> 2010 MS3 - Turbo Induction
Like Tree4Likes
  • 1 Post By JDW1
  • 1 Post By Mchart
  • 1 Post By SarcasticOne
  • 1 Post By Djohns
 Old 08-04-2012, 11:58 AM   #1
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Default BNR S3 without tune
Since the guys in europe still have no tuning solution for gen2 I have a question. I ordered a BNR S3 and wanted to install it. The plan was to run it only with WGA spring pressure which should be about 14psi until support will be available. Will I reach the stock tune load limiters? I have a AP here but it's useless ATM(no support yet). What do you think? Could any damage occurs to engine with this setup?
MPS_Fan is offline   Reply With Quote
 Old 08-04-2012, 12:08 PM   #2
Posts: 12,651   (View Stats)
You may reach load cut unless the ECU closes the throttle enough since the BNR is a lot more efficient at 14psi redline than the stock turbo and the ECU at that time is pulling WGDC and throttle.
AZSPEED3 (08-04-2012)
 Old 08-04-2012, 01:25 PM   #3
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Why if you had an AP couldn't you get @Lex here to tune it for you?
v8killer likes this.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
The Following 2 Users Say Thank You to JDW1 For This Useful Post:
Mikey (08-04-2012), v8killer (08-23-2012)
 Old 08-04-2012, 01:31 PM   #4
MPS_Fan's Avatar
I can tune myself but AP does not support EU cars ATM.
 Old 08-04-2012, 01:50 PM   #5
There are some other tricks you can do to play with the MAF sensor and/or the MAF housing .... Standback anyone?
 Old 08-04-2012, 02:21 PM   #6
MPS_Fan's Avatar
Yeah I could use bigger MAF. My g/s readings will be less. But this will also lead to high fuel trims and also lean WOT AFR. So no way. That sucks so much that we have no way to tune
Driving a Pu in Europe=fail.
 Old 08-04-2012, 03:17 PM   #7
StayBroke's Avatar
Posts: 2,075   (View Stats)
Maybe a us ecu?
The Following User Says Thank You to StayBroke For This Useful Post:
CWP_MS3 (08-29-2012)
 Old 08-04-2012, 03:22 PM   #8
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
I'd just wait.
Random ass-pulled guess sense says that Cobb will be adding EU support by the end of the year.
IMO it makes no sense to go BT without being able to get rid of the stock load cap.
p057 likes this.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following User Says Thank You to Mchart For This Useful Post:
p057 (08-27-2012)
 Old 08-04-2012, 03:26 PM   #9
MPS_Fan's Avatar
Was thinking about that. But found no genpu ecu on eBay. Also Cobb is working on support. But no ETA.
The conclusion is: i can use BNR s3 with stock tune and spring pressure without being worried about engine damage. Right?
 Old 08-04-2012, 03:58 PM   #10
Depends how much bigger. The gen2 adjusts AFRs under WOT (yes, yes it does) up to 10-15% unlike the gen1. Also, 10-15% LTFTs are fine.
I am not condoning not tuning, just letting you know what your options are in case you go ahead.
 Old 08-04-2012, 05:18 PM   #11
MPS_Fan's Avatar
Damn, you US guys are so lucky...
I have to think about swapping turbo before EU AP support. Driving a car where you can't go WOT isn't something I want to have... can somebody post a graph of the load limiter tables from stock tune? Would like to know if the limiter values are also tappering down on high rpm.
 Old 08-04-2012, 05:27 PM   #12
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Versa tune?
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
 Old 08-04-2012, 05:30 PM   #13
MPS_Fan's Avatar
Originally Posted by SarcasticOne View Post
Versa tune?
No PU Support! And no ETA for that. One more time EU Pu suxxxxxxx!
 Old 08-04-2012, 05:43 PM   #14
Macncheese's Avatar
Posts: 301   (View Stats)
Macncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the worldMacncheese is the leader of the world
Groans: 244
'Merica... Fuck Yeah
Mazda 6 with awd
Macncheese is offline   Reply With Quote
The Following 4 Users Say Thank You to Macncheese For This Useful Post:
CWP_MS3 (08-29-2012), easy (08-04-2012), GunGuru727 (09-04-2012), v8killer (08-23-2012)
 Old 08-04-2012, 05:49 PM   #15
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
You could always put a WTB in the FS Section. I'm sure someone somewhere has a PU US ECU and would be happy to get it to you.
DiGi Faggot is offline   Reply With Quote
 Old 08-04-2012, 06:03 PM   #16
Hopefully Getting there
Down under we got lucky with access port for gen 2's
Know there is a few people keen for VT tho
kritz likes this.
The Following 2 Users Say Thank You to SarcasticOne For This Useful Post:
atvfreek (08-05-2012), kritz (08-04-2012)
 Old 08-04-2012, 06:35 PM   #17
I know VT gen2 is in the works but don't know ETA.
 Old 08-05-2012, 05:34 AM   #18
Mchart's Avatar
Groans: 54
Cobb Stage 1 91 Octane maps have a load cap of 1.81. (I forget what stock is) With a BT you'll easily be going over 2 for much of the power band.
I imagine running BT with stock tune to be similar to being a shaken baby.
 Old 08-05-2012, 05:45 AM   #19
MPS_Fan's Avatar
I was talking about running it only from spring pressure, wiChat should be about 14psi. So you think I will be over 1.8 load?
And is the load cap a fixed value or dynamic? ( vs. Rpm)
 Old 08-05-2012, 05:57 AM   #20
Mchart's Avatar
Groans: 54
14PSI through a BNR S3 is substantially more flow then 14PSI through a K04.
I have no idea what sort of load you'd hit with stock tune and the S3, but I do imagine you going over the stock caps for most of the power band. Even more so up top.
 Old 08-05-2012, 06:07 AM   #21
86AmishMs3's Avatar
Posts: 3,635   (View Stats)
Groans: 338
You might be fine, might not. Only one way to find out. I think you'll be fine at low boost levels.
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Current: N54 135i FBO
 Old 08-23-2012, 02:59 PM   #22
v8killer's Avatar
Posts: 203   (View Stats)
v8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the world
Groaned at 5 Times in 2 Posts
any update on this? very curious how it went
363whp & 420trq (DynoJet)
384whp (Dyno Dynamics)
K04 + corn + nitrous + LEX = a happy v8killer
v8killer is offline   Reply With Quote
 Old 08-23-2012, 03:25 PM   #23
MPS_Fan's Avatar
Turbo is on the way to me. Shipping takes up to 4 weeks to germany
 Old 08-26-2012, 03:07 PM   #24
AndyT's Avatar
Posts: 36   (View Stats)
AndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant future
The UK has a few tuning options now though quite as good as AP. Some using mazda edit and others ecutek.
To the OP, you could go to the same place i did, he uses ecutek and now they've released the proecu kit he can map your car remotely so even though you're in a different country he can still map the BNR 3. The kit also allows you to log like the AP.
I have what is essentially the same as a BNR 1 and have had 20k happy miles, the tuner has also had plenty of articles in the motoring press and knows his stuff.
Freektuned - GTX2867 -Cobb AP V3 - Jetex Long Downpipe - Jetex CBE - HTP 3" Intake - Autotech HPFP - Forge FMIC - Cobb EBCS - CS RMM Inserts - CS SSP - ITV 22 - Turbosmart BPV - BBR Springs - Koni FSD shocks - Mtec Discs - Yellow Stuff Pads
AndyT is offline   Reply With Quote
 Old 08-26-2012, 03:23 PM   #25
MPS_Fan's Avatar
Sounds nice, but me and many others want to selftune their car. So ecutek is no option. I would only let tune my car by people who are specialized to our platform like atvfreek, lex and many other tuner here in the forums.
Cobb wrote that they are analyzing the last region in EU. So it seems we will get AP support soon. Also I already have an AP here
Ecutek is available for a long time here in Germany, but nobody wants it. We don't like the company policy like they handle with private users. If you write them a mail you won't get an answer. Also you have to pay lot of $$$ for their tune. This is no option, we want to have full control over tune and correct some parameters if something is wrong.
 Old 08-26-2012, 03:35 PM   #26
AndyT's Avatar
Would be good to get AP support here, versatune isn't too far away either.
 Old 08-26-2012, 03:39 PM   #27
MPS_Fan's Avatar
Versatune is good shit, but also not as comfortable as Cobb, because you have no standalone device which provides everything you need. Taking everytime the notebook if you only want to change map is fag....
 Old 08-27-2012, 01:23 AM   #28
Mchart's Avatar
Groans: 54
ECUTek is about the only option if one can't wait.
I can't reccomend it though considering euro/UK AP support will be out by the end of the year.
The horrible part about ECUTek is that the reflash changes the encryption on the ECU. So once you have an ECUTek tune you are fucked if you want to just start using an Accessport or Versatune.
And frankly, the AP is the best tuning solution. Having to wait on someone else to tune your car is bullshit.
MPS_Fan (08-27-2012)
 Old 08-27-2012, 07:40 AM   #29
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I'd just wait.
I'm sorry for sounding like a dick for saying it, but why upgrade the car significantly, knowing that without tuning you're running into higher risks?
can't you just wait? I know it's 'unfair' for me to say it because I do have support, but I honestly felt if I were in your shoes, i'd just wait it out. much better than spending all this money to end up blowing up on the side of the road just before cobb releases the euro-AP.
 Old 08-27-2012, 09:05 AM   #30
MPS_Fan's Avatar
I will do the swap with a friend(car machanic). He isn't available all the time. He has only next week time, because he is on vacation. So I have to do this job next week. I could swap the turbo also by myself but it will be pain in ass without lift and proper tools. I can't see any risks in driving without tune just from spring pressure. Stock tune is rich as hell and timing is far away from its limits. The only thing that could happen is fuel cut. And I will not go wot till tune:thumbup:
 Old 08-27-2012, 10:51 AM   #31
AT 14psi you're likely to get load cut with the stock tune. 14psi at redline from a BNR S3 is a lot more than the stock tune allows for and it will try lowering boost to no avail.
 Old 08-27-2012, 11:16 AM   #32
MPS_Fan's Avatar
That's the reason why I will avoid wot and redline. Also I never reached rev limiter on my k04 before. So everything will be fine
 Old 09-04-2012, 01:08 PM   #33
MPS_Fan's Avatar
Ok, Turbo is now in my car. It runs great without tune. AFR, Boost, KR looks absolutely fine. Like Lex said, the ECU tries to reduce Load with the Throttle plate on higher RPMs. I also tried some wot runs, AFR is rich like it should be on stock tune. I reach 248g/s just from spring pressure in 3rd gear at 5500rpm, then i get fuel cut. The ECU is doing great job, never thought it can correct that fast AFR, Boost and so on with a different turbo.
 Old 12-17-2017, 08:22 AM   #34
allservice's Avatar
Posts: 53   (View Stats)
allservice is infamous around these partsallservice is infamous around these partsallservice is infamous around these parts
Groaned at 65 Times in 47 Posts
N
allservice is offline   Reply With Quote
The Following 2 Users Say NO Thank You to allservice For This Un-useful Post:
sharksinspace (01-12-2018), Thor Hammer (12-18-2017)
 Old 12-17-2017, 10:40 AM   #35
Djohns's Avatar
Posts: 3,945   (View Stats)
Groans: 112
Neutral  -1 score
Originally Posted by allservice View Post
How did you setup the OEM EBCS. Or did you use another setup? With OEM tune?
I am in the same boat, my 2nd K04 is about to die, I am using Hypertech and until Ap comes here I have to do the BNR S3 swap.
This thread is 5 years old. Seriously?
2010 black mica speed3
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
monkey.bones.007 (02-21-2018)
 Old 01-12-2018, 08:14 AM   #36
allservice's Avatar
N
Db09ms3 (01-12-2018), sharksinspace (01-12-2018)
 Old 01-12-2018, 08:26 AM   #37
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
There's nothing wrong with searching and reviving a thread IMO, but the OP you are trying to ask hasn't been active for 2 years. So I don't think you'll be getting your response.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
allservice (01-13-2018)
 Old 01-12-2018, 08:36 AM   #38
Djohns's Avatar
Groans: 112
Neutral  -1 score
You're 5 years old too, so what?
Oh wow what a witty comeback. Get fucked.
sharksinspace likes this.
Soon:built motor
 Old 01-12-2018, 09:23 AM   #39
Jeff23spl's Avatar
Posts: 1,631   (View Stats)
To answer your question, if you take time to read it, he said he kept it on 14psi spring pressure. It's mean the EBCS is disconnected and straight vaccuum line is connected from the wastegate actuator to a boost source without the solenoid. The S3 seem to have a boost source on the discharge pipe so it won't take a long hose to connect it....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
To Perm tune or not and who to Perm tune with ? That is the question. stang9779 2010 MS3 - ECU Computer Tuning 27 10-28-2011 02:47 PM
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.60789 seconds with 35 queries
