Like Tree4Likes
  • 1 Post By FastblackS2K
  • 1 Post By Fstrnyou
 Old 12-31-2016, 08:25 PM   #1
FastblackS2K's Avatar
Posts: 23   (View Stats)
FastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really nice
Default Never ending brake squeal
I'll keep this short. Changed pads and rotors on all 4 corners in late summer. Went with the EBC Ultimax 2 to stick with stock like braking. All was good and then after the 1000 mile brake in I started getting a brake squeal while driving. The noise goes away when brakes are applied. It acts like there's a high spot on the rotor because it's not constant. Its like a "chirp" every rotation. But there is no pulsating or anything, and it only seems to happen after the brakes get some heat in them.
I've searched high and low for answers, and I've even swapped out the parts (EBC warranted them out). So, car stops great, it's just an annoyance, curious if anyone has ever experienced anything similar? Seems unlikely I would get 2 sets of bad pads / rotors and I've never had this type of a squeal on the many many brakes I've done over the years.
FastblackS2K is offline   Reply With Quote
 Old 01-01-2017, 07:15 AM   #2
ChaunceyM's Avatar
Posts: 940   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Are the calipers clean and all parts lubed and sliding well? Were the dust boots intact and the pistons clean? It almost sounds like they're sticking when you left off the pedal instead of retracting. So something might be binding the piston in the bore or the external moving parts are covered in gunk and corrosion and not moving freely.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 01-03-2017, 09:45 AM   #3
.Slug's Avatar
Posts: 136   (View Stats)
.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world.Slug is the leader of the world
This sounds a lot like the problem I had recently:
Botched dealer brake job
The squealing ended up resolving on its own. Caused possibly by a "glaze" on my rotors that needed to be burned/worn away.
I did shit tons of research while the sound was happening though and found that it can be a myriad of problems that you just need to troubleshoot away:
1.) get a dial gauge with a fixture to attach to the axel to measure for rotor run-out and compare to tolerances.
2.) check for anything impeding caliper piston operation
3.) re-lube the parts you're supposed to lube when changing things. After the dealer re-lubed my caliper parts, things quieted down a bit.
4.) improper bedding
5.) look for bent retention pins
Hope you get this resolved, let us know what fixes it, if anything. (mine seemed to fix itself)
.Slug is offline   Reply With Quote
 Old 01-10-2017, 05:42 PM   #4
Been a crazy week or so.
So I had checked runout, swapped pads + rotor, kept driving to see if it would "fix itself", etc. Was going to recheck / re-lube everything once it wasn't 10 degrees out but.... ended up trading the car in on a 2017 Focus RS this past Saturday. It's now the dealers problem. Most expensive way to fix brakes I've ever experienced...
sharksinspace likes this.
2002 S2000 - Sold
2013 Mazdaspeed 3 - Traded In
1937 Ford Rat Rod - Weekend trouble maker
2017 Focus RS - The new ride
The Following User Says Thank You to FastblackS2K For This Useful Post:
aznpersuazn (01-11-2017)
 Old 01-10-2017, 05:51 PM   #5
Fstrnyou's Avatar
Posts: 1,482   (View Stats)
This should be made a sticky for anyone else having brake squeal! Best solution ever.
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
 Old 01-10-2017, 06:02 PM   #6
Haha. I can't say it's not a good solution. The squeal is gone, and the braking got dramatically better.
2002 S2000 - Sold
 Old 01-10-2017, 06:58 PM   #7
sharksinspace's Avatar
Posts: 749   (View Stats)
Groans: 117
Damn, dude. I have such a boner for the RS; if only I had like $40k to drop on one, haha
2007 MS3
PD by Will
 Old 01-10-2017, 07:02 PM   #8
Me too... just pile that debt on top of the student loans and mortgage, and then act like none of it exists.
2002 S2000 - Sold
 Old 01-10-2017, 07:05 PM   #9
Groans: 117
I do honestly hope to be able to make one my next car, maybe a couple or few years down the line. That or...an M3?
2007 MS3
PD by Will
 Old 01-10-2017, 07:14 PM   #10
I actually considered an E92 M3 but for what I was willing to spend, didn't make sense to get a used car with 40-50k miles and no warranty. Plus I have a thing for hatchbacks.
I don't regret the RS one bit though. Still getting used to it, only had it a few days. But so far so good. Way different power curve than the MS3 though, much more linear.
2002 S2000 - Sold
 Old 01-12-2017, 12:15 AM   #11
mituc's Avatar
Posts: 3,414   (View Stats)
Groans: 107
Yeah, that is an absolutely awesome car. The only things that keeps me from buying one is the fact that is has a trunk smaller than a regular fiesta. So if you don't really have any special needs regarding the trunk space (where the civic typeR shines, its problem being that they don't make the FK2 any more and will probably release the newer model sometime in 2017) then the focus is unbeatable for the money.
2008 Cosmic Blue Mazda 3MPS
JBR Tru-3" + CS CAI Box, SU TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071, CS 3.5BAR, Guardian Angel, CoolingMist WMI
StratiVersaTuned FTW to 28PSI, self-tned to 31PSI
SU TMIC, Autotech HPFP internals
Versatuned
MS6 rear brake squeal lescano88 MazdaSpeed 3/6 - Suspension & Brakes 0 05-03-2015 12:55 PM
Brake squeal when cold? pwrful4 MazdaSpeed 3/6 - Suspension & Brakes 12 02-11-2011 05:05 AM
Brake Squeal Help SpeedEMS 2010 MS3 - Suspension & Brakes 6 01-27-2011 02:14 PM
Front Brake Squeal ksirichanvimol MazdaSpeed 3/6 - Suspension & Brakes 6 04-02-2010 02:45 PM
Brake squeal after hooking battery back up. JimmyMac MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 05-24-2008 11:18 PM
Page generated in 0.36038 seconds with 25 queries
