Notices
Like Tree11Likes
 Old 07-16-2011, 07:42 AM   #81
ruthless013's Avatar
Posts: 599   (View Stats)
ruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the world
Groans: 52
any follow up todd? were you able to measure max neg. camber gained? and any ill effects - like more noise, since you're trading hardened rubber for aluminum?
2010 Black Mica Mazdaspeed3
2009 Black Cherry CX-9 AWD
1997 Classic Red Miata
ruthless013 is offline   Reply With Quote
 Old 07-16-2011, 08:11 AM   #82
Veblen Goods
Tomas's Avatar
Posts: 2,293   (View Stats)
Originally Posted by Todd98SE View Post
No issues going back to stock the OEM tophat would mount up just as it did stock you'd just see more of it.
Swaybar is a Racing Beat for the 2010 MZ3 2.5 and endlinks are Whiteline.
Thanks for taking the time to post pics of your install. How much camber are you able to get on stock springs?
I have been modifying the stock setup for a while and all I can get is -1.8 by elongating the shaft hole on the top hat and strut tower top hat holes. The problem is that the spring starts rubbing on the inner part of the spring tower. Any more neg camber than shown below and it rubbs. I even cut the top of the shaft on my FSDs thinking I would tuck them under the tower but couldn't get that far. Going lower 1" gets you about -0.4 degs of additional neg camber.
So in all I would argue that on any strut / spring combo, (I.e. not COs) the approx max neg camber one can get is -2.2 unless you get the LCA to push the knuckle out more.
and here is a failed attempt at increasing neg camber with top hats
GHEY THUNDER
FreeFlyFreak (08-11-2011)
 Old 07-16-2011, 10:13 AM   #83
Now with BNR Power
Todd98SE's Avatar
Posts: 964   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
Groaned at 10 Times in 9 Posts
The reason I haven't posted further information is because I ran into the same situation as you Tomas. The spring runs into the wheel well limiting camber change. With the stock springs I was only able to get -1.4 degrees negative camber. Corksport's shop car was able to get a little more since it had the new Corksport lowering springs which made the control arm a bit more parallel to the ground and placed the lower balljoint as far out in it's arc as possible allowing a little more tilt to the strut shaft. They are working on some solutions to this problem but it looks like we are relatively limited in camber gain because of the stock chassis dimensions.
In addition since the stock struts already offset the spring away from the inside of the strut tower I dont believe coilovers will offer much benefit even with their smaller diameter springs. At this point I think we need to explore a longer lower control arm if we want to run more than around -2.0 degrees camber.
As for the camber plates, they have been squeak and problem free since the day I installed them. They are well built with high quality components and beautiful machining.
Below are some pics of the interference problem.
www.MOTOIQ.com
2010 LSM Mazdaspeed3
Todd98SE is offline   Reply With Quote
The Following 4 Users Say Thank You to Todd98SE For This Useful Post:
FreeFlyFreak (07-24-2011), ruthless013 (07-16-2011), super_pablo_ (07-16-2011), Tomas (07-17-2011)
 Old 07-17-2011, 08:07 AM   #84
Veblen Goods
Tomas's Avatar
Yeah, not sure I would drill the strut tower for that little additional camber.
With CO's I'd have to disagree. I think if the spring diameter was less, that with these camber plates you could get up to about -3.0 or so. I know people with Kmacs can go that far.
GHEY THUNDER
 Old 07-17-2011, 08:23 AM   #85
Now with BNR Power
Todd98SE's Avatar
I did read a few different threads about people measuring more than -2 while using coilovers which is promising. From the pics it is hard to see how much closer a coilover can place the spring next to the strut for additional clearance. I just purchased one of the new aluminum lower control arms from the 2012 Focus ST to see if it is any longer than the OEM MS3 lower arm. If so it will be a cheap fix for this problem.
www.MOTOIQ.com
The Following User Says Thank You to Todd98SE For This Useful Post:
 Old 07-17-2011, 09:47 AM   #86
Veblen Goods
Tomas's Avatar
fuckin-a. With adjustable joints?
If they fit that'd be great. JBarone said he was going to start making them a few months ago but that never materialized.
Post up your results!
GHEY THUNDER
 Old 07-17-2011, 12:21 PM   #87
alien_sporez's Avatar
Posts: 1,013   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
Presuming that this is primarily for people who DD their cars and like to do the occasional track day, or canyon carve, is there really a need for more than -2.0 degrees camber?? I mean, if you're seriously tracking your car regularly, coilovers are an absolute necessity. If you're not, then you shouldn't need more than -2.0 degrees... right?
Cobb AP 50/50 e85 Tune by Monk cp-e nano Cobb TIP Custom FMIC Turbosmart BPV CNT Downpipe Ultimate Racing CBE TRZ Dogbone RMM JBR SSP & Bushings JBR Heavy Shift Knob 17x8.5 +45 Stern ST-8 Goodyear Eagle GT 235/45-17 Eibach Pro-Kit JBR Adjustable Rear Camber Links JBR Adjustable Rear Sway Bar FoMoCo Trans Fluid Rotella T6 AutoTech FP Internals RallyArmor Mud Flaps
TEAM LBN BEERS -- FYCN
TEAM MEAGHAN -- FYCN
alien_sporez is offline   Reply With Quote
The Following User Says Thank You to alien_sporez For This Useful Post:
SLOWHATCH (10-08-2011)
 Old 07-17-2011, 11:23 PM   #88
Now with BNR Power
Todd98SE's Avatar
Correct Alien, I don't know why anyone would want to run more than -2.0 on the street ever. For track use it all depends on the tire and the specifics of the track. Some tire like a lot of negative camber (old BFG R-1, Toyo RA-1) and some tracks like Streets of Willow or any autox would probably require more then -2.0 degrees. The problem with to much camber is the loss of ability to put down power earlier on the corner exit, so it really is a compromise either way.
www.MOTOIQ.com
 Old 07-18-2011, 01:46 AM   #89
frivolous_rob's Avatar
Posts: 1,370   (View Stats)
frivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the world
Groaned at 44 Times in 17 Posts
Neutral  -1 score
Yes I secretly knew thered be more fail in this thread! Your cost effective part just failed. Corksport should have known. I'd demand refund if there advertisement says works with stock springs.
Choke me, I like it.
frivolous_rob is offline   Reply With Quote
 Old 08-11-2011, 10:42 AM   #90
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,148   (View Stats)
Groans: 754
Update?
Suspension:
 Old 08-11-2011, 10:50 AM   #91
Nliiitend1's Avatar
Posts: 3,837   (View Stats)
Groans: 59
Originally Posted by FreeFlyFreak View Post
Update?
http://www.mazdaspeedforums.org/foru...tml#post953551
Stance is not a verb.
 Old 08-11-2011, 08:57 PM   #92
Now with BNR Power
Todd98SE's Avatar
Update?
Corksport has revised the initial design that I have for those that don't want to cut their strut towers. The revised design would require you to drop the strut to adjust camber if you don't want to make the cut. If you do make the cut they are adjustable just like mine. This was done to satisfy both groups of customers. Also Corksport performed a FEA analysis of the strut tower cut and uncut to see if it was any weaker after cutting and it is not, insignificant change in material stress in that area after the cut.
They are working on pricing options for the camber plates only and a camber plates + lowering springs package. I would expect the official announcement of their release to be made in a few weeks at most if not sooner.
In other news the other 2012 Focus LCA arrived in the mail today. I will be installing them this weekend hopefully and will post revised numbers if they allow me to run any additional camber with the OEM springs.
www.MOTOIQ.com
The Following 2 Users Say Thank You to Todd98SE For This Useful Post:
alien_sporez (08-12-2011), FreeFlyFreak (08-11-2011)
 Old 08-12-2011, 11:57 AM   #93
hnda etr's Avatar
Posts: 3,295   (View Stats)
Groans: 78
Groaned at 274 Times in 243 Posts
Did we ever hear if CS is going to make these for the GenWon also?
 Old 08-12-2011, 12:02 PM   #94
Nliiitend1's Avatar
Groans: 59
I don't know why these wouldn't work on a Gen 1...
As far as I know there were no significant changes made to the top mounts/bushings for the struts.
Somebody correct me if I'm wrong.
Could you try to take a lot of pictures during the install/install attempt?
I know I could look this up pretty easily, but does anyone know if there were any changes to the LCAs between Gen 1 and Gen 2 MS3s? I keep forgetting Todd has a Gen 2...
Last edited by Nliiitend1; 08-12-2011 at 12:03 PM. Reason: MSF Database - Automerged Doublepost
hnda etr (11-02-2011)
 Old 08-12-2011, 12:53 PM   #95
Now with BNR Power
Todd98SE's Avatar
I think the camber plates and LCA's are completely interchangeable between Gen 1&2. In fact the Whiteline bushings are only listed for the Gen 1 years and I know they will fit the newer arms if that helps any.
There is another camber plate beta tester but I dont know if he has a gen 1 or 2. If he is following this thread maybe he can chime in.
EDIT: according to onlinemazdaparts the gen 1 and gen 2 control arms are different costs. I cant find a part number but i dont know if the price means they are somehow different or not.
www.MOTOIQ.com
hnda etr (11-02-2011), Nliiitend1 (08-12-2011)
 Old 09-09-2011, 01:29 PM   #96
Manny's Avatar
Posts: 923   (View Stats)
Manny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the world
Groans: 195
Groaned at 34 Times in 24 Posts
updates?
Manny is offline   Reply With Quote
 Old 09-10-2011, 09:36 AM   #97
Now with BNR Power
Todd98SE's Avatar
I haven't heard anything further from CS on these. I guess we just have to be patient.
www.MOTOIQ.com
 Old 09-11-2011, 02:33 PM   #98
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,385   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 170
Groaned at 179 Times in 30 Posts
Originally Posted by letsfightrobbb View Post
You're all noobs. Cut springs ftw. Way more reliable than your crappy KW's and a lot cheaper.
P.S.
Why do you all care about your amazingly expensive coilovers? 1/2 of you noobs won't even be driving hard enough to actually utilize the coilovers to their maximum potential anyways...No one is auto-xing to the grocery store, cause that's what these cars are meant to be used for.
Shut the hell up
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
The Following User Says Thank You to Hamilton69 For This Useful Post:
frivolous_rob (09-11-2011)
The Following User Says NO Thank You to Hamilton69 For This Un-useful Post:
xbox4414 (11-06-2011)
 Old 09-11-2011, 03:56 PM   #99
your so old^
 Old 09-20-2011, 12:23 PM   #100
bigblazer87's Avatar
Posts: 2   (View Stats)
bigblazer87 will become famous soon enough
I just installed these on my '09 MS3 on Sunday, everything went very well, very nicely-made. Only thing I'm trying to pinpoint is a sort of clunking noise I'm getting over jarring bumps. Do camber plates tend to do that because of the lack of the factory rubber strut mounts? I've got them on top of H&R coilovers (all the way down) and everything is tight.
Currently maxed out with 18x9.5 +25 wheels...
bigblazer87 is offline   Reply With Quote
The Following User Says Thank You to bigblazer87 For This Useful Post:
Nliiitend1 (09-20-2011)
 Old 09-20-2011, 12:57 PM   #101
Nliiitend1's Avatar
Groans: 59
To an extent, yes.
 Old 09-20-2011, 02:47 PM   #102
tigermack's Avatar
Posts: 586   (View Stats)
Groans: 71
Ah, you had to bore out the strut tower hole, huh?
 Old 09-20-2011, 03:08 PM   #103
To an extent, yes.
Hmmm, cause that was really the only thing that was changed, and everything is tight. It's annoying but I guess I'll have to learn to live with it.
Yup, used a 3-1/8" hole saw. Pretty thick metal you have to go through so it takes a little while, but no biggie. Fits perfectly so as long as you hold the drill straight everything goes smoothly. Painted the inside satin black and you can't really even tell it was modified.
 Old 10-06-2011, 07:57 PM   #104
patABQ's Avatar
Posts: 31   (View Stats)
patABQ is a splendid one to beholdpatABQ is a splendid one to beholdpatABQ is a splendid one to beholdpatABQ is a splendid one to beholdpatABQ is a splendid one to beholdpatABQ is a splendid one to beholdpatABQ is a splendid one to behold
These look great. Let us know how they work and the adjustment range.
2007 630Hp Corvette Z06
2008 Hyabusa
2012 MS3
patABQ is offline   Reply With Quote
 Old 11-05-2011, 08:40 PM   #105
mr.panec's Avatar
Posts: 7   (View Stats)
mr.panec is just really nicemr.panec is just really nicemr.panec is just really nicemr.panec is just really nice
Yo...
I'm the other guy that was working with CS, along with Todd, on the design of the camber plates. I elected to not take the plates, as my initial request with CS was a 'no cut' install. I was able to achieve nearly the same camber with a very good alignment shop. I spoke with Rich and we discussed the plates and their development progress. I am of the school that Mazda has left all that metal in the strut tower for a reason. I autocross 1-2 times a month, and typically have 6-8 runs per event. I run Hoosier A 275's on stock rims with a 5mm spacer..I was very concerned about all of the additional stress that this setup was going to put on the suspension. All I envisioned was getting stress fractures, and being SOL with them. Rich informed me that he had developed a 'cut free' set up, but that it was fairly restrictive on camber settings. Rich and Corksport have been great throughout this venture, and they continue to keep in touch with me in regards to future developments.
Also...Gen1 & Gen2 have the exact same Mazda OEM part number 34-310 for the LCA, according to the spec diagrams listed on the Mazdaspeed Motorsports part program.
Keep the info flowing guys...nice installs on the plates that are out there. Everyone, some sharp rides out there!
Later!
Eric
Daily Driver
2010 Liquid Silver Mazdaspeed3
Corksport SRI & TIH
Cobb AccessPORT - OTS Stage 1
Hawk HPS Pads
Track Alignment
JBR Rear Sway Bar
Corksport Shift plate
PTP HPFP
245/35/18 Hoosier A's
Autocross DSP
mr.panec is offline   Reply With Quote
The Following User Says Thank You to mr.panec For This Useful Post:
FreeFlyFreak (11-21-2011)
 Old 11-05-2011, 08:51 PM   #106
Posts: 5,687   (View Stats)
Groans: 58
Groaned at 25 Times in 21 Posts
Let me understand this correctly, 275's on 7.5"x 18" wheel?
CorkSport Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now   Reply With Quote
 Old 11-06-2011, 02:49 PM   #107
Groans: 52
since you are familiar with the mazdaspeed parts program, do you know if a mazdaspeed camber/caster plate from mazdaspeed exists? there was mention of it in an article about the imoto racing ms3 that recently won at laguna seca.
and what was necessary to get this negative camber on a stock setup?
 Old 11-07-2011, 11:02 AM   #108
tigermack's Avatar
Groans: 71
It's possible with Hoosiers.
 Old 11-07-2011, 11:11 AM   #109
Groans: 58
You might want to check out this link.
tigermack
https://www.hoosiertire.com/rrtire.htm
 Old 11-07-2011, 12:09 PM   #110
daafisch's Avatar
Posts: 1,802   (View Stats)
Groaned at 6 Times in 6 Posts
A lot of people run massive hoosiers on narrow rims in autocross.
2012 Black Mica : Cobb AccessPort <> CP-e Nano//Nviscid//HPFP//TowPlate <> Forge BPV v1 <> SURE Countershift <> Kosei K4R 17x8 <> 235/45 ZII
OLD 2008.5 MGM : CP-e Nano//Nviscid//Downpipe//CBE//xFlex RMM Stage 1//xFlex PMM//xFlex TMM//Dashhawk Mount//Tow Plate <> SURE Countershift <> Cobb STS <> SeriouSpeed Slick Shift <> E4P Bushings <> Forge BPV v1 <> Koni Sports <> Swift Springs <> Progress RSB <> MSD Dashhawk <> Prosport Premium Boost <> RPM Ventpod <> Carbotech AX6 <> DBA 4000 T3 <> Technafit SS Brake Lines <> Brembo LCF 600 <> Kosei K4R 17x8 <> 235/45 Hankook RS-3 <> Stratified tuned
NATOR NY - Liquid Dinosaur Racing - liquiddinosaurracing.com
Lime Rock Park 01:06.0
Watkins Glen 2:23.608
Summit Point 1:28.895
NJMP Lightning 1:23.891
Pocono North 1:07.230
daafisch is online now   Reply With Quote
 Old 11-07-2011, 12:32 PM   #111
Groans: 58
wouldn't you get a fuckload of sidewall flex?
 Old 11-07-2011, 01:55 PM   #112
daafisch's Avatar
Not sure about the sidewalls on the A6's but I know people do it in Stock class. In this thread someone put 285's on a 7.5 inch wheel.
275/40R17 hossier A6 on a 17x8 wheel - Stock Classes
 Old 11-07-2011, 03:46 PM   #113
tigermack's Avatar
Groans: 71
tigermack
What about it?
 Old 11-07-2011, 07:00 PM   #114
justint5387's Avatar
Posts: 571   (View Stats)
justint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the world
275s on 6 inch wide wheels had been done. R comp tires are not like street tires.
2007 MS3 (STX):
http://www.mazdaspeedforums.org/forum/f541/2012-scca-stx-auto-x-build-94012/
justint5387 is offline   Reply With Quote
 Old 11-07-2011, 08:20 PM   #115
xbox4414's Avatar
Posts: 178   (View Stats)
xbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the worldxbox4414 is the leader of the world
Groaned at 21 Times in 12 Posts
Just went on the alignment rack with AMR Coilovers and without maxing out the camber plates and without adjusting the top bolts to push the coilovers furthest away from the wheel I measured -1.9 so pretty sure I can get above -2 easily.
xbox4414 is offline   Reply With Quote
 Old 11-07-2011, 09:01 PM   #116
Groans: 58
I don't want to get this thread off track so starting another on the R comp tires on narrow wheels.
tigermack,daafisch,justint5387
 Old 11-08-2011, 05:18 AM   #117
Manny's Avatar
Groans: 195
back on topic, how much difference in camber restriction are we talking about with a no cut setup?
The Following 2 Users Say Thank You to Manny For This Useful Post:
kritz (11-09-2011)
 Old 11-11-2011, 09:24 PM   #118
grantmm's Avatar
Posts: 501   (View Stats)
grantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the world
Mazdaspeed camber plates do exist and they cost roughly $1200.
grantmm is offline   Reply With Quote
The Following 2 Users Say Thank You to grantmm For This Useful Post:
kritz (11-12-2011), ruthless013 (11-12-2011)
 Old 11-12-2011, 07:13 AM   #119
Groans: 52
that's crazy - and i'd love to see them.
 Old 11-14-2011, 06:46 PM   #120
grantmm's Avatar
Corksport camber plates:
Todd98SE likes this.
The Following 6 Users Say Thank You to grantmm For This Useful Post:
daafisch (11-15-2011), justint5387 (11-14-2011), Manny (11-14-2011), ruthless013 (11-14-2011), tigermack (11-18-2011), Todd98SE (11-14-2011)
Question about camber plates?? lsorr1975 Auto-X / Road Racing / Time Attack 11 04-05-2011 07:56 PM
bc coilover with camber plates owner please help!? udontknowjack MazdaSpeed 3/6 - Suspension & Brakes 6 08-20-2008 05:25 PM
Page generated in 0.61210 seconds with 38 queries
