> 2010 MS3 - Turbo Induction
 Old 06-07-2018, 12:47 AM   #1
chorazy3's Avatar
Posts: 2   (View Stats)
chorazy3 is an unknown quantity at this point
Default JBR tru-3.0 wide path silicone intake/tih issue.
Hi guys!
I have a problem with my newly bought intake JBR tru-3.0 wide path all silicone.
The turbo inlet end of it can`t reach the end of the stock turbo, it`s too tight in there - a stock thick, black pipe under it (coolant line? marked with red arrow on the attached picture) gets in the way. I`m not sure if it`s too short, too stiff , or the TIH end of the new intake is just too fat/bulky to fit in comparing to OEM plastic TIH.
That damn pipe seems to be located too much in the front in my car comparing to the picture (picture isn`t exactly from my car) and it can not be moved away.
Have anyone had this problem ?
Is there a way to fix it ?
Thanks in advance for your help.
2012 Black Mica Mazda 3 MPS/Mazdaspeed 3
Autotech HPFP, JBR RMM, Cobb Access Port/ATR self tuned
chorazy3 is offline   Reply With Quote
 Old 06-07-2018, 03:05 AM   #2
JSmith's Avatar
Posts: 697   (View Stats)
Groans: 103
Groaned at 6 Times in 6 Posts
Common problem. Extending the hose is fairly simple.
HTP 3.5 heater hose wtf
The Following User Says Thank You to JSmith For This Useful Post:
chorazy3 (06-07-2018)
 Old 06-07-2018, 11:53 PM   #3
chorazy3's Avatar
Thanks for that info, I thought they sent me wrong part.
Is it necessary to flush the coolant fluid before you cut the line to extend it ?
 Old 06-08-2018, 03:25 AM   #4
JSmith's Avatar
Groans: 103
Probably not necessary to flush/drain the entire system. If by flush you mean bleed/burp (add more fluid, get system up to temp, rev to 2-3K RPM to heat system up and remove air bubbles) after you reconnect the hose then probably.
chorazy3 (06-08-2018)
 Old 06-08-2018, 07:26 AM   #5
sharksinspace's Avatar
Posts: 763   (View Stats)
Groans: 126
You don't cut the line, you just disconnect the stock hose from the block and add an extension piece using a hose connector. You can buy that HTP kit or build your own for cheaper at the hardware store. It adds a lot of space for larger intakes.
2007 MS3
PD by Will
 Old 06-08-2018, 07:27 AM   #6
LowFlyin's Avatar
Posts: 184   (View Stats)
LowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant futureLowFlyin has a brilliant future
Mine fits fine with a 3.5" intake. Just push it down
Sent from my LG-H820 using Tapatalk
LowFlyin is offline   Reply With Quote
The Following User Says Thank You to LowFlyin For This Useful Post:
 Old 06-08-2018, 01:13 PM   #7
tegxsi's Avatar
Posts: 1,240   (View Stats)
Groans: 87
I didn't extend the hose for 3" HTP. The TIP does touch heater hose when installed but the hose is sleeved so I'm not too concerned. For 3.5" or larger I would definitely extend the heater hose.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 06-10-2018, 08:18 PM   #8
Solarsurge's Avatar
Posts: 571   (View Stats)
That hose is a pain in the ass. It's ALWAYS in the way no matter what you're doing. It has a good bit of flex, though. I've pushed and pulled on mine for 2 years through two turbos and inlet pipes going in and out. It's still as strong today as it was the first time. With my never ending build, I am only replacing hoses that absolutely need to be replaced, and that hasn't been one of them yet.
 Old 06-11-2018, 04:54 AM   #9
KiwiFlavor's Avatar
Posts: 2,446   (View Stats)
You can source your own for like $5 or so for everything.
2012 NASA Spaceship Gray MS3
New Product Release…JBR 3.5" Wide Path IAS Full Silicone Intake Systems for MAZDASPEED 3/6 JBR JAMES BARONE RACING 51 03-27-2014 07:12 PM
Page generated in 0.32031 seconds with 27 queries
