![]() | | #121 | ![]() |
| Now with BNR Power ![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 849 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,188
Groaned at 10 Times in 9 Posts
__________________ www.MOTOIQ.com 2010 LSM Mazdaspeed3 |
![]() | | #122 | ![]() |
![]() Join Date: Jun 2010
5200s, so double adjustable + the can pressure.
![]() | | #123 | ![]() |
![]() Join Date: Jul 2009 Location: Bay Area, CA
Rep Power: 296 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 218
May I ask how much the setup cost you? How do you adjust the rebound on the rears? Looks like compression is on the can. I went with budget Koni's lol
__________________ 2007 MS3 (STX): http://www.mazdaspeedforums.org/forum/f541/2012-scca-stx-auto-x-build-94012/ |
![]() | | #124 | ![]() |
No idea on cost until later this week. I'll get the final bill once the machine work is done to adapt the Corksport camber plates to the STX legal setup. Compression is the bronze knob on the canister and rebound is on body of the coilover. Edit: I wasn't meaning to hijack this thread, just wanted to show my application for the camber plates I'll have a thread up sooner or later once this project's finished.Here's the rear coil's compression and rebound adjustment: |
| The Following User Says Thank You to grantmm For This Useful Post: | daafisch (11-15-2011) |
![]() | | #125 | ![]() |
| Not Ranked : 0 score ![]() |
![]() | | #126 | ![]() |
Once the alignment is done on Monday I'll have the camber numbers. ![]() ![]() |
| The Following 3 Users Say Thank You to grantmm For This Useful Post: |
![]() | | #127 | ![]() |
![]() Join Date: May 2011 Location: Martinez, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
Groaned at 21 Times in 12 Posts
Still doesn't look like tremendous amount of adjustability with the counter sunk screws...interested to see the max negative camber without cutting.
![]() | | #128 | ![]() |
Due to the massive inverted nut/bolt we were only able to get 2.1 degrees reliably. If we did some more adjusting/machining of spacers or other bits it would have been another half a degree to a degree. I'm pretty confident that a non inverted strut will yield 2.5-3 degrees.
![]() | | #129 | ![]() |
![]() Join Date: Jan 2011 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
While 2.1 degrees of negative camber isn't optimum for the full-time autocross competitor, it's right in the ballpark of where I'd want to be (the-daily-driver-occasional-autocross-and-track-day-car). And since it looks like that can be achieved without cutting of the strut towers, my wallet is on standby until the camber plates are available to the public.
| The Following User Says Thank You to oatmealboy For This Useful Post: | super_pablo_ (12-10-2011) |
![]() | | #130 | ![]() |
![]() Join Date: Aug 2008 Location: Bay Area, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 71
I got -2.8 and -3.2 from my alignment today, didn't quite max out driver side. lol
__________________ Fuck HPDE heroes. HPDE ain't road racing. |
![]() | | #131 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 1663 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,421
interested in these camber plates as well. Im maxed out at 1.5 right now. Id be PLENTY happy with 2.0 degrees up front. Even if I could get more... Id want 2.0-2.2 at most. Let us know if these are available to the public!
![]() | | #132 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2126 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,374
I had to go from -2.2 to -1.8 since I was wearing out the inside of the tires with the quaife LSD. So no camber plates for me. ![]()
__________________ ![]() GHEY THUNDER |
| The Following User Says Thank You to Tomas For This Useful Post: | rfinkle2 (02-27-2012) |
![]() | | #133 | ![]() |
![]() Join Date: Mar 2008 Location: 60607
Rep Power: 2151 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,488
Groans: 59
What kind of caster were you running when your camber was -2.2°?
__________________ Stance is not a verb. |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | super_pablo_ (12-11-2011) |
![]() | | #134 | ![]() |
almost stock. May be a lil more +.
![]() | | #135 | ![]() |
![]() Join Date: Jun 2011 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
The CorkSport Mazdaspeed 3 Front Camber Kit has officially been released! You can read about the whole development process on our blog or check out the product listing on our website.
| The Following 13 Users Say Thank You to Gwynne For This Useful Post: | anavrinIV (01-23-2012), bertrand_CX_7 (01-23-2012), Crarrs (01-23-2012), daafisch (01-23-2012), fishin53 (01-23-2012), kritz (01-23-2012), Mr_Bill (02-19-2012), Nliiitend1 (01-23-2012), ruthless013 (01-30-2012), tigermack (01-23-2012), Todd98SE (08-07-2012), Tomas (01-23-2012), Ziggo (01-23-2012) |
![]() | | #136 | ![]() |
I might actually jump on this. Any opportunities to get a group buy going?
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #137 | ![]() |
+1 on the potential Group Buy opportunity.
| The Following User Says Thank You to oatmealboy For This Useful Post: | Tomas (01-23-2012) |
![]() | | #138 | ![]() |
Hey cutey, What would be the minimum quantity and price for a group buy?
__________________ ![]() GHEY THUNDER | |
![]() | | #139 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 762 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 710
So if i read this right, these raise ride height by 1"? Cause that would be perfect for me.
![]() | | #140 | ![]() |
| The Following User Says Thank You to Gwynne For This Useful Post: | Celestspeed3 (01-23-2012) |
![]() | | #141 | ![]() |
looks nice. too lazy to read, so answer this... being on kwv3 coilovers, will this be the only thing I need to go from my shitty -1.3 to lets say... -1.8 ish? |
![]() | | #142 | ![]() |
| Not Ranked : 0 score Yes. The camber plates will allow you to go to -3 degrees of camber on your coilovers.
| The Following 2 Users Say Thank You to Gwynne For This Useful Post: | Celestspeed3 (01-24-2012), super_pablo_ (01-23-2012) |
![]() | | #143 | ![]() |
Yes. You should be able to get more than that without cutting. Mine are great! Thanks for the great product, Corksport!
| The Following 2 Users Say Thank You to grantmm For This Useful Post: | Gwynne (01-24-2012), super_pablo_ (01-23-2012) |
![]() | | #144 | ![]() |
Ill give em a shot. Ill post first impressions after my next track event. Edit. Checks price... decides to wait a month or two due to tight budget. :..( |
![]() | | #145 | ![]() |
Groans: 71
So you can get -3 without cutting...?
![]() | | #146 | ![]() |
| Not Ranked : 0 score Yes you can. The only difference is that you will not have the same access to adjust them once they have been installed. You will have to remove and re-install the strut assembly each time you want to adjust your camber. If you do not plan to change the camber setting frequently, then it would be a good alternate install option for you. |
| The Following User Says Thank You to Gwynne For This Useful Post: | rfinkle2 (02-27-2012) |
![]() | | #147 | ![]() |
![]() Join Date: Apr 2009
Rep Power: 319 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
Groans: 195
Groaned at 34 Times in 24 Posts
any more people have these yet?
![]() | | #148 | ![]() |
![]() Join Date: Mar 2008 Location: Dallas
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
I'm looking at getting H&R or KW coilovers and these camber plates. Is there anything from my stock setup I would have to reuse? It would be nice to not have to tear down shocks.
__________________ _____________________________________________ http://www.cardomain.com/ride/2930373 |
![]() | | #149 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 65 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Anyone else get a little tight in the pants reading GwynneCorkSport talk about camber and then looking over at her avatar picture. Maybe the Afghan sun is getting to me. |
![]() | | #150 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 1111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 802
Groaned at 6 Times in 6 Posts
-Derrick | |
![]() | | #151 | ![]() |
![]() Join Date: Jun 2009 Location: Lost Angels, Cali
Rep Power: 5069 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,683
Groans: 78
Groaned at 274 Times in 243 Posts
Just got my CS camber plates installed yesterday - some very high quality parts! Oh and can you say holy wheel gap Batman! It looks like it adds more than 1/3" in height - looks more like 1/2" but I didn't take measurements to be accurate... Looks like I'll be dropping my coils a bit lol... And don't ask about how much camber I have, cuz the suspension place set them to stock specs since I don't autox... ![]() ![]() ![]() ![]() Sent from my iPhone using lame ass Tapatalk
__________________ ![]() |
![]() | | #152 | ![]() |
Groans: 59
If you don't really care how much camber you have, then why did you drop $300+ on front camber plates??
__________________ Stance is not a verb. Last edited by Nliiitend1; 02-23-2012 at 11:24 AM. Reason: typo correction... |
| The Following 6 Users Say Thank You to Nliiitend1 For This Useful Post: | Crarrs (02-23-2012), Easter Bunny (02-28-2012), FreeFlyFreak (02-27-2012), silvapain (02-23-2012), super_pablo_ (02-24-2012), tigermack (02-23-2012) |
![]() | | #153 | ![]() |
Groans: 78
| Not Ranked : 0 score couple reasons... i had a discount through CS and didn't pay the full price and i wanted the option to increase camber if i wanted to...
![]() | | #154 | ![]() |
Groans: 71
Hook it up with the discount. lol
![]() | | #155 | ![]() |
yes, go on... tell us about the discount, some of us that actually NEED the camber would appreciate some support! I woulda bought these and reviewed with pleasure already if I had the money. |
![]() | | #156 | ![]() |
Groans: 195
| Not Ranked : 0 score |
| The Following User Says Thank You to Manny For This Useful Post: | tigermack (02-24-2012) |
![]() | | #157 | ![]() |
Groans: 71
^ Let us know how much camber you max out on...
![]() | | #158 | ![]() |
| Not Ranked : 0 score Is the spacer in the coilover stack to adapt the standard coilover spring size to the stock upper bearing? -Derrick |
![]() | | #159 | ![]() |
Looks like you can take the Tein piece off.
| The Following 2 Users Say Thank You to justint5387 For This Useful Post: | super_pablo_ (02-27-2012), tigermack (02-27-2012) |
![]() | | #160 | ![]() |
Groans: 195
| The Following User Says Thank You to Manny For This Useful Post: | CorkSport (02-28-2012) |
| Question about camber plates?? | lsorr1975 | Auto-X / Road Racing / Time Attack | 11 | 04-05-2011 07:56 PM |
| bc coilover with camber plates owner please help!? | udontknowjack | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 08-20-2008 05:25 PM |
