> 2010 MS3 - Turbo Induction
Notices
Like Tree19Likes
 Old 06-18-2012, 02:31 PM   #81
Alpha's Avatar
Posts: 3,430   (View Stats)
Groaned at 66 Times in 49 Posts
Originally Posted by Ezekiel81923 View Post
So it's more expensive but I don't need to buy an EWG or a BOV. That's good to know. That right there is 500-600$
And they fit back there in the stock location?? That's even better to know. I'm going to watch the tutorials and try that matchbot and see how the 7163 and 7670 would work on my car. Again, not going for crazy power output but in the 400 range and quick spool is what attacts me to these, the GTX's and the Precisions
My exhaust manifold is T3 flange so I would need a T3 flanged turbine housing.
SFWD 1934 Can you mix n match compressors with turbine housings or is that not an option or a good idea?
Yup, they really are a complete package.
Running an EFR turbo without a Full Race manifold would be an epic sin lol
PERM Tuned - EFR 7163 Street Sleeper
Alpha is online now   Reply With Quote
 Old 06-18-2012, 02:37 PM   #82
Ezekiel81923's Avatar
Posts: 351   (View Stats)
Ezekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the world
Groaned at 10 Times in 4 Posts
Originally Posted by Alpha View Post
Yup, there really are a complete package.
Perhaps, but $1300 for an exhaust manifold is pretty steep for me. The Steedspeed T3 EWG was ~$500 less
2011 VMR Mazdaspeed 3
Precision CEA 5858 forthcoming...
Ezekiel81923 is offline   Reply With Quote
 Old 06-18-2012, 02:38 PM   #83
SFWD 1934's Avatar
Posts: 682   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
The only option you have is if they make a turbine housing in a different AR. So lets say you are looking at a turbo that comes with an .82 hot side. You say to yourself you know I think I want to have a little bit more top end, so I want to go with a .90 or 1.01 hot side. You cannot just say oh look I want that one. They are all machined with certain clearances for that turbine wheel.
Now with that being said, you need to see what fits you best for your application. Some guys will opt to go larger on the hot side to like I said get more top end. Now this is where it can be a double edged sword. It allows to you to push that power out, but if you do not have the head and/or ability to flow higher in the RPM range is is kind of pointless.
Honestly for the money that you are going to spend, which between the 3 units is very close I would rock the EFR every day of the week and twice on Sunday.
A 5252 with an .82 hot side is going to run you around $700.
A Tial MVS gate will run you about $330
A Tial Q BPV will run you about $225
A total of roughly $1200
A Speed 3 specific GTX3071 will run you about $1800
A 4 bolt T3 .82 GTX3071 will run you about $1700
An EFR 6758 will run you about $1400
An EFR 7670 will run you about $1500
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 3 Users Say Thank You to SFWD 1934 For This Useful Post:
Alpha (06-18-2012), Don06speed6 (06-19-2012), rfinkle2 (06-18-2012)
 Old 06-18-2012, 02:40 PM   #84
rfinkle2's Avatar
Posts: 12,640   (View Stats)
Groans: 235
I guess the idea is simply to wait if you want one of these turbos.
Is there an idea of when one will definitely be able to pick up one of these turbos. i.e. assume that you aren't getting the first turbo and that they are widely available?
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
 Old 06-18-2012, 02:46 PM   #85
Alpha's Avatar
Not sure where you got that price, but the MZR manifolds are 1099 MSRP and are sold through Edge Auto for $899 with their infamous lifetime warranty.
You also can't compare a Steedspeed manifold to Full Race's work. It's on a whole other level.
 Old 06-18-2012, 02:46 PM   #86
SFWD 1934's Avatar
Is there an idea of when one will definitely be able to pick up one of these turbos. i.e. assume that you aren't getting the first turbo and that they are widely available.
I have some that will be coming in September 19.
Jason
www.full-race.com
The Following User Says Thank You to SFWD 1934 For This Useful Post:
 Old 06-18-2012, 02:51 PM   #87
Posts: 5,718   (View Stats)
Groans: 121
Jason
You will have 6758's for sale at $1400 and 7670's for $1500?
You and me need to talk.
silvapain is online now   Reply With Quote
Alpha (06-18-2012), rfinkle2 (06-18-2012)
 Old 06-18-2012, 03:02 PM   #88
It's $997 on Edge and that's for the regular ProStock manifold (that's before the famous MSF discount obviously).
The T25 EFR exhaust manifold is $1227 + $95 for coating (which the steedspeed comes with) per the full race website. I assumed this is the one you were talking about since we were talking EFR turbo's
I'm not trying to argue with you, I'm sure its a wonderful manifold but I'm not biting on much of anything at that price. For the setup I originally had planned the SteedSpeed was more than good enough, and should still be regardless of what Turbo I end up going with.
Jason
That's more or less it right there. I was actually looking at the S252 with .55 A/R or Precision 5557 with .63 A/R just to ensure I get quicker spool. I've read plenty of drivers on other platforms (SRT's, Cobalts, Evo's mainly) running 400whp-500whp on those turbos/housings no problem so it'd suit my needs perfectly fine.
The larger turbine housings that the EFR's come with made me nervous at first but if the word is even with a .82 A/R housing it'll still spool lightning fast then I guess I won't argue with the numbers.
Last edited by Ezekiel81923; 06-18-2012 at 03:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-18-2012, 03:02 PM   #89
SFWD 1934's Avatar
My number is at the bottom. You can give me a call whenever.
Jason
www.full-race.com
The Following 2 Users Say Thank You to SFWD 1934 For This Useful Post:
Alpha (06-18-2012), silvapain (06-18-2012)
 Old 06-18-2012, 07:34 PM   #90
Alright...
I dunno if this is really considered "narrowing it down" but I think I've got it down to 3.
Bullseye S252 Batmowheel w/ T3 .55 A/R 4-bolt housing (w/ 4-bolt to V-band apapter) ~$1500
Precision Billet BB 5557 (4" ported inlet) w/ T3 .63 A/R V-band housing ...$1439
BorgWarner EFR 6758 / 7163 with T25 V-band housing ...$ ??
All are pretty close in price and ALL are much less expensive than the GTX's. If I went EFR I'd probably sell the Steedspeed and use the money saved on not needing an EWG and BOV to buy the T25 EFR manifold.
That of course assumes I can even get a BW in the next couple months. If I knew I could put money down now to guarantee myself one by fall then I'd do it.
Here's looking at you SFWD 1934
The Following User Says Thank You to Ezekiel81923 For This Useful Post:
Alpha (06-18-2012)
 Old 06-18-2012, 08:52 PM   #91
SFWD 1934's Avatar
Ezekiel81923
You get the money set up, and you can have yourself and EFR this fall.
Jason
www.full-race.com
Alpha (06-18-2012)
 Old 06-18-2012, 09:25 PM   #92
Eth Fiend
phate's Avatar
Posts: 4,336   (View Stats)
phate has disabled reputation
[8374]
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
Alpha (06-19-2012), Realgib3 (06-24-2012), rfinkle2 (06-19-2012)
 Old 06-18-2012, 09:49 PM   #93
SFWD 1934's Avatar
I know the graph that I am about to show is not the best, but it will give you some idea of what to expect once you go EFR. The two cars are both on a Full-Race manifold. The Gen 1 car has the Pro Stock with a GTX3071, the Gen 2 car has the T25 with the 7163. The 7163 was running just off the gate preload, which was set to 12 PSI. The GTX3071 was running about 20 PSI. There will be more graphs from the 7163, I am waiting for the Sure Halos to get here, so I can put them through the paces as well.
Jason
www.full-race.com
Alpha (06-18-2012), Ezekiel81923 (06-19-2012), rfinkle2 (06-19-2012)
 Old 06-19-2012, 03:17 AM   #94
rfinkle2's Avatar
Groans: 235
SFWD 1934...
I'd be all over that 7163 as well, but I am afraid in the fall, Borg Warner will not be able to produce the turbos, or the amount of turbos needed.
Is there any way of us knowing they will definitely be available by a particular date? If so, I would put a deposit on one.
dr_banano (06-21-2012)
 Old 06-19-2012, 03:41 AM   #95
SFWD 1934...
Haha that's essentially the exact same thing I message him about. We might have Full-Race sold out of EFR's before long!
 Old 06-19-2012, 05:19 AM   #96
86azms3's Avatar
Posts: 3,065   (View Stats)
86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world
Groans: 256
Groaned at 79 Times in 41 Posts
Jason
So what's this compare?
Either way...my best advice is to ditch the k04...whatever it is you'll be happy. Just don't go overboard with sizing.
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP,
Turbosmart Hybrid bpv, SURE TIG's + coolant bypass,
ITV24's, CP-E 75d RMM, Medefail Tranny mount,
DDM 35W 6000K HID's, SURE Counterweight,
18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's
390whp/400wtq
86azms3 is online now   Reply With Quote
The Following User Says Thank You to 86azms3 For This Useful Post:
 Old 06-19-2012, 05:33 AM   #97
Ziggo's Avatar
Posts: 3,093   (View Stats)
I am glad I dropped in here. I have been futzing around getting the other pieces in place to support a 7163. So mid- September is the word? I would be picking up a package, manifold, turbo and downpipe.
I am very interested in the prospect of an IWG T4 divided housing, particularly if someone can supply a manifold to go with it. I'd wait longer for that.
Ask Me About My:
Ziggo is online now   Reply With Quote
 Old 06-19-2012, 07:30 AM   #98
Alpha's Avatar
Thumbs up
6258 and 6758 turbos in august/sept time then 7163 in nov/dec.
The T4 TS housings are a strong possibility and if we do get them, Full Race will have us covered manifold wise.
Once I get built I'm definitely going to be waiting to do a T4 TS hotside/manifold swap if it comes out.
The Following User Says Thank You to Alpha For This Useful Post:
 Old 06-19-2012, 01:27 PM   #99
As of now through the 7163's will be T25 flanged right?
This is hard work hahah. Getting one of these when they first come out won't be easy and then being prepared for any turbine housing changes (and subsequently waiting for manifolds to be adapted for those) is going to be a process.
 Old 06-19-2012, 01:33 PM   #100
Alpha's Avatar
The 7163s, as of now are T25 flanged and Full Race has a manifold available for them.
If and when the T4 housing is released, I'm sure their T4 manifold will be as well.
 Old 06-19-2012, 02:49 PM   #101
SFWD 1934's Avatar
The 7163 was designed to be a "drop in" replacement that is interchangeable with the 6258/6758 turbo. It has almost identical spool as the 6758, but will flow more on the top end and allow for a higher peak HP. There are supposed to be new turbine housing options for the 7163, but I am not sure what those are at this point. Honestly we will probably find out at SEMA this year what exactly those options are. I know that there is a T4 twin scroll that is coming out for the 6758. The 7163 has the new lighter aluminum center bearing housing.
My plan now is I am going to bring some of the 6758 units with me to the Mazfest in September this year.
Jason
dr_banano and rfinkle2 like this.
www.full-race.com
Alpha (06-19-2012), dr_banano (06-21-2012)
 Old 06-22-2012, 05:44 AM   #102
Alright well for me personally I think it's between the EFR 6758 and the Batmowheel S252.
The nice thing about the Batmowheel is I can have it now, and all I need is an adapter to convert the turbine housing to V-band. The EFR would require an all new manifold and a "more custom" DP than I had already planned.
Time to watch some dyno vids and check out some maps.
Alpha (06-22-2012)
 Old 06-22-2012, 08:23 AM   #103
Alpha's Avatar
Once my new motor and clutch go in I'll have a mess of high boost videos up to show you guys what these EFRs can do.
 Old 06-22-2012, 08:52 AM   #104
Unicorn Farts
Deldran's Avatar
Posts: 2,188   (View Stats)
Groans: 96
Groaned at 35 Times in 28 Posts
Just out of curiosity why doesnt anyone ever look at turbonetics turbos?
rfinkle2 why you no use gtx2867, or whatever number it was. it turn out to be a crappy turbo or something?
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
 Old 06-22-2012, 08:57 AM   #105
rfinkle2's Avatar
Groans: 235
No, not @ all (crappy turbo). I wish it had a longer outlet on the hotside, but I can have that addressed.
I also wish it had an integrated high pressure boost source, but that can be addressed as well.
Also wondering about any creep, considering ATP seems to have dropped the ball on the IWG on there Mazda offerings.
Little things that wouldn't bother some people make me antsy about ATP as a turbo choice, but they are one of the only companies with a so-called drop in solution @ this time.
I'm worse than any woman when it comes to parts choice.
It is a good turbo for certain power goals, no doubt.
 Old 06-22-2012, 10:28 AM   #106
Voltwings's Avatar
Posts: 1,740   (View Stats)
Groaned at 34 Times in 14 Posts
i just installed my 3071 and felt tapping the silicone was slightly sketchy so what i did was just run my boost controller to my vacuum block. That block is fed by the manifold nipple that would normally go to the BPV, and then it disperses the boost/vacuum equally through up to 6 ports. I have my BPV, Meth, Boost gauge and now this, going off that block, its MUCH cleaner than just having T's everywhere, going to start tuning in about an hour so we'll see if this works.
Sorry for the janky pic, its bright and i scratched the lens on my phones camera.
GTx3576, 93 + Direct Port Meth -
Self Tune in progress...
Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar.
Limitless Performance and Fabrication Built:
K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth.
TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN
Voltwings is online now   Reply With Quote
The Following User Says Thank You to Voltwings For This Useful Post:
rfinkle2 (06-22-2012)
 Old 06-22-2012, 11:41 AM   #107
Ziggo's Avatar
I don't know specifically about the ATP wastegates, but I know damage has occurred in the past from applying vacuum to the actuator so I don't think that's a great idea. They are not meant to be "sucked" on
Zigatapatalka
Ask Me About My:
rfinkle2 (06-22-2012), Voltwings (06-22-2012)
 Old 06-22-2012, 01:25 PM   #108
I have looked at them but honestly don't know shit about them.
I can't identify an offering with a T3 hotside that compares to any of the other Billet compressor wheel turbo's (S252 Batmowheel / Precision 5557 / GTX3071R / BW EFR 6758)
I'd like to know more though, a few people run 50trim Turbonetics and make a lot of power with them.
 Old 06-22-2012, 01:42 PM   #109
Unicorn Farts
Deldran's Avatar
Groans: 96
They have alot of options for turbos if you look at there site. I am not yet very well versed in what all the differnt trims mean but here is a link
T3/TO4B Turbochargers | www.TurboneticsInc.com - Boosting Since 1978 | turbochargers, intercoolers, wastegates, blow-off valves, controls, boosting systems, turbo kits, forced induction parts & accessories
Those seem to be comparable to a GT or GTX30R. t3 turbine housing, with a t4 compressor housing.
 Old 06-22-2012, 04:20 PM   #110
covelife1016's Avatar
Posts: 5   (View Stats)
covelife1016 will become famous soon enough
I have a holset hx35 with aT3 .70ar hotside from back in my dsm days. Anyone thoughtabout running one?
covelife1016 is offline   Reply With Quote
 Old 06-22-2012, 06:10 PM   #111
I think I'm pretty set on the S252 BatMoWheel. I've only seen a few maps / dyno charts of it, can't find any videos of it, but it looks like it spools really fast on the Cobalt and SRT platforms so I'd think it'd spool just as well if not better on ours given the correct supporting mods. Also a lot of Cobalts hitting 500whp+ on this turbo, way more than I'd ever need.
Can't find many places that still sell it. Curious if the options available on other BEP BatMo's are available on this little guy. Like a V-band turbine housing or a double BatMo set up.
I'd be afraid to jump to the 256 or 259, don't want to lose the fun on the bottom end.
Waiting to hear back from some folks on their impressions. We. Will. See.
 Old 06-24-2012, 12:02 PM   #112
Realgib3's Avatar
Posts: 1,427   (View Stats)
Groaned at 14 Times in 7 Posts
I'll just never understand all you guys wanting to run these little turbos that make huge tq numbers... on FWD cars... I've never seen such a premium put on "Spool time" from ANY other platform. It's just mind boggling to me.
On a speed 6, were the tq can be utilized, yes, by all means go with a smaller efficient BT so you can have near identical HP/TQ number, but on a 3 that logic just doesn't make sense.
Anyway, good luck but you (and everyone else that can't get off the "initial spool" train) would be much better off with a car with a flat 350-375 tq from 5k-RL, making 450+ hp, than a car making 400hp but even more tq.
Built Motor
PTE 6466 BIG Turbo
Tuned by me
4 cylinders... 6 injectors... Because Racecar
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
86azms3 (06-25-2012), Fatguy729 (06-24-2012), Pseud0logik (06-24-2012)
 Old 06-24-2012, 03:59 PM   #113
SFWD 1934's Avatar
Bullseye turbos are worked Holset units with the nice compressor wheel. Real Holset units are not the cheapest and you want to be very careful of those nice China replicas that are sold.
Jason
www.full-race.com
 Old 06-24-2012, 04:10 PM   #114
got mine off a cummins and got the hotside from a fellow dsmer.
Tyler K.
CS sri,tip,ssp// AT hpfp// COBB ap// JBR rmm// GFB bov
 Old 06-24-2012, 05:39 PM   #115
Jason
Are you implying the Bullseye's are one of the nice China replicas? Wasn't sure if those were separate thoughts.
At least from pictures It looked like the Bullseyes still used a BW compressor with an extended top (Batmowheel) compressor wheel. Every compressor I've seen still says BorgWarner (at least it does on the S252)
 Old 06-25-2012, 12:07 AM   #116
SFWD 1934's Avatar
No there are a bunch of people who try to pass off $300 China turbos as Holset units.
Jason
www.full-race.com
 Old 06-25-2012, 03:38 AM   #117
SpdDemon89's Avatar
Posts: 215   (View Stats)
SpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the world
I run a k04 because its what was on the car when i bought it :cry:
'12 S3 Black
CS intake+TIP - AT Internals - JBR RMM - UR DP+TP - CPE TMIC - Denso ITV22 - Carseat 25hp shot
SpdDemon89 is offline   Reply With Quote
 Old 06-25-2012, 12:35 PM   #118
Jason
Best place to get a used holset would definitely be on a cummins forum in the classifieds. Not that your in the market for one, just for anyone that is.
Tyler K.
The Following User Says Thank You to covelife1016 For This Useful Post:
SFWD 1934 (06-25-2012)
 Old 06-25-2012, 12:47 PM   #119
theschrum's Avatar
Posts: 920   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
Groans: 24
I started with the ATP GT2872,
Switched to a T3 housing,
I am currently installing a Billet 6262.
06 Speed 6 GT|Build in progress: T4 T/S Billet 6262, EWG, Wiseco Pistons, K1 rods, FMIC
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
 Old 06-25-2012, 04:21 PM   #120
I can't disagree with you here. I'm looking for a middle ground I think, not something that seems non-existent until it hits like a ton of bricks at 4200rpm but rather something that feels like it's always there, gradually building. Though I suppose if 390wtq feels like it's always there it's probably because it is.
I just don't want to have to keep switching out hot sides until I feel the response I'm looking for, that's why I put so much emphasis on it now. I want it to be right the first time.
GARRETT 3" Turbo Inlet Pipe Kit Blackedout1978 2010 MS3 - Turbo Induction 3 03-13-2012 12:51 PM
Garrett SRI?!?!?! bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 8 09-02-2008 03:33 PM
Page generated in 0.64182 seconds with 34 queries
