> 2010 MS3 - ECU Computer Tuning
Notices
 Old 10-12-2012, 10:39 AM   #1
Speed3eak's Avatar
Posts: 2,269   (View Stats)
Groans: 82
Default ~3 gal e85 tune knock
Attached are two recent 3rd gear logs taken with a ~3 gal e85 mix. I'm still getting quite a bit of part throttle knock when I shift below 2500 rpm, which you can't see here. What you can see is that I get ~.7 KR at WOT even with a 3/9 mix of e85.
When I say 'quite a bit' of part throttle knock, I mean I've pegged the KR sensor (8*) in 4th gear just cruising around 2k rpm. I've heard that the ECU does this to find the knock threshold for CL/part throttle, but I've never noticed it while cruising in CL on the highway at 2.5k+ rpm, and I've done a LOT of highway driving.
I'm also targeting AFRs of 17:1 in cruise loads so that may have something to do with it, but nobody else targeting those AFRs is seeing the same kind of knock. Any boost at all below 2.5k rpm and I usually see over 1*.
I'm only targeting ~10.5* at redline, and the tune has been modified as per Bucker's sticky, and bnoon's closed loop MPG tooning tables, so it is pretty generic in any case. It's a self-tune, obviously.
I have a few tunes with timing increases, going up to 12* @ RL, which I think I'm going to try out at some point later today when I get a chance. I'll post those logs up as well.
I haven't modified my tune for e85, I'm just trying to use it as a knock suppressant right now. Obviously it isn't working.
Mods that matter are JBR 3.5" WP intake - CNT 3" Catted DP - CS TMIC - Stock Plugs. I had one step colder plugs in there, but car didn't respond well, so I went back to stock.
I think the g/s reads high because my intake is so massive - vdyno has me around ~270 whp and ~315 wtq, even though I occasionally see 300+ g/s.
This particular tune shoots for AFRs of 11.8, but I'd like to move to 12-12.2 @ 16.5 psi and 12* at redline once I get this knock figured out.
Suggestions and thoughts are welcome, if anybody sees power on the table without increasing boost or timing, let me know.
Speed3eak is offline   Reply With Quote
The Following User Says NO Thank You to Speed3eak For This Un-useful Post:
econman (10-12-2012)
 Old 10-12-2012, 11:37 AM   #2
himurax13's Avatar
Posts: 2,289   (View Stats)
Did you alter the scalar for the JBR intake?
Ohnononono pinoyboi.
Listen my adobo cooking friend. You will move to NJ. I shall take you under my wing. You will void that warranty. Your wife will be very upset with you that you spend every Tuesday night with us, and you use all your extra monies to buy all the parts I shall find for you. You will sushi roll and ffs up and down the GSP with us. You will end up on YouTube and in the street racing videos. And last, but not least, you will allow us access to employee pricing on all parts thru your dealership.
Are you sure you still want to come to NJ? We go hard here.....be warned.
I too once was a naive ayshun with a stock pu. Then I met these fuckers. My wife hates me now Tuesday nights. My neighbors hate my car for the uber cool cold start. My garage is a fucking mess. My warranty went out the window. My life has not been the same since April. I should have bought a Mazda2.
himurax13 is online now   Reply With Quote
 Old 10-12-2012, 11:51 AM   #3
smoogs12's Avatar
Posts: 3,303   (View Stats)
Groans: 154
Took a quick look at the logs and it seems like you are running a bit lean (relative to your targets).
you should try scaling the injectors and setting the specific gravity to see if your afr come back down to 11.8 for the whole log. I think that 30% e is kind of a lot to not scale for.
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 10-12-2012, 02:47 PM   #4
Speed3eak's Avatar
Groans: 82
Well, it isn't exactly 1/3% e85. That was a rough estimation. It's probably closer to ~2.5 gallons, and I just started putting it in - so that figure is closer to e20 by my calculations, than e33.
I didn't alter the scalar for the JBR intake - just multiplied the MAF table by the % increase in surface area and fine tuned from there.
I'm hesitant to mess with the specific gravity of the table, because there's only one e85 gas station within probably a hundred miles of here, that I've found so far, so I won't always be able to fill up with it. So this tune is designed to be fine on regular old 93. Which it is, mostly.
I used the e85 to see if my knock was real knock, or if it was more indicative of injector seal issues. And to be honest, I can't tell. I don't know what engine noise disguised as knock looks like.
I guess toyota diesel seals are only like $2 and I need to clean my IM anyway. I just have been lazy and don't want to take the IM off.
Thank you for the feedback.
 Old 10-12-2012, 04:05 PM   #5
smoogs12's Avatar
Groans: 154
I'm on my phone so I can't really get a great look at your logs, but all the kr values were less than 1 right? That's not typically something to get to excited about. I cant say that it's not injector seals, because I have not seen many logs from cars with that as a known issue.
On the flip side, I would find it unusual that they would already be failing at your power level and (can I assume) low miles.
Also as far as the injector scalar/sg and not using them because you only have one source of e85, well, that's the beauty of them. We no longer have to rescale the fuel using an altered maf table every time we want to switch blends. You just change those 2 numbers.
Hopefully someone else will chime in on the seal thing.
rfinkle2
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 10-12-2012, 04:13 PM   #6
Mortose's Avatar
Posts: 1,637   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 30
so, my issue wasn't quite as bad as yours, but i used to get some pretty decent PT KR. i replaced them with the sure halo's, and now i only get like .3 to 1 pt kr. so that is a POSSIBILITY. just sharing to help OP make a decision.
2008.5 Metropolitan Grey Mica
GTX2867r--Cobb AccessPort--CNT Racing Catted DP & Catback Exhaust--Autotech Internals--NGK 1 Step Colder--PTP Injector seals/studs--Sure TIG (Intake Mani)--HTP 3" intake--Grimspeed EBCS--JBR OCC (V2)--TWM STS/Solid Base Bushings--JBR LTD Silver Vein Heavy Knob--JBR 80 duro trillogy--Synapse BPV--Synapse FMIC--Koni Yellow's--H&R springs--JBR Rear Sway Bar
getting re-Stratified
KO4 - 360 whp/426 wtq Corrected 6600 ASL
GTX2867r - we will see.......
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is offline   Reply With Quote
The Following 2 Users Say Thank You to Mortose For This Useful Post:
smoogs12 (10-12-2012), Speed3eak (10-13-2012)
 Old 10-12-2012, 04:34 PM   #7
Eth Fiend
phate's Avatar
Posts: 4,273   (View Stats)
phate has disabled reputation
Will look at logs when I get to a PC. You shouldn't be anywhere close to the knock threshold of 93 with that timing lol. I would look for loose stuff in the engine bay.
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
 Old 10-12-2012, 04:51 PM   #8
Posts: 5,628   (View Stats)
Groans: 121
Have you modified your VVT table at all? Too much intake valve advance at spoolup can cause KR.
Your datalogs all show KR <1 degree. I wouldn't be too worried about that.
 Old 10-13-2012, 01:30 PM   #9
Speed3eak's Avatar
Groans: 82
Thanks - I've reduced VVT some in the cruising/low load areas. I unplugged the EGR briefly, but I started getting more low throttle knock - 2-3*, so I plugged it back in. Still need to re-check p0401/p0403 in ATR.
What I was worried about, was the PT knock that I see when I'm accelerating. I've seen 8* below 2.5k rpms, still in vacuum, while accelerating. I don't think I've ever seen 8* PT knock while cruising. I would try and get it to show up in a log, but I don't want to force my engine to knock like that if it really is knock.
I don't know, maybe it's nothing. Or maybe my car will explode into flames, trap me inside, and melt my skin to the seat before they can get me out.
I'm gonna go back and look at my VVT table, because I just realized that I do see knock at part throttle when I start to spool. It seems that, in my case at least, changing VVT too much in either direction does increase knock. I remember it being a problem before.
Thanks again everybody, I appreciate the help.
Knock Knock Knock..Whose There? (<===total noob) thomas_cory2000 MazdaSpeed 3/6 - ECU Computer Tuning 155 10-25-2011 08:22 AM
How do I tune out this knock? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 0 06-26-2010 12:48 PM
Can I use ATR to tune out this knock? Speedn3
Cobb ATR Support
12 05-25-2009 06:09 PM
Persistent Knock Retard on stock tune Ploppity Drown MazdaSpeed 3/6 - ECU Computer Tuning 26 04-23-2009 12:37 PM
Tune day. knock retard after 5000rpm johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-23-2008 09:57 AM
Page generated in 0.31526 seconds with 26 queries
