Notices
Like Tree2Likes
 Old 10-07-2012, 06:12 PM   #1
SLOWHATCH's Avatar
Posts: 2,047   (View Stats)
Groans: 202
Groaned at 33 Times in 18 Posts
Default Lower rear ride height after Koni install
So I finally got around to installing my Koni shocks and I have to admit I am pretty disapointed with the results. My biggest complaint is the fact that the rear end is at least 1/2" lower now and I am having issues with my rear tires rubbing. To the point where my rear fenders got slightly fucked after hitting a big dip in the road.
Has anyone else had this issue? I'm really regretting having purchased these shocks when I could have bought some Ksport co's and sold my swifts springs and spent about the same without my rear end sitting lower than the fronts. Any help would be appreciated. If I can't get the ride height level somehow I'll likely be parting with this set up.
I'll try to post some pics tomorrow of the difference in height.
Ok, here are a couple pics that I think show the difference well. Didn't take any measurements since it's been raining all day, plus I don't have the measurements from before the install. It wouldn't bother me if I could get the front lower. But this sucks.
2010 CBM W/ Tech, Cobb AP Tuned by rfinkle2, PTP HPFP, Ported IM,
HTP 3.5" Intake, CS DP, CS TP w/QTP E Cut out, ETS TMIC, D.O WMI D07,
NGK Iridium Ix, JBR EGR Delete, Coolant Bypass, JBR IM TIG, GS EBC 3 Port Mode
JBR TMM 70, JBR RMM 88, JBR SSB, JBR AP Holder, Sure SSP
Swift Springs, Koni Yellows, GC Bump Stops, CS RSB, Ebay Adj. Camber Arms, Sonic Tuning ST8'S 18x8.5 on 245/40/18 NT-05
 Old 10-07-2012, 06:18 PM   #2
radioflyer's Avatar
Posts: 431   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
The only thing you changed was the shocks?
Power: // K&N SRI // Cobb TIH // ETS TMIC // CNT Catted Turbo-Back // AT Internals // ITV-22's
Tuning & Fuel: Cobb AP // 25% e85/91oct // Cobb EBCS // Stratified Tuned
Suspension: Koni Yellows // Swift Spec R Springs // Hotchkis FSB // JBR RSB
Mounts: CPE Stage 2 RMM // CPE PMM // CPE TMM
Shifting: Corksport SSP // Corksport Shifter Assembly Bushings
Wheels & Rubber: XXR 527 // Some crappy free tires at the moment
How to make your car BSOD:
http://www.mazdaspeedforums.org/forum/f13/carputer-105207
radioflyer is online now   Reply With Quote
 Old 10-07-2012, 06:52 PM   #3
vrspeed10's Avatar
Posts: 977   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
something is not right.. your shocks dont support the cars weight.. on a side not how do you like the swift spring and did you ever run a different spring before it?
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 Bolted and getting Dizzy!!
vrspeed10 is offline   Reply With Quote
 Old 10-07-2012, 06:55 PM   #4
FY"IED"N
dMuze's Avatar
Posts: 497   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
Groaned at 6 Times in 4 Posts
stock tires/rims with koni yellow rears and CS springs = perfect homie. not sure what the issue is.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is online now   Reply With Quote
 Old 10-07-2012, 06:58 PM   #5
SLOWHATCH's Avatar
Groans: 202
Only thing changed was the shocks. I've only had the Swifts on the car, no other shocks. Same shock mounts in rear since they were in good shape. Got new mounts for the front.
I think the swifts are great. No complaints there. Just feel like I've had a harder time than expected to match the dampers to the springs.
So your ride height stayed the same? I have taken them off a few times now to play around with the setting. Thought maybe I set them too soft at first, even though common sense tells me the shocks do not control ride height, wanted to be sure. Set them almost to full stiff to see if it changed anything and no difference in height.
Last edited by SLOWHATCH; 10-07-2012 at 07:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-07-2012, 07:09 PM   #6
Cyclops's Avatar
Posts: 239   (View Stats)
Cyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the world
You're right.. shocks do not control ride height. This seems strange. I have a gen1 with yellows and cobb springs and i love the set up. I've had no problems at all and did not experience the problem you're having.
I also have mine set at full soft in the back and about midway up front. Wish I could help you.. Not really sure whats going on here tho..
2008.5 Mazdaspeed 3 GT True Red
COBB AP. COBB Springs. Autotech HPFP. HTP Full 3" Intake. UR Test Pipe. JBR SSP. JBR BPV Hose. JBR EGR Delete. JBR Chrome-Molly RMM. JBR Shifter Bushings. JBR 5mm Spacers. Stratified EBCS. SURE AGS SS Heavy Shift Knob. NGK Iridium. Koni Yellow. Prosport Boost Gauge in Vent Pod. Conti Extreme DWS 215/45/18 on Stock Wheels. Conti Extreme DW 235/40/18 on Sonic Tuning ST100 18x8.5+48.
270whp/310tq @ Moore Automotive 4/13/13
Cyclops is offline   Reply With Quote
The Following User Says Thank You to Cyclops For This Useful Post:
SLOWHATCH (10-07-2012)
 Old 10-07-2012, 07:10 PM   #7
King Pimp/Scammer Hunter
Raider's Avatar
Posts: 14,805   (View Stats)
Groans: 446
Regular 3 Konis drop the rear. What model did you get?
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
 Old 10-07-2012, 07:12 PM   #8
SLOWHATCH's Avatar
Groans: 202
I ordered the specific 2010+ model ones. I forget the part numbers but I double checked they were correct, at least for the year.
 Old 10-07-2012, 07:24 PM   #9
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,722   (View Stats)
Groans: 66
For every set of MS3 Koni's I've installed, the front struts had to be modified to get the proper ride height. It seems like more or less of a quality control issue at koni, since the bracket that stops the strut in the knuckle, never seems to be welded in the right spot.
If you didn't already modify your front struts, you'll prob have to remove them and check them compared to the OEM struts. Here's a thread detailing what to do: http://www.mazdaspeedforums.org/foru...install-73387/
Current Fail:
2006 Mazdaspeed6 Building, soon DD, future track whore
1986 Porsche 944 turbo Listed
2007 Kawasaki ZX-6R DD/Beater
MATT DAMOND is online now   Reply With Quote
The Following User Says Thank You to MATT DAMOND For This Useful Post:
 Old 10-07-2012, 07:47 PM   #10
SLOWHATCH's Avatar
Groans: 202
Thanks, I've seen the thread and have considered this as an option to leveling the ride height back to or as close to normal. I don't see this "mod" to the front struts getting me close enough to where I want to be, but I guess it's worth a shot. Just not sure if doing so will void my warranty...?
FWIW this is the part # for the rear shocks I ordered. 8040 1353Sport
 Old 10-07-2012, 07:56 PM   #11
anavrinIV's Avatar
Posts: 2,078   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
is the rear actually lower or is the front higher? there's a different issue in each situation
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
Big_Burd (10-08-2012)
 Old 10-07-2012, 08:00 PM   #12
Groans: 66
Yeah, I'd maybe check with Koni, letting them know you have to modify the bracket, so the car sits properly.
Can you post some pics of the side of the car, so we can see how it sits? Did you cut the rear bumpstops at all?
Current Fail:
 Old 10-07-2012, 08:19 PM   #13
SLOWHATCH's Avatar
Groans: 202
The front is not noticeably higher, maybe an 1/8", but I went from having a tight two finger gap in the front and back to a slightly loose two finger gap in front and a loose 1 finger gap in the rear if that gives you a perspective. I'll post some pics and measurements tomorrow.
Yeah I'll give them a call asap and see if I can get any insight from them on this issue. I'll have some before and after pics tomorrow. I cut approximately 1/2" off the rear bumpstops, but that shouldn't affect the height since the car is not resting on the stops.
 Old 10-07-2012, 08:51 PM   #14
Analog Troll
Easter Bunny's Avatar
Posts: 1,492   (View Stats)
Groans: 1,465
Groaned at 45 Times in 34 Posts
The rear has shocks, shocks do not change ride height but struts will. There has to be another issue.
Big_Burd likes this.
 Old 10-08-2012, 07:42 AM   #15
SLOWHATCH's Avatar
Groans: 202
If there is an issue it must be with the shocks themselves. Kinda hard to screw up the install of the rear shocks IMO.
 Old 10-08-2012, 07:47 AM   #16
Raider's Avatar
Groans: 446
I have the FSD's and my car sits fine. I do know the passenger strut mounting tab was 1/8 too low, would not go in all the way. had to Dremel a notch in the tab, pop it off, and it sat flush. The strut had a mark where it was supposed to be, but it was lower. Thankfully, it was all below the weld.
 Old 10-08-2012, 07:52 AM   #17
Big_Burd's Avatar
Posts: 405   (View Stats)
Big_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the world
Groans: 79
I have koni yellows (sports) on stock springs and they barely dropped the ride height. Try putting your stock springs back on and see how you like it. I have a genwon and idk if there are differences between the konis in genwon and pu.
However like a lot of people said, sounds like you have a different issue, and I"m no suspension guru.
2008 Speed3// Cobb SRI / Cobb TI/ Cobb STS Koni Yellows, stock springs/ JBR 88 Trilogy / JBR RSB / JBR CamberArms/ Hotchkis FSB
Big_Burd is offline   Reply With Quote
 Old 10-08-2012, 04:46 PM   #18
SLOWHATCH's Avatar
Groans: 202
Added pics to the OP
The Following User Says Thank You to SLOWHATCH For This Useful Post:
MATT DAMOND (10-08-2012)
 Old 10-08-2012, 10:21 PM   #19
specvspeedfreak's Avatar
Posts: 1,684   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 53 Times in 26 Posts
doesn't look bad. If you want, remove anything in the trunk that is heavy. I removed my spare (now have a fix a flat can) and I think it helped. I had the same problem when I installed bilsteins. Not sure if it was to the same degree but similar. Also, make sure you have the front shock all the way in. You can always do the cutting tab trick to have the fronts go in further. I was actually thinking of doing it with the bilstein but after removing the weight in the hatch and getting fatter tires, it really doesn't bother me much... If the setup feels good to you, don't mess it much.
this is mine:
http://www.mazdaspeedforums.org/foru...s-img_2957.jpg
http://www.mazdaspeedforums.org/foru...s-img_2959.jpg
*COBB: AP, shifter weight *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, 88TMM, EGR delete, WP *Grimmspeed: EBCS *TWM: Full Shifter *Tomei: Shift knob *KDM: HPFP internals *Ford: syn trans fluid *UR: TP, CBE *Bremmer Kraft:18x8 et45 BR05 (5mm rear spacers) *Dunlop: 245/40/18 Sport Maxx TT * Bilstein: B8 Sport *SWIFT: Spec-R springs *gtspec: 4point ladder brace, rear subframe brace * AC DELCO : Adj. camber arms *Denso:ITV22 *Stoptech: Performance pads *MORIMOTO: 5K HID elite *OEM: Gutted primary cat
specvspeedfreak is online now   Reply With Quote
The Following 2 Users Say Thank You to specvspeedfreak For This Useful Post:
MATT DAMOND (10-08-2012), SLOWHATCH (10-09-2012)
 Old 10-08-2012, 11:58 PM   #20
Groans: 66
SLOWHATCH Thanks for the pics. When you had the stock dampers in, and just the springs in, did the rear sit at that height?
Swift springs do lower the car quite a bit, and seeing as how the front is lifted, I'm pretty sure some grinding and cutting is needed on the front strut brackets.
Current Fail:
 Old 10-09-2012, 06:27 AM   #21
jack_hammer's Avatar
Posts: 4,157   (View Stats)
Groans: 412
Groaned at 104 Times in 60 Posts
what a disappointment to hear about the koni's. for those prices you should expect them to fit. i'm installing sen-sen's right now and am comfortable chopping up things to get them in place. but they are significantly less so it doesn't bother me. plus, they're a stop-gap solution. people buy koni's to be the final solution.
<edit>
i read the link to dano's thread. i had seen that before but forgot. still a bummer, then, to see it continuing.
it's fun to do bad things
 Old 10-09-2012, 06:42 AM   #22
Crarrs's Avatar
Posts: 900   (View Stats)
Groans: 59
Did the upper spring perches fall out when you had the car jacked up to change the shocks? I know it would be weird for it to happen to both, but double-check that the springs are sitting where they're supposed to. For a sanity check, you can pull the shock out and set the car down to see where the ride height ends up without it in. Take measurements. Also, try to run the suspension through its full travel arc to make sure nothing is binding. I'm looking at your eBay camber arms as a possible culprit, I haven't seen anybody else running those.
2010 MS3
CS SRI/TIP - CS RSB - CP-E RMM - MD OCC - Cobb AP - CS FSB - Koni Sport - EBC Yellow
 Old 10-09-2012, 09:57 AM   #23
Groans: 66
The ebay camber arms the OP is using are re-branded SPC's. I've compared a set of ebay CAs against a set of SPC CAs. SPC CAs have a raised SPC logo in the casting, and on the ebay arms you can see that raised casting grinded down.
Current Fail:
 Old 10-09-2012, 12:39 PM   #24
SLOWHATCH's Avatar
Groans: 202
this is mine:
Yeah, I already run around with no spare, jack etc. I never keep anything in my car haha. I made absolutely sure twice now that the shock is in as far as it can go. The tab is resting flat on the knuckle. Looks like I'll have to cut the tab down. I even set the rear super stiff just to be sure and made no difference. If I get the chance I'll have to grind down the front tabs. I need to put in my new bumpstops in the front anyways. Any idea how much more it can lower the front? If I can get mine to look like yours I'll be very happy.
The pic of the front angle is with Swift Springs only. I loved how even the ride height was. I wanted it to stay just like that. I can deal with it being lower, if I can get the front a bit closer to the same amount of drop.
I didn't remove the springs at all to remove or install the rear shocks and everything looked normal after install as far as the springs are concerned. But I guess it's worth a shot. I'm thinking the overall length of the oem vs koni shocks are different.
I haven't had any issues with them so far. Didn't know they were rebranded but good to know. Thanks for everyones input. I'll make sure to post up if I find out anything.
 Old 10-27-2012, 01:58 PM   #25
iammike's Avatar
Posts: 545   (View Stats)
iammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the world
SLOWHATCH, if it makes you feel any better, I'm having the EXACT same issue since installing the Koni Yellow's today.
FWIW, I can backup your assessment that it's not the front that's all jacked up higher than it was. My front has virtually the same wheel gap now as it had with just the CS springs and OEM struts.
The rear, on the other hand, I noticed immediately after pulling out of the garage. I went from having the same wheel gap as the front to significantly less.
Here's my one and only theory. If the OEM shock body was sitting on the bump stop after putting the springs on but the Koni shock body is shorter...then the rear would sit down lower after the install.
The car rides fine and the Koni's were a large improvement over OEM though. Just have a weird tiny squeak in the front left that I'm hoping will work it's way out.
SLOWHATCH likes this.
Mike -- www.theoreticaljerk.com for mod details.
iammike is offline   Reply With Quote
The Following User Says Thank You to iammike For This Useful Post:
SLOWHATCH (10-27-2012)
 Old 10-28-2012, 08:16 PM   #26
Nliiitend1's Avatar
Posts: 3,828   (View Stats)
Groans: 59
Lee
Any thoughts?
I have some of my own, but I'm wondering what the guy who works for Koni has to say...
Stance is not a verb.
SLOWHATCH (10-29-2012)
 Old 10-28-2012, 08:21 PM   #27
iammike's Avatar
Well before making any more permanent attempts to get things leveled out, I've ordered some shorter front bump stops. Figure if the front is riding on the bump stop with the lowering springs, replacing with shorter stops (which I should have done right off the bat anyway) will help bring the front down.
 Old 10-29-2012, 11:05 AM   #28
Kawiralph's Avatar
Posts: 13   (View Stats)
Kawiralph has a spectacular aura aboutKawiralph has a spectacular aura about
I had the same issue after installing koni yellows with eibach springs and OEM bumpstops front and rear. I modified the alignement tabs on the front struts resulting in an additional 8mm in lowering the front. This setup rides with no issues so far and the overall stance looks perfect for me. pics of your gen2 thread post 2860
After installation of the Koni yellows, the front actually had the same height as with the OEM struts and the eibach springs. Only the rear sat about 10 mm lower than with the OEM shocks.
The same issue is also reported by some guys in the german forum using Bilstein shocks.
I don't have an explanation, but it does seem to be related to the design of the OEM rear shocks.
Initially I used the OEM bumpstops on both ends with the Koni yellow/Eibach combination. After a while I changed the bumpstops from OEM to FatCat bumpstops. In my case, this didn't have any effect on ride height.
Last edited by Kawiralph; 10-29-2012 at 11:05 AM. Reason: MSF Database - Automerged Doublepost
Kawiralph is online now   Reply With Quote
 Old 10-29-2012, 11:09 AM   #29
pwned's Avatar
Posts: 472   (View Stats)
pwned has disabled reputation
In the Legacy Gt wagon world when owners would lower their car the ass would be lower than the front. The fix was to add a saggy butt spacer(went on top of the rear shock). Maybe someone could make one for us??
-13' CWP MS3-
JBR 88a Rmm // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs
323hp/351tq SAE
Sold // 12' Ms3 // 305hp 336tq SAE
pwned is offline   Reply With Quote
 Old 10-29-2012, 12:50 PM   #30
iammike's Avatar
Unfortunately, because of the way our rear coils are mounted, I don't see how this solution would help us. Wish it would though. Would be a perfect solution for me since I'd rather raise the rear than lower the front.
 Old 10-29-2012, 03:49 PM   #31
pwned's Avatar
The OP stated it was lower after the shock install. Maybe creating a 1/4 spacer to slide up where the studs come down would do the trick? Im not talking about washers. But some kind of hard treated plastic cut to fit by a dremel.
-13' CWP MS3-
323hp/351tq SAE
The Following User Says Thank You to pwned For This Useful Post:
SLOWHATCH (12-27-2012)
 Old 10-29-2012, 04:42 PM   #32
iammike's Avatar
I have no idea honestly. It might make a difference. From everything I knew before this situation I would never have expected shocks to change ride height unless maybe the old ones were completely busted.
The most solid piece of info I ran across that might have to do with this was something I found in the Gen1 section.
Apparently the OEM setup has low gas pressure tubes in the front struts but high pressure tubes in the rear shocks. Most OEM setups and aftermarket setups have the same front and rear.
As a result of the lower pressure in the shock, that could let it sit a little lower.
Makes sense I guess. Best way I personally see to fix it would be to come up with some kind of plate that sits in the lower or upper coil spring cups in the rear.
 Old 10-29-2012, 05:03 PM   #33
pwned's Avatar
I saw a picture in a thread somewhere of stock vs koni side by side. The koni was definately shorter plain as day.
-13' CWP MS3-
323hp/351tq SAE
 Old 10-29-2012, 05:10 PM   #34
iammike's Avatar
Shorter should only be able to make the car lower in one of two cases that I can think of.
A: The shock is fully extended before the car can reach the ride height it's supposed to be at. This is not the case.
B: The OEM shock body being longer had it riding harder on the bump stop which would effectively increase spring rate and cause the car to ride higher. If the Koni shock body was not making contact or making less contact, this could let the car sit lower.
If it has anything at all to do with the length of the shock, it has to be B. The gas pressure I read about also sounds like a legitimate possibility.
Either way, I'm looking into ways to raise the rear of my car. While lowering the front some is doable with some permanent modification to the front struts, I really didn't want to be that low.
I've considered air bags and coil inserts but both of those would alter the spring rate in the rear. Only way I can think to not change spring rate but raise the rear is to come up with some kind of inserts that would go above or below the coil in the cups. Upper would probably be easier since you don't have to worry about the coil stop.
 Old 10-30-2012, 11:33 AM   #35
Kawiralph's Avatar
In my case, the bodies of both the OEM and the Koni yellow shocks were identical in length.
However, with fully extended rods, the koni Yellow was longer than the OEM shock.
 Old 10-30-2012, 12:31 PM   #36
pwned's Avatar
1/4", 1/2", 3/4" & 1" Saggy Butt Spacers --> SUBTLE SOLUTIONS - Subaru Impreza WRX STI Forums: IWSTI.com
-13' CWP MS3-
323hp/351tq SAE
 Old 10-30-2012, 01:08 PM   #37
iammike's Avatar
While I can see how these would work on Subbie rear struts, I don't think it will work on our rear shocks.
 Old 10-30-2012, 02:19 PM   #38
Kawiralph's Avatar
As long as they have the correct dimensions they should do the job. The bolts for attaching the top shock mounts are plenty long.
Gesendet von meinem HTC One X mit Tapatalk 2
 Old 10-30-2012, 03:52 PM   #39
iammike's Avatar
That's not the problem. Problem is that the shock does not exert more pressure because it is depressed more. In other words, all putting this on top the shock would do is remove suspension travel.
What needs to be done is something like the saggy butt things but made to go above or below the coil which is separate from the shock.
 Old 10-30-2012, 06:18 PM   #40
pwned's Avatar
If the all the koni shocks do this then maybe we need to look somewhere else. Like the top of the line napa/sears/midas shocks or something like that. Since bilsteins do the same as well.
-13' CWP MS3-
323hp/351tq SAE
Koni Yellow rear strut install problem btstarcher MazdaSpeed 3/6 - Suspension & Brakes 17 06-13-2012 03:19 PM
Whiteline ride-height sensor SpeedCheese MazdaSpeed 3/6 - Suspension & Brakes 3 04-23-2012 05:09 PM
Setting rear ride height on BC coil overs trdsw MazdaSpeed 3/6 - Suspension & Brakes 2 03-25-2011 05:47 PM
OEM Speed 6 spring rates and ride height FWD=WWD MazdaSpeed 3/6 - Suspension & Brakes 4 05-04-2009 09:02 AM
Will SPC links be ok at stock ride height thanotosq MazdaSpeed 3/6 - Suspension & Brakes 12 04-21-2009 06:58 PM
Page generated in 0.60914 seconds with 37 queries
