 Old 08-14-2019, 07:53 AM   #1
spinfly's Avatar
Posts: 21   (View Stats)
spinfly can only hope to improve
Default Rear sway bar bushing replacement, end link removal needed???
Hey guys,
Going to replace my rear sway bar bushings. Do I need to remove the end link? Or can I just remove the sway bar brackets and replace the bushing?
Thanks!
spinfly is offline   Reply With Quote
 Old 08-14-2019, 08:08 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,894
Check the FSM.
 Old 08-14-2019, 05:25 PM   #3
spinfly's Avatar
Sorry but FSM?
 Old 08-14-2019, 05:34 PM   #4
Db09ms3's Avatar
Posts: 427   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 88
Factory Service Manual. Or google it. Pick your poison!
Stockish
 Old 08-14-2019, 06:41 PM   #5
MSMS3's Avatar
Posts: 2,586   (View Stats)
Groans: 144
Originally Posted by spinfly View Post
Hey guys,
Thanks!
It will probably have some preload, so it will be much easier to undo one end of one or both end links so it “relaxes”. You might have trouble going back together if you don’t. I’d replace the brackets and bushings with ones with zerk fittings that can be greased while at it.
Db09ms3 (08-14-2019)
How-To: Front Sway Bar Bushing replacement w/o dropping subframe DeadWayt MazdaSpeed 3 - How-To's 69 04-15-2019 02:12 PM
Easy OEM Front Sway Bar Bushing Replacement spl 2010 MS3 - Suspension & Brakes 7 12-30-2017 06:42 PM
MS6 driver-side sway bar bushing removal wdautrem MazdaSpeed 3/6 - Suspension & Brakes 16 06-01-2012 09:44 PM
Sway bar link bolt removal MARKSPEED3 MazdaSpeed 3/6 - Suspension & Brakes 12 03-18-2012 08:28 AM
Page generated in 0.26196 seconds with 23 queries
