![]() | | #1 | ![]() |
![]() Join Date: Oct 2011 Location: La Porte, Tx
Rep Power: 107 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 6 Times in 4 Posts
__________________ 65 yrs young..2012 MS3 with Tech, Cobb AP, JBR 88 dogbone, JBR Rear Swaybar,Autotech Internals..JBR 88TMM & 80PMM, HTP 3" tip with a custom fab MAF housing, UR FMIC, TWM short shifter assembly, Sure SSP and Weight, UR CBE, UR metal catted DP, UR res. TP,Forge V2 BPV, Grimmspeed EBC, Bosh 3 bar map sensor, Denso ITV22's, FoMoCo Trans Fluid, Corksport aluminum skid plate, Sonic ST8's 18X8.5X40 running PSS 245/40's, Nitrogen filled tires, GoPro Hero, Hero-2 (For those moments, adds 20+driverhp) TUNED BY: mrmonk7663 _______________________________ Team LBN BEERS--FYCN TEAM MUMFORD---FYCN |
![]() Join Date: Jan 2011 Location: Richmond, Va
Rep Power: 770 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,525
Groans: 203
Groaned at 33 Times in 18 Posts
You got a 1st gen tmic.
__________________ 2010 CBM W/ Tech, Cobb AP Tuned by rfinkle2, PTP HPFP, Ported IM, HTP 3.5" Intake, CS DP, CS TP w/QTP E Cut out, ETS TMIC, D.O WMI D07, NGK Iridium Ix, JBR EGR Delete, Coolant Bypass, JBR IM TIG, GS EBC 3 Port Mode JBR TMM 70, JBR RMM 88, JBR SSB, JBR AP Holder, Sure SSP Swift Springs, Koni Yellows, GC Bump Stops, CS RSB, Ebay Adj. Camber Arms, Sonic Tuning ST8'S 18x8.5 on 245/40/18 NT-05 |
| I got all dem pipes ![]() Join Date: Feb 2010 Location: Dallas,TX
Rep Power: 591 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
Groans: 60
Groaned at 24 Times in 24 Posts
the gen 2 shroud sits way higher. the one you got is for gen1
__________________ 2011 MS3 Cobb AP,Cobb SF, Cobb TIP, KMD interals, ETS TMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR shifter bushings, Corksport CAB, Corksport Short Shifter Plate, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, Nitto NT-555 245/45/17 E85 FREEKTUNE ![]() |
![]() | | #4 | ![]() |
This is the one I bought..looks like it came off a Genpu..so.. just get the genpu shroud and space it??? http://www.mazdaspeedforums.org/foru...-black-120653/
![]() | | #5 | ![]() |
Think I'm just going to space the shroud to fit...that way I'll get some air flow over the end tanks too. The IC is perfect to the bottom of the scoop area.
![]() | | #6 | ![]() |
![]() Join Date: Jul 2012 Location: West Palm Beach FL
Rep Power: 94 ![]() Thanks: 15
If its not that far off just shim the shroud to fit...
![]() | | #7 | ![]() |
Really like this TMIC.. under boost I'm running 10degree above ambient..just running @ 45mph holds good @ 18degrees above.
![]() | | #8 | ![]() |
![]() Join Date: Oct 2011 Location: Long Island, NY
Rep Power: 40 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
I have the same issue, bought an ETS used from a member here and it appears to be for a gen 1 as well. Post up how much spacing you have to add to make it fit properly when you do it. I was sizing it up the other day and it looks like quite a bit.
__________________ 2012 Mazdaspeed 3 - Tech - Liquid Silver - CorkSport SRI/TIP - Autotech Internals - Cobb AP - JBR AP Mount - CorkSport Interior Light Kit - SURE Street RMM - Cobb Shift Knob - Denso ITV22S Plugs - SURE Oil Rig - ETS 3.5" TMIC - SURE Boost Tubes - TiAL QR BPV - ATP Catless Downpipe - HKS Legamax Exhaust - Stratified Tune in progress |
![]() | | #9 | ![]() |
It's dark here now and I shined a light thru the scoop and the IC set flush with the bottom of it and fills the whole area...I don't feel the shroud does anything of much importants...the fit is perfect...take a look and let me know what you think.
__________________ 65 yrs young..2012 MS3 with Tech, Cobb AP, JBR 88 dogbone, JBR Rear Swaybar,Autotech Internals..JBR 88TMM & 80PMM, HTP 3" tip with a custom fab MAF housing, UR FMIC, TWM short shifter assembly, Sure SSP and Weight, UR CBE, UR metal catted DP, UR res. TP,Forge V2 BPV, Grimmspeed EBC, Bosh 3 bar map sensor, Denso ITV22's, FoMoCo Trans Fluid, Corksport aluminum skid plate, Sonic ST8's 18X8.5X40 running PSS 245/40's, Nitrogen filled tires, GoPro Hero, Hero-2 (For those moments, adds 20+driverhp) TUNED BY: mrmonk7663 _______________________________ Team LBN BEERS--FYCN TEAM MUMFORD---FYCN Last edited by shifter48; 08-13-2012 at 11:22 PM. | |
![]() | | #10 | ![]() |
| I R has bhoost ![]() Join Date: Oct 2008 Location: Calgary Alberta
Rep Power: 158 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
Groaned at 84 Times in 23 Posts
The shroud should be available from ETS. The intercooler itself is an awesome piece. Well worth the money.
__________________ Cobb AP | Cobb TIP | Cobb SRI | CS|UR|MF TurboBack | Forge ?? | Denso Plugs | ETS TMIC | AutoTechs | JBR RRM | Ksport Pro Coilovers | Whiteline Front Endlinks | 18X8.5+ 38 W/ 235 40 18s Sold 2010 Evo X 440AWHP 11.7 @ 113 2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108 2004 srt-4 s2 2006 ms6 2005 srt-4 s3 w/toys 12.16 @ 117 | |
![]() | | #11 | ![]() |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 304 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 429
I'm going to derail this thread because I truly don't care to start a new one. Has anyone had an issue with the cold pipe boost tube. I have the sure ones and the cold pipe isn't long enough to completely seal on the throttle body. I ran into an issue with it coming off under hard acceleration and boost. It just seems to short. Anyone else experience this or something familiar?
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
![]() | | #12 | ![]() |
| SFLA Nator's Toretto ![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 2907 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,535
Groans: 56
__________________ 2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail Full Race:Verticle Flow fmic//HTP:3" Inatke//ATP:Catless DP JBR:Holy Trinity,Rsb,Tigs//Forge:v.2 BPV//NGK:Plugs//AutoTechs:FP Internals PTP:Seals&studs//Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:v.1's//RotaGrids:18x9.5+38 Meth//E85//Nitrous Tunning by ms3blackmica | |
![]() | | #13 | ![]() |
Groans: 203
I have cs boost tubes, have my tmic raised 12mm and still have no problem.
![]() | | #14 | ![]() |
Yeah they were bought all while back when the group buy was going on. When it blew off I didnt have time to look I was more concerned with getting off the side of the freeway and getting to work. The hot pipe seems to long
| HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC | chimmike | MazdaSpeed 3/6 - Turbo Induction | 6 | 07-04-2011 02:18 PM |
