Notices
Like Tree10Likes
 Old 09-13-2012, 02:42 AM   #1
Reedy's Avatar
Posts: 145   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Default 4 Piston Brake Kits for a 2010 MS3 (and what happens when you push the stock brakes as far as they will go)
Ok I have started shopping around for some 4 piston brakes because I have reached the limits of what the stock ones can handle at the track. With racing compounds and rotors the stock brakes flex way too much on their guide pins and that causes the pads to wear very unevenly.
By that I mean this:
Here's a video showing the way the caliper flexes once the pads have worn unevenly.
That is all caused by me doing this:
That is using Project Mu Club Racer Pads with DBA4000 slotted Rotors. Combined with Yokohama A050 semi slicks you can see why my brakes are copping a bit of a flogging. They actually do a fantastic job of pulling the car up, the problem is with excess heat causing my ABS sensors to start melting, and rapid/uneven wear of consumables - this alone could justify the cost of a big brake kit.
So far here in Australia I have been quoted the typical range of incredibly overpriced bullshit and a big problem is the lack of aftermarket brake kits for this car. I can get Alcon or AP racing kits made up but they need custom brackets to be fabricated in order to fit. Quotes i've had range around the $3500au mark which is roughly equal to the American national debt once you convert the currencies.
Consumables can also cost quite a lot with these setups so ideally I would want something that have alternate rotors (DBA5000 preferred) and pads available.
TLDR: Who knows of/sells a bolt on 4pot brake kit for a 2010 MS3/MPS?
Reedy is online now   Reply With Quote
The Following 24 Users Say Thank You to Reedy For This Useful Post:
86azms3 (12-14-2012), ABolewski (12-07-2012), Balagan (09-14-2012), bertrand_CX_7 (09-14-2012), BigJimMs3 (09-13-2012), daafisch (09-13-2012), Easter Bunny (09-13-2012), grantmm (02-17-2013), GunGuru727 (09-15-2012), helmetface (09-13-2012), kritz (09-13-2012), LittleredMPS (09-13-2012), Menace1 (01-29-2013), Monotonous ONE (09-13-2012), Ms3_Miami (03-20-2013), Pointless (09-13-2012), SarcasticOne (02-11-2013), SLOWHATCH (09-14-2012), Stangcobra (12-06-2012), Todd98SE (09-13-2012), Tomas (09-13-2012), Twofer (03-26-2013), wolly6973 (09-13-2012), xb2ms3 (12-07-2012)
 Old 09-13-2012, 02:46 AM   #2
(Toe-kay)
Tokay444's Avatar
Posts: 9,547   (View Stats)
Groans: 503
You'd have more even wear without slotted rotors.
Pads don't gas like they used to. Slots really aren't. Relevant anymore.
kritz and Standsideways like this.
Demodded.
Mwho?
Tokay444 is online now   Reply With Quote
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
802MS3 (09-14-2012), LittleredMPS (09-13-2012), Mizzle (09-13-2012), Standsideways (01-31-2013), super_pablo_ (12-06-2012), Tomas (09-14-2012)
 Old 09-13-2012, 02:56 AM   #3
Posts: 5,680   (View Stats)
Groans: 58
Groaned at 25 Times in 21 Posts
Rotors are consumables don't spend the big bucks on the rotating mass.
CorkSport Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now   Reply With Quote
The Following 3 Users Say Thank You to kritz For This Useful Post:
beachshoer (09-13-2012), Tokay444 (09-13-2012), TRex (09-13-2012)
 Old 09-13-2012, 04:23 AM   #4
Able
helmetface's Avatar
Posts: 4,425   (View Stats)
Groans: 125
Exactly, Centric OEM's
Gen1 is ~$45 for a rear, ~$75 for a front..Pu is probably close.
The Following User Says Thank You to helmetface For This Useful Post:
TRex (09-13-2012)
 Old 09-13-2012, 04:32 AM   #5
LittleredMPS's Avatar
Posts: 171   (View Stats)
LittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the worldLittleredMPS is the leader of the world
Interesting information....Appreciated.
Time for some BT action...Bring it!!!
LittleredMPS is offline   Reply With Quote
 Old 09-13-2012, 06:39 AM   #6
Nliiitend1's Avatar
Posts: 3,831   (View Stats)
Groans: 59
How much thought/effort have you expended in the arena of brake cooling?
I know a few guys have had some luck with makeshift cooling ducts...
It might bring the temps down to a more manageable level (i.e., more what you'd see if you were still on street tires), and would be a lot cheaper than a "big brake" kit.
Stance is not a verb.
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
dcamp2 (09-13-2012), wolly6973 (09-13-2012)
 Old 09-13-2012, 07:41 AM   #7
Reedy's Avatar
The caliper flex is the main problem I want to fix and the only way to fix that is to get rid of the floating caliper that our cars come with. Brake ducting is something I am looking into but doesn't change my overall goal.
The Following User Says Thank You to Reedy For This Useful Post:
Nliiitend1 (09-13-2012)
 Old 09-13-2012, 08:23 AM   #8
TRex's Avatar
Posts: 3,051   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 102 Times in 66 Posts
StopTech Big Brake Kit Mazdaspeed 3 MS3
KSport ProComp Big Brake Kit BBK Mazdaspeed 3 MS3
those ksports are 8 piston and i would personally love to pick up that set...not sure if they fit pu's, but i dont see why they woudnt
TRex is offline   Reply With Quote
The Following 3 Users Say Thank You to TRex For This Useful Post:
bertrand_CX_7 (09-14-2012), Menace1 (01-29-2013), uncorked11 (09-15-2012)
 Old 09-13-2012, 09:24 AM   #9
Now with BNR Power
Todd98SE's Avatar
Posts: 964   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
Groaned at 10 Times in 9 Posts
I had Fastbrakes on my Sentra racecar and they were awesome. Great company to deal with and relatively cheap for what you get. If you are a NASA member they offer discounts also.
13" rotor with 4/6 piston Wilwoods.
2007-2008 Mazdaspeed3 13" 4 piston performance big brake kit
or Wilwood 6 piston Dynapro's that work with the stock rotors.
2007-2008 Mazdaspeed3 6 piston performance brake kit
Stoptechs are great too. I have no experience with the Ksports but I would pass on them, they are Ksports..........
www.MOTOIQ.com
2010 LSM Mazdaspeed3
Todd98SE is offline   Reply With Quote
The Following 8 Users Say Thank You to Todd98SE For This Useful Post:
easy (09-14-2012), Lex (09-13-2012), Ms3_Miami (03-20-2013), Nliiitend1 (09-13-2012), Ron (05-04-2013), tddvrrn (09-13-2012), Tokay444 (09-13-2012), uncorked11 (09-15-2012)
 Old 09-13-2012, 09:59 AM   #10
MSP611's Avatar
Posts: 1,017   (View Stats)
Groaned at 17 Times in 11 Posts
evo brembo caliper conversation??? cost 3-500 bones plus a little stock bracket modding.z there's right ups on here...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Installed: PTP reworked turbo//\\M2 Ebay DP//\\PNP intake mani.(by me)//\\DEI header wrap exh. mani//\\VCTS delete//\\EGR delete//\\CPE injector seals//\\Cobb AP//\\Autotech FP internals//\\Cobb SRI//\\Corksport TIP//\\Corksport FMIC//\\Silicone hoses//\\TWM STS stg 1 with bushing kit//\\BSD//\\Centric Blanks//\\HAWK HPS perf. pads//\\MOTUL DOT 4//\\RHO side plate mount//\\JBR heavy shift knob//\\HKS SSQV1//\\Shark fin antenna//\\Smoked side marker//\\SU RMM//\\DIY ipod adapter.
In progress: Powdercoated Rims //\\SURE rear diff mount//\\SURE dreadnaught mount//\\SU rear interior brace//\\GT spec ladder braces//\\Whiteline adjustable RSB//\\Saiko Michi custom OCC setup//\\SPC adjustable ball joints//\\Devils own stage 2 meth injection//\\AWR adjustable front&rear end links//\\JBR intake manifold and throttle-body gasket//\\Perrin EBCS.[SIGPIC][/SIGPIC]
 Old 09-13-2012, 10:20 AM   #11
daafisch's Avatar
Posts: 1,799   (View Stats)
Groaned at 6 Times in 6 Posts
I've been experiencing the same thing when it comes to pad wear. No way I can afford a big brake kit though. I plan on doing something like brake ducts as well next season.
2012 Black Mica : Cobb AccessPort <> CP-e Nano//Nviscid//HPFP//TowPlate <> Forge BPV v1 <> SURE Countershift <> Kosei K4R 17x8 <> 235/45 ZII
OLD 2008.5 MGM : CP-e Nano//Nviscid//Downpipe//CBE//xFlex RMM Stage 1//xFlex PMM//xFlex TMM//Dashhawk Mount//Tow Plate <> SURE Countershift <> Cobb STS <> SeriouSpeed Slick Shift <> E4P Bushings <> Forge BPV v1 <> Koni Sports <> Swift Springs <> Progress RSB <> MSD Dashhawk <> Prosport Premium Boost <> RPM Ventpod <> Carbotech AX6 <> DBA 4000 T3 <> Technafit SS Brake Lines <> Brembo LCF 600 <> Kosei K4R 17x8 <> 235/45 Hankook RS-3 <> Stratified tuned
NATOR NY - Liquid Dinosaur Racing - liquiddinosaurracing.com
Lime Rock Park 01:06.0
Watkins Glen 2:23.608
Summit Point 1:28.895
NJMP Lightning 1:23.891
Pocono North 1:07.230
daafisch is offline   Reply With Quote
 Old 09-13-2012, 10:22 AM   #12
Posts: 9,597   (View Stats)
Great info. I am quite interested in the Dynapro's with the stock rotors as well. Do you know the overall piston surface area and/or if we need bias adjustment? Also very curious if they'd clear stock wheels which is doubtful.
 Old 09-13-2012, 10:26 AM   #13
Now with BNR Power
Todd98SE's Avatar
Caliper flex also causes pad knockback giving an inconsistent pedal which really screws you if you late brake a lot. The OEM caliper is really beefy, I wouldn't have thought it would flex that badly.
Lex, i'm not sure about the bias adjustment. I'm sure there are Dynapro dimensions available on the internet so we can measure piston size vs. OEM and compare.
Edit: Found it. http://www.wilwood.com/Calipers/Cali...%20Lug%20Mount
They come in 3 different piston area sizes, I have no idea what size the Fastbrakes kit uses.
www.MOTOIQ.com
Last edited by Todd98SE; 09-13-2012 at 10:33 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Todd98SE For This Useful Post:
Lex (09-13-2012)
 Old 09-13-2012, 02:07 PM   #14
Reedy's Avatar
It's not the actual caliper that's flexing, it is play in the guide pins that is causing it.
Todd98SE (09-15-2012)
 Old 09-13-2012, 02:12 PM   #15
TRex's Avatar
^custom guide pins?
 Old 09-13-2012, 02:15 PM   #16
anavrinIV's Avatar
Posts: 2,084   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
I've done some measurements and it's not that easy on 3s. It work on the 6s, but the bolt spacing for the 3s is completely different and would require custom brackets at the very least
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
 Old 09-13-2012, 02:29 PM   #17
The guide pins are surprisingly small and on top of this the spring in front of the caliper does way too much of the work on the outside to keep the assembly together.
daafisch (09-13-2012), Todd98SE (09-13-2012)
 Old 09-13-2012, 03:32 PM   #18
SFWD 1934's Avatar
Posts: 677   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I am having the brackets machined now. I have a kit that will be Wilwood 6 piston in the front and Wilwood 4 piston in the rear. The rear will come with an additional bracket adapter to facilitate the parking brake so it can still be used. I did not want to oversize the calipers compared to the stock master cylinder bore/stroke.
These will work with stock sized rotors. They should also help with cooling and any additional warping from the stock calipers retaining all that extra heat.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 10 Users Say Thank You to SFWD 1934 For This Useful Post:
86azms3 (09-13-2012), dot584 (04-25-2013), LittleredMPS (09-19-2012), Ms3_Miami (03-20-2013), rfinkle2 (12-06-2012), ruthless013 (11-14-2012), tddvrrn (09-13-2012), Tokay444 (09-13-2012), uncorked11 (09-15-2012), wolly6973 (09-13-2012)
 Old 09-13-2012, 03:49 PM   #19
MSP611's Avatar
Jason
price for tht whole kit and caboodle?
 Old 09-13-2012, 03:53 PM   #20
Reedy's Avatar
Jason
Who is doing that for you? Got a link? The brackets are the main sticking point, if we can get that sorted out for a reasonable price then we can pretty much pick whatever caliper and rotor combination we want.
Gen I or II?
 Old 09-13-2012, 04:24 PM   #21
SFWD 1934's Avatar
MSP611 Reedy
Give me until the end of next week. The brackets should be done for the rear by then. The fronts are done. These should work on both a Gen 1 and Gen 2. I do not know if I am allowed to post anything about pricing? If I am OK to do so, then I will. I am sure you will be pleasantly surprised by the cost of the entire kit, which will also include stainless steel lines. If you want to see them in person and are attending the Mazfest, they will be on my car at the event (Please note that I am not participating in the track day event, I have a booth).
Jason
www.full-race.com
The Following 6 Users Say Thank You to SFWD 1934 For This Useful Post:
anavrinIV (09-13-2012), Ms3_Miami (03-20-2013), Nliiitend1 (09-14-2012), tddvrrn (09-13-2012), uncorked11 (09-15-2012), wolly6973 (09-13-2012)
 Old 09-13-2012, 04:32 PM   #22
Mizzle's Avatar
Posts: 2,578   (View Stats)
Groans: 297
Groaned at 186 Times in 102 Posts
tl:dr
I've had my Gen1 for 70,000 miles and my pads don't wear like that. It's almost like one size is seized on the slide.
The Following User Says NO Thank You to Mizzle For This Un-useful Post:
fallenangel1 (09-14-2012)
 Old 09-13-2012, 04:35 PM   #23
Macedawg's Avatar
Posts: 1,156   (View Stats)
Macedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the world
Porsche Cayenne brakes are doable..
Brembo 6pot on MS3
Ferg: ive been inside so many deep dark loose holes even ron jeremy would be impressed.
Macedawg is offline   Reply With Quote
The Following User Says Thank You to Macedawg For This Useful Post:
Tomas (09-14-2012)
 Old 09-13-2012, 04:38 PM   #24
Now with BNR Power
Todd98SE's Avatar
Originally Posted by Mizzle View Post
tl:dr
Do you track your car like the OP does? This isn't something that will happen from street driving.
www.MOTOIQ.com
 Old 09-13-2012, 04:48 PM   #25
Reedy's Avatar
tl:dr
It doesn't happen on the street, I have 2 sets of pads and rotors that I swap out for track days and my street gear has never shown any signs of this.
 Old 09-13-2012, 04:51 PM   #26
speedms6's Avatar
Posts: 816   (View Stats)
nothing good to add at all to this, but that's a sweet pic
 Old 09-13-2012, 05:15 PM   #27
Veblen Goods
Tomas's Avatar
Posts: 2,293   (View Stats)
Well, Billabong, I have a few comments for you. This is all my opinion so you can completely disregard it if you want but I have a lil bit of experience on this brake system doing road racing type of track work.
1. The vid you posted is not an accurate representation of caliper flex. The unevenness of the pad is what is causing the caliper to clamp at an angle. If you used an even pad it would not look like that. I've gone through 2 set or Carbotechs. 1x XP10 and 1x XP12 in the fronts and a set of Hawk DCT70 (or so - don't remember now) in the front. On top of that about 4 sets or OEM rotors. Never had uneven wear to the degree you are having. You might want to try a different set of pads. Can't comment on those MU Club race pads since I've never heard of them. I'd try another brand before you upgrade depending on what you intend to do with this car. For stock turbo I would not upgrade the brake system. If you have bigger power goals it's a different story.
2. Brake ducts are a cost effective solution even if you decide to upgrade with a BBK at some point.
Link here: MS3 Brake Ducts
3. For the rear you can get 2008.5 and later model Mazda5 rear rotors and caliper brackets. That will also help a little applying more brake torque to the rear. Stock system biases too much to the front. The calipers will have the same clamping force but due to the higher distance from the hub it will exercise more torque on the rotors /wheels. Think of it as more leverage.
Link here: Mazda 5 rear brake conversion
4. The fastbrakes Willwood kits aren't very good from what I have seen. I know someone running them and they worked worse than stock. The pads are very narrow and only clamp about 3/4 of the rotor. You will see about 20mm on the inside area of the rotor that does not get any wear after driving with this kit for a while. Fluid started boiling, dude had the fastbrakes guy make titanium shims to prevent heat transfer. Did not help much. Don't know of anyone else using the willwood kits for road racing so may be 1 review of them is not conclusive.
5. I have a stoptech 332mm kit waiting for install. I got it cheap so I am sticking with it. If I had to start from scratch I'd get Cayenne calipers. 18ZL with 355mm rotors for 18" wheels or 17ZR with 330mm rotors for 17" wheels. I haven't figured out how all the piston area / quantity / effect of rotor diameter work together yet but a guy in the Ukraine says the 18ZL work fine. Piston area sum of the 18Zl come closer to stock so that might yield a better pedal feel.
Ukraine style: Brembo 6pot on MS3
bertrand_CX_7 likes this.
GHEY THUNDER
The Following 8 Users Say Thank You to Tomas For This Useful Post:
bertrand_CX_7 (09-14-2012), Boosten Ya(josh) (12-11-2012), charlesfist (10-02-2012), Mchart (09-14-2012), Nliiitend1 (09-14-2012), Tokay444 (09-13-2012), wolly6973 (09-13-2012), xtasy (09-19-2012)
 Old 09-13-2012, 05:32 PM   #28
SarcasticOne's Avatar
Posts: 416   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Huzzah for Australia's resident racecar driver getting answers
GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP | Hyperflow TMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | SURE REM | Forge V2 BPV
SarcasticOne is online now   Reply With Quote
 Old 09-13-2012, 05:45 PM   #29
Reedy's Avatar
Yes the uneven pad is causing the flex in the video but it is the flex under heavy load that is causing the pad to wear unevenly in the first place. That video shows its final resting position if you will.
I agree that the brakes don't need to be upgraded in one sense, they have great stopping power as they are, my wheels lock up long before my brakes run out of stopping power but that doesn't address the issue at heart. I didn't notice the QFM pads I used to use wearing unevenly but I only noticed this was happening by chance so they could well have been doing the same thing all along (I was using street tyres back then tho so things were a lot more tame). No doubt it is accentuated with the Pmu pads, as the stopping force they possess is miles above any street pad I have used. Combined with best-on-the-market semi slicks means the forces my car is being subjected to have steadily grown.
 Old 09-13-2012, 06:03 PM   #30
Eatin' Your Tuna
Haltech's Avatar
Groans: 212
Weird my pads wore more evenly length wise, opposite of yours. The front inside pads on mine were slightly worn more on the tops of inner and outer pad.
 Old 09-13-2012, 06:34 PM   #31
Analog Troll
Easter Bunny's Avatar
Posts: 1,504   (View Stats)
Groans: 1,469
Groaned at 45 Times in 34 Posts
Are you certain that both pistons in the caliper are working properly?
edit: im stupid it is a single piston
 Old 09-13-2012, 06:44 PM   #32
Veblen Goods
Tomas's Avatar
There is only 1 on the MS3
GHEY THUNDER
Easter Bunny (09-14-2012), Mizzle (09-13-2012), Nliiitend1 (09-14-2012)
 Old 09-14-2012, 07:04 AM   #33
Analog Troll
Groans: 1,469
I stand corrected, I wrongly assumed that it would have been 2 piston. i guess the single piston is contributiong to the problem.
 Old 09-14-2012, 07:06 AM   #34
bertrand_CX_7's Avatar
Posts: 1,371   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Groans: 46
Groaned at 145 Times in 38 Posts
Michael Cooper Mazdaspeed 3 @1:05
But outch the price......
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e HPFP, CP-e TMIC, CP-e 75A RMM, CorkSport [ RSB, Coilover, camber plate ], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness, Enkei RPF1 wheels && Done
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
The Following User Says Thank You to bertrand_CX_7 For This Useful Post:
 Old 09-14-2012, 09:23 AM   #35
naoandlater's Avatar
Posts: 346   (View Stats)
naoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the world
Not sure if its a bolt on but I've seen Civic Type-R (FD2R) Brembos on the front of a gen one.
07 True Red Mazdaspeed 3 GT
|Cobb AP OTS Stage 2 (Freektune in Progress)|Cobb CAI|Cobb TIP|PG FMIC|SU TP|AT Internals|Denso ITV 22|JBR EGR Delete|JBR 88 Duro RMM|JBR 88 Duro TMM|JBR 80 Duro PMM|Tomei Duracon Shift Knob|DM SSP|JBR Shifter Bushings|H&R springs + Koni Yellows|SPC Rear Camber Arms|Desmond Regas Marquis Promoda 18x8.5 +45|235/40/18 Nitto NT555|Work Steel Lugnuts|Recaro Speed Seat w/ Wedge Engineering Bracket|DM OCC|
naoandlater is offline   Reply With Quote
 Old 09-14-2012, 01:13 PM   #36
Reedy's Avatar
Originally Posted by bertrand_CX_7 View Post
How much are those stop techs? Most ive seen are about $2000 and that's in my price range.
 Old 09-14-2012, 01:24 PM   #37
(Toe-kay)
Tokay444's Avatar
Groans: 503
If you're serious about getting really serious (and want to switch calipers for track days) you need AP racing brakes.
Demodded.
Mwho?
 Old 09-14-2012, 05:38 PM   #38
Reedy's Avatar
What sets them apart from an equivalent Alcon/Brembo/Stop Tech or Willwood setup?
 Old 09-14-2012, 05:58 PM   #39
Now with BNR Power
Todd98SE's Avatar
IMHO nothing. All will work superbly if properly sized for the application.
www.MOTOIQ.com
 Old 09-14-2012, 07:33 PM   #40
(Toe-kay)
Tokay444's Avatar
Groans: 503
It's the little things. They add up.
Essex - AP Racing CP8350
Demodded.
Mwho?
Rear brake caliper piston wont go in? AFcadet MazdaSpeed 3/6 - Suspension & Brakes 19 09-19-2012 03:06 PM
Rear brake piston rotating but not compressing????? buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 14 03-18-2012 06:22 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 09:34 AM
Page generated in 0.53930 seconds with 41 queries
