> 2010 MS3 - Turbo Induction
Like Tree5Likes
 Old 02-29-2020, 06:44 PM   #41
55suarod's Avatar
Posts: 39   (View Stats)
55suarod is a jewel in the rough55suarod is a jewel in the rough55suarod is a jewel in the rough55suarod is a jewel in the rough
Originally Posted by shaneski View Post
Give the MAF a clean as well.
Yup, did that last Sunday already.
55suarod is offline   Reply With Quote
 Old 03-01-2020, 03:37 PM   #42
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Originally Posted by Jeff23spl View Post
are you sure it is spark blow out at just 11psi with a good gap ? have you tried old plugs in case 1 is bad ? You may try copper but i would also check connection, grounding and wiring as usually oem spark can handle way more boost without issues with close gap...
Agree. It usually takes boost in the neighborhood of about 18 psi or higher, combined with a plug gap more like .035” or greater before we get boost induced spark blow out on this engine.
One step colder NGK plugs come with a huge gap, more like .045” and might produce blow out at stock boost level, but I doubt that would happen at just 11 psi. Gap to .026”, as suggested by Justin while he is tuning.
Jeff23spl likes this.
 Old 03-01-2020, 08:53 PM   #43
55suarod's Avatar
Originally Posted by MSMS3 View Post
...Gap to .026”, as suggested by Justin while he is tuning.
Yea man they are gapped as directed.
I am going to try the EGR cleaning, copper wire mode, and fuel system cleaner. If nothing fixes it im going to have to take it to speedperformance here in NJ.
The Following User Says Thank You to 55suarod For This Useful Post:
MSMS3 (03-01-2020)
 Old 03-02-2020, 09:02 AM   #44
Jeff23spl's Avatar
Posts: 2,238   (View Stats)
don't give too much hope on fuel cleaner cans...
At the beginning i did try ngk with something like 0.042'' gap and it was misfiring above 12-13 psi. bringing them to proper 0.026 make it bend a little further than 90deg....it looks weird but it is needed.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
MSMS3 (03-02-2020)
Need help deciding to replace turbo or not mazdamx3freak MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 03-24-2016 06:24 PM
Help deciding on ms3/ si, etc jaco1234 Mazdaspeed3/6 General Discussion 42 03-02-2009 02:49 PM
Help deciding on ms3/ si, etc jaco1234 MazdaSpeed 3 - Engine, Transmission & Driveline 39 02-23-2009 01:58 PM
Page generated in 0.30922 seconds with 23 queries
