![]() | | #41 | ![]() |
![]() Join Date: Jul 2010 Location: Charlotte Nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 352
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score Looks like your on the right path!
__________________ 2006 Mazdaspeed6 GT Liquid Platinum Metallic "because racecar!" " I love this $%&*ing car" ![]() -Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps -2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete -TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender -Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod -Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2450 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,551
The only issue I've been having with blow through is the air flow can get a little rough at WOT. I think a straightener will take care of it though. Other than that very tiny issue, it has been great. Especially when I blew an intercooler coupler on the highway and was able to drive the 5 miles back to the shop to fix it. lol!
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - ![]() - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh NC
Rep Power: 821 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 837
Groans: 35
Groaned at 25 Times in 14 Posts
__________________ 2007 Black Mica MS3 Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion | |
![]() | | #44 | ![]() |
| Not Ranked : 0 score You just scale the MAF. There is no difference really. Air is going past the MAF sensor, its reading it and adjusting fuel accordingly. Blow through just changes the location of the sensor to be placed after the turbo.
![]() | | #45 | ![]() |
Groans: 35
| Not Ranked : 0 score That's what I thought and hoped. I have a plan for pipe routing that should give me a good length for air straightening and still have good distance to the TB. Now to find a job and actually get things done...
![]() | | #46 | ![]() |
| Not Ranked : 0 score How are you planning to route the piping?
![]() | | #47 | ![]() |
Groans: 35
| Not Ranked : 0 score I'm going to try to go from the turbo to the IC on the driver's side with at BOV on the hotside, then from the passenger's side do a U pipe and go straight in front of the engine (long enough straight for the MAF) then hook back and up to the TB. Not the shortest routing, but seems a bit more "ideal" in terms of spacing for the cold side components.
| The Following 4 Users Say Thank You to anavrinIV For This Useful Post: |
![]() | | #48 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 1138 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,587
Groaned at 32 Times in 13 Posts
i have been advised against running an air straightener in the positive pressure stream because it is "a restriction" "they dont handle boost / heat very well" yada yada but of couse a lot of people just like to talk out of their ass. I appreciate everyones input very much but forgive me if i dont adhere strictly to it, i am simply on a bit of a time crunch to get things done this weekend so i may just have to wing it and hope for the best ;P
obviously it is beause everyone keeps saying that but if someone could just explain it for me please.
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN Last edited by Voltwings; 09-14-2012 at 07:12 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Voltwings For This Useful Post: | rfinkle2 (09-14-2012) |
![]() | | #49 | ![]() |
Groans: 35
| The Following User Says Thank You to anavrinIV For This Useful Post: | Voltwings (09-14-2012) |
![]() | | #50 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 1939 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,593
Groans: 297
Groaned at 186 Times in 102 Posts
I dunno if it would fit, but I woke up with a thought. Get one of those cores that has the input & output on the same side, then run a really long pipe across the bottom/back/wherever for your maf sensor. Assuming there's room I mean.
![]() | | #51 | ![]() |
Groans: 35
Now, there's an option like the treadstone tr82 if you want to go that route, but again, I want to leave my crash bar in tact since I can
![]() | | #52 | ![]() |
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - ![]() - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - | ||
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | Voltwings (09-14-2012) |
![]() | | #53 | ![]() |
Groans: 35
When i say scale the maf i mean account for the difference in diameter (if you're changing it). A calicration will still be necessary afterward, but you have to get the basis down first
![]() | | #54 | ![]() |
yes im already scaled for the 3" but yes i do plan on doing a recallibration. i had originally wanted to go with a same sided intercooler, similar to Full-Race because it would be super bad ass but as anavrinIV stated the shortest one i could find was like 12" tall and i would like to keep some sort of Crash bar in tact. Also im not looking to spend any more out of pocket, i was able to sell my ETS and 2nd hand meth kit for enough to cover this intercooler and then some so id like to still come out ahead haha.
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN |
![]() | | #55 | ![]() |
Rep Power: 11933 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,951
Groans: 235
I don't want to shit up the thread, but Forge makes an intercooler that sounds exactly like the ticket for this set-up. Assuming they would sell you the core only:
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Voltwings (09-14-2012) |
![]() | | #56 | ![]() |
Groans: 297
Like these: ![]() ![]() Then do this, but obviously on the same side going opposite: |
![]() | | #57 | ![]() |
Nah its all good, id like this to be a comprehensive blow through MAF thread if thats what it ends up turning into any and all input is appreciated, but where was this two weeks ago when i ordered this shit though Fink haha just kidding. www.frozenboost.com also sells very comprehensive LTA kits that i had seriously considered but the TR8L was a proven core so i figured it was better to stop before i got too ambitious haha.
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score ![]() ![]() Just kidding haha, pipes are finished and car is running, trims seem to be ... stable for the most part at idle haha but it looks like it will need a tweak or two. Ill have more comprehensive pics of the pipes and their routes in the AM, as well as the brackets ill be making to hold the core in place. All in all this setup was retarded simple haha, i didnt even use 4 pieces of the Ebay kit, and i only had to make 4 cuts and will only need 2, maybe 3 sections welded together (currently held on with clamps so car is still drivable as is). I guess ill need to get more to Tuning once its running though since this is in the ECU section
![]() | | #59 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Very nice. Can't wait for pics and results.
| The Following User Says Thank You to dantes5823 For This Useful Post: | Voltwings (09-16-2012) |
![]() | | #60 | ![]() |
ok heres the final install pics, i have an 8 page paper to write tomorrow so tuning will commence monday, it seems to be what was mentioned a few posts up by JacksonMS30 when you're daily driving it seems to do ok, but the second i tried to floor it haha it was a cluster fuck haha, we'll see whats up next week though. Thanks for everyones input on this thread, i highly suggest this intercooler route to anyone because it was incredibly simple. The only thing you really would benefit from having done else where is i had an exhaust shop torch my crash bar, and realistically i should have that pipe welded on the cold side so i can eliminate that middle coupler but ehh one thing at a time. Also, note the little trick with the painters tape to make sure you get a straight cut on the pipe, its a nifty little trick.
| The Following 7 Users Say Thank You to Voltwings For This Useful Post: | dantes5823 (09-16-2012), ESB Jiu JItsu (09-17-2012), JacksonMS30 (09-17-2012), mrmonk7663 (09-16-2012), NJSPEED3 (09-17-2012), snailD (09-16-2012), uncorked11 (09-17-2012) |
![]() | | #61 | ![]() |
yeah it will have you hitting some sort of load cut before wot can be reached due to the increased density of air flow the maf is seeing. Thats exactly what happened to me. except i couldnt proceed with tuning but will soon. The ap fund is growing so long as we dont need food to eat with anytime soon Ill have an AP super fast! lol
| The Following User Says Thank You to ESB Jiu JItsu For This Useful Post: | Voltwings (09-17-2012) |
![]() | | #62 | ![]() |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 525 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,225
Groans: 156
| Not Ranked : 0 score Voltwings did you happen to datalog while driving around? I'm interested to see what the car is doing.
__________________ 2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
![]() | | #63 | ![]() |
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN | |
![]() | | #64 | ![]() |
Groans: 156
Yea it does trying to figure out how to mount a tablet in the car for that purpose. good stuff either way looking forward to some sweet data coming.
| The Following User Says Thank You to uncorked11 For This Useful Post: | Voltwings (09-17-2012) |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Anything in particular you're after so i can make sure its logged?
![]() | | #66 | ![]() |
![]() basically the volts aka cfms go up, which makes fuel increase, and makes you hit load cut prior to wot.
__________________ 2006 Mazdaspeed6 GT Liquid Platinum Metallic "because racecar!" " I love this $%&*ing car" ![]() -Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps -2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete -TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender -Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod -Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge | |
![]() | | #67 | ![]() |
Groans: 156
| Not Ranked : 0 score yea ESB that would be good I'm trying to get some more info before I put this together, Voltwings, Im looking to see the Air you are flowing, and the IDC % as well. thank you gentlemen.
![]() | | #68 | ![]() |
Looks like it's just some maf cal love
| The Following 2 Users Say Thank You to dantes5823 For This Useful Post: | uncorked11 (09-17-2012), Voltwings (09-17-2012) |
![]() | | #69 | ![]() |
ok well apparently i havent driven enough for my LTFT's to settle yet so i dont have an update as far as an MAF cal is concerned, however my STFT's are like -10-15% so apparently im running quite rich, which i believe we've established would happen. Im also targeting a 12.4 AFR at WOT and as you can see it is dipping a bit below that, just gonna need some love and then we're back up and running. Attached is what i could get of a quick 3rd gear pull, now when i was on stock top mount waiting for this intercooler to ship i was running wastegate spring pressure of 8 psi... odd now that its going up to 10 but the key thing i would like to highlight is the difference between Intake temp (measured at MAF about 8" pre throttle body) and BAT's measure in the intake manifold. Goes to show even in 76* weather and with TIG's the shit heatsoaks haha.
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | ESB Jiu JItsu (09-17-2012), uncorked11 (09-17-2012) |
![]() | | #70 | ![]() |
| The Following 3 Users Say Thank You to Voltwings For This Useful Post: |
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score you did haha, guess i was being a bit thick, yeah i have my draw through honey comb sitting on the work bench, and hopefully it stays there but even if it doesnt im not going to tell you. Not going to give you two "I told you so's" in the same thread haha.
![]() | | #73 | ![]() |
| Not Ranked : 0 score I would make sure you find a way to secure it in the pipe as well.
| The Following User Says Thank You to dantes5823 For This Useful Post: | Voltwings (09-17-2012) |
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score i ordered one that is exactly 3" so it matches the outside diameter of the pipe, a few strips of aluminum tape to keep it steady, then slide the coupler over and clamp the coupler on the connection of the two.
| The Following User Says Thank You to Voltwings For This Useful Post: | dantes5823 (09-17-2012) |
![]() | | #75 | ![]() |
check my blow through thread. I ended up using a air straightener aka honeycomb and it helped a lot even in my untuned setup. Also no matter what weather you go with a larger maf housing when going blow through or not i can confirm you will have to do maf cal and scale for it to work properly. Without a maf cal / scale your maf will still read higher values in the blow through position. As shown in his logs and his issue with going wot. But once a cal is done it should be smooth sailing! cant wait to get an AP and go back to blow through!!!!
| The Following User Says Thank You to ESB Jiu JItsu For This Useful Post: | Voltwings (09-18-2012) |
![]() | | #76 | ![]() |
arent LTFT's supposed to settle after like 50mi? ive done like 80 since going blow through and they're still zerod out o_O ???
| The Following User Says Thank You to Voltwings For This Useful Post: | uncorked11 (10-04-2012) |
![]() | | #77 | ![]() |
Groans: 35
I was thinking about my setup and I plan on using the longest straight pipe of whatever diameter maf housing I go with as I can, hence my routing plan. It was my thought that the 2-3" of space after the coupler and before the MAF wasn't enough space for the air to expand properly into the pipe, giving you off readings. another thought, I wouldn't run the straightener that far ahead of the MAF, but more like a couple inches to make sure that you're getting a good reading.
| The Following User Says Thank You to anavrinIV For This Useful Post: | Voltwings (09-18-2012) |
![]() | | #78 | ![]() |
well this is currently at a standstill for anyone following this thread, heres the skinny: LTFTs are at 0, constantly. WTH
![]() | | #79 | ![]() |
Ok heres an update, after trying several different set ups: 2.5" - 3" directly at MAF X 6" of 3" pipe Pre MAF X 6" pipe pre MAF + Air straightener directly before MAF X Air straightener at 2.5" - 3" connection = success having the straightener right after the 90* 2.5" that goes into the 3" section i am having good consistent AFR readings and the MAF is mmmuuuccchhhhh easier to dial in now. Thanks everyone for their input and i hope this is helpful to others. Oh and dantes5823 ... not a word about that damn air straightener haha
| The Following User Says Thank You to Voltwings For This Useful Post: | anavrinIV (09-26-2012) |
![]() | | #80 | ![]() |
I told you so lol | |
| The Following User Says Thank You to dantes5823 For This Useful Post: | Voltwings (09-26-2012) |
| Blow Through MAF | Mid_Life_Crisis | MazdaSpeed 3/6 - Turbo Induction | 44 | 10-31-2012 10:14 AM |
| Blow through MAF | ESB Jiu JItsu | MazdaSpeed 3/6 - Turbo Induction | 84 | 09-14-2012 06:57 AM |
| blow through maf help | mrkdspd | MazdaSpeed 3/6 - Turbo Induction | 10 | 08-13-2012 12:59 PM |
| How much can the K04 blow? | sallyspeed3 | MazdaSpeed 3/6 - Turbo Induction | 26 | 03-30-2012 11:15 AM |
| 1.5k to blow on my '09 MS3 | M4Nathan | MazdaSpeed 3 - How-To's | 25 | 06-11-2010 07:22 PM |
