![]() | ![]() | #1 | ![]() |
![]() Join Date: Jul 2014 Location: Saskatoon, SK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
(Thread Starter) | ![]() ![]() ![]() This takes around an hour. I chose to use OEM bushings because they are cheap, plug and play and easy to source. If you have a front end clunk this is where I would start. You will need: OEM PN: B37F-34-156B (x2), these are about $14/ea (I paid in CAD) 1 jack, 2 jack stands, Torque wrench and breaker bar, 17mm socket, 14 or 15mm wrench+ratchet (depending on your end links), Wheel removal tools, Some penetrating lube, Grease. Jack up the car, place on stands and remove the wheel. Use penetrating oil as required: Remove your endlink from the strut. Remove the (2) 17mm bolts that secure the rear lower control arm bushing to the subframe and the oem bushing bracket. Lift the end link up and let it rest on the spring like this: ![]() Now you can pull the oem bushing out of the bracket/dust cover. ![]() This was my old bushing. Didn't look too bad ![]() Grease up the new bushing and stuff it back in underneath the bracket and make sure you aligned it properly. ![]() Take the endlink off the spring and let the bracket rest above the LCA. Take a jack and jack up on the bushing like this until you can feed the 17mm bolts through the holes and the bracket and tighten it back up. I torqued mine to 110ftlb. ![]() Put the endlink back in the strut and you're ready for the other side.
__________________ 2010 BM - FREEKTUNED - BNRS3 |
The Following 6 Users Say Thank You to spl For This Useful Post: | Awal (10-14-2015), ksto3 (04-01-2018), mazdaspeedmyk (10-20-2015), ruthless013 (04-22-2018), speedfreak44 (10-12-2015), Ziggyboy (10-12-2015) |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Jun 2015 Location: Salt Lake City, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
| ![]() ![]() ![]() Always good to have another walk through. Thanks!
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 290 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
| ![]() ![]() ![]() Nice write up spl, short and sweet. so glad this cured yer front end clunk, clunks from the front or rear are hella annoying..
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 19
| ![]() ![]() ![]() Nice write up. |
![]() | ![]() | #5 | ![]() |
![]() Join Date: Nov 2011 Location: Cape Cod, Ma
Rep Power: 0 ![]() ![]() Thanks: 3
| ![]() ![]() ![]() For anyone with a GenOne,I just did this on my 2008 and went at it the same way SPL did except with a slight twist. I disconnected all three bolts front and back of the lower control arm and pushed it away from the subframe and just let it hang, leaving the ball joint connected. This gave me much better access, it's still a a small space to work in. Using a 14 mm closed end wrench and a 4 lb. hand sledge I was able to break the bolts loose. Then I used a 14 mm swivel head ratchet wrench to get the bolts the rest of the way out, this is a must if you don't want be doing this all day. Hope this motivates anybody putting this off like I did because I knew that access was going to be a bitch. Thanks to SPL for the insight in the write up, it wasn't that much of a pain in the ass. Only took me about 2.5 hrs. |
![]() | ![]() | #6 | ![]() |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 61 Times in 34 Posts
| ![]() ![]() ![]() Does anybody happen to know any remarkable difference between the oem bushings vs. jbr? I bought oem ones but then was second thinking that maybe I should of bought the jbr ones but don't know if its all the same thing performance wise
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//CS RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 225/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS ![]() ![]() |
![]() | ![]() | #7 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,287
Groans: 74
| ![]() ![]() ![]() Hey good to know your still alive after the hurricane.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() | ![]() | #8 | ![]() |
| ![]() ![]() ![]() Thanks guy! we are still recovering from that dam hurricane Maria, that thing was a monster! to be honest i do not want to ever in my entire life want to go through that again, Jesus that shit was scary as hell
Display Modes | |
How-To: Front Sway Bar Bushing replacement w/o dropping subframe | DeadWayt | MazdaSpeed 3 - How-To's | 66 | 11-29-2018 08:40 PM |
How-To: MS6 Front Sway Bar Bushing | TiGraySpeed6 | MazdaSpeed 6 - How-To's | 44 | 08-23-2017 09:16 AM |
front control arm front/rear bushing | specvspeedfreak | 2010 MS3 - Suspension & Brakes | 7 | 12-28-2013 11:37 AM |
MS6 driver-side sway bar bushing removal | wdautrem | MazdaSpeed 3/6 - Suspension & Brakes | 16 | 06-01-2012 10:44 PM |
