 Old 08-10-2018, 07:09 AM   #1
ozzy610's Avatar
Posts: 5   (View Stats)
ozzy610 is an unknown quantity at this point
Default Strut top mounts
Hi I am changing struts and spring for the bilstein b12 pro kit and the garage has asked me to supply strut top mounts and bearings.can people let me know if I need updated ones if any and if it is front only and is there a prefered make. thanks
ozzy610 is offline   Reply With Quote
 Old 08-10-2018, 07:21 AM   #2
MSMS3's Avatar
Posts: 2,361   (View Stats)
Groans: 133
OEM or Ford Focus. About the same price. Aftermarket like Moog and Dorman are ok, but don't last as long.
You cannot reuse your old ones. They will be shot or will fail very rapidly with new struts.
 Old 08-10-2018, 07:40 AM   #3
shamie's Avatar
Posts: 924   (View Stats)
You can reuse your rears but get new fronts or rebuild them.
Tasca parts has great prices for OEM.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
Strut Mounts TrueReddd Mazdaspeed3/6 General Discussion 12 06-11-2013 06:06 PM
Is it possible to replace strut mounts without completely removing the strut (bottom) from car? MARKSPEED3 MazdaSpeed 3/6 - Suspension & Brakes 8 04-15-2013 11:11 AM
Page generated in 0.31805 seconds with 22 queries
