> 2010 MS3 - Turbo Induction
Bookmark and Share LinkBack Thread Tools Display Modes
 Old 03-11-2010, 08:33 AM   #1
Driver
Fobio's Avatar
Posts: 1,808   (View Stats)
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
Default Pro-sport EGT Bung replacement suggestion?
I have a Prosport EGT gauge that's missing the EGT bung...I msg'd them and they want $10 plus shipping...might be $20 be it gets to Canada. Any other suggestion?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
DONE . Cobb AP Stg 2 SF+ FMIC 1.06 tweaked . Cobb SRI w/ AEM dry-flow . RPMC inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . PTP IM Spacer w/ EGR delete . GrimmSpeed EBCS . PTP WGA . PG v3 CC'd Exhaust Manifold . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Stg 2 Suspension . Cobb STS w/ TWM bushing . JBarone SSP + weight . CP-e rear MM . PTP transmission & kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 Toyo RA1/R888 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD .
SOON . Meth . Pro-tune . GlowShift 60mm Combo Gauge . Tri-Point RSB+Endlinks . Koni Yellow . CSCS 2010 . ATTS 2010 . NEED . Driver mods . Seat/track time . Brass nuts .
-- Mario Andretti --
Fobio is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
 Old 03-11-2010, 08:35 AM   #2
phillyREPOphail's Avatar
Posts: 10,522   (View Stats)
phillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the world
Groans: 1,421
Groaned at 660 Times in 488 Posts
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10522
ebay could definitely be your friend. there are a few different flavors.
EGT stainless weld bung for pyrometer thermocouple : eBay Motors (item 350326133122 end time Mar-11-10 14:55:19 PST)
oem part numbers -
donations to the site -
creating an avatar -
do you own a miata? post in the miata section -
phillyREPOphail is online now
The Following User Says Thank You to phillyREPOphail For This Useful Post:
Fobio (03-11-2010)
 Old 03-11-2010, 08:38 AM   #3
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
I have the PG V3 manifold with the bung already welded on. This is the part I'm looking for:
Fobio is offline
 Old 03-11-2010, 09:08 AM   #4
Groans: 1,421
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10522
ohhhhhhhhhhhhhhhhhhhhhhhh...
oem part numbers -
 Old 03-11-2010, 09:15 AM   #5
djuosnteisn's Avatar
Posts: 3,703   (View Stats)
Groans: 60
Groaned at 17 Times in 17 Posts
Activity Longevity
17/20 18/20
Today Posts
7/7 sssss3703
I want an egt gauge....
Highest hp stock block ms6
449awhp 527awtq WCF
gt3071, SB + flash combo, self tuned and more on the way...
djuosnteisn is online now
 Old 03-11-2010, 09:16 AM   #6
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
there's one for sale in the FS section...good price too..just a bit more than just this freaking connector + shipping to Canada...
Prosprot wants $24 shipped...I'll bite if they can do $20...I can't be bothered with the hassle...
Fobio is offline
 Old 03-11-2010, 09:22 AM   #7
Groans: 1,421
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10522
so get them on the horn and offer them 15 shipped and see what they say...
oem part numbers -
 Old 03-11-2010, 09:24 AM   #8
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
I did...they're like that's Priority Shipping cost from USPS...I sent them an email seeing if USPS regular will be better...
this thing fits in an envelope...
Fobio is offline
 Old 03-11-2010, 09:36 AM   #9
Walrus's Avatar
Posts: 4   (View Stats)
Walrus has a spectacular aura aboutWalrus has a spectacular aura about
Activity Longevity
3/20 5/20
Today Posts
1/7 ssssssss4
Fobio, this is what you are looking for?
SS-300-1-2BT - SS Swagelok Tube Fitting, Bored-Through Male Connector, 3/16 in. Tube OD x 1/8 in. Male NPT
$9.90. Swagelok has several locations in Ontario.
Depends on the size of the probe, usually 3/16"?
First post.
Walrus is offline
The Following User Says Thank You to Walrus For This Useful Post:
Fobio (03-11-2010)
 Old 03-11-2010, 09:36 AM   #10
speedms6's Avatar
Posts: 263   (View Stats)
speedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond reputespeedms6 has a reputation beyond repute
Activity Longevity
3/20 6/20
Today Posts
1/7 ssssss263
its 4 dollars. that big of a difference?
2007 Mazdaspeed 6 - CP-E CAI, CP-E Inlet Pipe, HKS SSQV Limited Edition Black Recirc, ETS 3.25" TMIC, Street Unit Test Pipe, Denso ITV 22, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, 6000K Low Beams, LED Parking and License Plate Lights
speedms6 is offline
 Old 03-11-2010, 09:53 AM   #11
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
First post.
Thanks...I'll take a look!
Not if it was a $50 part...but seriously, this is a $2 part...they want to charge me more than whatit's worth in shipping.
After looking at this:
DIY: Installing Gauge EGT probe in stock location - Subaru Impreza GC8 & RS Forum & Community: RS25.com
I think it's 1/8" NPT.
Last edited by Fobio; 03-11-2010 at 09:53 AM. Reason: MSF Database - Automerged Doublepost
Fobio is offline
The Following User Says Thank You to Fobio For This Useful Post:
phillyREPOphail (03-11-2010)
 Old 03-11-2010, 10:30 AM   #12
Walrus's Avatar
Activity Longevity
3/20 5/20
Today Posts
1/7 ssssssss4
Ah.. if the compression nut is welded to the EGT probe, you are just looking for a 1/8" NPT to compression adapter. Have you tried the plumbing section at Home Depot? Although they may only have brass ones.
Walrus is offline
Fobio (03-11-2010)
 Old 03-11-2010, 10:37 AM   #13
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
Thanks to your suggestions, I looked around the local suppliers...and yeah, HD might have it and I shouldn't be lazy and just bring the 2 parts with me for fitting.
I've went back to DTC where I got the fittings for the catch-can...here's what I've found:
http://dtcindustrial.com/Steel_Adapters_v1.pdf#page=7
it's either the 5404-0202 - 1/8" Male NPT Hex Nipple or 5404-0602 - 3/8-1/8 Male NPT Hex Nipple
I emailed their sales with the pics...hopefully I'll find out soon.
Fobio is offline
 Old 03-11-2010, 11:50 AM   #14
Walrus's Avatar
Activity Longevity
3/20 5/20
Today Posts
1/7 ssssssss4
It won't be either of those.
Look in this picture:
http://i165.photobucket.com/albums/u...install007.jpg
The top thread where his finger is, is tapered, that is 1/8" NPT. The bottom (thumb) has a chamfered end, and will be a straight thread for the compression nut.
http://dtcindustrial.com/Steel_Adapt...ntinued_v1.pdf
You need something more like 768FS-0302 3/16" Tube Compression x 1/8" NPT on page 2, and you just unscrew the compression nut on the left side of the fitting and toss it, and screw that end into your probe. See the 'imperial tube nut' on the top right of the page, that is what you remove from the fitting, because that is already attached to your egt probe.
Walrus is offline
Fobio (03-11-2010)
 Old 03-11-2010, 12:34 PM   #15
Driver
Fobio's Avatar
Groans: 40
Activity Longevity
9/20 19/20
Today Posts
1/7 sssss1808
They have all 3 in stock...I plan to drop by sometime this week and it's about $10 - 12 for each.
Thanks!
Fobio is offline
 Old 03-16-2010, 05:07 AM   #16
Walrus's Avatar
Activity Longevity
3/20 5/20
Today Posts
1/7 ssssssss4
Update?
Walrus is offline
Thread Tools
Synthetic transmission oil suggestion jamesjjj 2010 MS3 - Engine, Transmission & Driveline 15 02-09-2010 09:13 AM
O2 sensor bung, is AEM = innovate for bung size? marcusdigi MazdaSpeed 3/6 - Turbo Induction 5 07-19-2009 07:16 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 01:30 PM
Forum Suggestion freebird_78
MazdaSpeed Forums - Lounge/New Member Welcome
1 11-05-2008 05:11 PM
Suggestion for AP software ... Stan-O
Cobb Access Port/Maps
6 07-30-2008 07:57 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.1
Advertisement System V2.6 By   Branden
©Copyright 2008 ; 2010 Cymru Internet Services LLC
Page generated in 0.53715 seconds with 59 queries
