 Old 05-26-2010, 03:45 PM   #1
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Default Autoexe chassis bracing ?s
2010 Mazdaspeed 3 :: Other Suspension - CorkSport Mazda Performance - 360-260-CORK
I wanted to know if anyone had used any of these chassis bracing products in the link above, and whether or not they were good. I do plan to autoX and open track, and I love backroads, so I do use and will continue to use the suspension mods like they should be used. I'm holding out on some suspension parts because I want to see if some more 2010 specific parts come out in the next year or so. I would like a set of springs that only drops 1" specifically for the 2010 suspension. Any help, info, or stories from experience would be greatly appreciated.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
 Old 05-26-2010, 11:03 PM   #2
Slow*Jim's Avatar
Posts: 210   (View Stats)
Slow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond repute
Groans: 30
IMO chassis braces are unnecessary and just add weight. The 2nd gen chassis is stiff enough, spend your money on sway bars and a good set of coilovers (KW v3 if you have the $$).
And some big fat sticky tires of course
Black '10 15,800mi FOR SALE 20k!!! | Corksport SRI/TIP | Corksport Racepipe
http://www.mazdaspeedforums.org/forum/f430/2010-speed3-15-800-miles-101327/
Slow*Jim is offline   Reply With Quote
The Following User Says Thank You to Slow*Jim For This Useful Post:
Aetherfury (05-27-2010)
 Old 05-27-2010, 04:43 AM   #3
Nataphen's Avatar
Groans: 31
I'm waiting on a F/R sway bar set because I'm not even sure if the FSB fits 2010s. I wish that Cobb would make their stage 2 sway bar and spring set for the gen 2. The Cobb springs are exactly the drop that I'm looking for.
I'm pretty sure that I don't want to spend $1800 on a set of coilovers, springs will be fine.
 Old 05-27-2010, 05:28 AM   #4
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
i'd save your money. especially since autoexe suspension parts are made for JDM vehicles and are not guaranteed to fit on USDM models - there were reports of the 07-09 braces not fitting at all on the USDM models.
that said - that strut tower brace would be nice engine bling. are the 2010 strut towers different??
xcoldricex is offline   Reply With Quote
 Old 05-27-2010, 05:36 AM   #5
Nataphen's Avatar
Groans: 31
Well, that's all that I need to know then. If they may not fit, I'll just forget about it. I could see some of the suspension having a different setup for the JDM models, but I wouldn't think that there would be any difference in the location of the strut towers. I would say that the STB and the rear floor brace would probably fit the US model exactly like the JDM.
 Old 05-27-2010, 05:49 AM   #6
ILL3ST
xcoldricex's Avatar
Groans: 105
the old strut tower braces didn't fit, but they were of a different design.
the rear floor brace fits, but with the underbody ones only one fit i think.
 Old 05-27-2010, 06:48 AM   #7
ruthless013's Avatar
Posts: 603   (View Stats)
ruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the world
Groans: 52
strut tower brace is not necessary because you already have one! look real close, it's black.
for auto x, any one of those braces will bounce you into a class you would mostly likely get demolished in - if that matters to you.
rear sway will most likely fit, front is unknown. but there are (or will be soon) cheaper alternatives from the more well-known sources.
2010 Black Mica Mazdaspeed3
2009 Black Cherry CX-9 AWD
1997 Classic Red Miata
ruthless013 is offline   Reply With Quote
 Old 05-27-2010, 06:56 AM   #8
RacerX78's Avatar
Posts: 818   (View Stats)
RacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the worldRacerX78 is the leader of the world
Groaned at 6 Times in 4 Posts
The stock bracing seems to be doing well for the Gen2. I got the Hotchkis RSB, and it fits just fine.
RacerX78 is offline   Reply With Quote
 Old 05-27-2010, 11:04 AM   #9
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
^ How do you like it? Noticeable difference when just running around town?
Speed3eak is offline   Reply With Quote
 Old 05-27-2010, 12:41 PM   #10
RacerX78's Avatar
In daily driving you don't notice it that much even with it on its stiffest settings. But with the stock suspension its to be expected. On the autoX course though it really helps kill understeer. I am able to do lift-off oversteer on demand, which is really nice.
 Old 05-27-2010, 02:06 PM   #11
Nataphen's Avatar
Groans: 31
I have seen the stock STB tucked up under the wiper cowl. I thought that was a pretty good idea to keep the engine bay decluttered. I guess that the factory has a good idea every once in a while. lol
13 5.0
Wife's 13 Focus ST
 Old 06-01-2010, 12:50 PM   #12
Speed3eak's Avatar
Groans: 82
Which setting? I'm looking at a progress rsb right now, and the hotchkis 'soft' setting is stiffer than the progress 'firm' setting. I'd rather save my money and get the hotchkis if the progress won't let me get any oversteer whatsoever.
 Old 06-01-2010, 01:33 PM   #13
RacerX78's Avatar
I'm running the stiffest setting on the hotchkis bar now. Cornering is very neutral, less front end push. Its only when i'm autoX'ing, and i'm taking hard corners that i get controllable lift-off oversteer. The stock suspension isn't stiff enough to get the back end around. My CivicSi with Tein Coilovers and F/RSB i could easily get the back end to come around but it was much stiffer.
Schumacher reportedly getting new chassis for Spanish GP Haltech Automotive News 0 04-24-2010 08:00 AM
autoExe Ram Air Vinnie MazdaSpeed 3/6 - Turbo Induction 12 01-22-2010 11:08 PM
Chassis Thud in Reverse???? John F 2010 MS3 - Troubleshoot/Diagnostics 14 01-20-2010 05:18 PM
Lotus shopping Evora chassis to other automakers? Haltech Automotive News 0 10-28-2009 03:10 PM
Nissan, Ghosn bracing for the worst Haltech Automotive News 0 06-25-2008 04:20 PM
Page generated in 0.32014 seconds with 25 queries
