> 2010 MS3 - Turbo Induction
 Old 07-08-2014, 08:22 PM   #1
CleanMS3's Avatar
Posts: 27   (View Stats)
CleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond repute
Default Possible blown turbo?
I recently got tuned on my k04 at 22psi on 91 oct by Lex at stratified. It was running good. Then last week I went with Lex again for an e85 tune and for the first 40 miles my car was running strong. The next day before I went to work I took 2 datalogs which both ended up with fuel cut.
I had an overboost code and I saw the vacuum caps on the bottom port of my WG, and the one on the compressor were torn. I replaced them with silicone caps and went for a test run. Now I'm boosting 13psi starting at 3k rpm and 15psi by 6k.
I've checked all the lines, my bov, there's no blow-by, no smoking turbo, nor is there shafts play. Anyway, here are my logs.
Sent from my SM-G900T using Tapatalk
CleanMS3 is offline   Reply With Quote
 Old 07-08-2014, 08:23 PM   #2
speed23's Avatar
Posts: 1,477   (View Stats)
No log attached
 Old 07-08-2014, 08:25 PM   #3
CleanMS3's Avatar
3rd gear
 Old 07-08-2014, 08:39 PM   #4
CleanMS3's Avatar
here are my logs with the fule cut. 4th gear
 Old 07-09-2014, 12:31 AM   #5
shaneski's Avatar
Posts: 490   (View Stats)
Possibly something to do with waste gate actuator or spring ?
 Old 07-09-2014, 06:41 PM   #6
CleanMS3's Avatar
Ended up being that I got tuned with my vacuum caps being cracked. I had a small leak and once I started to get tuned for e85 the vacuum caps were complete torn off. Which is why I got fuel cut, then once I fixed it I was boosting only 13psi.
The Following User Says Thank You to CleanMS3 For This Useful Post:
speed23 (07-09-2014)
Blown turbo acidhalo 2010 MS3 - Turbo Induction 24 10-16-2013 02:08 PM
Another Blown Turbo... dcamp2 Gen2 MS3 General Discussion 75 06-29-2012 10:35 AM
Blown Turbo JD80 Gen2 MS3 General Discussion 23 07-27-2011 08:23 PM
blown turbo h0rsies MazdaSpeed 3/6 - Turbo Induction 1 07-07-2010 05:42 AM
Page generated in 0.26145 seconds with 23 queries
