Notices
Like Tree18Likes
 Old 08-14-2012, 02:09 PM   #281
cshunter's Avatar
Posts: 372   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groaned at 7 Times in 5 Posts
Bro Spiders.
File Type: jpg rage_comics_spider_bro-s500x738-170689.jpg (57.4 KB, 68 views)
2012 LSM Autotech Internals // Cobb SRI // Cobb TIH // Cobb AP // JBR RMM // NGK 1 Step Colder Spark Plugs // Ultimate Racing Cat-less DP // Ultimate Racing Resonated TP
Future Mods when I get back: SSP, weighted shift knob, Suspension, Wheels 18x8 or 18x8.5 w/ 245's, CP-e Triton SS CBE, and window tint....
cshunter is online now   Reply With Quote
The Following User Says Thank You to cshunter For This Useful Post:
ASHMS3 (10-04-2012)
 Old 08-14-2012, 02:10 PM   #282
dantes5823's Avatar
Posts: 6,674   (View Stats)
Originally Posted by specvspeedfreak View Post
what are the specs of your alignment?
Outside wear usually means your car is pushing around corners. Check your tire pressures and adjust according. You might need a alignment
Damn this has been on the rack twice already. Whenever I get my tires put on I'll have them check it. Last time I had them give it more toe out.
 Old 10-04-2012, 09:19 PM   #283
redneck4Christ's Avatar
Posts: 49   (View Stats)
redneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to beholdredneck4Christ is a splendid one to behold
Neutral  -1 score
Subbed for future reference.
redneck4Christ is offline   Reply With Quote
 Old 10-06-2012, 03:02 PM   #284
Speed3eak's Avatar
Posts: 2,269   (View Stats)
Groans: 82
FWIW, I got my alignment done at 19k miles - I had some slight toe-in, but IIRC it wasn't terrible. My tires should last until 25k but I also do a lot of highway driving.
Had the alignment changed to 0 toe in the front and 1/16 toe-in in the rear. Car follows the crown of the road a little more on the highway now, but it's a subtle difference. Camber was -1* front and -1.5* rear, +/- .1*
Big thank you to Nataphen for the suspension suggestions - I'm really happy with the new alignment settings.
I'd like to get a set of quality shocks (Bilstein B8) and springs (swift), but that's not in the budget right now.
Speed3eak is offline   Reply With Quote
The Following 2 Users Say Thank You to Speed3eak For This Useful Post:
Nataphen (10-09-2012), rfinkle2 (11-11-2012)
 Old 10-06-2012, 04:15 PM   #285
Now with BNR Power
Todd98SE's Avatar
Posts: 964   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
Groaned at 10 Times in 9 Posts
I'll bet you'll like a little more front and a little less rear camber.
www.MOTOIQ.com
2010 LSM Mazdaspeed3
Todd98SE is offline   Reply With Quote
The Following 3 Users Say Thank You to Todd98SE For This Useful Post:
Nataphen (10-09-2012), Nliiitend1 (10-07-2012), SLOWHATCH (10-07-2012)
 Old 10-07-2012, 07:03 AM   #286
Speed3eak's Avatar
Groans: 82
I'd like to, but I've heard there isn't enough adjustability in the stock suspension. Ideally, I'd have the setup the same as now, but with -1* of camber, front and rear.
I'm not entirely sure which products allow you to change the camber in the front of the car. I've seen someone post up spc camber bolts for the rear, which fit the C1-chassis ford focus. I have no idea whether they will work for the mazdaspeed 3 however.
I don't plan on getting coilovers, or going slammed, or what have you. When the stock suspension shits the bed I'm probably going to get Bilstein B8's and swift springs. I'd like FSDs, but I've heard bad things about the quality control on those particular struts.
 Old 10-07-2012, 07:36 AM   #287
Now with BNR Power
Todd98SE's Avatar
To adjust the fronts you need camber plates or slot the upper mount holes. For the rear you need camber arms, dont mess with camber bolts.
www.MOTOIQ.com
Nataphen (10-09-2012), Nliiitend1 (10-07-2012), Speed3eak (10-07-2012)
 Old 10-07-2012, 05:07 PM   #288
ThizSpeed3's Avatar
Posts: 242   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
Groaned at 13 Times in 3 Posts
link to where we can purchase these
ThizSpeed3 is offline   Reply With Quote
 Old 10-07-2012, 05:10 PM   #289
Now with BNR Power
Todd98SE's Avatar
Corksport for front camber plates. There are a million different makers of rear camber arms. When you donate I'll tell you how to use the search button.
www.MOTOIQ.com
FreeFlyFreak (10-11-2012), galens47 (12-12-2012), ThizSpeed3 (10-07-2012)
 Old 10-07-2012, 07:34 PM   #290
ibcrusn's Avatar
Posts: 164   (View Stats)
ibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond reputeibcrusn has a reputation beyond repute
Ever heard of Bing or Google?
Bing
Google
Welcome to the interweb.
'10 VRM MS3
CP-e Stg1 RMM, CS TMM insert, SURE SRI, Cobb TIH, Grimmspeed, Swift's, SPC camber arms, maisonvi SS Knob, JBR bushings, DDR 5k HID, RokBlokz mudflaps, LED cargo lighting
'94 Land Cruiser
Plenty of goodies
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
Todd98SE (10-07-2012)
 Old 10-07-2012, 07:44 PM   #291
Speed3eak's Avatar
Groans: 82
I'll tell you how to use the search button for free
Easter Bunny (10-07-2012), Todd98SE (10-07-2012)
 Old 10-13-2012, 05:58 PM   #292
Pedal-Force's Avatar
Posts: 403   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
Got an alignment today. Front left toe went from -0.08 to 0.08. Front right from 0.21 to 0.09. Caster left/right stayed at -.7, -1.1.
Rear toe from -.09/.08 to 0.00/-0.01. Camber stayed at -2.1 both side.
Total toe from .13 to .17. Thrust angle went to 0.01.
I know fuck all about suspension. I know what toe and camber mean, but not what's good. I gave them the numbers that you guys said, but they said they didn't make much sense and would wear badly. I don't have what I told them, but it was what Nataphen had. 1/16 total front in?, 1/16 total toe out? rear. 1 camber front, -2.5 rear or something? Anyway, hopefully what they did is good.
I just put new tires on yesterday. I ended up getting 25k out of the stock tires. I forgot to look at the inside edge, but they seemed to be wearing relatively evenly all around. Hopefully the ExtremeContact DW I put on will last just as long or longer, while being stickier and better (and quieter?).
Anyway, just adding some data to the pile.
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is online now   Reply With Quote
 Old 10-15-2012, 04:51 PM   #293
Nliiitend1's Avatar
Posts: 3,837   (View Stats)
Groans: 59
Are those your front caster values you've listed or are those camber values (I don't see front camber specified anywhere in your post)?
Stance is not a verb.
 Old 10-16-2012, 06:09 AM   #294
Sorry, camber. They didn't do anything or measure caster.
Sent from my DROID RAZR using Tapatalk 2
 Old 10-20-2012, 11:06 AM   #295
Nataphen's Avatar
Posts: 2,728   (View Stats)
Groans: 31
If those are the specs you gave them, they're not at all what I recommended. For longest wear, I said:
0 front toe
1/16 rear toe IN
You need rear camber arms so you can set that between negative 1.0-1.5
Front camber needs to be more negative than rear. If you have a way to set front camber, try negative 1.5-2.5 depending on your driving style, but more negative than the rear at least. If you just lower your car and don't have front camber plates, the front camber is usually about -1.5. If that's the case, try setting the rear to -1.0 for starters.
06 BM MS6=stock (totaled)
13 5.0=stock
Wife's 13 Focus ST=stock
 Old 10-20-2012, 12:19 PM   #296
So is 1.7 total front and 0 rear bad? They said what I told them would wear or something. I told them what you have early in thread (unless I messed it up, which is likely).
Originally Posted by Nataphen
I've learned a lot about alignments since I've started working in a shop that does them day in and day out. I have since set my car up for 1/16 total toe out in front for turn in response, and 1/8 total toe in rear for rear stability. I need to get KW V3s and camber arms so that I can set up my camber and caster.
Is it worth another $90 to get it fixed? Is what I have decent? I just told them to do whatever they thought was best.
 Old 10-20-2012, 02:56 PM   #297
Nataphen's Avatar
Groans: 31
1/16 front toe out is for turn in response, 1/8 rear toe in is for hard braking stability. They aren't the best for tire life. The specs that I just mentioned in post #295 are probably the best for tire life.
 Old 10-20-2012, 05:18 PM   #298
Posts: 5,620   (View Stats)
Groans: 121
I'd go with 1/8" toe out in the rear to get the back end to rotate more, but that's me. I hate understeer, an don't care too much about tire life.
silvapain is online now   Reply With Quote
Todd98SE (10-21-2012)
 Old 10-22-2012, 11:28 AM   #299
Nliiitend1's Avatar
Groans: 59
There's your problem...
 Old 10-22-2012, 11:43 AM   #300
Nliiitend1's Avatar
Groans: 59
Remember though that your rear toes IN under compression on the MS3 (even more than most cars), so if you start with rear toe OUT you'll be forcing a transition from toe OUT to toe IN while in the compression stroke (i.e., while you're turning) that can upset the balance of the car if you're not accustomed to it, and make your corner transitions a bit more unnecessarily dramatic than they need to be.
1/8" rear toe out (even if that is TOTAL and not per side) is a LOT on this car, IMO. The only time I think I'd personally go for that much is if I was setting the car up for slow-speed (i.e., conventional autocross) handling. For me, that would be way too much at track speeds.
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
Nataphen (10-25-2012), silvapain (10-22-2012), SLOWHATCH (10-22-2012), wolly6973 (10-23-2012)
 Old 10-22-2012, 11:45 AM   #301
Groans: 121
I meant total toe out. Good points though.
Nliiitend1 (10-22-2012)
 Old 10-22-2012, 12:57 PM   #302
Nliiitend1's Avatar
Groans: 59
I would also like to clarify that depending on overall setup, one particular parameter (like toe, for instance) may be entirely appropriate under one but not the other, and that a lot of the finer points come down to driver preference and driving style as well with regard to what is "optimal" as far as alignment settings go.
If I were to change my rear toe settings to 1/8" total toe out without changing anything else on my current setup, I'd have a handful of a car, especially under braking and at speed.
The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post:
Nataphen (10-25-2012), SLOWHATCH (10-22-2012), Todd98SE (10-22-2012)
 Old 12-12-2012, 03:06 PM   #303
Spec's Avatar
Posts: 1,191   (View Stats)
Spec has disabled reputation
Could use some advice. Currently at 6k miles. Inside of both front tires are destroyed.
Took it to dealer.
Recommendation was, alignment and two tires.
I guess they didn't remember my mileage because they wanted to charge me for both.
Here I am, two weeks later with out my car still and got a call denying my claim per " Mazda corporate" and all the sudden I no longer need an alignment as its " in the green"
I've got a lot of reading under my belt for warranty denials and disputes and a guy from mazda of N. America currently trying to figure out what's up. Any insight would be appreciated. What would you do?
Spec is online now   Reply With Quote
 Old 12-12-2012, 03:23 PM   #304
Nliiitend1's Avatar
Groans: 59
Ask them for your exact current settings.
Do not settle for "in the green."
That would be the first thing I'd do.
 Old 12-12-2012, 03:30 PM   #305
Spec's Avatar
When I dropped it off I told him I wanted a print out. When they called me and said I needed the alignment and tires and I argued the fact of mileage the service wasn't performed. I then Left work to talk face to face with the guy and asked for my requested print out of my specs, to no avail it didn't happen.
As we were talking the mechanic shop foreman walked over and the advisor said" I told him I could cover the alignment under warranty" and my reply was " why would I want my car aligned with the tires fucked off like that"
He said it didn't matter and the shop foreman and I both looked at him like he just had just farted. The foreman replied " uh.... Yes it does" and then the resolution for that day was they'd call corporate to get an approval for tires.
Now as I said before, after having had an alignment recommended when I was to pay for it, now I don't need one and the tire wear is from my driving habits.
 Old 12-12-2012, 03:36 PM   #306
das macht kein sinn
mizboo102's Avatar
Posts: 1,112   (View Stats)
mizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the worldmizboo102 is the leader of the world
I agree with Nliiitend1. Ask them what your exact specs are and then post them here.
Are you the first owner? How long have you had the car?
IIRC, my car came with some sort of tire warranty, check that out. Although, I think it might just cover bubbling and manufacturer defects.
Did your car pull to one side or was your steering wheel offset when driving straight?
NATOR East Coast
2008.5 MS3 (big one) <3
& 1999 Miata (little one?) http://www.mazdaspeedforums.org/forum/f25/time-121773/
"Making your mark on the world is hard. If it were easy, everybody would do it. But it's not. It takes patience, it takes commitment, and it comes with plenty of failure along the way. The real test is not whether you avoid this failure, because you won't, it's whether you let it harden or shame you into inaction, or whether you learn from it; whether you choose to persevere."
mizboo102 is offline   Reply With Quote
 Old 12-12-2012, 04:19 PM   #307
Spec's Avatar
Yea, I tried to get the exact specs from the get go. They're basically fucking me around. I'm the first owner. Car has 6k miles total.
Car drifted left-right at highway speeds.
Tech stated tires have a warranty, granted its prorated. I don't want to have to come out of pocket 1 cent for tires after owning it for 4 months.
 Old 12-12-2012, 06:43 PM   #308
Spec's Avatar
Once I have the exact measurements, and even if they're in the "green" wouldn't Mazda claim that their end is good or within spec or would I have a leg to stand on?
Also, I'm no alignment expert but, wouldn't the actual alignment be off anyhow due to the tires being fubar?
 Old 12-13-2012, 04:14 PM   #309
Ten2Four's Avatar
Posts: 10   (View Stats)
Ten2Four will become famous soon enough
This was my inside wear @ 25K. Thought I had another 5K left in the tires but I went ahead and replaced them. Going in for an alignment shortly as the car is pulling hard left now
Ten2Four is offline   Reply With Quote
 Old 12-13-2012, 04:52 PM   #310
qweedqwag's Avatar
Posts: 222   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
Inside tire wear could also be from to much negetive camber.
qweedqwag is offline   Reply With Quote
 Old 12-13-2012, 05:04 PM   #311
edspeed3's Avatar
Posts: 67   (View Stats)
edspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of light
Groaned at 20 Times in 5 Posts
That is pretty much from toe in. I had that problem on my car too after 25k miles. These cars stock come with quite a bit toe to have nice sharp turn in rates. There's not much you can do except correct the toe in at an alignment place to 0 or as near 0 as possible leaning toward the negative end.
Sent from cmx evo4gLTE
2010 Silver Speed3 /w Tech
JbR SSP / shift bushings
e4p shift knob
CP-E 75dm RMM
DDM 55w 5k HIDs
resonator delete
Cobb SRI
Block8head defrost vent pod / Prosport 52mm electric boost gauge
Tanabe NF210 Springs
HKS SSQV V1 BPV
JbR Rear Sway Bar
edspeed3 is offline   Reply With Quote
 Old 12-13-2012, 05:20 PM   #312
2k4_8's Avatar
Posts: 533   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 53
Groaned at 18 Times in 6 Posts
Which we know isn't the issue when lowering only puts you at 1.5 degrees and stock is less than 1.
COBB AP, JBR RMM, CS SRI/TIP, AT HPFP INTERNALS, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 12-13-2012, 06:09 PM   #313
Spec's Avatar
Going to check into some things.
 Old 12-14-2012, 01:03 AM   #314
greatdane68's Avatar
Posts: 511   (View Stats)
greatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the worldgreatdane68 is the leader of the world
Groaned at 42 Times in 19 Posts
My rear camber was sitting at -2.4 after I lowered my car. Fixed that though.
2010 Mazda Speed3
Hypertech Tune, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP,
Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ebay 15mm Wheel Spacers
Soon to come: Fuel Pump internals (On order from Edgeautosports)
1995 Honda Prelude
2003 Chevy S-10
greatdane68 is offline   Reply With Quote
 Old Yesterday, 06:51 AM   #315
Hokie D's Avatar
Posts: 33   (View Stats)
Hokie D has a spectacular aura aboutHokie D has a spectacular aura about
I know most of you have your cars lowered, but what's the max camber adjustment you can get out of the stock suspension? From reading this thread I'm shooting for these settings on stock suspension:
Front
0" to 1/16" total toe "out" (turn-in)
0* steer ahead
-1.5 to -2.5* (should be more than rear, need front camber plates??)
Rear
1/16" to 1/8" total toe "in" (braking stability)
0* thrust angle
-1.0 to -1.5* (rear camber arms??)
Do I need camber arms/front camber plates on stock suspension? And would I even be able to get close to these settings without lowering the car?
2010 Celestial Blue Mazdaspeed3 - Cobb AP Stage 1 + Cobb SRI -- Not yet installed: Cobb TIP & OBX Test Pipe -- Coming Soon: FP Internals & Stage 2
1993 Reef Blue Ford Mustang LX - Stock motor, Ford underdrive pulleys, K&N w/ram air, T5 conversion, Steeda Tri-ax, 3.73 gears, Mustangs Unlimited lowering springs, KB subframes, Steeda camber plates, Steeda strut tower brace, Steeda aluminum adj upper control arms, Steeda aluminum lowers, torque boxes, Tokico blue shocks, Bassani stainless catback, Bassani stainless catted x-pipe, 3G alternator conversion, Flex-a-lite 185.
Youtube Channel -> http://www.youtube.com/user/HokieD1993
Hokie D is offline   Reply With Quote
 Old Yesterday, 12:59 PM   #316
You'll definitely need camber arms for the rear. Don't know about the front though. I think mine was 1.6 without camber plates.
2010 Mazda Speed3
1995 Honda Prelude
2003 Chevy S-10
 Old Yesterday, 05:59 PM   #317
Nliiitend1's Avatar
Groans: 59
Originally Posted by Hokie D View Post
Front
0* steer ahead
Rear
0* thrust angle
Arguably, "yes" to the first question and "not likely" to the second (at least regarding front camber)...
 Old Yesterday, 06:26 PM   #318
moonrider_99's Avatar
Posts: 41   (View Stats)
moonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to beholdmoonrider_99 is a splendid one to behold
this should be a sticky.
Question, why toe OUT in the front? I thought on a FWD drive car, it's best to have some toe IN since the car pulls the suspension as opposed to a RWD where it pushes the car... TOE should correct this flex in the suspension due to the drivetrain layout.
2012 MS3 Silver w/ Tech Package
2009 WRX Stage 2- sold
moonrider_99 is online now   Reply With Quote
Possible LSD issue? dwagner88 MazdaSpeed 3 - Engine, Transmission & Driveline 5 05-31-2011 10:48 AM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 08:12 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 07:40 PM
AWD issue caseygt2 MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-14-2010 01:38 PM
Page generated in 0.51262 seconds with 40 queries
