid any risk of interfering with the WGA.
Before installing it, I checked the spring pressure. The flapper cracked open almost exactly at 1-bar. After installing it, I ran spring pressure and it would hold around 15.5 psi and reach around 16.5 psi near redline. I'm tuned at 22 psi now and it holds like a champ across the board.
So just like everyone said.... it shouldn't be anything to worry about it.
2011 MAZDASPEED 3
VIRTUAL DYNO: 339 hp / 397 ft-lbs (BNR)
DYNOJET: 296 hp / 343 ft-lbs (K04)
BNR Supercars Stage 3 Turbo Cobb Tuning AccesPORT AccessTUNER Race KMD Tuning HPFP Internals v2.2 Denso ITV24 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs EGR Delete Rear Sway Bar PSMM TMM HTP 3" TIP Battery Tray SURE Motorsports 3" MAF RMM Shortcut CounterShift Anchors AGS 621g Shift Knob Ultimate Racing Catted Downpipe Test Pipe Cat-Back Exhaust CP-e FMIC SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Continental ExtremeContact DWS Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit ProSport Performance Boost Gauge Aeroforce Dual Interceptor Gauges
TO BE INSTALLED:
Aquamist HFS-4 Alcohol Injection Stratified Auto Guardian Angel
skeurton is offline   Reply With Quote
The Following User Says Thank You to skeurton For This Useful Post:
 Old 10-04-2012, 05:09 AM   #12
MPS_Fan's Avatar
Yes, thats nice!!! I done today another run. I see 17psi at redline. So everything should be fine. i will start populating my WGDC Table with 20 and see what boost i get. Target is 18psi tappering up to 20 at redline. Don´t want to VTA my block on german autobahn
BTW, our gas here in germany is the shit! I´m running Stage 2 98oct map and use 95 (E10) gas. Getting 0 KR all the way
 Old 10-04-2012, 05:16 AM   #13
dr_banano's Avatar
Posts: 510   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
yeah take it off that was my problem also i was hitting 18 psi on just spring and saw that the shield was pressing the wastegate arm causing this .....so rip it off better...
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- Nitto NT05 tires on stocker wheel - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers-
ptp studs/seals - JBR TB/IM Thermal ins - EGR block - pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 10-04-2012, 02:47 PM   #14
MPS_Fan's Avatar
Problem solved, it was the heat shielding. I've bent it a little bit, now the WGA can move freely. He was slightly touching the shield. After bending i got about 15.5psi up top. This should be ok.
ATM i dial in my boost (18psi tappering up to 20psi). Car pulls great even with OTS timing values.
help, boost tapers off to quickly turbo test 2010 MS3 - ECU Computer Tuning 43 04-22-2012 07:54 PM
Only running 12psi- spring pressure speed23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 02-25-2012 05:52 AM
DOes ANYONE have OEM high pressure Pump spring retainers!! PAM.srt4 Mazdaspeed3/6 General Discussion 12 12-15-2009 02:07 PM
Now the meth is wokring.:) 19.5psi,70dgr boost temp,12.5afr(65dgrs outside)! gsrtype1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 100 04-02-2009 02:25 PM
Page generated in 0.35414 seconds with 26 queries
