> 2010 MS3 - Turbo Induction
Notices
 Old 08-12-2012, 10:43 PM   #1
MS309's Avatar
Posts: 386   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Default Corksport FMIC w/ Ram air Review
I'll just cut to the chase and give you my impressions of this kit, haven't seen many people talk about it.
The good: FMIC works at bringing bats down quickly. Install is not too bad, everything fits and lines up.
The bad: Not sure about the ram air intake, Stock shifter weight bangs against hot pipe.
Lets start with the bad. I had to take the stock shifter weight out because it wouldn't let me engage completely in forward gears. only two solutions for it, no weight or shorter weight, I just went with what I could do to fix the issue at hand, no weight. It shifts just fine without it, a bit notchy but I like it.
I don't know what to think of the ram air kit. It looks cool, but does it really work I don't know. I wasan't too happy with how the filter was seated, it left a brief opening towards the front and back, not compltely sealing the box. I should also mention that this was a used kit, so I'm not sure if this is how the filter comes from CS new. You are supposed to use the stock IC shroud to make it seal I assume but the shroud is a tough fit. Even after all the trimming, It was very hard to shut the hood, I had to force it shut, just didn't seem normal to me. As for performance, I noticed a slight lag in throttle response, my trims were off quite a bit (+7/+10 at idle and cruise) and also, the CS maf housing is a smaller diameter compared to the Sure maf housing.
EDIT: See post #19 , its all fixed and runs pretty well.
I wanted to see if there was any difference running the sure intake instead and yes there was, throttle response was much better and I dont' have to worry about water/snow/bugs getting inside the intake. Regarding this intake setup (see attached pic), it only works because the CS inlet houses the crank vent hose, which allowed me to directly bolt the maf housing to inlet pipe.
The FM core itself works well, it drops bats much faster than the stock unit could, so no complaints there. I did experience some pressure drop, about 2 psi I believe. Today was a hot day (about 85) and the car felt consistent every time I stepped on it, no boost leaks yet either.
Here are some logs for comparision, the one's with this kit are labelled with FMIC, the v1.5 one's are with stock IC during my tuning process.
only have one log with the ram air system which I took late at night (datalog 4), the increased g/s flow could be due to the really low temps or maybe its the ram air kit, I don't know, but It's not a significant difference. I switched back to the sure intake today, so datalog# 7/8/9 are all with SU intake.
datalog 24 would compare with datalog 7 in terms of bat's and how they fare stock ic vs fmic (similar outside temps/bats).
datalog 8 is just random stop/go driving (outside temp around 84ish)
datalog 9 is what I took later this evening with outside temps being around 68ish.
Lex I believe I can run more timing now and still have some room to increase WG to achieve the same boost targets as before ?
Feel free to post up comments/questions.
'11 CWP Speed3
| RallyArmour | Cobb AP | AT Internals | Gutted stock DP | SU TP | HKS BOV | CS FMIC w/ram air | Strat tuned | TWM FRShifter | CS TMM insert | CS PMM |
MS309 is offline   Reply With Quote
The Following 4 Users Say Thank You to MS309 For This Useful Post:
Bob-o (08-12-2012), kritz (08-13-2012), Lex (08-13-2012), Ryguy (08-14-2012)
 Old 08-12-2012, 10:51 PM   #2
MS309's Avatar
some more pics, The Core was painted black by previous owner, so can't really even notice its there.
'11 CWP Speed3
The Following User Says Thank You to MS309 For This Useful Post:
Pointless (08-14-2012)
 Old 08-13-2012, 09:05 AM   #3
Posts: 9,589   (View Stats)
It's interesting that the ram air box doesn't seem to be sitting straight. You want the seal on the hood to seal against the plastic just as it does with the OEM IC for the best effect.
You did gain some flow (g/s) while boost dropped which means the VE of the motor has increased with the kit. This is good because less boost pressure = less heat = less knock. The BATs are quite low so I think it will take more timing as well. We can probably tweak the map for a few more ponies whenever you're ready.
In terms of the shifter weight, a few manufacturers make smaller ones - COBB does for sure for their FMIC kits.
helmetface (08-13-2012), MS309 (08-13-2012)
 Old 08-13-2012, 11:20 AM   #4
Bivash's Avatar
Posts: 13   (View Stats)
Bivash has disabled reputation
Great review!
Bivash is offline   Reply With Quote
 Old 08-13-2012, 09:34 PM   #5
Instrument_Guy's Avatar
Posts: 175   (View Stats)
Instrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the world
Can't wait to check this out! I think the Sure filter set-up that you hooked up is better than the top-mount Corksport filter; that thing looks a little hokey. Time for a DP
I've got a small Sure counterweight in a box somewhere; we can see if it fits around the IC piping
2010 CWP - Cobb AP Stage 2 Stratified tune - CPE HPFP - CS SRI/TIP - CPE TMIC - CNT de-catted DP - Bnoon Bolt - Magnaflow CBE - Turbosmart BPV - Synapse synchronic BPV (not installed yet)- Denso ITV-22 - CPE RMM - Motorcraft XT-M5-QS trans fluid - Momo V10 18" * 7.5 +45 offset - Michelin Pilot SuperSports - TWM full replacement shifter, JBR 70D TMM, 70D PMM, Stage 2 OCC, EGR delete, TB TIG - Sure Boost Tubes & Recirc Tube
Last edited by Instrument_Guy; 08-13-2012 at 09:34 PM. Reason: MSF Database - Automerged Doublepost
Instrument_Guy is offline   Reply With Quote
The Following User Says Thank You to Instrument_Guy For This Useful Post:
MS309 (08-13-2012)
 Old 08-13-2012, 09:41 PM   #6
Ray Danger 2020's Avatar
Posts: 525   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
I like the way you have the SURE SRI in there. I think it's much more asthetically pleasing than the ram air system. I'd definately run it that way if I could.
'12 Mazdaspeed 3
//SURE//JBR//Cobb Tuning//Ultimate Racing//Go Fast Bits//Corksport//Denso//Autotech//DDM Tuning//
277HP/320TQ Self Tuned On 93 (Mustang Dyno)
314HP/356TQ Rfinkle2 Tuned With 33% Corn (Dynojet)
Ray Danger 2020 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ray Danger 2020 For This Useful Post:
MS309 (08-13-2012), reko (10-30-2012)
 Old 08-13-2012, 09:55 PM   #7
Hold on a sec ... you're not running the RAM air intake? That is the best part of the kit IMO because it really increases pressure pre-turbo. Give me a shout, perhaps the MAF cal was the issue because I think that the RAM air will make a positive difference (given the filter fits properly).
v8killer (08-23-2012)
 Old 08-13-2012, 10:41 PM   #8
outshined's Avatar
Posts: 372   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
So...does one simply just stay home when it's raining?
I'm trying to understand how the "ram-air" filter's open exposure to the elements is a remotely good idea outside of dedicated dry-weather track duty.
Originally Posted by James Madison
[The Constitution preserves] the advantage of being armed which Americans possess over the people of almost every other nation...(where) the governments are afraid to trust the people with arms.
outshined is offline   Reply With Quote
 Old 08-13-2012, 10:54 PM   #9
Slow Canuck
Bob-o's Avatar
Posts: 636   (View Stats)
Bob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the world
The plastic shroud "seals" the filter to the intake so it holds out water.
Lex, the issue we had with the ram air is that the filter seemed to flex and bend too easily to sit on the intake box properly. We concluded this because once he put the sure intake on, we gained some, but not all the boost he has pre-fmic install.
Also, the plastic shroud did not fit well on his car for some reason with the ram air. Could be installer error, I'm not sure.
Bob-o is offline   Reply With Quote
The Following User Says Thank You to Bob-o For This Useful Post:
Lex (08-13-2012)
 Old 08-13-2012, 11:07 PM   #10
The MAF Cal was likely messing with the load targets. Also less boost is not always a downside. You have to calibrate the MAF and compare airflow, not boost.
Sent from Stratified Mobile Headquarters
 Old 08-13-2012, 11:34 PM   #11
MS309's Avatar
Lex I'm away for holidays starting next week, when I'm back in September we can retune and compare both setups.
But the issue would still remain with that filter, I'll contact CS and see what they say or fab up some way of my own to seal it properly.
Also, with the current intake setup, there are less bends, only one at the inlet and the rest is straight to filter, I recall you saying somewhere less bends equals better VE ?
'11 CWP Speed3
 Old 08-13-2012, 11:37 PM   #12
dantes5823's Avatar
Posts: 6,674   (View Stats)
Hmm I wanna see the ram air setup dialed in and dailied. I almost got this kit a while back but shit happened and I had to stop it. Lex convince him to go ram air again lol.
 Old 08-14-2012, 12:59 AM   #13
Track Fiend
Standsideways's Avatar
Posts: 405   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
Sure less bends= more VE..thats common sense.
But that big ram air box with the scoop likely blows the SRI out of the water.
Get the maf cal and tune on that ram air box going OP
Standsideways is offline   Reply With Quote
 Old 08-14-2012, 08:02 AM   #14
MS309's Avatar
I'm trying to get a PN for the filter via CS, its just a k/n pre oiled one, fix up the maf cal and give it another shot.
'11 CWP Speed3
 Old 08-14-2012, 08:09 AM   #15
[QUOTE=MS309;1558180]I'm trying to get a PN for the filter via CS, its just a k/n pre oiled one, fix up the maf cal and give it another shot.
If it is just a generic K&N filter, give JB Automotive a shout when you get the PN; they carry a lot of K&N's @ their west end store
 Old 08-14-2012, 11:56 AM   #16
MS309's Avatar
PN: 33-2319 in case anyone else needs it. its $70 @ partsource/JB's and has to be ordered since no one has it in stock. So I'm just going to improvise and ductape seal the current filter around the box, trim the shroud by the intake pipe a little and make this work. Its raining all day today so lets see what happens.
forgot to mention earlier, the small under tray towards the front of the bumper doesn't fit anymore due to the fmic core, the core clears it just fine but there are numerous tabs sticking out from the plate that can't fit due to the core, just an FYI not a big deal.
'11 CWP Speed3
 Old 08-14-2012, 12:30 PM   #17
Scammer Hunter
Raider's Avatar
Posts: 14,849   (View Stats)
Groans: 448
I had issues with my stock weight and CPE CAI. Cut the weight down. Lighter is better.
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
Raider is online now   Reply With Quote
 Old 08-14-2012, 12:41 PM   #18
Ryguy's Avatar
Posts: 390   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Groaned at 4 Times in 2 Posts
K&N 33-2319 High Performance Replacement Air Filter:Amazon:AutomotiveK&N 33-2319 High Performance Replacement Air Filter:Amazon:Automotive
Alot cheaper.
2012 MS3-COBB AP, SRI, TIP, air box; Autotechs; CS TMIC, strut bar, lca bar, occ, boost tubes, flaps, hangers; Forge BPV v2; TWM full replacement; Cobb rmm; ebay dp; UR ABE; NGK 6510; DDM 5000K; Dizzy tune in progress
Ryguy is offline   Reply With Quote
The Following User Says Thank You to Ryguy For This Useful Post:
MS309 (08-14-2012)
 Old 08-14-2012, 10:53 PM   #19
MS309's Avatar
so you guys are gona love this. I sealed up the intake to the box, adjusted the intake piping a little and made the shroud fit better this time, it's still a little raised up on the right side, but I believe that's because of how the piping is coming out of the box, also I can't tighten that right side any more since the bolt eventually touches the ram air box. anyway, it seals pretty damn good, hood closes just fine with a little force.
also adjusted my maf values, drove around a little to let the trims settle and took this log. Car does indeed drive better with the proper seal, and it does pull harder up top. max g/s was 260, looks like I gained a good 15-20 g/s over a traditional SRI setup; boost and load are also up. so Thank you all for making me give this another shot, it does work and it works very well, I didn't know it would actually make a difference. !! Brydon@CorkSport
someone plot this on VD !
EDIT: wanted to also mention, after getting home I looked at the filter again and what I noticed was that due to air flow the fins at the front itself get pushed backwards, which would explain why it looses its seal eventually, the tape I used is still intact so there are no gaps between the filter and box. And I also drove around in heavy rain today, water doesn't get in there at all
'11 CWP Speed3
dantes5823 (08-15-2012)
 Old 08-15-2012, 07:16 AM   #20
dantes5823's Avatar
Very nice. Glad rain doesn't get in there. How's the turbo sound?
 Old 08-15-2012, 08:30 AM   #21
MS309's Avatar
Quite. No more whoosh or psshh. I just hear more of tranny and engine noise from the mounts now.
'11 CWP Speed3
 Old 08-15-2012, 08:52 AM   #22
dantes5823's Avatar
Oh that sucks. No more ricer noises for you lol. I know the feeling. Stupid gtx. But I haz ewg to keep me happy lol.
 Old 08-15-2012, 09:03 AM   #23
JDW1's Avatar
Posts: 312   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
I've always liked this set up but from what I've heard having the ram air kit for some one like me in a hot climate it would cause higher IAT's making it harder to get the BAT's down. More g/s at speed yes but the main purpose of getting a FMIC would be lower BAT's.
Have you noticed any think of the sort? I see your BAT's look pretty low.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas self tune
JDW1 is offline   Reply With Quote
 Old 08-15-2012, 09:18 AM   #24
MS309's Avatar
Haven't noticed anything of the sort yet since I just put this on recently, but after driving around during the day I checked the filter and ram air box, it was normal temp, cooler than the rest of engine bay.
I can take a small log just driving around the city, that should give a good idea of what's happening.
'11 CWP Speed3
 Old 08-15-2012, 09:27 AM   #25
Pu Manchu's Avatar
Posts: 3,475   (View Stats)
Groans: 382
Groaned at 66 Times in 63 Posts
How do you figure? Ambient temps from outside<Underhood Air temps
Pu Manchu is online now   Reply With Quote
 Old 08-15-2012, 09:48 AM   #26
JDW1's Avatar
I've seen logs posted (granted from a warmer climate) where BAT's weren't as low as hoped and the IAT readings were way above ambient. The IC can only drop the temps so much lower than the air temp coming in. It made sense seeing how the ram air kit is sitting right on top of the engine. Kind of like how you see a little lower IAT's with a CAI vs SRI.
 Old 08-15-2012, 09:48 AM   #27
MS309's Avatar
Lol I need less noise, it's all racecar sounds on the inside already with shit rattling everywhere.
I'm excited to see how much more timing can be run now.
'11 CWP Speed3
 Old 08-15-2012, 10:36 AM   #28
Floridaspeed's Avatar
Posts: 94   (View Stats)
Floridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond reputeFloridaspeed has a reputation beyond repute
MS309 I'm doing the same setup. I really like the idea of having air go through the hood scoop to feed the intake. Today I ran into a problem. Don't ask me how but the rubber part under the hood scoop when you open the hood ripped off my car. I think the main purpose of this part was to feed the TMIC as much air as possible.
Will this effect the Ram intake? I will still have the shroud on top of it. I'm thinking with the intake sucking in air it shouldn't really effect anything but I wanted to be sure! Especially with the potential water issue. I have an E-mail to Corksport asking as well but figured I ask here as well.
Thanks bud.
Mods in order: CS SRI/TIP//JBR RMM//JBR Bushings//COBB AP//AT Internals//CS RP//UR DP//JBR Short Shift Plate//DIZZY TUNE// CS FMIC // UR CBE // Forge V2 BPV// BNR S3//3 Bar Map sensor
Next Mod: meth or E85
Floridaspeed is offline   Reply With Quote
 Old 08-15-2012, 11:03 AM   #29
MS309's Avatar
Thanks bud.
can you post a pic of where it ripped off from ? I'm thinking maybe you can just buy weather strips of similar thickness and glue em on top where the rubber ripped off. I think having that tight seal is cruicial to this intake's function, I ran it without the shroud (i.e no seal) and it didn't have the same effect.
Regarding the water issue, from what I noticed water doesn't really get in that far, also do what I did and seal the filter around the box before putting on the shroud.
'11 CWP Speed3
 Old 08-15-2012, 11:28 AM   #30
CorkSport's Avatar
Posts: 1,251   (View Stats)
CorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the world
Groaned at 6 Times in 6 Posts
We sell the panel filters for $63 if someone needs a replacement. Being in Canada I would check locally like you did to see if it is cheaper than having one shipped to you.
We have tested out the ram air setup by running the car through a car wash and driving the setup in the rainiest days we have here in the North West. Unless you submerge your car you should have no problems with water. The water that gets to the filter gets evaporated by the passing air and pulled through the engine as water vapor.
-Derrick
WWW.CORKSPORT.COM
CorkSport is offline   Reply With Quote
The Following User Says Thank You to CorkSport For This Useful Post:
MS309 (08-15-2012)
 Old 08-15-2012, 11:39 AM   #31
Posts: 5,634   (View Stats)
Groans: 58
Wafer injection! Not that you would need it when it is raining,lol.
Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
CorkSport (08-15-2012)
 Old 08-15-2012, 06:29 PM   #32
I will definitely post some pics. Can't now but will tomorrow. If you open the hood it is the rubber square thing underneath the hood scoop on the inside. It got caught on the RAM filter because I'm an idiot and didn't put the shroud on. When I tried to open it this morning I felt it get caught and forced it up (again I'm a dickhead)
I think it was just to force more air into the stock TMIC. With the Ram intake acutally sucking in air I'm sure it will be fine.
 Old 08-15-2012, 09:11 PM   #33
CorkSport's Avatar
That is a bummer. Is the seal in good enough shape to re-install?
WWW.CORKSPORT.COM
 Old 08-16-2012, 05:44 AM   #34
I don't think so. Mostly all of the holes ripped on it. I could probably glue it up there lol. Would you highly recommend getting a new piece?
 Old 08-16-2012, 10:42 AM   #35
Did you rescale the entire MAF? The gen2 is a little harder to draw direct g/s comparisons to since at WOT it DOES adjust to hit WOT AFR targets unlike the gen1.
When you're ready for a top-up I will take a closer look at the numbers but I was expecting you to see higher g/s flow.
CorkSport (08-16-2012)
 Old 08-16-2012, 12:16 PM   #36
CorkSport's Avatar
I would see if anyone has a used seal to buy here on the forum.
-Derrick
WWW.CORKSPORT.COM
 Old 08-16-2012, 12:44 PM   #37
Pu Manchu's Avatar
Groans: 382
If you're slick, you may be able to fab up your own with some garage door weatherstripping./
 Old 08-16-2012, 01:43 PM   #38
MS309's Avatar
Yes I did rescale the entire MAF.
'11 CWP Speed3
 Old 04-30-2013, 06:42 PM   #39
1sicms3's Avatar
Posts: 1   (View Stats)
1sicms3 is an unknown quantity at this point
i have this on my speed 3 and i have to say its great, i have a custom tune done by ptuning , i am fully bolted cobb down pipe, hpfp upgrade, grimspeed ported intake manifold and throttle body corksport exhaust corksport ram air/fmic, car dyno 323 whp and 364 wtq
1sicms3 is offline   Reply With Quote
CORKSPORT FMIC WHAT DO YOU THINK? blacknight87 MazdaSpeed 3/6 - Turbo Induction 12 03-24-2012 09:41 PM
Page generated in 0.53814 seconds with 37 queries
